New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 367 - AVS Forum
Old 10-23-2014, 04:11 PM
darinf's Avatar
On the Dune HD Max, does anyone know if there's a way to default the sorting of the file list on the hard drive to sort by modified instead of by name?
I know I can change the Sort Settings, but every time I go up a directory and back, the sort settings change back to By Name.
I would like to have the Dune always sort by modified date.
Thanks in advance.
darinf is offline
Old 10-23-2014, 04:32 PM
ScottJ's Avatar
Quoted: 106 Post(s)
Liked: 68
Thanks in advance.
Create a file (using a PC) named dune_folder.txt in that directory with the following line:
sort_field = mtime
You might also need to specify the sort order:
sort_dir = asc (or desc)
More on dune_folder.txt from Dune's official doc.
ScottJ is offline
Old 10-23-2014, 05:04 PM
darinf's Avatar
sort_field = mtime
Wow, thanks Scott for the quick response. I should have asked a long time ago.
Worked perfectly.
darinf is offline
Old 10-30-2014, 07:10 AM
hifiaudio2's Avatar
Quoted: 144 Post(s)
Liked: 74
I am interested in the new Zappiti but it doesn't work on my current Dune Smart D1. I am considering buying an HD Base 3d.
What functionality from the Smart D1 do I give up to go to the Base 3D? There was a reason back when I bought it, but now I cant remember .
Perhaps it was menu functionality which I thought I needed at the time, but now all of my rips are movie only MKVs. Anything else that the Base 3d is missing?
hifiaudio2 is offline
Old 10-30-2014, 07:31 AM
dbone1026's Avatar
Quoted: 29 Post(s)
Liked: 71
Since you are using mkvs not much. IIRC the one thing you may miss is if you have any mkvs with TrueHD and are trying to downmix it may not work. Also, forced subtitle support for mkvs (ScottJ has a pathc but don't think it works for the latest fw updates)
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 10-30-2014, 07:34 AM
hifiaudio2's Avatar
Quoted: 144 Post(s)
Liked: 74
Ah OK.. so forced subtitle support is better (or much better?) on the Smart than on the Base 3D? That would probably be a deal breaker for the Base 3d.
Old 10-30-2014, 07:36 AM
dbone1026's Avatar
Quoted: 29 Post(s)
Liked: 71
Yes and no. Yes if you are doing Blu Ray rips (folder/ISO) which the Smarts support but the Base 3D does not. For mkvs the issue applies to both the Smarts and the Base 3D, neither natively support forced subs in mkvs, you need to use ScottJs patch. I think though that once you go past a certain FW update the patch doesn't work (regardless of Smart or Base3D). Maybe ScottJ can confirm up to what version fw his patch supports?
Cheers,
Damian
Old 10-30-2014, 07:44 AM
hifiaudio2's Avatar
Quoted: 144 Post(s)
Liked: 74
Hmm Ok.. Maybe I put the patch on a long time ago... but I have upgraded firmware a few times as well. My forced subs still work. Although all I rip are the forced subs so maybe I just set it to display all the subs at some point. Lol its been too long since I set it up!
Old 10-30-2014, 08:23 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 35 Post(s)
Liked: 53
Surprised you got a Dune. I thought you were a "iso via Oppo with old firmware only" guy.
GetGray is offline
Old 10-30-2014, 08:25 AM
GetGray's Avatar
Quoted: 35 Post(s)
Liked: 53
sort_field = mtime
I use My Movies to create my meta data. What I'd like is a way to have a particular category sort by time instead of name, but other categories sort by name. Not sure how to get that to work (automatically). You?
GetGray is offline
Old 10-30-2014, 08:50 AM
hifiaudio2's Avatar
Quoted: 144 Post(s)
Liked: 74
Lol I still have that for backup! But I moved to MKVs and the Dune a while back as I decided I really wanted a coverflow style interface. Really like not messing with the menus as well.
Old 10-30-2014, 12:21 PM
ScottJ's Avatar
Quoted: 106 Post(s)
Liked: 68
If you could get MM to generate the right thing in that one dune_folder.txt (and you can't) it still wouldn't work because when MM regenerates the entire index (which I find necessary every few months) he recreates them in alpha order, so even sorting by mtime wouldn't work anymore.
I have a rather complex process I scripted years back to take the MM-generated index and convert it into something I prefer. That includes sorting the "Last Added" by date instead of alpha, and sorting "The Blind Side" under B instead of under T. But it's not something that's portable to other people's systems.
ScottJ is offline
Old 10-30-2014, 12:23 PM
ScottJ's Avatar
Quoted: 106 Post(s)
Liked: 68
I know that it's broken on 131224_0132_b8 or newer.
Some day I might try to fix it, but no promises
dbone1026 likes this.
ScottJ is offline
Old 11-02-2014, 07:11 AM
stefuel's Avatar
I have 2 D1's everything is working fine but on my more expensive flat screen I notice that ripped BD playback looks grainy compaired to playing from a BD player. Is there a adjustment I'm missing somewhere to smooth out the image some? Thanks,
Chip
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
Old 11-02-2014, 08:22 AM
ScottJ's Avatar
Quoted: 106 Post(s)
Liked: 68
Chip
Not in the Dune. It's likely due to a setting on the tv. Look for "sharpness" or "digital enhance" or something like that, and turn it off or all the way down.
It seems the more expensive the tv, the more of these dubious "features" they include.
ScottJ is offline
Old 11-02-2014, 02:04 PM
bosoxfan's Avatar
Quick question, i have 3 usb drives connected to my dune smart d1. Is there a way to access those drives using a wdtv in a seperate room over wifi? Thanks!
bosoxfan is offline
Old 11-02-2014, 02:33 PM
ScottJ's Avatar
Quoted: 106 Post(s)
Liked: 68
Yes, they are available over SMB. I believe the Dune manual calls this feature "NAS Function".
ScottJ is offline
Old 11-02-2014, 02:44 PM
bosoxfan's Avatar
Sweet, thank you!
bosoxfan is offline
Old 11-02-2014, 04:12 PM
rdgrimes's Avatar
Quoted: 348 Post(s)
Liked: 250
As mentioned, yes. Any volume connected to the Dune will be served up to the network. Likewise you can manage those files from a networked PC.
rdgrimes is online now
Old 11-16-2014, 04:31 PM
sukumar's Avatar
clips mixture of dth hd and dolby hd
I have lot of m2ts clips and most of them are dts hd. However some are dolby hd. When it tries to play dolby hd, I don't hear any audio, but when next one with dts hd comes, I can hear voice. When I stop and play again, I can hear sound.
I am wondering if there is any trick to be able to hear audio when I have mixture of m2ts clips in a folder that use dts hd and dolby hd. Appreciate your help
sukumar is offline
Old 11-22-2014, 01:41 PM
DiabloZoe's Avatar
So what's the deal with dune? No new player for a while? Is the future of dune done? Is there a player out there that compares?
DiabloZoe is offline
Old 11-22-2014, 06:48 PM
hifiaudio2's Avatar
Quoted: 144 Post(s)
Liked: 74
Not sure what Dune is doing but Zappiti, who used to have players based on Dune, is coming out with a new unit that can upscale to 4k and has a more powerful interface than they have had before, including XBMC support. Its based on the Realtek RTD1195.
Old Yesterday, 07:55 AM
dbone1026's Avatar
Quoted: 29 Post(s)
Liked: 71
My understanding is that Zappiti had a bit of a falling out with Dune which may in part be the reason why the move to Realtek. Would definitely be interested to hear though what, if anything, is in store from Dune as I have seen very little in the way of new Sigma chips.
Cheers,
Damian
Dune Hd Smart B1 1080p Media Player
Gear in this thread - 1080p by PriceGrabber.com
