New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 377 - AVS | Home Theater Discussions And Reviews
post #11281 of 11296 Old 04-12-2015, 06:22 PM
ChldsPlay's Avatar
Quoted: 178 Post(s)
Liked: 39
Originally Posted by fcwilt View Post
Does Z support an fairly common (at least in other programs) "shorthand" like "s01e01e02"?
I have no idea. It would have made things a little easier.
The Hodor Theater - In Progress
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT
Surround/Back Speakers - Klipsch Pro Cinema KPT-8000M
Subwoofers - Dual Passive JTR Captivator Pros
Receiver - Onkyo TX-SR608
ChldsPlay is offline
post #11282 of 11296 Old 04-13-2015, 02:14 AM
Mr Eric's Avatar
Quoted: 60 Post(s)
Liked: 47
it should support something like S01E01-05 to scrape ep 1/2/3/4/5.
but the best thing for TV shows is always to rip as individual episodes...
Mr Eric is offline
post #11283 of 11296 Old 04-14-2015, 07:52 AM
dbone1026's Avatar
Quoted: 121 Post(s)
Liked: 89
Originally Posted by ChldsPlay View Post
I only have one more thing I think I would like to be able to do, and I'm not sure it is capable. Is it possible to make Zappiti ignore the word "The" at the beginning of a title when sorting alphabetically?
This really annoys me. Somewhere in there "The" is noted to ignore, but Zappiti doesn't actually ignore. I end up having to go in after the movie is scraped and either remove "The" or move it to the end. For instance, "The Ring" I would edit after scraping to either show "Ring" or more commonly I do "Ring, The"
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #11284 of 11296 Old 04-14-2015, 10:09 AM
ChldsPlay's Avatar
Quoted: 178 Post(s)
Liked: 39
Yeah, I was going to do that, but I was hoping for the title to appear correctly on the synopsis screen. That's a little disappointing.
post #11285 of 11296 Old 04-17-2015, 10:48 PM
CD_in_NM's Avatar
Ethernet problem with Smart B1
Originally Posted by dbrons View Post
Do you have a disc in the bd drive? Will the tray open if you press the button? My B1 went bad a year or two ago - I got it repaired/replaced. As I recall it was the bd drive that was malfunctioning but it causing the unit to not network correctly.
Dave
Finally got a chance to get back to the B1 problem. There was no disc in the drive. Did not try a BR disc but the unit played a DVD so I guess the drive is working correctly. Still no Ethernet connection. Tried switching between static and DHCP again, still no luck. For grins tried changing the IP address in the router's reservation table then changed the B1 to static with the new address. As expected, no change. Thought maybe the flash card was bad, so I pulled it out. Still no change. When I cycle the power and go into the network page, it says disconnected. I go into manual setup but change nothing, just so it will display the APPLY button. When I hit apply it changes to connected but still will not pull data from the NAS or respond to pings.
CD_in_NM is online now
post #11286 of 11296 Old 04-18-2015, 06:23 AM
Liked: 0
Fantastic thread. I am deciding whether or not to purchase a D1. My main concern is that all my movies are archived on 6 3TB drives all formatted Mac OS Extended (journaled) drives. These are all instantly recognized by my WDTV Live Plus. Is that format recognized by the D1?
Chomsky is offline
post #11287 of 11296 Old 04-18-2015, 07:01 AM
Mr Eric's Avatar
Quoted: 60 Post(s)
Liked: 47
D1 (and dune players) are able to read HFS drives, not sure about HFS+ but I would say very probable. It can only read, not write.
Mr Eric is offline
post #11288 of 11296 Old 04-18-2015, 09:55 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 87 Post(s)
Liked: 80
Do you hav a crossover cable? Maybe hook a PC to the D1 back to back with the crossover cable, set the D1 to the same network as the PC and see if you can ping then. Try to deremine if you have a defective network interface. Move up the network chain from there.
GetGray is offline
post #11289 of 11296 Old 04-18-2015, 10:40 AM
CD_in_NM's Avatar
dbrons and GetGray, thanks for the suggestions.
GetGray - see posts 11273, 11275, 11285, 11288. These are previous posts about the problem and things I have tried so far. I am fairly confident that the network is working correctly.
Also this morning, thought the firmware might have gotten corrupted. I downloaded 0032_b9 and installed. Not brave enough to try beta releases when there is a problem Still no change with the network issues.
post #11290 of 11296 Old 04-18-2015, 10:59 AM
GetGray's Avatar
Quoted: 87 Post(s)
Liked: 80
Sorry about that, late to the party.
GetGray is offline
post #11291 of 11296 Old 04-19-2015, 12:47 PM
golobulus's Avatar
Ha ha! I do this exact same thing!
Just curious, has anyone tried the Zappiti 4K player? When the Dune Smarts go I wonder if it would be a good replacement/upgrade. I only use BDlite.
golobulus is offline
post #11292 of 11296 Old 04-20-2015, 03:42 AM
Mr Eric's Avatar
Quoted: 60 Post(s)
Liked: 47
keep your Smart. Z4K is clearly not ready for primetime... (no Android player is ready TBH)
Mr Eric is offline
post #11293 of 11296 Old 04-20-2015, 12:58 PM
dbone1026's Avatar
Quoted: 121 Post(s)
Liked: 89
This ^
Cheers,
Damian
post #11294 of 11296 Old 04-24-2015, 06:47 AM
johnBlanker's Avatar
Quoted: 133 Post(s)
Liked: 27
just ordered my second B1. Mike said he's got refurb B and D's. If anyone is interested. D1's going for $250. He said they are practically brand new.
johnBlanker is offline
post #11295 of 11296 Old Today, 10:16 AM
CD_in_NM's Avatar
Ethernet problem with Smart B1 - Update
So, it turns out the problem was not the B1. I did a bit more experimenting before sending the B1 back for repair. I had already tried swapping ports and cables with known good ones with no luck. For the last experiment, I opened the interface for both the switch and the router. The switch sits between the B1 and the router. I was able to ping the B1 from the switch interface but not from the router interface. Did a factory reset and reconfigured the switch. Now the B1 is able to get onto the network again. I don't understand what happened, but I guess all's well that ends well.
post #11296 of 11296 Old Today, 10:25 AM
bluewhale1's Avatar
Quoted: 103 Post(s)
This ^
+1 As much as I want something that will play h.265 and 4k video nothing seems close to the whole Smart series for my dvd and blu ray movies.
bluewhale1 is online now
Dune Hd Smart B1 1080p Media Player
Gear in this thread - 1080p by PriceGrabber.com
