Oppo BDP-83/93/95/103/105 DLNA/UPnP thread - Page 91 - AVS | Home Theater Discussions And Reviews
 23Likes
post #2701 of 2718 Old 05-10-2015, 10:54 AM
Smarty-pants's Avatar
Quoted: 351 Post(s)
Liked: 228
^ You CAN access the setup menus with the Oppo Media Control app.
Make sure that you have the latest version. An easy way to do that is to erase the one you have and then
install it again from the IOS or Play store.
I am not sure right now if the IOS version is a bit different from the Android version,
but on my Android phone right now, when I open the app, at the bottom of the screen there are selections to choose from.
If I hit the little right-arrow in the bottom right corner of the screen, it will show more selections.
Then choose SETTINGS and you will see all the menus for the setup menu.
Aside form that, with regard to your non-hdmi monitor...
The player does have what is called a "DIAG" output. I do not recall if I ever tried it,
but I think it is basically a single composite video output used for diagnostics.
If your monitor does have a composite (or even component) input, then you may be able to use that connection.
I am not 100% sure it will work, but is worth trying.
However if your monitor only has something like VGA input, then you would need an adapter to pair the two together.
Instead you may be better off just using your iPhone and the MC app.
~Dave
...Theater Room Setup...
JVC DLA-RS40-U... Oppo BDP-105D... Toshiba HD-XA2... Uverse VIP-2250... Roku Streaming Stick... Emotiva XPA-3... Onkyo TX-SR805
JBL LC2 (x3) ... JBL L820 (x6) ... SVS PB10-ISD (x2) ... SVS 20-39-PCI
Smarty-pants is offline
post #2702 of 2718 Old 05-10-2015, 11:05 AM
LairdWilliams's Avatar
Quoted: 133 Post(s)
Liked: 161
Originally Posted by Wolf_D3 View Post
Thank you both for your very prompt replies. I have a spare computer monitor, but it does not take HDMI inputs. Unless I'm mistaken, the video outputs from the Oppo 105 are HDMI, so I can't use this monitor. If I open my copy of JRMC on my PC, under "players" it shows the Oppo 105 and if I start an album in JRMC, it will play on my Oppo, so the Ethernet connection less works. However, what I cannot do is figure out a way of accessing the Oppo set up menus. I have both the Oppo remote app and Oppo mediaControl app on my IPhone, but neither shows the set up menus. My JRMC remote app, which generally works to control my JRMC when playing through my computer speakers, doesn't seem to work controlling it when operating the PC as a DLNA server to the Oppo. I'm assuming I could fix all of this somewhere in the setup menus. Any idea of what app that works on an IPhone or Ipad would show the setup menus?
While I tend to prefer the MUCH richer media browsing and playback capabilities of JRiver combined with the BDP-10x over the Oppo MediaControl App and it makes a lot of sense to use your system the way you have it set up - you will still want to download/install the Oppo MediaControl App for the simple reason that it has a setup menu that will let you view/update the settings on your BDP-10x without having to turn on a TV/monitor/whatever. The app will run on iOS (iPhones and iPads) or android - so if you have a smartphone or a tablet, I would recommend you go get it. You may be able to get the rest of the functionality you need there.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is online now
post #2703 of 2718 Old 05-10-2015, 11:30 AM
SeeMoreDigital's Avatar
Quoted: 235 Post(s)
Liked: 110
Android DLNA Streaming App Recommendation
Can anyone recommend an Android DLNA Streaming App I can install on my Android tablet that's able to push audio and video files stored on my Synology NAS to my UPnP connected devices, such as the Oppo and my TV's?
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is online now
post #2704 of 2718 Old 05-10-2015, 01:51 PM
pbarach's Avatar
Quoted: 174 Post(s)
Liked: 124
I have a 103, and no trouble accessing the Oppo setup menus using the Media Control app on an iphone. Just used it today...
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is online now
post #2705 of 2718 Old 05-10-2015, 03:04 PM
rdgrimes's Avatar
Quoted: 800 Post(s)
Liked: 395
Be aware that the latest version of the MediaControl app requires the latest version of player firmware, and vice verse.
If your monitor has a composite video input, you can use that from the player to see setup menus.
rdgrimes is online now
post #2706 of 2718 Old 05-10-2015, 05:13 PM
tezster's Avatar
Quoted: 187 Post(s)
Liked: 126
Cheers
Take a look at Bubble uPNP.
tezster is online now
post #2707 of 2718 Old 05-11-2015, 06:38 AM
ctbarker32's Avatar
I have recently purchased an Oppo 105D. My primary goal for this is to use it as a player/renderer for audio files on my PC to be sent using DLNA, as well as playing SACD discs directly from the Oppo. I do not use any video features and do not have a TV monitor in my set-up. My question is whether I can set up the Oppo, including the networking features (described on pages 44 and 81 of the manual), without adding a monitor to the system. All of the instructions seem to say that you have to use the remote to open up set up screens that only appear on a separate monitor. Right now, I can't set up the network, and I can't even perform what I thought would be basic functions like selecting a specific "album" on a SACD. (For example, I have DSOTM on Blue Ray and DVD, which have multiple mixes of the album. I cannot see how to select specific mixes now).
I know this is a dumb question, but I've skimmed the 90 pages or so on this forum, and started looking at the +400 pages on the general Oppo 105 forum, and just thought I would ask the experts. If this is relevant to the answer, the rest of my system is a Synology 412 NAS connected to a Windows PC running JRiver Media Center 20. The NAS is recognized by the PC as an internal drive, not a NAS. The PC is connected to the Oppo by a Cat 6A wired Ethernet connection. The Oppo plugs by RCA cables into my Odyssey preamp.
Thanks in advance.
You might want to look into LMS (Logitech Media Server) and this plugin https://github.com/philippe44/LMS-to-uPnP which would allow you to use your Oppo as if it was a Squeezebox Player.
More info here:
http://forums.slimdevices.com/showth...highlight=upnp
-CB
ctbarker32 is online now
post #2708 of 2718 Old 05-12-2015, 06:20 AM
richmond5's Avatar
Quoted: 12 Post(s)
A few years back, with media file containing lossless soundtrack in MKV format, have to convert to .M2TS format in order to play MA-DTS/HD-Dolby using my then Oppo 95. Now with my current 105, I accidentally discovered even in .MKV format, I can play the lossless sound, interesting. Any input on that, thanks in advance!
richmond5 is offline
post #2709 of 2718 Old 05-16-2015, 09:04 PM
Liked: 0
It turns out that an out of date firmware on the Oppo was the issue (or one of them). My MediaControl app would not display setting options or other features that should show on a TV monitor. I downloaded the latest firmware to a USB drive and installed that in the Oppo 105. Then my MediaControl App was finally able to connect to the Oppo and show the settings. (It's not clear to me why a new Oppo was shipped with an out of date firmware). This solves some issues, and I am now able to finally control my PC with the MediaControl remote app and play music on my Stereo over DLNA. This was a major goal, to be able to use the Oppo as a DAC without having a PC in the listening room. However, I'm still missing a lot of functionality. Basically, most of the buttons on the "remote" part of the MediaControl, like Top Menu, Pop Up Menu, and Option, and Page don't work, or don't have any visible function. Possibly related to this, I cannot figure out how to access specific "albums" on DVDs or SACDs that have multiple versions of the same album in different mixes or formats. E.g., my DVD copy of DSOTM has 5 versions of the album, but I cannot see how to access 4 of them. Any further advice would be welcome.
Wolf_D3 is offline
post #2710 of 2718 Old 05-17-2015, 08:14 AM
Quoted: 133 Post(s)
Liked: 161
Completed units can sit in inventory for a long time after being boxed up - even if sent straight from the manufacturer. They get what was the latest firmware at the time that the unit was manufactured - but once the box is sealed and taped and stuck in a warehouse...
This is true of nearly all electronics. It is generally a VERY good policy to ALWAYS check the firmware version pretty much as soon as possible after acquisition with ANY kind of electronics.
mhobart likes this.
post #2711 of 2718 Old 05-20-2015, 08:04 PM
owlvn's Avatar
Quoted: 34 Post(s)
Hi, wonder if anyone could help me. I have been having trouble opening movies stored on my synology nas from oppo 103. Everything worked fine earlier, then it just stopped. I am now unable to browse my movies folder from Oppo anymore. Have no clue what happened.
From Oppo main menu, I was able to navigate through my NAS/movie then nothing showed up. Sometimes it kicked me back to the top path which showed all the connected devices on my network.
owlvn is online now
post #2712 of 2718 Old Yesterday, 12:25 AM
pvanosta's Avatar
OWLVN,
Couple of quick questions:
1. How is the Oppo connected to the Synology? Wifi via router or ethernet via switch?
2. Have you rebooted the Synology (and your router)?
3. Have you made any other changes to the network (added/removed devices which need their own IP address)? (possible IP address conflict)
4. Is the Synology up to date on all its software packages?
5. Can the Oppo and/or the Synology 'see' the internet? (goes to prove connectivity)
Just a few things to start the investigation...
pvanosta is online now
post #2713 of 2718 Old Yesterday, 09:41 AM
owlvn's Avatar
Quoted: 34 Post(s)
Originally Posted by pvanosta View Post
OWLVN,
They're both wired to a switch which connected to my router
Yes, they're both working fine.
The changes I made was (1) go to Synology DSM/Control Panel/Network/ and switch back and forth between Get Network Configuration Automaticall (DHCP) and Use Manual Configuration which I assigned specific IP for my Synology.
In addition, I used Apple Airport Extreme to create a wireless network. I first connected my Verizon router to the LAN port on my Airport extreme, then later switch back to the WAN port.
I checked and all is up to date
They do. As said, the Oppo can see the Synology media server as well as its IP. When I selected the Media server, it did not show any folders within movie, music, photos. When I tried to access the NAS through its IP with username and pass, it kepts saying the invalid login.
I had a Dune HD before and had no problem access my Synology Nas, either directly through SMB or Zappiti. I just got the Oppo and a Popcorn A410 and both of them had problem accessing my NAS. I googled and found some others also have the same problem with their Oppo 93, but no solution yet.
Also note that it used to work earlier, which mean both the Oppo and the Popcorn.
owlvn is online now
post #2714 of 2718 Old Yesterday, 10:01 AM
DanF8500's Avatar
Quoted: 447 Post(s)
Liked: 241
^ I've been using a Synology NAS with my 105 for over a year now with very little problems. I'm using all wired connections, directly to my router...no switches. I use Synology's Media Server, and my 105 communicates perfectly with that server. I also use Synology's SMB server with high robustness.
DanF8500 is offline
post #2715 of 2718 Old Yesterday, 10:10 AM
Quoted: 235 Post(s)
Liked: 110
I've never had any problems connecting my Synology NAS to my Oppo either. I use SMB and UPnP connection protocols. All my media devices are connected to a switch and have fixed IP addresses.
Cheers
owlvn likes this.
post #2716 of 2718 Old Today, 12:55 AM
pvanosta's Avatar
Owlvn,
Thanks for the feedback. Based on the fact that many of us in this thread use similar configurations to yours without issue (current model OPPO, Synology NAS, wired LAN, some with static IP, some with DHCP, like myself), combined with the fact that the only things that have changed in your environment have been network related changes (some as part of the troubleshooting for this connectivity issue no doubt), is it possible to try the following:
Connect the Synology directly to the OPPO (via ethernet or USB) and check whether you can see the files on the nas at that stage.
If you can, you know for sure that SOMETHING in your network configuration is causing the issue. Add one component at a time to the chain from there and check each step of the way (reset your router to factory mode and insert it into the chain, check that the OPPO is set to DHCP, the router is set to DHCP, go to a PC and view the router config in a browser to view the connected devices and their IP address, add the next step and so on)
Alternatively, before moving the NAS to the Oppo, can you view, browse, access the files on the Nas from a PC?
These steps may seem obvious, but it's like the principle of Occam's razor. Strip the issue down to its most basic form (in this case: straight wire connection between NAS and OPPO) and start from that until you figure it out.
post #2717 of 2718 Old Today, 07:41 AM
owlvn's Avatar
Quoted: 34 Post(s)
Cheers
Thanks guys for chimming in.
Owlvn,
I can browse and access files on my NAS from my Mac. Also my Nas can see all the devices connected to it (Oppo, AVR, Popcorn A410, etc.). Now I set everything to DHCP and am able to connect to my NAS media server. I guessed all the problem was due to I accidently clicked on the reindex button in my NAS DSM (under shared folders, I believe), which resulted in the NAS reindex all media files and folders under the movie, music and photo. Now the indexing is completed, but occasionally I am still kicked back to the Network browsing screen on my Oppo when trying to open a file on my Nas (using the Media server). I am still having problem to connect to my NAS using SMB protocol, using the admin credentials. I can see and browse through all the folders, but there is no media files at all.
In addition, I am surprised that when I connect from my Verizon router to the WAN port of my Apple airport extreme, the Oppo could not access my NAS. But connecting the V router to Apple router through the LAN port, it works fine.
Another question, when I connect my WD My book to the USP port of my Oppo, the machine could not recognize any media files on it (under main menu of the Oppo, when I select music/movie/photos, nothing shows up). Oppo manual says the player supports USB drive formated in FAT, FAT32 and NTFS. Even my Popcorn A410 could not see the WD as well. It drives me crazy as my Dune HD had no problem accessing my NAS and the WD. I thought buying the Oppo and Popcorn would be a nice upgrade to my system, but it turned out a dissater so far.
owlvn is online now
post #2718 of 2718 Unread Today, 02:08 PM
pvanosta's Avatar
OWLVN
Glad you got most of it working again.
Your WD drive, what is the formatting on it? Have you tried the Popcorn manual for more info?
Oppo Bdp 83 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Bdp 95 Blu Ray Player , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player
