Oppo BDP-83/93/95/103/105 DLNA/UPnP thread - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #1171 of 2805 Old 09-29-2010, 12:05 AM
locsmiley's Avatar
hey guys
wondering if someone could give me a hand.
i have installed Tversity and replaced the profile file with the one on the previous page of this forum.
Then i rebooted my pc and opened up tversity
question at this point - what do i need to do with the settings? do i need to set the device type or keep it on automatic detection? do i need to set the ip address of the pc or the oppo?
when i turn the oppo on tversity is only listed every now and then. It seems to be quite random. Even when i have used a hard wire it doesn't show. Any suggestions?
When it does show - it doesn't seem to want to play anything. I have tried to play an mp3 - i try to load it and the oppo responds slowly. The blue play symbol comes up and then disappears to the next listed mp3 and this repeats itself. I have been able to stream the same file from my Samsung galaxy S phone with no problems. (which incidently is picked up straight away all the time!)
any help would be most appreciated.
locsmiley is offline
post #1172 of 2805 Old 09-29-2010, 04:23 AM
noaid's Avatar
Automatic detection
No.
Try to stop your firewall and/or antivirus (especially NOD). If it start to work, then you should configure Tversity as allowed in these softwares.
Maybe AV or FW problem, too. Or Oppo firmvare version with different ID then specified in Tversity config. You should see Oppo in Tversity status page as Oppo and not Device or so.
noaid is offline
post #1173 of 2805 Old 09-29-2010, 05:24 AM
locsmiley's Avatar
[quote=noaid;19260920 Or Oppo firmvare version with different ID then specified in Tversity config. You should see Oppo in Tversity status page as Oppo and not Device or so.[/QUOTE]
i think this is the problem as i am running the august beta
where in the profile do i change this? had a look but can't seem to find it
running norton 360 - which seems to be ok in letting stuff through
post #1174 of 2805 Old 09-29-2010, 06:13 AM
noaid's Avatar
replace
by
noaid is offline
post #1175 of 2805 Old 09-29-2010, 10:29 AM
lap777's Avatar
I think that all current and previous ID's could be included in the example profile, I just don't remember if there are quotes around the OR's. Something like this:
And where did TVersity get their bad OPPO profile...
lap777 is offline
post #1176 of 2805 Old 09-29-2010, 10:41 AM
lap777's Avatar
How can I debug my TVersity/OPPO setup if the OPPO always tells me that the file format is not recognized each time that transcoding is activated? Like if the transcoded MPEG was no good. TVersity is on a fresh 64bit OS install.
Similarly, how can we debug particular files? There's almost no feedback on errors from either the software or the OPPO.
I tried ffdshow with and without the TVersity codec pack, and I'm using this website's OPPO profile.
lap777 is offline
post #1177 of 2805 Old 09-29-2010, 04:08 PM
locsmiley's Avatar
Originally Posted by noaid View Post
replace
by
replaced
with
now tversity wont connect to the sever
is this right?
post #1178 of 2805 Old 09-29-2010, 05:18 PM
Spacekiller's Avatar
Read my post (# 1164, page 39) to see, what happens with the different OPPO-strings (on my system).
By the way, is there no one to answer my question about the curious reactions between strings and firmwares?
Spacekiller is offline
post #1179 of 2805 Old 09-29-2010, 07:23 PM
locsmiley's Avatar
i have given up with tversity
downloaded the trial of nero media home and got it working straight away
what i am finding funny is that the oppo takes a while to start streaming a 320kbs mp3 but started streaming a HD mkv straight away.
any thoughts on that?
post #1180 of 2805 Old 09-30-2010, 12:57 AM
noaid's Avatar
Probably configuration - server is transcoding.
I use Asset for audio and Tversity or PS3MS for mkv video. Sometimes happens that PS3MS does not play some mkv and Tversity does.
noaid is offline
post #1181 of 2805 Old 09-30-2010, 05:45 AM
locsmiley's Avatar
but i thought mp3 were native to the oppo's UPnP?
post #1182 of 2805 Old 10-04-2010, 06:52 PM
adydula's Avatar
Been using Asset UpnP beta 3.0 for weeks and its working well for me.
I have some 24 bit cds and in the edit part of Asset you can select 24 bit LPCM..by default its not selected.
When I do this the 24 bit files I have do not show up via the Oppo BD 83SE network menus.
When not selected the files show up and play..??
Wonder if this is a bug? are the files being transcoded as 16 or 24 with this switch not on?
Alex
adydula is offline
post #1183 of 2805 Old 10-04-2010, 10:27 PM
timkeeler's Avatar
Alex
This is a known issue. 24 bit LPCM streaming is not working so you have to leave it unchecked which allows the 24 bit files to be played but knocked down to 16 bit LPCM. From what I have gathered, it is an issue on the Oppo side but one that, in theory, can be corrected. Unfortunately it has not been fixed yet and there doesn't appear to be any strong motivation on the Oppo side to pursue it further. That said, the 24 bit files streamed as 16 bit still sound great!
timkeeler is offline
post #1184 of 2805 Old 10-05-2010, 06:26 AM
adydula's Avatar
I posted on the dbpoweramp beta forum as well. Spoon indicated he is in dicussions with Oppo about this..
FINGERS CROSSED!
and yes the 24 to 16 bit sounds great..
Alex
adydula is offline
post #1185 of 2805 Old 10-05-2010, 06:33 AM
timkeeler's Avatar
FINGERS CROSSED!
Alex
I am very glad to hear that Spoon is still talking to Oppo about it to try to work it out. That conversation began several months ago so I was starting to assume it had fizzled out.
post #1186 of 2805 Old 10-05-2010, 09:13 AM
John Ormsby's Avatar
Sorry if this is a newbie question but I have not been able to find an answer. I have owned a Oppo-83 for a while. I recently purchased a Synology NAS drive and have been playing around with (trying to learn) the DLNA features.
I was wondering if there is a way to display cover artwork when using the Oppo as a media player. When I use my Apple TV, I can put the artwork in and it will show up when I browse the Apple TV. Is this possible with the Oppo?
If so, how would I go about doing it?
John
John Ormsby is offline
post #1187 of 2805 Old 10-05-2010, 09:23 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3326 Post(s)
Liked: 2598
John
There only cover art I have seen displayed is for mp3 files with id3v2 embedded "PIC" tags.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #1188 of 2805 Old 10-05-2010, 10:42 AM
adydula's Avatar
Oppo replied very quickly to my questions (as always!!):
1. 24-bit LPCM should be supported. Ensure that you have FORCE LPCM set to no maximum bit/frequency (Advance Settings in Asset UPnP). Ensure that both the player and Asset UPnP are using the latest firmware builds.
2. Unfortunately the player was designed to populate these fields based on ID3 Tagging and embedded album art. We can't push data from the DLNA server. This is something that we are looking into, but we do not know if it will ever become a part of our products.
for question 1, I will check to see what my setting is in V3 beta of Asset!!
and for 2 at least its not 100% negative for the FLAC metadata etc.
Alex
adydula is offline
post #1189 of 2805 Old 10-06-2010, 12:39 AM
timkeeler's Avatar
Alex
I just downloaded the latest (Sept. 29) Asset beta and was already running the latest Oppo beta firmware. Still no luck on the 24 bit support. Files are still being forced to 16 bits with L24 unchecked and no files listed at all when L24 is checked (same behavior as with previous releases). Hopefully Oppo and Spoon can get to the bottom of this and get it fixed in the near future!
post #1190 of 2805 Old 10-06-2010, 05:56 AM
adydula's Avatar
I tried a few backlevel Oppo firmwares and could not find a combination and swich settings to allow 24 bit flacs to show up from the oppo interface when the 24 bit LPCM was selected in Asset, the 29th build as well.
Alex
adydula is offline
post #1191 of 2805 Old 10-09-2010, 03:36 PM
ronton3's Avatar
Quoted: 56 Post(s)
Twonky which can be used with PPC macs was updated to day. No release notes available. ron
ronton3 is offline
post #1192 of 2805 Old 10-09-2010, 04:03 PM
nathan_h's Avatar
Quoted: 1475 Post(s)
Liked: 960
How is this release in terms of performance? I upgraded a while back and the OPPO stopped seeing content. Haven't had time to troubleshoot but my plan was to roll back to an older version.
My current setup.
My favorite movie review podcast, the Next Picture Show.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is online now
post #1193 of 2805 Old 10-10-2010, 12:15 AM
ronton3's Avatar
Quoted: 56 Post(s)
Things show up and play from the OPPO-83
ronton3 is offline
post #1194 of 2805 Old 10-10-2010, 09:34 AM
alatham's Avatar
Okay I am sure that this is covered somewhere in the many pages of this thread, but I am having trouble piecing the latest solution together. I have an Oppo blu ray player with my airport extreme/time machine connected via hard wired ethernet. I have a 2009 MacBook Pro. What do I need to download on my MacBook and or my Oppo to stream from my computer to my Oppo 2 channel setup. Note I have loaded the latest beta firmware on my Oppo which states that it fixed network streaming. Thank for anyones help here and please include my nickname "alatham" in your reply if you can so I am clear that the response is to my request.
alatham is offline
post #1195 of 2805 Old 10-10-2010, 10:54 AM
wmcclain's Avatar
Liked: 2598
You'll need a DLNA server on your Mac. I have not kept up with the options, but read the FAQ starting at What is DLNA? and perhaps the first post in this thread for server comments.
I use Twonky on Linux and it is available on Mac and Windows as well.
-Bill
post #1196 of 2805 Old 10-10-2010, 12:09 PM
Whatever1's Avatar
Quoted: 27 Post(s)
Has anyone gotten the Oppo to play FLAC files... using a server ?
What format would I save a dvd in to play through a server ?
Whatever1 is offline
post #1197 of 2805 Old 10-10-2010, 12:29 PM
nathan_h's Avatar
Liked: 960
yes several people using the solution from the bdpoweramp folks. see first post of this thread. requires the server to transcode to an oppo understandable format.
My current setup.
post #1198 of 2805 Old 10-10-2010, 11:16 PM
nathan_h's Avatar
Liked: 960
Thanks. My issue was a vista sharing setting. Now resolved.
My current setup.
post #1199 of 2805 Old 10-11-2010, 10:57 AM
Quoted: 219 Post(s)
Liked: 104
Yes, I use Foobar2000 for my flac music files.
Perpendicular is online now
post #1200 of 2805 Old 10-11-2010, 11:12 AM
peteS's Avatar
You have to use a server which can transcode FLAC to something else - e.g. LPCM. I use Asset - works pretty well.
peteS is offline
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 83 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Bdp 95 Blu Ray Player
