WDTV Live - Latest Firmware 1.01.11 - Bugs ?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-29-2009, 09:01 AM - Thread Starter
sugar's Avatar
Hi,
After upgrading to the last official firmware I no longer was able to play the famous Killer Sample - Planet Earth
It just hangs, but worst than that, I was unable to play a 1080p with DTS audio just like this sample spec :
Land.Of.The.Lost.1080p.BluRay.x264-HD1080
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1mn 6s
Bit rate : 9 295 Kbps
Width : 1 920 pixels
Height : 1 040 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.194
Stream size : 74.1 MiB (84%)
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1mn 6s
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Video delay : 27ms
Stream size : 12.0 MiB (14%)
Language : English
I had to upgrade my WDTV Live to a HomeBrew - non official - firmware from B-RAD
I already had fixed my WDTV live with that firmware, all plays fine now
but does anyone have had this problems with the official firmware ?!
sugar is offline
post #2 of 13 Old 11-29-2009, 11:08 AM
toomeypj's Avatar
I had audio sync problems in .mkv files with version 1.01.11
The audio was off by several seconds in about half of my mkv movie rips.
I tried B-Rad's software based on the factory 1.01.11 version and it did the same thing.
So I reinstalled 1.01.01 and everything is working as before.
I would be wary of updates unless you know how to roll back to an earlier version. (took a bit a research to figure it out).
toomeypj is offline
post #3 of 13 Old 11-29-2009, 11:20 AM - Thread Starter
sugar's Avatar
Thanks for your reply, The new WD firmware is buggy
I took B-RAD 0.2.2.1
WDLXTV_LIVE-0.2.2.1
It seams it works fine, what is yours ?!
How did you rollback ?!
sugar is offline
post #4 of 13 Old 11-29-2009, 02:36 PM
toomeypj's Avatar
In the file "WDTVLIVE.ver" which is one of files you put on a USB memory stick to update the WDTV Live, you edit this line (the only line in the file):
VERSION='1.01.00'
LOCATION='wdtvlive.bin'
PKG_LOCATION='wdtvlive.pkg'
You change the version number to a higher number than you currently have on the device. When you start it up it will say a new update is available and allow you to install the updated software.
toomeypj is offline
post #5 of 13 Old 11-29-2009, 02:39 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
VERSION='1.01.00'
cant u upgrade via internet connection?
zoro is offline
post #6 of 13 Old 11-29-2009, 02:44 PM - Thread Starter
sugar's Avatar
VERSION='1.01.00'
thank you very much for your info
sugar is offline
post #7 of 13 Old 11-29-2009, 03:10 PM
toomeypj's Avatar
Zoro,
You can upgrade by internet connection (from Western Digital only) but you cannot downgrade to an earlier version.
toomeypj is offline
post #8 of 13 Old 11-29-2009, 03:46 PM - Thread Starter
sugar's Avatar
Zoro,
toomeypj, I suppose you still use B-RAD HomeBrew firmware, right ?!
But what is your stable version ?!
I have from B-RAD this one :
WDLXTV_LIVE-0.2.2.1
which seams to be based on the buggy 1.01.11 WD's launch
It seams to work fine right now, but I don't know further
you didn't said what version you got, can you help ?!
sugar is offline
post #9 of 13 Old 11-29-2009, 05:06 PM
toomeypj's Avatar
I went back to the WD 1.01.01 that came on the unit because I had no problems with it.
The update only gave me a problem with audio sync, so I decided to be more cautious about updating even from the manufacturer.
But now I now how to install any firmware, so I await more features that I can use.
toomeypj is offline
post #10 of 13 Old 11-29-2009, 05:34 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Zoro,
thanks! so if I upgrade online then only way to downgrade is use old version on USB! Is it right?
zoro is offline
post #11 of 13 Old 11-29-2009, 06:17 PM
toomeypj's Avatar
Yes,you can get any of the old firmware from B-Rad's website
toomeypj is offline
post #12 of 13 Old 11-29-2009, 09:40 PM
silvereyes's Avatar
HDMI does not seem to work when you use a HDMI to DVI cable. It sets OK, but seems only to send 480 signals even though it is set to720p.
WDTV1 handled the HDMI to DVI fine. New fw hasn't fixed this problem.
silvereyes is offline
post #13 of 13 Old 11-30-2009, 04:31 AM
willise's Avatar
Does anyone have a link to a tutorial for installing the custom firmwares? I will probably need something specific (at least for the first time).
My unit shows up this week.
willise is offline
