Official Codec/Container Test Videos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 46 Old 09-22-2009, 05:18 PM - Thread Starter
candre23's Avatar
EDIT: I have been informed that the drop.io links no longer work. You can get the entire collection in two parts here: part 1, part 2
All current-generation streamers can play standard encodes with ease. They'll all do Divx/Xvid and h.264 DVD rips with AC3 or MP3 audio. Nearly all will do reasonable BD rips as well. It's only when you get to the really high-end encodes or uncommon stuff that you can run into compatibility issues.
Here is what is included in this collection of test files to determine the limits of a given device. I've tried to cover all the bases, but if something is missing, please let me know.
  • M2TS: Standard 1080p M2TS ripped from a blu-ray
  • DVR-MS: Microsoft's old proprietary TV recording format
  • WMV9: 1080p WMV9 video with 5.1 WMA audio
  • HDTV: 1080i 60hz HDTV rip, no audio
  • AVCHD: 1080p M2TS from a Sony HD camcorder
  • Improper encode: The infamous Planet Earth clip with an absurd 16 reframes. The bird scene stutters even on high end PCs
  • DTS: Standard DTS 5.1 audio
  • DTS-MA: 7.1 DTS-MA lossless audio
  • Dolby TrueHD: 7.1 lossless TrueHD audio
  • MP4: 1080p L5.0 Apple trailer with 9 reframes and AAC audio
  • 5.1 FLAC + SSA: Multichannel FLAC audio and SSA (ASS 4.0) subs including complex styles and transitions
  • OGG: 720p Ogg Theora video with Vorbis audio
  • RMVB: Real Video variable bitrate. Unknown if it is RM9 or RM10, as they both use the same header (RV40)
  • TRP: 1080p Kaon DVB Transport Stream with dual AC3 audio
  • UTF-8: MKV with the following UTF-8 SRT sub tracks: Arabic, Chinese, English, Greek, Hebrew, Hindi, Japanese, Korean, Russian, Thai, Turkish and Vietnamese
  • Deinterlacing: 1080i test pattern to determine deinterlacing capabilities (see here for details)
If anybody can point me to small (under 300MB if possible) DVD and BD ISOs with menus and/or a short clip with 7.1 FLAC, I'd love to add them.
candre23 is offline
post #2 of 46 Old 09-22-2009, 09:36 PM
kneedragger's Avatar
Quoted: 18 Post(s)
This is great. I always wished I could find test samples of video files.
kneedragger is offline
post #3 of 46 Old 09-23-2009, 06:28 AM
iboum's Avatar
A unified list of test files is a great idea. Thanks for posting them. Here are my results using an Xtreamer with 1.0.3.1 firmware. All files were first tested streaming over wired Ethernet and Samba and then again using a USB drive. I found no difference between the two.:
  • M2TS: Standard 1080p M2TS ripped from a blu-ray - (8.3mbps-1080p-30fps-L4.1-3ref.m2ts) - PLAYED PERFECTLY
  • DVR-MS: Microsoft's old proprietary TV recording format (6mbps-480i-MPEG-ASF.dvr-ms) - FILE INVISIBLE TO XTREAMER, NOT TESTED
  • WMV9: 1080p WMV9 video with 5.1 WMA audio - (8mbps-1080p-24fps-WMV9-6chWMA.wmv) - PLAYED PERFECTLY
  • HDTV: 1080i 60hz HDTV rip - (10mbps-1080i-60fps-L5.1-8ref-HDTV.mkv) - WOULD NOT PLAY
  • AVCHD: 1080p M2TS from a Sony HD camcorder - (11.6mbps-1080p-AVCHD-Sony-Camcorder.m2ts) - PLAYED PERFECTLY
  • Improper encode: The infamous Planet Earth clip with an absurd 16 reframes. The bird scene stutters even on high end PCs - (19mbps-1080p-24fps-L5.1-16ref-improper.mkv) - COLOUR PROBLEMS FROM START, STUTTERING AND PICTURE BREAKUP THROUGH BIRD SCENE
  • DTS: Standard DTS 5.1 audio - (10.2mbps-1080p-24fps-L4.1-5ref-DTS.mkv) - PLAYED PERFECTLY
  • DTS-MA: 7.1 DTS-MA lossless audio - (28mbps-L4.1-DTS-MA.m2ts) - PLAYED PERFECTLY
  • Dolby TrueHD: 7.1 lossless TrueHD audio - (30mbps-L4.1-TrueHD.m2ts) - NO AUDIO, OTHERWISE PICTURE OK
  • MP4: Apple trailer with 9 reframes and AAC audio - (4377kbps-1080p-24fps-L5.0-9ref-AAC.mp4) - PLAYED PERFECTLY
  • 5.1 FLAC + SSA: Multichannel FLAC audio and SSA subs including complex styles and transitions - (L4.1-8ref-6ch-FLAC-SSAsubs.mkv) - NO AUDIO, PICTURE PERFECT, SUBS DISPLAYED
  • OGG: 720p Ogg Theora video with Vorbis audio - (4.6mbps-720p-30fps-Theora.ogg) - WOULD NOT PLAY
  • RMVB: Real Video variable bitrate Unknown if it is RM9 or RM10, as they both use the same header (RV40) - (SD-25fps-RV40.rmvb) - PLAYED PERFECTLY
  • TRP: 1080p Kaon DVB Transport Stream with dual AC3 audio - (15mbps-1080p-L4.0-4ref-dualAC3.trp) - PLAYED PERFECTLY
So a total score of 8/14.
iboum is offline
post #4 of 46 Old 09-23-2009, 11:13 AM - Thread Starter
candre23's Avatar
Most streamers do a half-assed job of displaying SSA subs. They don't support the advanced formatting features. Try playing the video on your computer with something that definately supports all the features (XBMC, SMplayer, etc) and then see if the Xtreamer is really displaying the subs correctly. Were there two sets of subtitles, one on top of the screen ond one on the bottom? Were they two different fonts? Did the transition effects work? It should look like this:
candre23 is offline
post #5 of 46 Old 10-13-2009, 12:20 AM
IeeSiang's Avatar
I just bought the latest TVix M6600N, verfiy the tested result as foolowing:
THe resuylt seento be better than Streamer.
DVR-MS: Microsoft's old proprietary TV recording format (6mbps-480i-MPEG-ASF.dvr-ms) - FILE INVISIBLE TO TVIX
PLAYED but video JERKY
5.1 FLAC + SSA: Multichannel FLAC audio and SSA subs including complex styles and transitions - (L4.1-8ref-6ch-FLAC-SSAsubs.mkv) - PLAYED PERFECTLY
OGG: 720p Ogg Theora video with Vorbis audio - (4.6mbps-720p-30fps-Theora.ogg) - CAN'T PLAY -NOT SUPPORTED
RMVB: Real Video variable bitrate Unknown if it is RM9 or RM10, as they both use the same header (RV40) - (SD-25fps-RV40.rmvb) - PLAYED PERFECTLYTRP: 1080p Kaon DVB Transport Stream with dual AC3 audio - (15mbps-1080p-L4.0-4ref-dualAC3.trp) - PLAYED PERFECTLY
IeeSiang is offline
post #6 of 46 Old 10-13-2009, 01:09 PM - Thread Starter
candre23's Avatar
Even the transition effects? See the image above for what the subs should look like.
candre23 is offline
post #7 of 46 Old 10-13-2009, 08:50 PM
IeeSiang's Avatar
I overlook this.
The transition effect seen to be failed !!
Nothing appear on top image area.
Best REgards,
IeeSiang is offline
post #8 of 46 Old 10-13-2009, 09:01 PM
cjm187's Avatar
im too lazy to test it all but for now on the new WDTV live this plays just fine the bird scene is quite nuts but it seems to be smooth.
cjm187 is offline
post #9 of 46 Old 10-13-2009, 09:06 PM
IeeSiang's Avatar
Dear Candre,
Could you post more video clip for test and verficaiton purpose, especially include DTS portion, my friend seen having other Sigma 89635c player, Kaiboered K009 player failed on most of the MKV with DTS audio track.
Still looking solutions.
IeeSiang is offline
post #10 of 46 Old 10-13-2009, 09:21 PM - Thread Starter
candre23's Avatar
I already posted clips with DTS 5.1 and 7.1 audio. If those don't work, then the player doesn't support the format.
candre23 is offline
post #11 of 46 Old 10-14-2009, 09:40 PM
IeeSiang's Avatar
Hope youcoudl share us more nerw interting video clips ??
Very keen to use on demo and verifcaiton purpose ?? Thanks!!
IeeSiang is offline
post #12 of 46 Old 11-09-2009, 08:02 AM
dleach's Avatar
This is a good idea. I would suggest though that you name the files with an appended or prepended number so that people can keep them straight on which one is which when playing them. Then a table could be generated of tested system configuration and the results.
dleach is offline
post #13 of 46 Old 11-13-2009, 01:27 AM
bluewhale1's Avatar
Quoted: 473 Post(s)
Liked: 214
Hey can someone with a xtreamer with the new firmware test the files.
bluewhale1 is offline
post #14 of 46 Old 11-13-2009, 08:46 PM
Opentoe's Avatar
Quoted: 89 Post(s)
Below is a collection of test files to determine the limits of a given device. I've tried to cover all the bases, but if something is missing, please let me know. All files have been uploaded to drop.io because they're one of the few file hosts that doesn't have annoying transfer limits, capchas or timers. Once I'm sure there's nothing worth testing that isn't included, I'll bundle it up into one big pack.
  • M2TS: Standard 1080p M2TS ripped from a blu-ray - link
  • DVR-MS: Microsoft's old proprietary TV recording format - link
  • WMV9: 1080p WMV9 video with 5.1 WMA audio - link
  • HDTV: 1080i 60hz HDTV rip, no audio - link
  • AVCHD: 1080p M2TS from a Sony HD camcorder - link
  • Improper encode: The infamous Planet Earth clip with an absurd 16 reframes. The bird scene stutters even on high end PCs - part1 part2
  • DTS: Standard DTS 5.1 audio link
  • DTS-MA: 7.1 DTS-MA lossless audio - link
  • Dolby TrueHD: 7.1 lossless TrueHD audio - link
  • MP4: 1080p L5.0 Apple trailer with 9 reframes and AAC audio - link
  • 5.1 FLAC + SSA: Multichannel FLAC audio and SSA subs including complex styles and transitions - part1 part2 part3 part4
  • OGG: 720p Ogg Theora video with Vorbis audio - link
  • RMVB: Real Video variable bitrate. Unknown if it is RM9 or RM10, as they both use the same header (RV40) - link
  • TRP: 1080p Kaon DVB Transport Stream with dual AC3 audio - link
  • UTF-8: MKV with the following UTF-8 SRT sub tracks: Arabic, Chinese, English, Greek, Hebrew, Hindi, Japanese, Korean, Russian, Thai, Turkish and Vietnamese - link
  • Deinterlacing: 1080i test pattern to determine deinterlacing capabilities (see here for details) - link
Instead of my just hijacking your files would you mind if I put these files on my domain which would enable immediate fast download? You also can upload more media (if you come across) to the same place.
Opentoe is offline
post #15 of 46 Old 11-14-2009, 06:14 AM
oliverjg's Avatar
to fully test blu ray rips you need separate test files for 1080p avc, vc1, mpeg2 video encodes because they can cause different problems for different players. audio is a huge can of worms.... which is why i rip everything to flac and/or ac3.
oliverjg is offline
post #16 of 46 Old 11-14-2009, 02:50 PM - Thread Starter
candre23's Avatar
Drop.io is a free file hosting site, not my site. You can use the links I posted or host the files yourself. Your call.
candre23 is offline
post #17 of 46 Old 11-16-2009, 04:30 AM
bluewhale1's Avatar
Quoted: 473 Post(s)
Liked: 214
I tested this with the new firmware 2.02 for the Xtreamer.
It now plays with sound.
post #18 of 46 Old 11-16-2009, 07:10 AM
MonkeySnax's Avatar
^was this with the xtreamer or a different player?
MonkeySnax is offline
post #19 of 46 Old 11-16-2009, 03:26 PM
bluewhale1's Avatar
Quoted: 473 Post(s)
Liked: 214
Sorry Monkeysnax i'll fix it, yes its the Xtreamer
post #20 of 46 Old 11-18-2009, 12:09 PM
iboum's Avatar
Xtreamer Firmware 2.02:
  • HDTV: 1080i 60hz HDTV rip - (10mbps-1080i-60fps-L5.1-8ref-HDTV.mkv) - PLAYED BUT JERKY + NO SOUND ************
  • Improper encode: The infamous Planet Earth clip with an absurd 16 reframes. The bird scene stutters even on high end PCs - (19mbps-1080p-24fps-L5.1-16ref-improper.mkv) - COLOUR PROBLEMS, SOME PICTURE BREAKUP. LESS BREAKUP THAN PREVIOUS FIRMWARE. **********
  • DTS-MA: 7.1 DTS-MA lossless audio - (28mbps-L4.1-DTS-MA.m2ts) - PLAYED PERFECTLY IN STEREO ON TV.
  • Dolby TrueHD: 7.1 lossless TrueHD audio - (30mbps-L4.1-TrueHD.m2ts) - PLAYED PERFECTLY *********
  • 5.1 FLAC + SSA: Multichannel FLAC audio and SSA subs including complex styles and transitions - (L4.1-8ref-6ch-FLAC-SSAsubs.mkv) - PLAYED PERFECT WITH AUDIO. SUBS ONLY AT BOTTOM **********
  • OGG: 720p Ogg Theora video with Vorbis audio - (4.6mbps-720p-30fps-Theora.ogg) - WOULD NOT PLAY. 'INVALID MUSIC FILE'
  • TRP: 1080p Kaon DVB Transport Stream with dual AC3 audio - (15mbps-1080p-L4.0-4ref-dualAC3.trp) - PLAYED PERFECTLY AUDIO TRACK 1/2. TRACK 2/2 MUTE?
So some improvements over the last test with 1.03.1 firmware. The differences are marked *************.
The TrueHD file now works, as does the FLAC audio track. The HDTV 60Hz clip also worked this time but without sound.
iboum is offline
post #21 of 46 Old 11-19-2009, 04:28 AM
protg's Avatar
please test with wdtv live. thanks
protg is offline
post #22 of 46 Old 11-23-2009, 01:32 AM
Digz's Avatar
agreed
Digz is offline
post #23 of 46 Old 11-23-2009, 12:53 PM
oRBIT2002's Avatar
Here are my WDTV Live test results. I've got my WDTV Live connected to a LCD TV using a HDMI connector (no external reciever or such)..
Notice that I'm no professional so I could be mistaken about these results. The files were played from an external Western Digital Passport harddrive (500GB)
# M2TS: OK
# DVR-MS: Microsoft's old proprietary TV recording format - OK
# WMV9: 1080p WMV9 video with 5.1 WMA audio - NO AUDIO
# HDTV: 1080i 60hz HDTV rip, no audio - OK
# AVCHD: 1080p M2TS from a Sony HD camcorder - OK
# Improper encode: The infamous Planet Earth clip with an absurd 16 reframes. The bird scene stutters even on high end PCs - OK (Perhaps there's some very small stuttering but I could be mistaken, very hard for me to see anyway..)
# DTS: Standard DTS 5.1 audio link - OK
# DTS-MA: 7.1 DTS-MA lossless audio - OK
# Dolby TrueHD: 7.1 lossless TrueHD audio - NO AUDIO
# MP4: 1080p L5.0 Apple trailer with 9 reframes and AAC audio - OK
# 5.1 FLAC + SSA: OK
# OGG: 720p Ogg Theora video with Vorbis audio - N/A
# RMVB: Real Video variable bitrate. N/A
# TRP: 1080p Kaon DVB Transport Stream with dual AC3 audio - OK, Only audio track 1 available
# UTF-8: MKV with the following UTF-8 SRT sub tracks: OK, however some subs looked like a few chars missing (Vietnamese for example)..
oRBIT2002 is offline
post #24 of 46 Old 01-05-2010, 02:56 PM
mr_jbloggs's Avatar
Thanks for starting this thread with test files.
mr_jbloggs is offline
post #25 of 46 Old 03-23-2010, 11:10 PM
Donny Bahama's Avatar
Location: Steps from the beach in Margaritaville (a state of mind between Inebriation and Sahuarita), AZ
Quoted: 12 Post(s)
Liked: 27
I'm getting a 404 on every file I try to download. Do I need a drop.io account? Or have these files been removed? (If so, is there a newer thread somewhere with similar test files?)
Donny Bahama is offline
post #26 of 46 Old 04-11-2010, 06:10 AM
fabriciogcbh's Avatar
Teste com CinemaTube / Test CinemaTube
resolução de 720p / resolution 720p
firmware IPB10102111,
10-04-2010
Adaptador USB/SATA-IDE, HD externo Seagate 80Gb (USB 2.0)
I added 1 video to the list, download link: http://www.4shared.com/video/mrVnYA5..._The_Scen.html
fabriciogcbh is offline
post #27 of 46 Old 04-11-2010, 07:01 AM
BobSalita's Avatar
Location: CHI, CLD, PAR, PHX, PDX, NKC, AUK, MEL, SYD, BUE, SCL
Wonderful idea, Candre23. I believe a complete and authoritative test suite is essential to focusing media player developers about our expectations. Bravo.
Former Top 1000 Amazon reviewer bemoaning the loss of objective user reviews. Amazon, stop your complacency!
BobSalita is offline
post #28 of 46 Old 04-12-2010, 05:59 AM
iboum's Avatar
The problem is the very limited take-up of the invitation to test..
I would very much like to add something like this to my site, on each player page. Hum.
iboum is offline
post #29 of 46 Old 04-12-2010, 07:31 AM
zrdb's Avatar
Sorry-I tried to download the samples but all the links are dead.
zrdb is offline
post #30 of 46 Old 04-17-2010, 10:50 AM - Thread Starter
candre23's Avatar
Sorry about that. Apparently drop.io removes files after they've been downloaded 1000 times. Kinda surprised that these files have been downloaded that many times. I've re-uploaded the whole lot in two parts to megaupload and updated the first post with the new links.
http://www.megaupload.com/?d=W75ZZHZM part 1
http://www.megaupload.com/?d=T36MZWHD part 2
candre23 is offline
