Oppo BDP-83/93/95/103/105 DLNA/UPnP thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #271 of 2805 Old 01-28-2010, 09:15 PM
Tokyo_Joe's Avatar
DVD shrink seems to work nicely. I wonder though, is there a Linux alternative which will make a single VOB file nice and simply?
DVDShrink works OK in Wine but my system seems to get upset when you have more than a couple of things running in Wine at one time. And I've got Asset running in the background.
Tokyo_Joe is offline
post #272 of 2805 Old 01-29-2010, 01:02 AM
Emil Faber's Avatar
The cat command does a nice job
cat file_1.vob >> file.vob
cat file_2.vob >> file.vob
etc.
Probably not the best thing if you want to pick audio tracks, etc. and no GUI interface
Cheers,
joe
Knowledge is good. - Emil Faber, Faber College
Emil Faber is offline
post #273 of 2805 Old 01-29-2010, 03:20 AM
Tokyo_Joe's Avatar
Hah. Who needs GUIs? We never had 'em when I were a lad.
Thanks for that.
post #274 of 2805 Old 01-29-2010, 07:10 AM
Gary P. Gibbs's Avatar
Blu-ray streaming
Thought I would summarize the little bit I have found:
blu-ray -> MakeMKV -> Tversity -> Oppo works on two discs tried. One disc was encoded with "Mpeg4" and had no problem. Player is a bit non-responsive (Pause, stop, etc.) during playback. The other was encoded with vc-1 and had the aspect ratio wrong during playback. If anyone has different or better experiences let me know. Looking for a method to play my blu-ray titles off network and I don't feel we are there yet.
Gary
Gary P. Gibbs is offline
post #275 of 2805 Old 01-29-2010, 09:38 AM
andersa's Avatar
Quoted: 36 Post(s)
Liked: 33
Originally Posted by Gary P. Gibbs View Post
Blu-ray streaming
AC3/DTS sounds only I pressume - i.e. no TrueHD or DTS Master HD?
andersa is online now
post #276 of 2805 Old 01-29-2010, 12:31 PM
Fadi's Avatar
using a mac with twonkymedia server. dvd rips with handbrake using mkv wrapper and h.264 encoding produce a that file plays fine on the computer but when streamed to the oppo have tons of block artifact and color distortion/streaking (large scale, not small). anyone else have/notice these problems? mpeg 4 encoding has no issue. raw vob files play without a problem.
thanks for any input....
Fadi is offline
post #277 of 2805 Old 01-29-2010, 01:52 PM
Sherbona's Avatar
Yes there's a known issue with the Oppo playing back files encoded with the most recent version of Handbrake. See posts 57 and 62 in this thread for more information and workaround (the workaround involves re-encoding in Handbrake with a change in setting).
Sherbona is offline
post #278 of 2805 Old 01-29-2010, 02:16 PM
Have not tried HD sound.
Gary
post #279 of 2805 Old 01-29-2010, 03:31 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Likely not what you want to hear, Gary, but a VC-1-transcoded MKV of mine also appears to play in a shrunk aspect ratio.
vinnie97 is offline
post #280 of 2805 Old 01-29-2010, 05:44 PM
Fadi's Avatar
Thanks. Works like a charm now.
Fadi is offline
post #281 of 2805 Old 01-29-2010, 06:52 PM
jcleve's Avatar
Originally Posted by vinnie97 View Post
That last one is easy...the profile as it is written should direct Tversity to transcode them to PCM.
I have gigabytes of FLAC files - none of which i've found will play on the Oppo.
In the menu, the FLAC files display as PCM files - but when I select play or enter, I get a little play "arrow" by the file - but no sound. After 15-20 seconds, the play arrow moves down to the next FLAC encoded song in the directory, tries to play it, then moves on to the next - so on and so forth.
So I'm not sure why they aren't playing.
jcleve is offline
post #282 of 2805 Old 01-29-2010, 08:49 PM
rdgrimes's Avatar
Quoted: 2481 Post(s)
Liked: 1785
If they are 24 bit, you'll need Asset to play them. If they are 5.1, no go.
rdgrimes is online now
post #283 of 2805 Old 01-29-2010, 10:44 PM
Dawgmatix's Avatar
I am wondering if there is anyway I can get the following setup to work -> I am on my pc programming and my pc is serving files via a dlna server (say tversity) - can I control what songs playing from my pc ? Basically I want to use the dlna server as a remote which forces the oppo to play the songs I want. Currently I have to get up from the pc - walk to the oppo and then change songs.
Dawgmatix is offline
post #284 of 2805 Old 01-30-2010, 05:50 AM
generalhead's Avatar
Your Oppo didn't come with a remote?
generalhead is offline
post #285 of 2805 Old 01-30-2010, 06:35 AM
offten's Avatar
From the last sentence in DawgMatix's post, I believe he wants to change songs from the PC.
Since my preference for songs changes from week to week, I just copy the songs I want to hear into the server's library folder rather than pointing the server to the folder with all my songs.
Alan
offten is offline
post #286 of 2805 Old 01-30-2010, 08:00 AM
jcleve's Avatar
I'm not sure how to determine this. I used Exact Audio Copy, with the standard FLAC front end to encode them. This is the info I could get for one of my FLAC files
Comment: Encoded by FLAC v1.1.2a with FLAC Frontend v1.7.1
Track Number: 1
File Format: FLAC
Duration: 3:08
Volume Adjustment: -4.30 dB
Album Volume Adjustment: -5.23 dB
Sample Rate: 44.1 kHz
EDIT - I think they're just regular 16 bit files - after a bit of research I found that 24 bit is a 'higher resolution' audio format - but standard CDs are 16 bit - all of the CDs I encoded to FLAC are standard CDs.
jcleve is offline
post #287 of 2805 Old 01-30-2010, 08:22 AM
sac8d4's Avatar
I apologize if it has already been asked... Does Tversity transcode files into Mp3 or LCPM? I have the free version of Tversity
"Without music life would be a mistake." -Friedrich Nietzsche
sac8d4 is offline
post #288 of 2805 Old 01-30-2010, 08:47 AM
scoogs's Avatar
Just for kicks, I added a BDP-83 icon for the Tversity profile that the OP created.
Add this line to the top of the profile code in post #1 right after the modelName tag.
/images/device_icon_Oppo.png
Then add the attached PNG file to Program Files\\TVersity\\Media Server\\web\\images
Obviously not really needed, but if you want to get rid of the generic icon, this will do it. Now if I could only figure out the profile ID for my AVR...
scoogs is offline
post #289 of 2805 Old 01-30-2010, 08:56 AM
Dawgmatix's Avatar
But unfortunately the pc and the oppo are at such an angle that I have to get up and and walk a bit before the remote is in line of sight with the oppo. Ideal case would be if something like the foobar upnp plugin which has a upnp controller could control the oppo remotely.
post #290 of 2805 Old 01-30-2010, 09:48 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Track Number: 1
File Format: FLAC
Duration: 3:08
You may need a FLAC decoder on your machine that Tversity can access. Did you install the ffdshow codecs that come with the Tversity install?
vinnie97 is offline
post #291 of 2805 Old 01-30-2010, 10:27 AM
Mactavish's Avatar
Liked: 29
Track Number: 1
File Format: FLAC
Duration: 3:08
Rdgrimes, brings up a subject that I was never able to find much more about. I kept a simple text clipping :"FLAC Studio Master" 24-bit, 44.1KHz". I use xAct for creating FLAC rips or converting to FLAC, and there is NO 24-bit option, so I don't know how, or if, one can create these higher bit flac files on their own, or what software can do it. I assume if the source is a CD at 16 bit, there would be NO advantage anyways. I believe this is possibly a setting available in some "studio" software. Anyone know more about "FLAC Studio Master 24-bit"? THanks.
Mactavish is offline
post #292 of 2805 Old 01-30-2010, 10:54 AM
andersa's Avatar
Quoted: 36 Post(s)
Liked: 33
You can buy 24/96 5.1 flacs from places like linnrecords.com and 2l.no, or you can get them by ripping DVD-A discs.
2 channel 24/96 and 24/88.2 can also be purchased from hdtracks.com.
I've done some testing using Jriver's Media Center 14 (JRMC14) as a DLNA Server last week. 2ch 16/44.1, 16/48, 24/96 and24/192 flacs worked great, but anything 5.1 did not play.
Playing back a DTS WAV encoded in flac played worked too, which is a good indication that the chain from the JRMC converting flac to pcm to oppo to preamp over HDMI is bitperfect.
/Anders
post #293 of 2805 Old 01-30-2010, 10:55 AM
offten's Avatar
You have control over the transcode target via the Oppo profile (provided in the first post). The default now is LPCM (i.e. audio/L16) but you can change it to MP3 by making changes to the Oppo part of the profile as shown in http://www.avsforum.com/avs-vb/showp...&postcount=164
Alan
offten is offline
post #294 of 2805 Old 01-30-2010, 10:57 AM
rdgrimes's Avatar
Liked: 1785
I've not been able to get TVersity to play any FLAC. I do have the FLAC Frontend on the PC. ffdshow is also present.
Edit to add: I have had success with .wav files, but they are always reencoded to 16/44 2-ch or 16-48 2-ch. No 5.1 allowed.
post #295 of 2805 Old 01-30-2010, 11:12 AM
Mactavish's Avatar
Liked: 29
/Anders
You said "ripping DVD-A", one can get 24-bit. What software do you use to rip with. xAct on the Mac computer does not seem to have that option or setting, I do have DVD-A, to use as a test, not sure what software you refer to?
post #296 of 2805 Old 01-30-2010, 12:31 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I'm going to recheck FLAC playback now to see if I dreamt it up...I haven't tried it since initially installing the new firmware.
vinnie97 is offline
post #297 of 2805 Old 01-30-2010, 12:40 PM
Sherbona's Avatar
Windows - for ripping DVD-Audio to an iso file the clone mode of DVDFab is great. To rip tracks to flac there is Foobar2000 (with the MLP Decoder plugin) or DVD-Audio Explorer.
I'm not sure what options exist for Mac users however.
Sherbona is offline
post #298 of 2805 Old 01-30-2010, 12:52 PM
Sherbona's Avatar
-- snip --
/Anders
That's great news Anders, I'm using Jriver MC (14.0.131). I tried a week or two ago but didn't get it to work (but I didn't try all the settings either).
Could you list out your exact settings in the JRMC DLNA configuration, especially under the Audio, Images and Video headings in the DLNA settings? Also, which boxes do you have checked under Advanced?
Then in the Oppo, do you navigate to the file to be played via 'by folder'?
Thanks in advance!
Sherbona is offline
post #299 of 2805 Old 01-30-2010, 01:01 PM
jcleve's Avatar
Yes, I have ffdshow. However, you helped me to identify the problem and find the fix - I hadn't thought to look at ffdshow settings.
In ffdshow, FLAC was shown as disabled, with a statement that a source filter was needed. So I downloaded a "DirectShow Filter Pack", extracted to the ffdshow folder, and then ran the DSFP_inst batch file - that last step adds the necessary registry items for Windows to know where to look for the codecs.
In fact, it won't work unless you run the .BAT file above - very important - but once I ran it, now the Oppo plays FLAC files.
Thanks for the hint! I'm up and running.
jcleve is offline
post #300 of 2805 Old 01-30-2010, 01:23 PM
Mactavish's Avatar
Liked: 29
I have software that does FLAC from CD's, or files, but the question was specifically about 24-bit flac using software, don't know if that exists for consumers. Making a clone or an "image", is not what I am talking about either. Perhaps the windows software you mentioned can take a FLAC 24-bit CD or DVD-A and extract a 24-bit version, is this what you are seeing?
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 83 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Bdp 95 Blu Ray Player
