Patriot Box Office 1080P High Definition Media Player PCMPBO25 - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 859 Old 12-31-2010, 08:22 PM
Azlen's Avatar
Originally Posted by bub View Post
Fellas, just received my PBO from Amazon. I think I have the latest firmware, 18-61. I'm not able to play any of my MKV files, I get the 0 with a line through it and a 'unsupported file type' or something similar.
I'm on a wired network using TVersity, HDMI to Onkyo receiver.
I've read all pages up to about 20 and I keep reading that everybody is claiming their PBO reads all their files including MKV's.
Can somebody help?
Thank you,
bub
I have a WD Live, but it doesn't play MKV's either, that's why I bought this.
Don't play them through Tversity. You need to set up shared media folders and play them that way.
Azlen is offline
post #722 of 859 Old 12-31-2010, 09:26 PM
bub
bub's Avatar
Thanks Azlen. I was having problem logging into any of my other folders but I figured it out. I'm really liking this media streamer so far. I unplugged the fan as it was making a weird noise. Wasn't loud but was intermittent so didn't like it. I thought they had a problem with the fans at first but I thought they would have figured it out by now. I'm really looking forward to getting to know this product. I can watch my mkv files now, wowzer!
Thank you very much Azlen,
bub
bub is offline
post #723 of 859 Old 01-01-2011, 08:00 AM
gmd024's Avatar
bub
A while back PM was telling PBO owners not using an internal HDD in the PBO to unplug the fan if it bothered them - but I recenly was told they do not recommend this now -- and PM was also offering to ship a new fan to 'in warranty' PBO owners with fan issues - I don't know if this is the case today, but it wouldn't take long to call or email them and ask
gmd024 is offline
post #724 of 859 Old 01-01-2011, 09:22 AM
rajdori's Avatar
Quoted: 13 Post(s)
bub
i am aware people face problems sharing folders with win7 PCs and PBO. so can someone please list our steps i should follow? my PBO is on wi-fi, not wired connection. thanks in advance.
rajdori is offline
post #725 of 859 Old 01-01-2011, 10:51 AM
replayrob's Avatar
Quoted: 669 Post(s)
Liked: 628
There is a section on the Segate FreeAgent-Theater+ Media player site that list the steps to successful Windows 7 sharing (scroll down about 1/3rd from top of the page):
http://forums.seagate.com/t5/FreeAge...FAT/td-p/48382
“You cannot play God and then wash your hands of the things you created.”
Commander Bill Adama
replayrob is offline
post #726 of 859 Old 01-06-2011, 07:51 AM
crumblebar's Avatar
I just got PBO Core and when I set it up using WEP it works on my dynalink on wep64 but it drops out after 10 mins and I have to reset dynalink to get it back.
My friend has one and same thing happens. He gets his working good with only access list security. It seems WEP has problem. Have not tried wpa. I am hoping for firmware update to fix wep. I am using the recommended wifi usb.
crumblebar is offline
post #727 of 859 Old 01-06-2011, 05:08 PM
unmesh's Avatar
I just got any box and am stuck trying to figure out how to access my shared media folders that or on a Linux-based NAS on my LAN that is set up to use SAMBA as the network file system. Other media players have no trouble accessing these folders.
The NAS does not show up under Browser->NET->My_Shortcuts or My_Neighbors
Did I miss a fundamental setup step?
unmesh is offline
post #728 of 859 Old 01-06-2011, 09:25 PM
replayrob's Avatar
Quoted: 669 Post(s)
Liked: 628
Make sure your NAS uses "WORKGROUP" for it's SAMBA workgroup.
"WORKGROUP" should show up along with "My_Shortcuts" and "My_Neighbors" then in the PBO's network browser.
post #729 of 859 Old 01-07-2011, 06:57 PM
TheKrell's Avatar
I use my last name for my workgroup, and that works too. All windows boxes and two NAS's from Netgear and Buffalo (which I believe are running Linux themselves) show up fine.
TheKrell is offline
post #730 of 859 Old 01-08-2011, 01:08 AM
unmesh's Avatar
I use a different workgroup name (i.e. not WORKGROUP) that does not show up in the UI under net but will try WORKGROUP to see if it makes a difference.
I can ping the PBO so low level network functionality is working.
unmesh is offline
post #731 of 859 Old 01-08-2011, 01:37 AM
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
Setup a shortcut instead of going through Browser ->Net -> Workgroup or My_Neighbors.
You will find the shortcut list empty when go there, press options on the remote and fill the info as requested, for more info refer to the PM support forums.
aasoror is offline
post #732 of 859 Old 01-10-2011, 01:15 AM
crumblebar's Avatar
wpa works fine. Happy with unit.Wifi does not fit rear connector and had to use cable. Fan quiet. Seems great unit for price with free wifi. I still use xp and networking all works. This forum was helpful to read. Thanks everyone.
post #733 of 859 Old 01-15-2011, 09:24 AM
Wdnuwndr's Avatar
Got one of these for Christmas & just got around to hooking it up.
It will only play about 2/3 of my mkv files, which means I now have about 40 titles that wont work. Sound but no video.
They played fine thru my htpc using MPC-HC, is there a fix for this?
Tried searching this thread but didnt hit on anything.
Wdnuwndr is offline
post #734 of 859 Old 01-15-2011, 11:10 AM
replayrob's Avatar
Quoted: 669 Post(s)
Liked: 628
Those 40 MKV's could have been encoded with header compression enabled. Try updating to the latest PBO firmware- I believe it addresses the header compression issue.
post #735 of 859 Old 01-15-2011, 02:14 PM
Wdnuwndr's Avatar
thanks, will try it.
is there a how to on upgrading or does it update itself?
Wdnuwndr is offline
post #736 of 859 Old 01-16-2011, 08:54 AM
TheKrell's Avatar
No, it doesn't check automatically. Go here for formware updates and instructions: http://www.patriotmem.com/forums/showthread.php?t=2131
TheKrell is offline
post #737 of 859 Old 01-16-2011, 04:22 PM
Wdnuwndr's Avatar
Updated & they all work now.
Thanks replayrob & thekrell!
Wdnuwndr is offline
post #738 of 859 Old 01-17-2011, 11:36 AM
replayrob's Avatar
Quoted: 669 Post(s)
Liked: 628
It's really a great little player for under $100, I'd buy another without hesitation if I needed another simple media player.
post #739 of 859 Old 01-17-2011, 08:58 PM
TheKrell's Avatar
Same here. Netflix client would really clinch that deal.
TheKrell is offline
post #740 of 859 Old 01-22-2011, 08:11 AM
Dan89's Avatar
Looking to buy this unit, just wanted to check its right for my set up.
I have all my media on a win 7 pc,
It will have a gigabit hardwired connection to box for transfers.
Wanted to check it will pull High def movies over the cable ok.
Also, my wife is the main person to use it.
Is the UI ok for none techies to use? been using XBMC so far for her. Don't expect it to be that refined but would like your feedback.
thanks
Dan89 is offline
post #741 of 859 Old 01-22-2011, 10:04 AM
replayrob's Avatar
Quoted: 669 Post(s)
Liked: 628
Originally Posted by Dan89 View Post
I have all my media on a win 7 pc...
No problem as long as you set up the Win 7 sharing properly- see http://forums.seagate.com/t5/FreeAge...FAT/td-p/48382 for details (scroll about 1/3 down from the top of the page and start reading at "WINDOWS 7, NETWORK PROBLEMS:".
It will have a gigabit hardwired connection to box for transfers. Wanted to check it will pull High def movies over the cable ok.
Even a properly working 100mbs connection is good enough for HD, so you should be fine.
You can setup a shortcut to your Win 7 shared folder on the PBO's main menu so it's very easy to find your media.
PS.... make sure you update to the latest firmware (see post # 736 in this thread for the link to the official PBO firmware) for compatibility with current MKV's.
Interestingly enough, this particular player can be cross flashed to use modded firmware from the A.C. Ryan Playon!HD media player. You can not use the AC Ryan firmware directly from the AC Ryan site- it has to be modded for use on the PBO unit. Once modded for the PBO- it's then labeled "ACRBO" (AC Ryan Box Office). The latest ACRBO firmware is "9/12/2010 : 4824 patched" and can be found here: http://www.patriotmem.com/forums/sho...&postcount=807. After running the stock PBO firmware I find I much prefer the ACRBO firmware because of it's much nicer GUI and also better navigation (specifically timeline navigation).
post #742 of 859 Old 01-22-2011, 10:17 AM
Dan89's Avatar
Thanks Rob.
Can you do multiple Shortcuts? i have multiple drives.
great help its on sale at $60 so want to get the offer
Dan89 is offline
post #743 of 859 Old 01-22-2011, 10:29 AM
replayrob's Avatar
Quoted: 669 Post(s)
Liked: 628
Thanks Rob.
Can you do multiple Shortcuts? I have multiple drives.
Don't know as I don't use the shortcuts- I just use simple folder browsing, but looking at it- there is an "add" function so I'm sure it's for multiple Shortcuts.
If you don't mind me asking- where is it on sale for $60??
post #744 of 859 Old 01-22-2011, 10:56 AM
Dan89's Avatar
ok cool.
going to buy it now from here.
Code:
http://www.canadacomputers.com/product_info.php?cPath=44_567&item_id=026754
hope its ok for the link
Dan89 is offline
post #745 of 859 Old 01-22-2011, 11:18 AM
replayrob's Avatar
Quoted: 669 Post(s)
Liked: 628
ok cool.
Code:
Nice.... just FYI, Patriot is notorious for "losing" rebate submissions- so keep copies of everything!
post #746 of 859 Old 01-22-2011, 12:06 PM
unmesh's Avatar
Uh, oh! I hope they don't lose mine.
P.S.: I'm another fan of the ACRBO modded firmware load referenced a few posts above.
unmesh is offline
post #747 of 859 Old 01-22-2011, 12:08 PM
unmesh's Avatar
You can set up multiple shortcuts but each one of them has to be to the root of a SMB share and cannot be directed deeper into the folder hierarchy within that share.
unmesh is offline
post #748 of 859 Old 01-22-2011, 12:39 PM
unmesh's Avatar
My understanding through playing with Seagate FAT+ firmware upgrades is that Netflix requires the vendor that includes the client to tighten down firmware such that installing modded firmware becomes difficult if not impossible. Once you upgrade to 2.x, you can't go back.
Similarly, there are 3rd party mods available for WDTV Live but not for WDTV Live Plus that includes the Netflix client.
Thus there is a tradeoff to be considered.
unmesh is offline
post #749 of 859 Old 01-23-2011, 12:15 PM
aasoror's Avatar
Quoted: 26 Post(s)
Liked: 32
True, though don't know for sure if FAT+ added netflix to their already to be locked firmware, or if netflix asked for the firmware to be locked for them to certify it for netflix.
Nonetheless, you can push netflix to the PBO (and similar devices) via Playon.tv using UPnP. Works like a charm but not as slick or convenient as having native support.
aasoror is offline
post #750 of 859 Old 01-28-2011, 11:46 AM
LastButNotLeast's Avatar
Quoted: 1500 Post(s)
Liked: 1102
From DealNews:
Today only, for its newsletter subscribers, newegg.com offers the Patriot Box Office Network Media Player, model no. PCMPBO25, bundled with the Patriot 2K Games 4GB USB 2.0 Flash Drive, model no. PSF4GUSB-NE, for $45.99 with free shipping via the directions below. That's $5 under our December mention of a bigger bundle and $60 under the lowest total price we could find for these items purchased separately elsewhere. You can connect both USB external or 2.5" internal hard drives to this media player and stream media to a television via its 1080p HDMI output. To get this deal:
1.Add the Patriot Box Office Network Media Player to your cart for $89.99
2.the flash drive adds automatically to the cart
3.apply coupon code "EMCKJHB22" drops it to $80.99
4.redeem this $35 mail-in rebate for a final price of $45.99
Brand: PatriotModel Number: PCMPBO25
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
