Dune firmware 100307_2100_beta discussion - NEW - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-07-2010, 11:09 PM - Thread Starter
Opentoe's Avatar
Quoted: 87 Post(s)
I like it so far. But I'm an easy one to please.
http://dune-hd.com/firmware/bdprime3/
Opentoe is offline
post #2 of 5 Old 03-08-2010, 02:26 AM
VAMET's Avatar
Dear Friends
How to update FirmWare to the newest Beta from the 1st stable FirmWare?
I need to download FirmWare file .dff from http://dune-hd.com/firmware/hdbase3/
I need to copy it to USB Flash Drive to the main folder or other specified folder?
Connect USB to Dune USB port and what next?
Start Dune and it should automaticaly run .dff file or should I do something?
Any manual with how to update FirmWare?
I will be glad. Thank you very much.
Best regards
Sincerely
VAMET
Lapsus Angelus
VAMET is offline
post #3 of 5 Old 03-08-2010, 04:33 AM
lundman's Avatar
put it on usb, use dune to go to usb, push Enter on the .dff file. Upgrade starts
if it does not recognise the dff, you need to do the stepping firmware, but that is an old old firmware, so very unlikely.
lundman is offline
post #4 of 5 Old 03-08-2010, 04:52 AM
MaxBurn's Avatar
I upgraded to it and I don't see any problems but I haven't checked out the new features.
MaxBurn is offline
post #5 of 5 Old 03-12-2010, 02:33 PM
o0Lo0P0o's Avatar
I'm going to check it out when I get home tonight. I wish they would add keyboard support for adding SMB shares though.
Never mind, I found an app on the firmware site that allows you to manually edit the shares to a text file.
o0Lo0P0o is offline
