New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 265 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #7921 of 11643 Old 04-07-2012, 08:45 PM
RaggedEdge's Avatar
Originally Posted by DiabloZoe View Post
Ok this I gotta know how you did is it a feature of yaDIS? I use MM and really want to have an icon on the home screen, I do have one for favorites!
With the newest firmwares you cannot put a favorite on your home screen.
Alex
RaggedEdge is offline
post #7922 of 11643 Old 04-07-2012, 10:12 PM
Litlgi74's Avatar
I am using FW 120202_1544_beta... and I am able to add Favorites to my home screen.
Home Screen Before
Select file to add to Favorites
Home Screen After
The world ends when you're dead. Until then, you got more punishment in store. Stand it like a man -- and give some back.
~ Swearengen
Litlgi74 is offline
post #7923 of 11643 Old 04-07-2012, 10:34 PM
DiabloZoe's Avatar
Quoted: 14 Post(s)
Home Screen Before
Home Screen After
Looking at your home screen you have you bluray on LAN?
DiabloZoe is offline
post #7924 of 11643 Old 04-07-2012, 11:18 PM
Litlgi74's Avatar
I do... "BluRay Drive" is the drive on my WHS Server... but its shared just for testing purposes.
The first "BluRay" (with the star) is a temporary "favorite" I just made to show how it was done.
~ Swearengen
Litlgi74 is offline
post #7925 of 11643 Old 04-08-2012, 12:10 PM
diamond design's Avatar
Kutkgu74m
In testing, how has the blu ray over lan performed? Is it usable (for either dvd or blu ray)?
diamond design is offline
post #7926 of 11643 Old 04-08-2012, 09:12 PM
Litlgi74's Avatar
Originally Posted by diamond design View Post
Kutkgu74m
It doesn't work very well! I just tried Toy Story 3 on the Bluray Drive over LAN. It wouldn't even load the menu... It does work with DVDs but the menus don't work very well.
~ Swearengen
Litlgi74 is offline
post #7927 of 11643 Old 04-09-2012, 06:14 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Only option I have tried is using MakeMKV with a Blu-ray drive. It will stream via DLNA to any DLNA player. However, all it does is give you folder access, so you have to drill down to the m2ts file for playback
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #7928 of 11643 Old 04-09-2012, 10:31 AM
tightrope's Avatar
When I add my Yadis folder to my Favorites, the icon appears on the Favorites page, not the Home page. I wonder what I'm doing wrong
tightrope is offline
post #7929 of 11643 Old 04-09-2012, 10:37 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I think it just depends on what home screen you are running. I forget the exact wording, but there are two home screens options you can choose
Cheers,
Damian
post #7930 of 11643 Old 04-09-2012, 10:45 AM
tightrope's Avatar
That might be it. Right now my Home screen is the Sources page. Let me dig into the options.
post #7931 of 11643 Old 04-09-2012, 11:35 AM
Litlgi74's Avatar
Goto Setup>Appearance and change the Main screen style: to "Plain"
This will put your favorites on your home screen... then you should be able to get your harmony to work!
~ Swearengen
Litlgi74 is offline
post #7932 of 11643 Old 04-09-2012, 11:50 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
I got my Harmony 600 to work by setting more button commands. So, when the Dune turns one, I have it making 4 commands. Right, right, down and enter, and it goes to my Zappiti screen
I follow this directions from the MPC forum.
http://www.mpcclub.com/forum/showthread.php?t=28643
GusGus748s is offline
post #7933 of 11643 Old 04-09-2012, 11:54 AM
tightrope's Avatar
That was it, thanks!
I can now see my Yadis folder in the home page, but it's several rows down. Is there a way to move it up the list so that it's the first item?
post #7934 of 11643 Old 04-09-2012, 12:32 PM
Litlgi74's Avatar
Glad it worked for you!
I am not sure I can tell you how to get your yaDIS icon to the first position. My yaDIS is stored on a USB flash drive attached to the Dune.
And because I have only the the yaDIS file structure on the drive... the yaDIS icon is displayed
All the other icons on my home page are network shares... not favorites.
~ Swearengen
Litlgi74 is offline
post #7935 of 11643 Old 04-09-2012, 12:33 PM
Litlgi74's Avatar
Glad my info helped you... who wants to look at the Dune home page anyway?
~ Swearengen
Litlgi74 is offline
post #7936 of 11643 Old 04-09-2012, 12:49 PM
tightrope's Avatar
My Yadis folder is the only item on a SDHC card, and there are no other favorites on my Dune. I removed it from the favorites and re-added it after restarting my D1, hoping that it would appear as the first item as in your layout, but it went back to the same (lower down the list) position
I noticed that you don't have Setup listed on your Home screen, is there an option to determine whether an item appears on the Home screen or not?
Thanks for your help
post #7937 of 11643 Old 04-09-2012, 01:03 PM
Litlgi74's Avatar
I think I figured it out... make sure you have "Network folders at the end" set to Yes... it is the last item on this screen:
You can disable the "Setup" icon ... on this screen as well... its the second item from the bottom...
If you can't get yaDIS to be the first icon... you can just add direction inputs prior to pressing "Enter" in the power on action via Harmony software.
~ Swearengen
Litlgi74 is offline
post #7938 of 11643 Old 04-09-2012, 01:40 PM
tightrope's Avatar
That did the trick, thanks again, Litlgi!
I realised that I also had to disable the Home display of each application individually (Torrents, Web Broser, etc.), and I now have a much cleaner Home screen, with my Yadis folder as the first item
post #7939 of 11643 Old 04-09-2012, 02:23 PM
Litlgi74's Avatar
Were you able to get your harmony remote to automatically start yaDIS?
~ Swearengen
Litlgi74 is offline
post #7940 of 11643 Old 04-09-2012, 02:25 PM
willscam's Avatar
Thanks from me too litlgi74. I never could figure out how to put favorites on my homescreen. This will help alot with my Harmony settings. Right now I have too many steps to get to mymovies and it's kind of hit or miss. Can't wait to go home and try this out.
"Trying is the first step towards failure" - Homer Simpson
willscam is offline
post #7941 of 11643 Old 04-09-2012, 02:29 PM
tightrope's Avatar
Actually I already had my Harmony programmed to go to my Yadis page, but I will be able to hugely simplify the process by eliminating all the additional navigation commands I needed to get there. Now all I need is an "Enter"
post #7942 of 11643 Old 04-09-2012, 03:25 PM
rodspr's Avatar
I've had a Dune 3.0 in the main room for a while and use it hooked up for multichannel. Recently added a Dune H1 for the bedroom to watch movies late at night.
The issue I am having is I like to listen thru headphones, so the Dune is connected via HDMI to my TV and I'm using the RCA outs from the TV to the headphone amp. This had worked for an Xtreamer I have, but I got the Dune so I could have the ease of full BR menus. Using the Dune I am getting audio dropouts connected like this. I have tried using both decoded and bitstream settings along with stereo and 48khz.
Any ideas as to how to make this work? Would getting a cheap receiver that does HD Audio and using the headhone jack be the best solution?
rodspr is offline
post #7943 of 11643 Old 04-09-2012, 08:26 PM
Opentoe's Avatar
Quoted: 87 Post(s)
Originally Posted by jconjason View Post
So you dont buy gas then either?
Buying gas isn't a luxury. It is a need. Not even in the same boat.
Opentoe is offline
post #7944 of 11643 Old 04-10-2012, 09:30 AM
Solfan's Avatar
Quoted: 14 Post(s)
Liked: 32
Solfan is offline
post #7945 of 11643 Old 04-10-2012, 04:10 PM
FTracy3's Avatar
Can someone clarify the difference between the D1 and H1? Looking at the specs I don't see any other than a possible difference between internal hard drive connections.
FTracy3 is offline
post #7946 of 11643 Old 04-10-2012, 04:19 PM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
Well the D1 has a display on the front where messages and such appear.
The H1 doesn't have the display instead it has a hot swap slot where you can insert (and remove) a hard drive.
Regards, Frederick C. Wilt
fcwilt is offline
post #7947 of 11643 Old 04-10-2012, 04:56 PM
rdgrimes's Avatar
Quoted: 2071 Post(s)
Liked: 1394
Both have internal HDD bays, the only functional difference is the D1's front display and the method for accessing that internal HDD bay.
rdgrimes is offline
post #7948 of 11643 Old 04-10-2012, 05:29 PM
pgodden's Avatar
I just received a Dune HD today, I am about to hook it up, what should I be looking for? In regards to firmware updates etc? I am using my Onkyo to do the decoding and ,will be using the HDMI to hook to it. It is a Smart H1, the packaging looks a bit worn although the contents appear to be new
pgodden is offline
post #7949 of 11643 Old 04-10-2012, 05:30 PM
pgodden's Avatar
Btw it is a H1, the box looks a little beat up.
pgodden is offline
post #7950 of 11643 Old 04-11-2012, 02:22 AM
Mr Eric's Avatar
Quoted: 295 Post(s)
Liked: 141
for a start : setup a system storage (you will need a 2gb USB thumb for this) and update to latest beta firmaware (120202).
It should be enough, then you can test the jukeboxes
Mr Eric is offline
Dune Hd Smart B1 1080p Media Player
