Simple and cheaper 1080p media player - AVS Forum | Home Theater Discussions And Reviews
Old 08-23-2009, 12:08 PM - Thread Starter
asscube's Avatar
Hi AVers,
I'm looking for a media player that can play digital movies on my TV in the bedroom. I don't want nothing really fancy like XBox, PS3, or Netgear's media player, but something that plays enough different video formats in HD.
I have done a little bit of research, and I found Zinwell ZP 500 HD media player listed on ebay. It seems to play quite a bit of different formats with reasonable price tag.
Has anyone used it before? Any feedback on this player? Does anyone have other recommendatoin?
Thx
asscube is offline
Old 08-23-2009, 12:30 PM
Afrsa's Avatar
Originally Posted by asscube View Post
Hi AVers,
Thx
Well... if you dont use subtitles and all your movies dont have DTS sound and are light 1080p files (5 reframes max!), I recomend the WD TV.
If you use subs and DTS and have more demanding 1080p files, you can try Egreat M34a, Xtreamer or AC Ryan PLAYHD!
Afrsa is offline
Old 08-23-2009, 11:27 PM
didibagle's Avatar
you might want to check out on this (zinwell zp500) on ebay:
cgi[dot]ebay[dot]com/ws/eBayISAPI.dll?ViewItem&item=230368979234
change [dot] to .
My friends in asia all have good things to say about this product. i think it's reasonably priced, supports lotsa formats and streams media files smoothly. i can't wait to get my hands on one of these.
happy huntings~
didibagle
didibagle is offline
Old 08-26-2009, 10:41 PM
didibagle's Avatar
i found something similar to the zinwell zp-500...
www[dot]hardwaresphere.com/2009/07/21/olevia-hd-media-player-decodes-and-playbacks-full-hd-video/#comment-4676
change [dot] to .
the blog says it's selling at $177....mmm...looks to be a little more expensive than the zinwell ($159).
