Samsung AllShare and Internet@TV Discussion - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 792 Old 05-07-2010, 07:51 PM
oneway23's Avatar
I've currently got Mediaplay/Allshare rolling on my brand new Samsung LN46c630. It has been, for the most part, a fairly rewarding experience. I have played primarily .MKV files and DVD rips from Video_TS folders, with seemingly unavoidable intermittent dropouts of the DTS soundtrack. Obnoxious? Certainly....A complete and utter deal breaker? Not quite yet...I have the USB drive connected directly to the TV so I'm fairly certain the audio drops aren't a bandwidth issue, but who knows? Help greatly appreciated, but unfortunately not the impetus for the post.
I'm afraid I've already got the answer to this one, but I'll throw it out there regardless. I'm curious as to whether or not there exists any possible means of enabling subtitles within my .MKV files once connected to the TV? If not, is there anything I can do beforehand that would allow me to pre-select, so to speak, a subtitle track to be enabled and displayed from a muli-language subtitled file? Any help greatly appreciated.
oneway23 is offline
post #92 of 792 Old 05-07-2010, 09:12 PM
enigma9o7's Avatar
Quoted: 66 Post(s)
oneway23 - I haven't figured out how to do it yet, but I believe it is possible, you gotta extract the subs from the mkv into a seperate srt file... but like I said havent tried it so dunno how to do it or if it really works... but I think it definitely should work on usb/disc for sure... name the subs the same as the .mkv but with .srt as the extension, once you get them out of the mkv (which I dunno how to do!)
Brit - that reminds me... on the serviio forums he said he might try to make it so his software pulls the subs out from mkv's and sends them separately somehow so the samsung sees them... did he end up doing that in the beta? (If he did, is there a way to enable/disable the subs if you dont want them, does it work with the subtitle button on the remote?)
Samsung F8500 | Tivo Roamio OTA | Yamaha RX-A1040 | Oppo BDP-103
enigma9o7 is offline
post #93 of 792 Old 05-08-2010, 07:13 AM - Thread Starter
BritInVA's Avatar
Nothing in 0.4 for subtitles
BritInVA is offline
post #94 of 792 Old 05-08-2010, 10:21 AM
oneway23's Avatar
If anyone is curious, I burned the midnight oil last night attempting to remove the subtitle files from my .MKV and place the resulting .srt file inside the folder w/ the file. The subtitles were not acknowledged by the Samsung.
Undaunted, I attempted to re-mux the file with MKVmerge, making sure to check the force track flag, hoping to coax the TV into seeing them. As the TV clearly has no means of recognizing subs, the flag was ineffective as well.
At this point, I believe I've reached the end of the line w/ this particular experiment and will most likely be springing for a NMT of some sort. Before I take the plunge, would anyone please tell me if the PCH A-200 has any particular issues whatsoever that I should be aware of with subtitle tracks from .MKVs? Thanks again...
oneway23 is offline
post #95 of 792 Old 05-10-2010, 06:26 AM - Thread Starter
BritInVA's Avatar
So nobody using Serviio has a troublesome file format not curretnly supported in 3.1?
If you do, let me know and I can try to test using the new transcoding feature in the 4.0 Beta .
BritInVA is offline
post #96 of 792 Old 05-10-2010, 11:40 AM
enigma9o7's Avatar
Quoted: 66 Post(s)
mpeg1 video with mp2 audio doesn't work for me.
post #97 of 792 Old 05-12-2010, 01:43 AM
wolfzero's Avatar
My two cents:
The Samsung PC Share software is much better than Serviio. Serviio's Java server is a pile of crap, IMHO. The redundant, overly-complex and completely non-customizable folder system they use is ridiculous and obtuse. Is there any benefit in using this over the Samsung software? I certainly haven't found one.
Features I would like in a uPNP server that the Samsung Share doesn't do:
-Customizable folder database/system that scans imdb/thetvdb for info and shows that instead of filenames. i.e. "Videos>TV Shows>Lost>Season 1>Episode 1 - Pilot" instead of whatever folder/filename structure I have on my hard drive. A good example of this is Boxee or XBMC which are supposedly servers as well, but I don't and won't run them 24x7 on my gaming PC/media server. I definitely need a background application to serve media.
-Auto-update so I don't have to refresh the server every time I add a video to the share folders.
-Online media like Hulu and YouTube (Investigating PlayOn for this soon)
-The ability to jump ahead more than the 1min or so it does when pushing left or right on the Samsung remote. Also, fast forward/rewind capability (which may be a device issue, not the server).
wolfzero is offline
post #98 of 792 Old 05-12-2010, 02:13 AM
wolfzero's Avatar
I just remembered something else useful. I wasn't able to get subtitles to show that are embedded in MKV files. However, you can use mkvmerge GUI to extract subtitles from MKV files to individual (srt if memory serves) files. As long as they're named the same as the video, it works just fine.
wolfzero is offline
post #99 of 792 Old 05-12-2010, 06:37 AM - Thread Starter
BritInVA's Avatar
I would agree that it would be nice to have greater flexibility over the folder system. But PCSM is not great either as it forces you to create the structure on the PC.
How about:
- Auto refreshing of the Server when you add files. With PCSM you have to manually refresh
- Ability to create custom thumbnails or use on-line metadata (although the Samsung Blu-ray player interface makes that useless).
- In upcoming 4.0 version you can trans-code files. Again the Samsung Blu-ray player is a bit limited in what it supports)
Personally on the Server side I think were better off leaning on a 3rd Party to develop the software..... I think ts more of a sideline/gimmick for Samsung. But we will always be constrained by their renderer.
If you have suggestions to improve Serviio why not post over in their forum. Petr seems to be open and responsive to suggestions..... don't think we will ever get a response from Samsung.
BritInVA is offline
post #100 of 792 Old 05-12-2010, 10:13 AM
phatka's Avatar
I got my new BD-C6500 blu ray player from Samsung yesterday. Connecting it to my home wireless network was easy. It connected to it and I was able to watch online content (movies on Netflix, Accuweather, USA News, etc.) using the Internet@TV applications from Samsung. So this basically proves that my blu-ray player is indeed connected wirelessly to my home network.
Now I installed the PC share manager on my Windows Vista laptop (also connected wirelessly to my router) and shared one of pictures folder. Now when I hit the Share button and choose the 'Set Device Policy' I just don't see my Blu-Ray player.
I have tried doing everything I can think of but still can't make the PC Share manager to recognize my blu-ray player. Anybody has any suggestions as what to do?
phatka is offline
post #101 of 792 Old 05-12-2010, 10:34 AM - Thread Starter
BritInVA's Avatar
Might want to post also in the BD-C6500 forum
BritInVA is offline
post #102 of 792 Old 05-12-2010, 11:00 AM
Al Sherwood's Avatar
Quoted: 739 Post(s)
Liked: 271
I know you mentioned that it has 'wireless' connection, have you tried a hard wire connection for both devices?
Al
Al Sherwood is offline
post #103 of 792 Old 05-12-2010, 11:19 AM
phatka's Avatar
Yes I tried that too, connected both my laptop and the Blu-ray player to the router using LAN cables but I still had the same problem (blu-ray player not being detected in the PC Share Manager)
phatka is offline
post #104 of 792 Old 05-12-2010, 11:31 AM
Quoted: 739 Post(s)
Liked: 271
Strange, just so you understand my set up is a bit different, I have a Samsung TV, PN58C550 that has the AllShare feature, and it of course shows up in the Device Policy list of PC Share Manager.
I would assume the the C6500 runs a similar if not the identical AllShare program.
Al
post #105 of 792 Old 05-12-2010, 11:37 AM
phatka's Avatar
The specifications on websites for BD-C6500 does say that it has an AllShare feature. Do you know a place in the settings for Blu-Ray menu where we can check that or needs to be enabled before it can be shared with networks?
phatka is offline
post #106 of 792 Old 05-12-2010, 12:00 PM
Quoted: 739 Post(s)
Liked: 271
Although I don't have a BD-P6500 pages 27-29 in the manual pretty much cover it all.
Also remember: To use AllShare function, please locate both this player and PC in same subnet.
Al
post #107 of 792 Old 05-12-2010, 03:01 PM
phatka's Avatar
The only difference I can see is that they have connected the computer through LAN wire where as mine is connected wirelessly. I'll try this out today.
phatka is offline
post #108 of 792 Old 05-12-2010, 03:11 PM
Quoted: 739 Post(s)
Liked: 271
That shouldn't make any difference.
Also check the DHCP clients table in the router that both devices can be seen and appear on the same subnet.
Al
post #109 of 792 Old 05-12-2010, 03:19 PM - Thread Starter
BritInVA's Avatar
Also any firewall involved?
Have you tried another DLNA Server (like Serviio)?
BritInVA is offline
post #110 of 792 Old 05-12-2010, 04:43 PM
hydrogin's Avatar
Interesting thread! I've been using a modified original Xbox since 2006 to drive my TV with media stored on my home LAN (Xbox runs XBMC which uses Windows CIFS network file sharing protocol). But the old Xbox isn't very suitable for HD so I'm looking for alternatives.
Has anybody successfully used a Synology NAS (DLNA/UPnP-compliant vesions) or PlayOn with their Samsung DLNA-compliant devices?
p.s. PlayOn basic lifetime subscription will cease to be offered on May 20.
p.s.s This is the Synology I'm considering, has very nice RAID capabilities for the price:
http://www.synology.com/enu/products/DS210j/index.php
hydrogin is offline
post #111 of 792 Old 05-12-2010, 05:00 PM
Quoted: 739 Post(s)
Liked: 271
As you are familiar with XBMC, why not install the windows version on a PC and run with that? I was looking at this product and the interface, capabilities and skins look pretty cool!
Al
post #112 of 792 Old 05-12-2010, 05:47 PM
hydrogin's Avatar
Good Q. While I'm a big fan of XBMC, my strategy going forward is to serve media off a NAS or my home PC (which is almost always on in the evenings) to a DLNA client. I prefer not to have an HTPC located near my HT. The Synology NAS is nice because it has a sleep mode for the HD's. Plus it can automatically turn itself on/off on a daily schedule. So from a power utilization viewpoint, its greener than most. Besides media serving, all the other typical reasons for having a NAS apply as well (RAID backup, BT client, web server, etc).
That said, if I had to run XBMC on an HTPC, I would lean towards Linux. I would not want to wait for Windows booting every time the HTPC is turned on. The idea is for the HTPC to be more like an appliance than a PC. In that sense, I would almost rather mod a PS3 and use that as both a set-top and DLNA client. But I'm not sure if the rumors of a PS3 hack (modchip) are really true.
There are so many options in this space! One could also look at set-tops, with or without DLNA/UPnP support. But I think the key is to find a system where both ends are open. On the back end, servers like Serviio are open source while others like PlayOn and J River are proprietary. DLNA on the client side is problematic since Samsung, Panny, etc aren't going to be flexible to users demands. I don't know which set-tops are DLNA-compatible, but if you look for example at WDTV, which is built on a Linux platform, there is an open development community actively supporting it. You can bet Samsung won't be adding/fixing many features on the C5500 & C6500 BDP's come next year. But it just so happens I need a new BDP player
hydrogin is offline
post #113 of 792 Old 05-12-2010, 10:18 PM
enigma9o7's Avatar
Quoted: 66 Post(s)
I ran XBMC on my xbox too, and yeah that was awesome. Windows filesharing works much much better and faster than this DLNA crap. But I gave it up for similar reasons, although it'll play mkv and everything works fine, it isnt fast enough to play them watch-ably... I looked into options for a faster cpu for it, but pretty much non-existent before finally giving it up.
post #114 of 792 Old 05-13-2010, 09:08 AM
podious's Avatar
In PCSM, there is a setting that you have to locate your Blu-ray player and tell PCSM to Allow that device to share files with it.
podious is offline
post #115 of 792 Old 05-13-2010, 09:39 AM - Thread Starter
BritInVA's Avatar
Thats what he is having trouble with by sound of it.
BritInVA is offline
post #116 of 792 Old 05-13-2010, 10:25 AM
phatka's Avatar
That's correct BritInVa, the PCSM is not able to even recognize my Blu-Ray player , so I cannot authorize it. I downloaded the Serviio thing yesterday night, will try it out soon and let you all know the results.
phatka is offline
post #117 of 792 Old 05-13-2010, 11:14 AM - Thread Starter
BritInVA's Avatar
Anyone following on this got the Samsung HTC5500 (HTIB)?
I'm just looking for something to replace a basic DVD HTIB system in a family room (got a proper HT for serious viewing). Looking for reasonable surround sound, Blu-ray support and DLNA.
BritInVA is offline
post #118 of 792 Old 05-13-2010, 11:14 AM
Razzorback's Avatar
Hey..
I have a Samsung 40C650 lcd tv.
Can i watch x264 files from DLNA ?
By PCSM or any other way to do that?
Thanks...
Razzorback is offline
post #119 of 792 Old 05-13-2010, 11:20 AM - Thread Starter
BritInVA's Avatar
Originally Posted by Razzorback View Post
Hey..
Thanks...
Yes, but caveat must be in correct container & and supported audio.See your TV's video file support page for more info.
Serviio will also allow transcoding in 4.0 (should be out by end of week) if you find your files are not supported.
BritInVA is offline
post #120 of 792 Old 05-15-2010, 04:50 PM
podious's Avatar
My bad! Is your player and your PC on the same subnet? If you have multiple routers, then having your PC with an IP address of say 192.168.1.100 and you player with an IP of 192.168.2.100 would make it very difficult to share. I doubt it would be an issue, but you may check your firewall settings.
podious is offline
