Oppo BDP-83/93/95/103/105 DLNA/UPnP thread - Page 88 - AVS Forum
 15Likes
post #2611 of 2621 Old 12-04-2014, 09:14 PM
Manic_D's Avatar
Originally Posted by wekya View Post
Sorry guys, call me stupid or crazy if you want, but still I'm missing this whole transcoding concept. Is everything related to the creation of images done by the silicon inside the OPPO (or as mentioned above, an iPad etc.)? Can the OPPO 105D handle anything thrown at it, which I'm guessing these days the most challenging thing would be playing a 3D Bluray .iso stored on a NAS? In my imagination the killer electronics inside the OPPO should do all the work. I think/hope the NAS is simply treated as a source of data, akin to the onboard disk player. The OPPO, or any device, says "gimme data so I can make pretty pictures" and the data stream comes either from the onboard disk player, or a NAS. The main reason I'm buying this unit is because my HTPC just can't cut the mustard with 1080p files anymore. That said, if the NAS, (rather than the 105D) with it's lesser CPU is being asked to "crunch data to make pretty pictures" I'm afraid I'll wind up back in uncut mustard land. That goes double if the NAS is also doing all of it's other duties sharing data to other users, and writing to itself.
The Oppo will play pretty much anything you can throw at it. Transcoding is only a factor if you want to play videos from your NAS on another device that can't play everything.
The Oppo only has a basic file view for browsing, without thumbnails or metadata (unless you count the Gracenote built in which is very poor), although Synology etc have their own apps for that if you prefer to use a tablet etc to send files to the Oppo. If you have used Kodi or Plex, you might find that look and information desirable!
I actually have a dedicated Kodi box and run Plex on PC, but the Oppo has better quality (although some say they can't see a difference.)
It all depends on what your needs are now and in the future.
Manic_D is offline
post #2612 of 2621 Old 12-04-2014, 10:29 PM
wekya's Avatar
Quoted: 20 Post(s)
Sorry, when I said pretty pictures, I should have said pretty moving images.
Totally OT...sremnick....where do you fall on youse and ain't?
Acer Revo RL100 HTPC Win7 64;1.3Hz Athlon II Neo K325 Dual Core;4GB 1,066MHz DDR3;512MB (shared) Nvidia GeForce GT9400 (Ion)>Panasonic P50ST60.
Audio: Revo USB>HRT Music Streamer II>Linn Classik K>Linn 5125>Aktiv Katans(K400 and black RCA), OR Optical(Realtek Digital output)>Vizio S4251w-B4 5.1
wekya is offline
post #2613 of 2621 Old 12-10-2014, 04:31 PM
SolRage's Avatar
Originally Posted by pvanosta View Post
Luckily, the Synology OS application package comes with a decent (note the word decent) audio player / controller app (called DS Audio Station), which also has a good iOS ap, which I promptly installed on my iPhone and iPad.
Now I can browse, search and play any of my files directly from the NAS to the OPPO without the PC and in truth I don't miss JRiver all that much (not enough to turn the PC on in any case).
Thanks for the response. I actually already have Audio Station installed but didn't know that I could use it to play the music through my Oppo. Is there anything within Audio Station that you have to set to make it send the player to the Oppo?
Also, sorry for the late reply, but I've been offline most all of last week!
SolRage is online now
post #2614 of 2621 Old 12-10-2014, 04:43 PM
pvanosta's Avatar
SolRage:
1. Turn the OPPO on (duh)
2. Make sure the OPPO and the NAS are on the same network (especially if using Wifi)
3. Launch the Audiostation app on your handheld device and go to settings (the cog wheel thingy, somewhere at the top)
4. look for the output option / player and select the OPPO (which should show up in the list, assuming you launched the app after you turned the OPPO on)
5. Browse your library and play.
pvanosta is offline
post #2615 of 2621 Old 12-11-2014, 11:50 PM
wekya's Avatar
Quoted: 20 Post(s)
Well now I'm back here with a different question. It's really a clarification though. I can't decide between the Synology DS215j, or the DS214play.
1. I think its been made clear that the OPPO 105D doesn't need transcoding done on any NAS using plex etc, the OPPO does all the video creation as it only needs the raw data stream correct?
2. I should buy the cheaper 215j because it should be able to serve all the bits the OPPO needs so it can play the most intensive video, say a ripped BluRay 3D 1080p .mkv, flawlessly, while the NAS is concurrently downloading files from the WAN and sharing other files with 2-3 users inside my LAN? (with a nod to the above, NAS to OPPO all in ethernet)
wekya is offline
post #2616 of 2621 Old Yesterday, 08:58 PM
SolRage's Avatar
Originally Posted by Nicoff View Post
You can also use your Oppo Media Control App (with your iPhone, iPad, etc.) you will see PLEX as an option to connect to.
I did NOT see an option for PLEX on my Oppo Media Control App.
post #2617 of 2621 Old Yesterday, 09:03 PM
SolRage's Avatar
SolRage:
Thanks for this. Spent most of today playing Christmas music like this while putting up decorations! Only hiccup is that I noticed Audio Station doesn't do gapless playback, which would be more annoying with serious listening. Any option that does gapless via iPad -> Synology -> Oppo?
post #2618 of 2621 Old Today, 08:02 AM
LairdWilliams's Avatar
Quoted: 57 Post(s)
Liked: 122
I've not looked closely, but my recollection is that AudioStation is functioning as a DLNA server in this configuration, so the Oppo is being used as a DLNA renderer. If I am correct about this, then there is no option for gapless yet. The Oppo does not do gapless over DLNA.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #2619 of 2621 Old Today, 10:07 AM
pvanosta's Avatar
Thanks LairdWilliams.
I have a quick question: I have been reading a lot about gapless playback. What exactly is meant by that phrase? Whatever it is, I don't seem to miss it. I'm enjoying the convenience of having a vast library on my NAS (over 10,000 CDs now) and having the ability to search, browse and play anything I want using my smartphone or tablet anywhere in the house.
If the 'gapless' in gapless playback refers to the short pause between tracks, that (to me at least) is such a minor inconvenience compared to the major upsides, that I don't even notice it.
I have now also ripped my collection of CDs (1000 or so actual discs) to my NAS and will be donating them to friends and colleagues once ripped. The only media I will hang onto, are a small collection of SACDs and DVD-A.
pvanosta is offline
post #2620 of 2621 Old Today, 02:39 PM
pbarach's Avatar
Quoted: 98 Post(s)
Liked: 102
If you are listening to material such as pop albums that end each track with silence or a fade-out at the end of a song, then gapless playback is irrelevant to your listening habits. However, classical pieces such as operas often break up each act of the opera into many tracks even though the music is continuous. Sometimes there are even multiple tracks within the movements of a symphony. With those kinds of material, as well as with live recordings of any music where applause continues uninterrupted into the next track, the several-second gaps are really annoying, and gapless playback is a blessing.
AT&T U-Verse Northeast Ohio
Denon x4000, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, etc.
pbarach is online now
post #2621 of 2621 Unread Today, 05:21 PM
SolRage's Avatar
+1 To this. Even outside of classical and opera (which I do listen to a lot), try listening to something like Dark Side of the Moon without gapless.
Oppo Bdp 83 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Bdp 95 Blu Ray Player , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player
