New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 365 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
Old 08-08-2014, 01:20 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Originally Posted by mecmec View Post
i am not sure i have EVER had an audio drop out with my dune...network issue?...
Hmmmm.... possibly.
I've always had a bit of an issue with the star wars 1-3 movies, but I always chalked that up to the burn. (I rip straight to .ISO, 1:1). I watched episode 3 the other night and it seemed to have more than normal.
Then I watched Crimson Tide and had a couple drop outs. The only thing I've changed is going from a smart to a duo, and dropping both down to firmware b-6.
I'll have to experiment more. I was hoping to avoid that.
pdxrealtor is offline
Old 08-08-2014, 01:50 PM
thetoad's Avatar
only time I've ever had issues with audio or stuttering is when my file server's HD is occupied with other tasks and can't keep up / small read buffer of the dune (if it had a larger buffer, it wouldn't make a difference).
thetoad is offline
Old 08-08-2014, 02:27 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Those discs had compatibility issues with some receivers (Denon and Pioneer). The DTS-HDMA tracks had lots of audio stutters, regardless of what player was used. Newer receivers fixed this issue.
Could this be the problem?
ScottJ is offline
Old 08-08-2014, 02:39 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
It could be, yes. My receiver is a Pioneer, but it is a newer higher end model. Last year to be more specific.
Old 08-09-2014, 12:54 AM
mrlittlejeans's Avatar
Quoted: 146 Post(s)
Liked: 246
Is it still necessary to have a drive locally on the Dune? I set up Zappiti tonight and mapped the network drive it resides on to my Dune and it seems to be working fine.
I had a few Dunes for a few years but haven't had one hooked up in over a year and it has been a few years since I set one up. I'm basically starting from scratch with new units (five of them) and can't remember why exactly I had USB sticks in my old ones.
Absence of evidence is not evidence of absence
mrlittlejeans is offline
Old 08-09-2014, 06:39 AM
rdgrimes's Avatar
Quoted: 1992 Post(s)
Liked: 1320
A small USB or SD drive is useful for system storage, which might be required by some BD discs and other software.
rdgrimes is offline
Old 08-21-2014, 02:21 PM
mickey79's Avatar
Quoted: 14 Post(s)
Is it possible to reset the last watched / resume status for all movies on dune smart d1? I hadn't used Dune for a while & I'm using it again. Everytime I start a movie, it resumes from where I last left it. I'd like them all to start from the beginning; is it possible to make dune forget where I last stopped them all?
7.1: Polk RTi12 Fronts, RTi8 Surrounds, Monitor70 Surround Backs, CSi A6 Center + Outlaw LFM-1 EX Subwoofer.
Yamaha RX-A2000 AVR
Epson 5010 3D Projector
Intel Sandy Bridge 3D HTPC / Blu-ray Player
mickey79 is offline
Old 08-21-2014, 02:30 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
dune_service_format_system_storage.dsf
Edit: maybe not...unclear if system storage holds the resume data or not.
Try powering down (not just standby), remove system storage, see if player is still resuming. If so, I think you're SOL...if not, reinitialize the system storage and it will clear all that data.
ScottJ is offline
Old 08-21-2014, 02:48 PM
jconjason's Avatar
Quoted: 517 Post(s)
Liked: 807
Its not a system storage issue. There is a setting to disable auto resume. Im not with my D1 so cant tell you exactly where, but i know its there somewhere.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Klipsch B-20 Rears,PA 120 12" Sub,klipsch R-10SW
jconjason is offline
Old 08-21-2014, 08:01 PM
mickey79's Avatar
Quoted: 14 Post(s)
You were correct! It's under Setup / Playback / Bookmarks. You can turn autoresume on our off.
Thanks man!
Yamaha RX-A2000 AVR
mickey79 is offline
Old 08-21-2014, 08:04 PM
jconjason's Avatar
Quoted: 517 Post(s)
Liked: 807
Thanks man!
You are most welcome.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch F-30 Fronts
Klipsch C-20 Center
Klipsch S-20 Sides
Old 08-21-2014, 08:24 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
There's also a shortcut to go to start of video IIRC. Pressing 0 I think.
GetGray is offline
Old 08-24-2014, 09:20 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
All of a sudden I am having an issue where the Dune player will not load a BDMV folder. It is a demo disc I downloaded from this web site, and it has always worked in the past. I tried a reset of all the settings, but no luck.
I thought it was an HDMI issue so I've also tried a different cable, but that's not the problem. Plus on top of that all of my .ISOs still load just fine. I am absolutely positive I've loaded this BDMV demo disc since swapping from my B1 unit to the DUO.
Also to note is that the demo disc did load after a re-set of the settings, once. Then it quit loading.
My projector spits out a no signal message
Switching sources, say to cable TV, then back to the Dune will fix the issue.
Anyone have any idea what the heck is going on? I'm stumped.
Old 08-24-2014, 09:26 PM
rdgrimes's Avatar
Liked: 1320
Erase the BD storage, then reboot (hard boot) the player.
rdgrimes is offline
Old 08-25-2014, 03:17 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Thanks. Is a hard boot just flipping the switch on the back of the unit?
Old 08-25-2014, 03:23 PM
rdgrimes's Avatar
Liked: 1320
That would be it. I've noticed that sometimes the player seems to get stuck on a bit of bogus JAVA. Clearing the persistent memory and a reboot sometimes helps. Sometimes it requires drawing the chalk pentagram on the floor and performing a sacrifice.
rdgrimes is offline
Old 08-25-2014, 03:30 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
HAHA....
Thx... I'll give it shot. Hopefully I won't have to put chalk lines on my floor!
Old 08-26-2014, 11:04 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Well if I did it right it did not work. I reset the bluray cache, system storage, and flash storage. Same thing..... Once the disc menu is loaded I get no signal, but only on this one disc and it's also the only folder structure disc I have.
With no signal, I can still hit play and the audio will come in as the disc plays but it skips in and out and the video remains non existent.
I guess the next thing to do is drag the smart series down here and see what happens....... PITA to remove it, install it, the do the same to get it back in its spot. *sigh*
Old 08-27-2014, 08:43 AM
Hyrax's Avatar
Quoted: 88 Post(s)
Liked: 45
pdx-
Try playing the m2ts file that is located in the Stream Folder. This is easiest done if by copying (and renaming) the m2ts file to the folder containing the folder structure. Another thing you might want to do is to use MKVMerge to create a MKV file from the m2ts file. You need to be on your computer to do this stuff, so, while you're at it, try using VCL to play the m2ts file. This may give you an idea why it isn't playing. The only times I've had something not play is when I did something wrong authoring the disk. Sometimes I just needed to re-author using the same m2ts file, other times I need to go back and encode my source files again.
Hyrax is offline
Old 08-27-2014, 12:43 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Originally Posted by Hyrax View Post
pdx-
Thanks, but I've never had a problem with this disc in the past, and I've used it a lot! The player is fairly new and it's a refurb unit. I want to make sure it's not the player. I don't think, it is but.......anyways.
I just opened the stream folder as you suggested and played a couple m2ts files both on windows media player and VCL player. The windows media player does not have audio but the VCL player does.
The disc is laid out nicely and I really did enjoy the menu loading up as it gives an option to play only certain files. Unfortunately once you make your selection from the main menu you cannot pull up a popup menu to choose 'chapters'. You're stuck just skipping forward until you find the scene you want.
Is it possible to mount a folder structure using clone drive and test it in TMT? I really only burn 1:1 .ISO so I'm real lost when it comes to folder structure.
Old 08-28-2014, 10:37 AM
Stevetd's Avatar
Quoted: 110 Post(s)
Liked: 31
Dune HD users can now buy a Zappiti premium license for full functionality and latest software version. Woohoo!
Stevetd is online now
Old 08-28-2014, 11:26 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Does not apply to the Dune Smarts, only the Dune 3Ds.
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 08-28-2014, 11:39 AM
Stevetd's Avatar
Quoted: 110 Post(s)
Liked: 31
Son of a.....
I just saw that.
Old 08-30-2014, 06:52 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Can I get some help, with getting the iPad app working. Says I need to enable cloud support; but I'm not sure exactly what to do in settings.
CDLehner is offline
Old 08-30-2014, 07:27 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
On the computer you have to have an account and then under settings go in and check the box 'enable automatic backup in the cloud' . On the iPad you go into settings, choose your Dune player under the 'Zappiti Player' tab and then proceed to the 'iOS' tab and enter/sign in your account info.
That should do it.....
Old 08-30-2014, 07:41 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Yeah...that's what I thought to start. But for some reason, I can't check 'enable automatic backup to the cloud'.
CDLehner is offline
Old 08-31-2014, 05:08 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
I also seem to vaguely remember not being able to check that box, but I don't remember what I did to finally be able to check it. You might want to check in with the Zappiti forums to get some clarification.
Old 08-31-2014, 05:09 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
What other functionality is there? Not that it matters since we obviously can't get it, but I'm curious.
Old 08-31-2014, 05:14 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
So it seems I'm having the no signal issue (see a few posts above for more info) sporadically. It will happen sometimes if I stop a movie midway, or even from just the movies menu screen. Other times it sends the signal just fine. If I do end up with no signal all I have to do is change sources on my AVR so for example I'll change it to cable tv, then back to the Dune. That always fixes the problem. But I NEVER had this problem with the Dune Smart.
Could this be a problem with the DUO's HDMI board or ???
Old 09-01-2014, 06:30 PM
CDLehner's Avatar
Quoted: 767 Post(s)
Liked: 1146
Man, answers come slowly over there! Anyone got iOS remote...working with their Smart series; that could get me through it?
CDLehner is offline
Dune Hd Smart B1 1080p Media Player
