Patriot Box Office 1080P High Definition Media Player PCMPBO25 - Page 29 - AVS Forum | Home Theater Discussions And Reviews
post #841 of 859 Old 07-15-2011, 07:46 PM
LastButNotLeast's Avatar
Quoted: 1792 Post(s)
Liked: 1403
Originally Posted by Irwinroad View Post
Processor ID/revision = 0x93 / 0x78 on a DD+
Thanks so much for checking.
Sorry it was to no avail.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #842 of 859 Old 08-26-2011, 10:42 AM
bugsy2277's Avatar
I am wondering if there is a way to delete saved NET Shortcuts?
bugsy2277 is offline
post #843 of 859 Old 08-26-2011, 10:43 AM
bugsy2277's Avatar
I was wondering if there is a way to delete shortcuts on this thing?
post #844 of 859 Old 08-27-2011, 06:50 AM
aasoror's Avatar
Quoted: 28 Post(s)
Liked: 33
Select shortcut -> Press "Options" button on the remote -> Press "Delete Shortcut" from the menu.
aasoror is offline
post #845 of 859 Old 09-09-2011, 12:25 PM
KillaB's Avatar
On a unit with the 1073DD+ and 3rd party firmware, will it bitstream HD audio from a DLNA server (FUPPES in my case)?
I'm pretty sure my PS3 Slim can handle bitstreaming HD audio as well, but ONLY with USB attached storage.
KillaB is offline
post #846 of 859 Old 09-10-2011, 12:25 AM
aasoror's Avatar
Quoted: 28 Post(s)
Liked: 33
Not even sure FUPPES itself can stream HD audio to DLNA clients.
The question is, why do you need a DLNA server instead of direct accessing the media over NFS or SMB shares ?!
aasoror is offline
post #847 of 859 Old 09-15-2011, 08:41 PM
KillaB's Avatar
Indeed it can. I just tested this with the latest SVN 0.686
My only home media streaming client up until now has been the PS3, so....no reason other than that's all I was used to working with.
On the PBO, I'm seeing stuttering with high bitrate video using DLNA, but not with Samba. It wasn't a problem for the PS3, but it looks like I'll be sticking to Samba for this new box.
KillaB is offline
post #848 of 859 Old 12-07-2011, 11:15 AM
blueribb's Avatar
Quoted: 17 Post(s)
I'm not sure if this is the right thread for this question but here goes:
A friend brought over his Patriot Box Office media streamer that stopped seeing his wired network completely (windows XP). It worked intermittantly over the last year. He never did any Firmware updates.
I have a wired network and Windows 7 (2 computers). My Western Digital Live Plus has been working flawlessly for over a year. When I connected his Box Office and went through network discovery, it found my network instantly and after clicking "browser" and then "workgroup", it found both my computers. Clicking on either one it brings up a login/password box. My wired network uses neither. I tried entering nothing and got "login failed". Then I tried "admin" and "123" and got the same. No way am I hacking my computers registry since it works perfectly with my Western Digital streamer.
Would a firmware upgrade fix this or is the registry hack the only fix ?
blueribb is offline
post #849 of 859 Old 12-08-2011, 06:17 PM
TheKrell's Avatar
I think you've proven that your friend's PBO is working fine. IIRC you do have to bend over to get W7 to show for what is essentially a Linux box. My advice; give your friend his PBO and tell him to fix his network!
TheKrell is offline
post #850 of 859 Old 03-13-2012, 08:58 AM
Live_now's Avatar
Originally Posted by nnn614 View Post
I found this information that was related to WD TV but it worked for my PBO too:
Win7 (and Vista) has some issues broadcasting its availability on a network.
You could try these changes to your Win7 box:-
Firstly, configure Sharing and Discovery:
1. Navigate to the Network and Sharing Center via the Control Panel
2. Click on the down arrow icons and select ON/OFF as follows:
Network Discovery - ON
File Sharing - ON
Public Folder Sharing - OFF
Printer Sharing - ON
Password Protected Sharing - OFF
Media Sharing - OFF
Next, configure the folder you want to share:
1. Select the folder
2. Right-click and choose 'Share' from the menu
3. From the drop-down box select the Everyone (All users in this list) account, making sure permissions are set to 'Reader'
4. Click the buttons Add, Share and Done.
Here are some further registry 'tweaks' if this doesn't work:
WARNING: This requires editing your PC's registry which, if edited incorrectly, can cause Windows systems to become unstable and unusable. So, follow the instructions below at your own risk. - we are not responsible for any damage caused by following these steps.
1. Navigate to the following location in the registry editor.
MACHINE\\System\\CurrentControlSet\\Control\\Lsa\\
2. On the right side, double-click on 'everyoneincludesanonymous' and change the 'Value data' from '0' to '1'
3. Double-click on 'NoLmHash' and change the 'Value data' from '1' to '0'
4. Navigate to the following location in the registry editor:
MACHINE\\System\\CurrentControlSet\\Services\\LanManServer\\ Parameters
5. Double-click on 'restrictnullsessaccess' and change the 'Value data' from '1' to '0'
6. Close the registry editor
Finally, restart your PC.
I think the registry tweaks are what actually got everything working. Now when PBO asks for the ID and Password I just leave them blank and it connects fine. Hope you guys have the same results:
Sorry, but it doesn't work with Windows7.
I still need netuser id and password...
Live_now is offline
post #851 of 859 Old 03-26-2012, 07:00 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
I'm having this same issue. I don't have a "log in" to the PC with the media on it, either. I haven't tried these tweaks because the PBO is now on a rarely used HDTV.
Sammy2 is offline
post #852 of 859 Old 03-27-2012, 06:32 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
So maybe it just took some time to be recognized on the network but now my media from my main PC is showing up but the media on my HTPC isn't. All data drives on my network a shared and work fine between each other through Windows.
Sammy2 is offline
post #853 of 859 Old 03-27-2012, 09:17 PM
Alexpatrascu's Avatar
Quick question guys.
I just bought a PBO from someone and it came already with the latest(???) firmware.
Is there a way to delete the files(movies) from the internal HDD through the PBO's menu ?!?
With this firmware there is no "File Copy" option anymore !!!!!
Any ideas if I can use the menu to delete he files or the only way to do it is to connect the PBO to the comp and delete the file like that ?!?
Also is there a way to make the movies look more like movies(no so real) on a Samsung ln52b610 through the PBO ?!?
The TV shows the info 1920×1080 24HZ when I switch the source to HDMI.
Alexpatrascu is offline
post #854 of 859 Old 03-28-2012, 07:05 AM
replayrob's Avatar
Quoted: 831 Post(s)
Liked: 844
My LG brand TV has a feature called "TrueMotion" that gives all video the Soap Opera effect. It's great for sports because it smooths out any jerkiness and judder, but I hate it on TV shows and movies because it makes them look like live TV rather than film. Your TV probably has Samsung's equivalent of "TrueMotion" look through the TV's menu and try to switch it off.
Everybody has a plan until they get punched in the mouth!”
M. Tyson
replayrob is online now
post #855 of 859 Old 06-25-2012, 09:59 PM
rajdori's Avatar
Quoted: 14 Post(s)
dont remember which firmware i have... but when on a file or folder.. press > Option > Delete..
rajdori is offline
post #856 of 859 Old 12-14-2013, 07:37 PM
luckydog2006's Avatar
If anyone is still having this media player, and your fan is getting noisy, all you do is a very simple fix. There is no need to buy a replacement fan. Just pop open the PBO media player and check the little PC fan in the media player. There is a sticker in the middle covering the bearing. Just peel the sticker slowly (you don't need to remove it) and uncover the bearing. Then put a few drops of 3-1 lubricating oil, and just cover it back up with the sticker.
Leave it for around ~ 20-minutes or so for the oil to lubricate the bearing, and then you can check it out. It should run extremely quietly ... smile.gifsmile.gif
luckydog2006 is offline
post #857 of 859 Old 01-26-2014, 02:27 PM
lazytrace's Avatar
I'm getting this as a hand me down. Is it still relevant to today's standards? I'm basicly just going to be watching movies from it through usb. Thanks in advance!
lazytrace is offline
post #858 of 859 Old 01-27-2014, 04:57 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Do you know which chip it has? It's been a while but I still have mine and it has th 1073 DD+ chip in it and you flash it with the MedeBO f/w hack it will bitstream and/or decode lossless audio like dts/HD-MA and Dolby TrueHD.
That said, because it is older hardware it operates quite slowly. I prefer my Roku 2 XS with Mediabrowser.
Sammy2 is offline
post #859 of 859 Old 01-28-2014, 06:54 AM
aasoror's Avatar
Quoted: 28 Post(s)
Liked: 33
even with the old chip that doesn't support bitstreaming you can still get 5.1 lossy audio passthrough. If its just click and play for MKVs and AVIs yes you should be good.
aasoror is offline
