New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 378 - AVS | Home Theater Discussions And Reviews
post #11311 of 11338 Old 05-20-2015, 07:38 PM
rdgrimes's Avatar
Quoted: 817 Post(s)
Liked: 409
Use whatever firmware is already on it, till you find a reason not to.
rdgrimes is offline
post #11312 of 11338 Old 05-25-2015, 04:20 PM
hifiaudio2's Avatar
Quoted: 253 Post(s)
Liked: 82
I have had a Smart D1 set up and running quite well for a long time now, but am about to change my Nas from a Synology to a Windows 2012 Essentials server. I know there are ways and programs to assist with setting up NFS shares on Windows, but are SMB shares still buggy or not recommended for the Dune as (I believe) they once were? In other words, should I just plan now to have an NFS share set up again or is it likely something I can forgo?
hifiaudio2 is offline
post #11313 of 11338 Old 05-25-2015, 04:39 PM
ScottJ's Avatar
Quoted: 166 Post(s)
Liked: 89
AFAIK the only problem with SMB is if you try to use two shares on a single server, and store your Zappiti/MyMovies index on one of them. When you try to play a movie from the other share, it gives an error.
If you don't use any index, or don't create two shares on one server, or put the index somewhere other than SMB, it should all work fine.
For details see SMB Share Limit.
ScottJ is offline
post #11314 of 11338 Old 05-25-2015, 05:57 PM
AVS Club Gold
fcwilt's Avatar
Quoted: 42 Post(s)
Liked: 25
JOOC why are you changing?
Regards, Frederick C. Wilt
fcwilt is offline
post #11315 of 11338 Old 05-25-2015, 06:01 PM
hifiaudio2's Avatar
Quoted: 253 Post(s)
Liked: 82
Ok cool. My index for zappiti is on the internal SD card so I should be good.
post #11316 of 11338 Old 05-25-2015, 06:06 PM
hifiaudio2's Avatar
Quoted: 253 Post(s)
Liked: 82
I wanted my NAS to have a good bit more power than the Synology when transcoding is required, and also I began to get worried about bit rot for my irreplaceable family photos and videos so I wanted a file system like Microsoft's new ReFS that does automatic data integrity checks and repairs. I have online backups of course, bit if a file gets silently corrupted then the backup does as well.
post #11317 of 11338 Old 05-28-2015, 04:49 PM
AVS Club Gold
fcwilt's Avatar
Quoted: 42 Post(s)
Liked: 25
You are a brave soul.
fcwilt is offline
post #11318 of 11338 Old 05-28-2015, 05:00 PM
hifiaudio2's Avatar
Quoted: 253 Post(s)
Liked: 82
So far relatively so good. I have my new 2012 Server essentials server set up and connected to a used Dell Md1000 storage array with 4 4tb drives running basically a raid 5 on ReFS. All is ok except that transferring my current movies files and folders from the Synology keeps doing something weird. I am initiating and controlling the transfer from my win 8.1 pro PC and just telling it to send the files from one network share to the other. I will get great rates, up to 112MB per sec, and then it will randomly drop very low, all the way to 0 for a bit, then climb back IP and stay for a few minutes, then back and up again. Super weird. I can find some threads about Win 8 doing some weird stuff like this, so maybe it is the culprit. Also, I can't just select my whole folder. It will tell me there isn't enough space on the destination drive, even though there is about 10 TB free. But if I do it a few movies at a time... like 200-300 GB at a time, it allows it.
post #11319 of 11338 Old 06-02-2015, 04:36 PM
Liked: 0
Hello all,
Hopefully someone can help me.....
I have a Dune HD Max. It works ok playing media from hard drives, usb sticks etc. But when ever I put a bluray disc in the machine it locks up. Ive spent the last 2 days getting it back to normal so it plays from drives.
Can anyone recommend a firmware that will work with blurays??? They used to work ok but Ive updated the firmware and cant remember which one I had.
The one thats installed now is 140223_0132_b6. Ive read that a lot of people use a b6 but theres a few to choose from.
Many thanks in advance.
Cyclone44 is offline
post #11320 of 11338 Old 06-03-2015, 02:56 AM
Mr Eric's Avatar
Quoted: 79 Post(s)
Liked: 47
B6 is OK.
try to open your Max and check if the cables are correctly attached to the internal BR drive and the motherboard.
If everything seems Ok, then it could be that your drive is simply dead
Mr Eric is online now
post #11321 of 11338 Old 06-03-2015, 08:04 AM
fatherom's Avatar
Quoted: 49 Post(s)
Liked: 36
Originally Posted by Mr Eric View Post
B6 is OK.
Which B6 do you recommend?
Version "140223_0132_b6"
Version "131213_0131_b6"
Version "130515_2104_b6"
Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D, Dune HD Base 3.0, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
post #11322 of 11338 Old 06-03-2015, 11:43 PM
Mr Eric's Avatar
Quoted: 79 Post(s)
Liked: 47
140223, that's the most recent one and should be ok.
post #11323 of 11338 Old 06-04-2015, 12:49 AM
Liked: 0
Thanks for the reply.
I tried all b6 firmware and no discs played. Updated to the very latest firmware and tried a bluray, and after pressing play about 6 times it started playing. But then the machine locked up at the menu. Having to do another reset
I know the drive is connected ok but need to install a stable firmware. Aarghhhh
post #11324 of 11338 Old 06-04-2015, 02:59 AM
Mr Eric's Avatar
Quoted: 79 Post(s)
Liked: 47
b6 is stable.
Any chance that the BR you are trying to play is a Fox one ?
post #11325 of 11338 Old 06-04-2015, 06:26 AM
johnBlanker's Avatar
Quoted: 155 Post(s)
Liked: 30
Does anyone know how to get movies to resume from where you left off? I only use mainly ISOs and a handful of MKVs. I'm talking about stopping the movie, powering down the player (standby), and coming back the next day and resuming the movie. Thanks.
johnBlanker is offline
post #11326 of 11338 Old 06-04-2015, 06:57 AM
denass's Avatar
Quoted: 16 Post(s)
Cyclone the Bluray disc player in the Max is crap.Many have complained of it and especially not playing some Fox titles.Dune know of the issues and many complained on Dune's Facebook page to then be banned.Dune gives the run around by saying send it in the authorized service agent.The problem Dune knows of and won't give a firmware update to fix the issues.Probably because they can't fix it.So my fix was to buy another stand alone bluray player.It's a bugga but the best solution.
ScottJ likes this.
I thought I was wrong once but I was mistaken
denass is offline
post #11327 of 11338 Old 06-04-2015, 02:41 PM
dbone1026's Avatar
Quoted: 123 Post(s)
Liked: 89
I only use mkvs but they always resume where I left off.
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #11328 of 11338 Old 06-05-2015, 12:02 AM
Liked: 0
b6 is stable.
No not a Fox.
Yeah I might have to do the same. It is annoying when you have a great 'all-in-one' machine thats stopped doing 'all'.
Ill go back to the latest b6 and leave it at that.
Many thanks for the helps guys!!
post #11329 of 11338 Old 06-05-2015, 12:10 AM
Mr Eric's Avatar
Quoted: 79 Post(s)
Liked: 47
there's a setting in the dune setup to turn on the auto-resume for the last 300 or 200 files played (sorry can't remember exactly where so you will have to find it...). But it doesn't work with ISO or folder structure (BDVM/video_ts), only with simple files including MKV.
post #11330 of 11338 Old 06-05-2015, 07:12 AM
Quoted: 155 Post(s)
Liked: 30
bummer. thanks Eric
post #11331 of 11338 Old 06-07-2015, 08:22 PM
TODDAVS's Avatar
I thought the resume did work with ISO's. I'm going to have to go test later tonight or tomorrow.
What I really came in for was to ask a similar question, on MKV's. For some reason when i restart an MKV, it resumes a couple minutes into the movie no matter where i left off. In fact it looks like its going to start where it left off, blinks and winds up a few minutes in. Every time at the same place no matter where I left off. This happens with all my MKV's.
The MKV's were created either straight from Handbrake, or by splitting the video with ClownBD, ripping the video file only with Handbrake and then reassembling with MKVMerge. I've tried it both ways and the same problem occurs.
Its been a long time since i created a full bitrate MKV, but maybe I'll try that next (no compressed video file).
Any help is appreciated.
TODDAVS is offline
post #11332 of 11338 Old 06-08-2015, 06:17 AM
Quoted: 155 Post(s)
Liked: 30
Had problems playing 2 full disc ISO rips. Cake, and Before I go to sleep. Play the movie, the 20th centrury logo begins and after about 5 seconds- black screen. Nothing happens. I stopped the movie and then played BDlite instead and that worked. Any ideas?
post #11333 of 11338 Old 06-08-2015, 08:45 AM
hifiaudio2's Avatar
Quoted: 253 Post(s)
Liked: 82
I am thinking about replacing my Smart D1 with a Base 3d. I want to add 3d capability, and all of my 2d movies are all MKV rips (from a gigE wired Windows network share). So no BD folder or .iso, except I *do* think that .iso is the easiest was to do 3d movies. Is that correct? Will the Base 3d play back 3D files left in .iso format? Do I lose anything else to be concerned with by making the change from the Smart to the Base 3d?
post #11334 of 11338 Old 06-10-2015, 05:42 AM
mjt5282's Avatar
i own several SMART and 2 3D boxes. The only way as far as I know to playback 3D blu ray is through ISO format on this machine. since you have MKV rips for 2D (pretty much same as me) you shouldn't have any trouble. i find the gig-ethernet port helpful on my LAN.
mjt5282 is offline
post #11335 of 11338 Old 06-10-2015, 07:06 AM
hifiaudio2's Avatar
Quoted: 253 Post(s)
Liked: 82
Ok cool, thanks. I know there was early talk about the Base 3d not handling streamless branching and forced subs. Has that been corrected over time? Does it handle those things as well as the Smart now?
post #11336 of 11338 Old 06-11-2015, 09:19 AM
mjt5282's Avatar
because my processor can't currently handle HD codecs, all my MKV's with HD soundtracks are transcoded to flac 5.1 or 7.1 and I experience no problems with branching. Forced subs are another matter entirely - I believe the plugin has been fixed but for me it is not too hard to select a subtitle stream when the movie begins. Nothing more annoying than ripping Kill Bill Vol. 1 and not understanding the Japanese dialogue! or the Chinese in Vol. 2. If you have a particular title that has problems with branching, I could try it and let you know how it works.
mjt5282 is offline
post #11337 of 11338 Old 06-19-2015, 02:20 PM
ChldsPlay's Avatar
Quoted: 232 Post(s)
Liked: 80
So I started using the Dune app to control my player from my phone, and it works pretty good. However, when I hit the power button, the Dune doesn't go to standby, but instead powers down. Is there a way to make it only go into standby mode instead?
Also, I think I may have already asked this. It's probably a firmware thing, but when I start something from Zappiti and then stop it, instead of returning to Zappiti, it goes to the Dune screens. Is there a way to change this?
The Hodor Theater - In Progress
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT
Surround/Back Speakers - Klipsch Pro Cinema KPT-8000M
Subwoofers - Dual Passive JTR Captivator Pros
Receiver - Onkyo TX-SR608
ChldsPlay is offline
post #11338 of 11338 Unread Today, 01:54 AM
Mr Eric's Avatar
Quoted: 79 Post(s)
Liked: 47
you can find the power management in the dune set up. you can set it to Stand By or Power Off.
For the other problem, it's a known bug in the latest firmware. Just downgrade to an older one (B6 is OK).
Dune Hd Smart B1 1080p Media Player
Gear in this thread - 1080p by PriceGrabber.com
