Ideas on how to hookup roku netflix box to lcd pc monitor? - AVS Forum | Home Theater Discussions And Reviews
Old 02-09-2010, 06:10 PM - Thread Starter
Zyzzyva100's Avatar
So I just bought the roku hd box so that I could watch netflix on a spare PC monitor that I have while I exercise. The monitor only supports DVI and VGA, and I figured that I could just use a dvi to vga cable that I have.
However, as it turns out the hdmi output on the box requires hdcp. Now I suppose I should have guessed this would be the case - Nowhere on the roku site does it mention under the specs that hdcp is required. Only if you dig through the FAQ's does it casually mention that you need it.
So, I am left with this box and monitor that I would like to connect, but I can't seem to figure out a way. The monitor only accepts RGB over VGA, and I can't seem to find any converting devices for component (or even composite or s-video) to vga that don't cost as much or more than the box.
I have 30 days to return this without penalty, but I would really like to be able to use it. Anybody have any ideas as to how to make this work?
Zyzzyva100 is offline
Old 02-09-2010, 06:26 PM
sean_w_smith's Avatar
HDMI to DVI adapter.
will pass through HDCP. most LCD's support HDCP....
Sean
sean_w_smith is offline
Old 02-09-2010, 06:28 PM - Thread Starter
Zyzzyva100's Avatar
Ahh, forgot to say. This monitor is a couple years old and does not support hdcp (as far as I can tell at least - its a 19" sceptre widescreen). I tried the hdmi to dvi cable and it didn't work. The monitor simply flashed no connection.
