Wdtv live plus hd - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 826 Old 07-23-2010, 11:43 AM
PoorSignal's Avatar
Quoted: 84 Post(s)
Originally Posted by penone View Post
. I'm curious to hear how that is going to turn out. Where do you plan on putting the box itself considering you need to use the remote to perform all functions and line of sight is required.
The box itself looks small enough to velcro under the glove box. With all the glass windows inside the cabin the IR reception should not be too hard.
Powered by 100W slim inverter, and a large capacity USB stick (I see they have something like 75GB now). Run the A/V cable to my nav screen aux input.
By no means a professional install, but should be sufficient.
PoorSignal is offline
post #272 of 826 Old 07-23-2010, 11:50 AM
hydrogin's Avatar
I've been borrowing a Live and will have my Live+ next week. Just be aware they run a little warm (they are passively cooled, big heat sink, plastic box). I only mention it because it can sometimes get hot inside a glove. I'm not aware of many people complaining about heat issues but there have been a few posts in the WD-sponsored forums. Sounds like an interesting project.
hydrogin is offline
post #273 of 826 Old 07-26-2010, 08:40 AM
penone's Avatar
Originally Posted by mjolson View Post
I think b-rad stated that he wouldn't be able to do movie sheets for the plus. If so, that's really unfortunate.
Yeah. I saw that too but am hoping he finds a way to do so. Also, am not sure he means that we wouldn't be able to use Thumbgen as an alternative for movie sheets. Since I am not a programmer - at times what is written is wayyy beyond my comprehension.
-P.
penone is offline
post #274 of 826 Old 07-26-2010, 09:23 AM
jcschlic's Avatar
Hello All,
I just bought the WDTV Live Plus HD on Friday and had some time over the weekend to mess around with it. I am coming from Apple TV usage so I have a large collection of mp4/m4v video files. The majority of these files were encoded with 5.1 audio. I noticed the WDTV Live Plus is only sending stereo audio to my receiver over HDMI. What happened? Why is Dolby Digital for these files not working on the WDTV Live Plus? Do I need to run an optical cable from the device to my receiver in order to get it?
jcschlic is offline
post #275 of 826 Old 07-26-2010, 08:05 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Originally Posted by jcschlic View Post
Hello All,
In setting choose digital and not stereo or digital, not hdmi( 3 options$
zoro is offline
post #276 of 826 Old 07-27-2010, 06:09 AM
jcschlic's Avatar
Yes I had already done this...no changes in audio. Perhaps it only sends multichannel audio over optical?
Either this is the case (and it would be really weird), or there is something wrong with my encodes.
jcschlic is offline
post #277 of 826 Old 07-27-2010, 06:16 AM
BrianD73's Avatar
Try using the digital audio port and see what happens. I believe I read in one of the specification footnotes somewhere that you could only do 2-channel through the HDMI.
BrianD73 is offline
post #278 of 826 Old 07-27-2010, 07:43 AM
slimoli's Avatar
Quoted: 647 Post(s)
Liked: 299
Hello All,
Unless something has changed with more recent firmware, I think only 2 ch is supported with mp4:
http://wdtvhd.com/index.php?showtopic=9624
I was so happy without HDR...
slimoli is offline
post #279 of 826 Old 07-27-2010, 10:54 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Not sure abt mp4, I am using hdmi for mkv and .ts files it plays perfect though.
Only thing I think my ps3 sounds better.
Btw I am using AV receiver in between.
zoro is offline
post #280 of 826 Old 07-28-2010, 11:19 AM
jcschlic's Avatar
That would explain it...I DID test out a Dolby Digital MKV file and it works just fine. This was done over HDMI.
jcschlic is offline
post #281 of 826 Old 07-28-2010, 11:22 AM
k2lounge's Avatar
i've read/searched through most of this thread (and the other wdtv live thread) and after all that, i'm still at a loss for a definitive answer:
will the wdtv live+ play mkv files at 20+Mbps bitrate (my avatar rip is 32.4Mbps) over my gigabit network from a shared win7 drive?
thanks!
k2lounge is offline
post #282 of 826 Old 07-29-2010, 08:07 AM
k2lounge's Avatar
thanks!
anyone?
k2lounge is offline
post #283 of 826 Old 07-29-2010, 08:20 AM
mbryanr's Avatar
k2...many have attempted to run high bitrate files on the wdtv live (identical to the "+" in regards to the processing power) with varying results. Some use NFS shares and report success.
Gigabit network means nothing to the "+" as it is 10/100.
Here is the response I received from Synology after their testing.
http://www.avsforum.com/avs-vb/showp...4&postcount=43
Note: I have also tried NFS shares (via cifs-interceptor and x-mount) in an attempt to play BD rips (MKV and m2ts files). Typically these files will play ok until it hits the WDTV ceiling.
The bitrate you mention is an average...so you may or may not have decent playback.
I agree with blackssr's assessment:
http://www.avsforum.com/avs-vb/showp...79&postcount=7
mbryanr is offline
post #284 of 826 Old 07-29-2010, 12:54 PM
hydrogin's Avatar
Good info, a friend has the 210j and I may get one myself.
Does Synology's observed 50Mbps ceiling on the CBR test files imply WDTV's implementation of their networking stack (e.g. TCP/IP or whatever was needed to support Synolgy's test) is underpowered? In an ideal situation where the WDTV has plenty of networking resources, would you have expected a higher stutter ceiling on the 10/100 port?
hydrogin is offline
post #285 of 826 Old 07-29-2010, 02:19 PM
mbryanr's Avatar
Yes. Particularly since the same files can play from a USB attached drive. I've read many forum posts where NFS has helped playback. Also, one user modified the readsize to improve playback (although the follow up indicated not complete success).
http://wdtvforum.com/main/index.php?...34045#msg34045
Using SMB...max of 80Mbps
mbryanr is offline
post #286 of 826 Old 07-29-2010, 02:50 PM
hydrogin's Avatar
Thanks, I'll keep that in my back pocket should I ever switch from the WD firmware.
Was Synology's test run using CIFS/SMB (e.g. Windows shares)?
I've never setup a DLNA server and use windows shares at home. I think of both DLNA/uPNP and CIFS/SMB as added functionality (overhead) on top of TCP. Any thoughts on which of the two would provide better LAN performance streaming to a WDTV (assuming things like on-the-fly transcoding weren't happening)? Those are the two options I think I'd have if I get a Synology NAS.
I'd be curious if performance differences in uPNP vs SMB are due to the network protocol themselves or just WDTV's implementation.
hydrogin is offline
post #287 of 826 Old 07-29-2010, 03:37 PM
David James's Avatar
Quoted: 41 Post(s)
Liked: 80
I'm looking for a replacement for Hauppauge MediaMVP's and SageTV.
I picked up the WDTV Live+ yesterday and have been exercising it. My technology needs are simple, play FLAC and MP3's, view JPG pictures and watch home video's recorded in MPG format.
I've got FLAC's playing both using shares and Tiversity but I can't get pictures to display at all. I can see the thumbnails but when I select a picture, the little circle thingy just spins and spins. I figure it's got to be something dumb on my end, but so far no luck. This issue occurs both using Tiversity and shares.
Any ideas?
David James is offline
post #288 of 826 Old 07-29-2010, 04:58 PM
mbryanr's Avatar
DLNA
3 options with the Syno in order of performance-
NFS (WDTV requires b-rad firmware to use NFS)
DLNA
CIFS/SMB
DLNA software such as tversity (w/transcoding) improves WDTV performance significantly. Tversity cannot be loaded onto the Syno.
I'd guess both. Tonight I started to use the .35 beta firmware. I have noticed an improvement with the latest beta firmware, enough that my higher bitrate movies playback well. l'll try the constant bitrate files later.
mbryanr is offline
post #289 of 826 Old 07-29-2010, 05:07 PM
Daveyd's Avatar
I just ordered one of these today for my bedroom. My movie library consists of 100% DVD isos an Blu Ray isos with just the movie and HD audio ripped using DVD FAB stored on a WHS server. I am assuming I should be good to go with this device?
Also, if there a b-rad firmware coming out for the Live Plus? Is there a thread to follow?
Daveyd is offline
post #290 of 826 Old 07-29-2010, 06:19 PM
hydrogin's Avatar
I'll probably go with the NAS as its a greener solution.
You mentioned you were streaming .ts and .m2ts containers to the WDTV. I recall someone saying for playback on a WDTV, its more efficient to use .m2ts than .mkv even though both can use similar codecs for encoding the video (something about the WDTV's Sigma chip being able to natively handle m2ts but not mkv).
Any comments about this tradeoff? I'm trying to determine the optimal way to rip my library given I'd like to stream to my WDTV (haven't purchased any ripping/encoding hardware or software yet).
hydrogin is offline
post #291 of 826 Old 07-29-2010, 06:45 PM
mbryanr's Avatar
That reference was here-
http://www.networkedmediatank.com/wi...roubleshooting
As noted in the nmtwiki, mprovements have been made so the difference is unknown now. I found no improvement in the WDTV Live.
mbryanr is offline
post #292 of 826 Old 07-31-2010, 11:51 PM
Quoted: 41 Post(s)
Liked: 80
I've boxed up my WDTV Live+ and will return it tomorrow. I never could get pictures to display. The other issue was searching for music will be to cumbersome for my wife.
The search continues.
post #293 of 826 Old 08-07-2010, 02:38 PM
lrch's Avatar
Could anyone shine some light on what the rationale could be behind the 10/100 LAN chipset on this version of the WDTV? Is gigabit simply not needed?
lrch is offline
post #294 of 826 Old 08-09-2010, 07:25 AM
mike_311's Avatar
well network just showed up on my wdtv, not really sure why or what changed, but it works now.
anyhow, i can seem to keep my win7 box awake while videos are streaming. this goes for network share and media streaming.
i have set all the power setting i could find and the pc should never sleep, yet it does.
"If the world didn't suck, we'd all fly off."
mike_311 is offline
post #295 of 826 Old 08-09-2010, 10:33 AM
wocasio's Avatar
Quoted: 16 Post(s)
Has anyone tested whether the Live Plus display PGS subtitles in m2ts files from Blu Ray rips?
wocasio is offline
post #296 of 826 Old 08-09-2010, 08:13 PM
hydrogin's Avatar
Yes, I can confirm.
BD's ripped with DVDfab to m2ts, existance of PGS subs confirmed with Mediainfo, WDTV Live+ played m2ts and displayed subs fine.
With PGS subs in mkv containers, that's a different story. I'm working on trying to get the forced subs in Avatar to be visible. Will know more tomorrow.
hydrogin is offline
post #297 of 826 Old 08-09-2010, 08:24 PM
hydrogin's Avatar
Yes.
This has been discussed quite a bit, don't recall if its this thread or the other big WDTV thread. Bottom line is 10/100 is good enough for full BD rips and is not the determining factor. Others have reported the bottleneck is either inside the WDTV's LAN interface (e.g. TCP/IP or higher level stack) or media processor - so a 10/100/1000 wouldn't necessarily help.
I recall someone saying ~50 Mbps (CBR) is about all the WDTV can handle. I believe this was based on some tests run by Synology. And streaming performance is better for uPNP than for CIFS/SMB (best results with NFS). I've also read the early media processors handled m2ts directly in hardware but not mkv, so that was a streaming performance factor as well. Not sure if that's the case anymore.
hydrogin is offline
post #298 of 826 Old 08-09-2010, 09:06 PM
foxnews's Avatar
Yes.
I can confirm that copying files to wdtv plus is a bottleneck. I hook up two HHDs directly to WDTV USB ports so that I can have search capability and fast navigation. moreover, storing movies on PC requires keeping pc on all the time. then I connect WDTV to my router. whenver I need to add a movie, I just copy from my pc to WDTV. the speed is very slow 7MBps. I tried to connect wdtv to router by using wifi N usb dongle and speed is the same. I am not sure what is the bottleneck here: USB, 10/100 network, or wdtv itself.
WD should add gigabit ethernet. if you copy a big movies over network, gigabit ethernet is definitely needed. 10/100 ethernet is just enough for streaming movies stored on PC/NAS.
foxnews is offline
post #299 of 826 Old 08-09-2010, 09:27 PM
saiga6360's Avatar
Even if the WDTV has gigabit, it is still bottlenecked by USB. I imagine copying files over is excruciating and not worth the effort. Maybe if it had eSATA, like the ViewSonic.
saiga6360 is offline
post #300 of 826 Old 08-09-2010, 10:21 PM
hydrogin's Avatar
I had assumed the OP was referring to streaming from a PC or NAS, but I understand your point about copying files.
I plan on checking out a Synology NAS. They're low power, can auto-shut themselves on/off (I believe) and support CIFS/SMB and uPNP/DLNA. If I run two 2TB drives in a RAID-1 mirror, that will make for a nice backup as well. Need more storage!
hydrogin is offline
