Dune HD Base 3.0 and Prime 3.0 on Sigma 8642 in Q4 2009 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 10-31-2009, 02:08 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
Originally Posted by BangoO View Post
Hi there ;-)
I'm really interested in buying an HD Prime 3.0, but I live in Europe and have tons of Region A Blu-rays... how easy is it to make it region free ?
Thx !
Its will be same like on Dune 1.0. Look for more info http://www.mpcclub.com/forum/
Mike:SH is offline
Old 11-04-2009, 04:58 AM
deon's Avatar
I don't see FLAC file support anywhere...
deon is offline
Old 11-04-2009, 03:51 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
http://dune-hd.com/hd_players/110-dune-hd-base-3.0.html
Audio file formats: MP3, MPA, M4A, WMA, WAV, DTS-WAV, DTS, AC3, AAC, FLAC.
Mike:SH is offline
Old 11-05-2009, 05:10 AM
spida_singh's Avatar
Multi channel flac as well as stereo is supported, inside mkv containers, not sure about what other containers.
The actual spec on the main page is out of date, check the firmware change logs here to find out whats available:
http://dune-hd.com/firmware/bdprime/
EDIT
.fla and .flac files are supported, over at mpcclub forums, it has been confirmed that multichannel flac does indeed work. I have opted in for the buy in on Prime 3.0 models, its had a slight facelift, and looks better IMO, MPCC say the first 30 users should have their units by the end of next week, or mid week W/C 16/11.
Once i receive mine, i will keep this post updated with findings, as the buy is not available to the US.
With regards to region free, there was a patch released for the 1.0 to make it region free....im guessing its only time before one is released for the new model.
spida_singh is offline
Old 11-05-2009, 06:49 PM
dogone's Avatar
Will these units support video library plugins similar to "mymovies" or
mediabrowser"?
dogone is offline
Old 11-05-2009, 07:49 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
mediabrowser"?
Yes,on Dune player its- dune_folder.txt
more info: http://dune-hd.com/firmware/misc/
http://dune-hd.com/firmware/misc/Ine...nfig_howto.txt
http://dune-hd.com/firmware/misc/dune_folder_howto.txt
Mike:SH is offline
Old 11-06-2009, 04:07 AM
lofgents's Avatar
Does anyone have a Dune 3.0 yet, if so is it possible to confirm if the unit supports dolby Truehd and dtsma passthrough via hdmi?
lofgents is offline
Old 11-06-2009, 01:46 PM
eurotrance's Avatar
Don't see why they wouldn't, 1.0 units already do...
LIVE every wednesday 12pm-2pm PST on http://www.discovertrance.com
eurotrance is offline
Old 11-06-2009, 04:55 PM
sinker442's Avatar
Dune 3.0 has a new chip, wait for the reviews...
C-200 looked great too, but Sigma's libs are incomplete with many bugs/missing features...
sinker442 is offline
Old 11-06-2009, 05:02 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
This why they(C-200) rash to be first,before Dune 3.0 .
Mike:SH is offline
Old 11-07-2009, 04:50 PM
wiatrak's Avatar
"Small first impression from a user". Base user I think...
http://www.mpcclub.com/forum/showthread.php?t=21766
"...Those who go beneath the surface do so at their peril..."
Don Quixote was a villain! http://commons.wikimedia.org/wiki/Windmill
wiatrak is offline
Old 11-07-2009, 10:35 PM
dogone's Avatar
If you buy the unit with the built in blu-ray player, can you rip blu-rays from this included blu-ray player to your hard drive?
dogone is offline
Old 11-07-2009, 10:42 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Nope.
Killroy is offline
Old 11-08-2009, 04:53 PM
reticentwookiee's Avatar
I know it says that it doesn't come with one, but can a Blu-ray drive be installed onto the Base model?
I'm thinking of getting one from Newegg.
reticentwookiee is offline
Old 11-08-2009, 07:06 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
- Compatibility of the player with a particular equipment (A/V equipment, network equipment, disk drives, etc) may depend on particular equipment model, specifics of equipment installation, specifics of the configuration of the player and equipment, and other factors; compatibility of the player with any equipment is not guaranteed.
Mike:SH is offline
Old 11-08-2009, 08:09 PM
Not sure how reproducing the generic disclaimer from the manufacturer should answer my question?
Can i hook up a BD drive to the base model? I do not see where in the link above it says that. It may also be that some language exists that implies it and that I do not know enough to interpret it so.
Thank you.
Old 11-08-2009, 08:27 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
Thank you.
Compatibility disk drives
-its min-yes you can hook up a BD drive-nobody guaranty its will work,-you have to by BD drive from HDI- same have Dune prime.
Mike:SH is offline
Old 11-09-2009, 11:13 AM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
MPC Club has their review up for the Dune Prime 3.0 (PDF link): http://www.mpcclub.com/download.php?...bd_prime30.pdf
Killroy is offline
Old 11-09-2009, 07:40 PM
Opentoe's Avatar
Quoted: 87 Post(s)
Ok, where are the shipments! Been waiting for mine and of course my patience runs out!
Opentoe is offline
Old 11-09-2009, 07:44 PM
Kei Clark's Avatar
Patience, grasshopper.....
I'm getting signs that it's very close.
Kei Clark is offline
Old 11-10-2009, 03:54 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
Mike:SH is offline
Old 11-10-2009, 05:24 PM
Opentoe's Avatar
Quoted: 87 Post(s)
Yea, I know. I read a legit review on it and it is directly compared to the Popcorn 200. I'm glad the Dune has the 8642 chip in it, instead of the odd number set.
Opentoe is offline
Old 11-10-2009, 07:50 PM
Kevenz's Avatar
finished reading the review, sounds like a great machine, the only thing I don't like is the music player... it looks so cheap.
Kevenz is offline
Old 11-10-2009, 08:49 PM
Opentoe's Avatar
Quoted: 87 Post(s)
What the review says is ok...but a little odd since they never really mentioned about making it better via firmware update. They know these products can be updated and made better with new firmware...so the potential for being a "better" player is there. How come that wasn't mentioned.
Opentoe is offline
Old 11-10-2009, 09:02 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
Opinion like ass hole-everybody have one.
Mike:SH is offline
Old 11-10-2009, 09:03 PM
SVM
SVM's Avatar
From the review this is the first player that I came across that can play Bluray ISO files without issues, but there is no mention of audio bitstreaming etc. - may be the earlier versions do hence not mentioned? I wish it was little easy on the wallet though!
SVM is offline
Old 11-10-2009, 09:18 PM
Mike:SH's Avatar
Quoted: 34 Post(s)
SVM-this something min:
Mike:SH is offline
Old 11-10-2009, 10:49 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
I hope they get the hardware issues worked out before they ship DC their units. MPC Club reporting numerous BD drives not working properly.
I don't think DC wants to test every unit before they go out.
Killroy is offline
Old 11-10-2009, 11:07 PM
Kei Clark's Avatar
We could, but it would slow down shipping considerably.
Old 11-10-2009, 11:17 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Out of the first 52 units shipped, so far there has been 6 reports of DOA or non-functioning BD drives and those are from the people that either picked them up in person or were close enough to get them in a day or two. One poor fellow got two units and BOTH were non-functioning.
Killroy is offline
Dune Hd Base3d Media Player , Xbox 360 Console , Popcorn Hour C 200 Networked Media Tank Black
