access external drive over network - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-18-2009, 12:09 PM - Thread Starter
chads29's Avatar
I'm trying to get files onto an external hard drive wirelessly. Can I just plug a WiFi adapter into a USB slot on the external drive and be able to recognize over the network? If not, is there another solution besides buying an expensive external drive that has network support out of the box?
chads29 is offline
post #2 of 4 Old 09-18-2009, 02:40 PM
candre23's Avatar
You cannot plug in a regular PC USB wifi dongle. Belkin makes a NAS USB hub that you can plug into your wireless router and connect up to 5 USB devices (hard drives, printers, etc). It's a bit pricey though. It's actually cheaper to replace your current wireless router with one that includes USB NAS support like this one from Asus.
Another option is the Dlink DSM-G600. It's an external wireless NAS enclosure that is made for older PATA hard drives, but it also has 2 USB ports for attaching additional external drives. If your current external enclosure has a PATA drive inside, you can take it out and stick it in the G600. If not, you can plug it in over USB. It's no longer manufactured, but shops that still have stock usually sell them for cheap.
candre23 is offline
post #3 of 4 Old 09-18-2009, 02:52 PM
whiteboy714's Avatar
If you can get it hooked up to one of your pc's you can just share it over your network like any drive. But sounds like you want it solo.
whiteboy714 is offline
post #4 of 4 Old 09-18-2009, 04:19 PM - Thread Starter
chads29's Avatar
Yes, trying to get it solo. Thank you both for your help!
chads29 is offline
