New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 380 - AVS Forum | Home Theater Discussions And Reviews
post #11371 of 11379 Old 07-17-2015, 01:28 AM
Liked: 0
A slightly bit of good news. I pulled the power and left it 24hrs for a reset. Turning it back on and the drive ejects which is good, but it still wont play anything. Even after trying a few different firmwares.
Im now going to order a new media player, (not a Dune one unfortunately), and get a stand alone bluray player. Im gutted as I love my HD Max but without the bd/dvd playback its kinda 50% useless.
Thanks for the reply Hyrax & Mr Eric
*edit* bought a bluray player and it fits on my tv unit, pretty much out of sight. So no need to get a new media player. Ill use the HD Max til it dies, or until Dune release a new one (if at all)
Cyclone44 is offline
post #11372 of 11379 Old 07-17-2015, 05:05 AM
JohnnieBGoode's Avatar
I recently got an used Smart H1 since my C200 died (logic board, not PSU).
I have trouble getting system storage to initialize with an USB thumb drive.
The drive is empty (a single MBR partition, 4 GB) it shows up in the sources menu and can be accessed but when I try to use it as system storage it says "no suitable empty device found".
Is there something I'm missing?
What I've tried so far:
- Formatted the thumb drive's partition with FAT/FAT32/NTFS on a Windows PC
- Just a RAW MBR partition without any file system
- Used different thumb drive (16 GB) but all the same
- Tried multiple USB ports
The Dune's firmware version is the latest non-beta release (150227_0032_b9)
Any thoughts?
Thank you very much for your help!
*Edit*: Found the solution: Completely delete all partition data on the USB thumb drive, then plug it into the Dune, try to access it, it states that it isn't formatted - use the GUI to format it with EXT3 and then it can be used as system storage
JohnnieBGoode is offline
post #11373 of 11379 Old 07-22-2015, 06:15 PM
jakeabone's Avatar
I have an almost new Dune D1 barely used for about 2 years... PayPal accepted. I've decided to use the streaming on my Oppo 105D instead. Let me know if this should be posted elsewhere...
Eddy
jakeabone is offline
post #11374 of 11379 Old 08-02-2015, 04:50 PM
EVT
EVT's Avatar
Quoted: 22 Post(s)
Can't find windows 10 shares
Hi guys,
My server is down temporarily for repair so I'm trying to use my WIN 10 PC to stream via SMB to my Dune - the trouble is my Dune can't seem to connect.
I had previously setup up manual paths on my Dune before upgrading from WIN 8.1 and that worked fine - the Dune was able to access the files. The files are still in the same place and the relevant folders appear to be shared but I can't seem to access anything via the Dune - anyone have any suggestions?
EVT is online now
post #11375 of 11379 Old 08-02-2015, 06:11 PM
dbrons's Avatar
Originally Posted by EVT View Post
Hi guys,
Boy, I remember I had trouble when I went from Windows 7 to Windows 8. I can't remember really how I got it working again. I'll look back and see if I posted here about my issues. I do remember I never was able to get the network browser working again.
Could you please let me know if you get it working? I'm going to be going to Windows 10. thanks
Dave
dbrons is offline
post #11376 of 11379 Old 08-02-2015, 08:06 PM
rdgrimes's Avatar
Quoted: 873 Post(s)
Liked: 433
Hi guys,
Win-10 is supposed to have more robust DNLA which supports MKV, FLAC and maybe more.
rdgrimes is online now
post #11377 of 11379 Old Yesterday, 12:21 PM
EVT
EVT's Avatar
Quoted: 22 Post(s)
Dave
I managed to get it working and fortunately I didn't have to change anything on my Dune.
I fumbled around with the network settings and I managed to get it to work - it seems in my case what seemed to do the trick was unchecking the box that allows Windows to manage homegroup connections and instead selecting the box - use user accounts and passwords. My guess is that Windows must have changed this setting during the upgrade to Win 10 but in truth I don't know what I had it set to under Win 8.1 as it's been forever since I had changed anything in the network settings.
Of note, just like with Win 7 and Win 8 the network browser on the Dune still can't be used - you still have to create your paths manually.
EVT is online now
post #11378 of 11379 Old Yesterday, 02:41 PM
rdgrimes's Avatar
Quoted: 873 Post(s)
Liked: 433
I let you know if I figure it out. I know in Win 7 I had to manually entire the network locations on the Dune but when I upgraded to Win 8 and then later to 8.1 I didn't have to change anything. In Win 10 I set my share settings to what I believe is the same as before the upgrade but my Dunes are unable to access the shared folders.
There must be something wrong in Win 10 though as even my Oppo which is able to browse and find the shares can't access any files due to password restrictions which I have incidentally turned off! I guess this is what I get for upgrading so early.
Check the NTFS security settings for the shared volumes, maybe they got restricted. Sometimes just turning everything off including NTFS permissions, then turning it all back on again will do it.
post #11379 of 11379 Old Today, 08:16 AM
EVT
EVT's Avatar
Quoted: 22 Post(s)
Thanks for the tip, however it ended being one of the settings related to homegroups that probably got changed during the upgrade from Win 8 to Win 10.
EVT is online now
Dune Hd Smart B1 1080p Media Player
Gear in this thread - 1080p by PriceGrabber.com
