New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 386 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #11551 of 11557 Old 02-07-2016, 08:01 AM
Irwinroad's Avatar
Quoted: 70 Post(s)
Liked: 36
Originally Posted by Killroy View Post
Try Bitstream on the Dune. I had mine set to PCM/5.1 and that works fine but your AVR may have issues with the method of the Dune decodes.
Bitstream works fine but you are unable to use DTS's Neural X upmixer on a Dolby signal and vice versa.
When you send Multi Channel PCM from a bluray player both upmixers will work.
It is an issue with the code that DTS implemented in the Denon & Marantz 7200 & 8802 in the past 2 weeks. It remains to be seen whether or not D & M will correct the issue or whether it is a chipset limitation.
Time will tell whether or not other manufacturers will have the same issue with their chipsets until DTS X is available to update their AVRs.
The issue is referred to as "Cross Pollination" on AVS
Being able to send Multi Channel PCM makes it easier to compare movies from a NAS instead of loading each movie in to the bluray player.
Irwinroad is online now
post #11552 of 11557 Old 02-07-2016, 08:10 AM
mecmec's Avatar
Quoted: 247 Post(s)
Liked: 88
Hmmm, looks like you have everything set up correctly. The 7200 will not allow you to use a bitstream signal and use the DSU mode. It must be decoded first. HOWEVER, I see that you have the Dune doing that, so I have no idea why it is only showing as stereo when received by the 7200...
Let us know if you figure it out. This is one of the reason why I went with the 5200 as I LOVE the DSU mode and can't imagine it being much better with the new DTS firmware...
mecmec is offline
post #11553 of 11557 Old 02-07-2016, 11:12 AM
rdgrimes's Avatar
Quoted: 1150 Post(s)
Liked: 559
I think there was an issue with PCM output in a few of the firmware releases, which restricted them to 2-ch output.
rdgrimes is online now
post #11554 of 11557 Old Yesterday, 05:04 PM
johnBlanker's Avatar
Quoted: 323 Post(s)
Liked: 54
What do you guys use for your jukeboxes? I'm currenly running yaDIS but would like to experiment with others. I am trying Zappitti (again). I thought someon (Blackssr?) mentioned that they dropped support or something was broken.
johnBlanker is offline
post #11555 of 11557 Old Yesterday, 05:04 PM
Quoted: 323 Post(s)
Liked: 54
What do you guys use for your jukeboxes? I'm currenly running yaDIS but would like to experiment with others. I am trying Zappitti (again). I thought someone (Blackssr?) mentioned that they dropped support or something was broken.
post #11556 of 11557 Old Yesterday, 05:16 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 138 Post(s)
Liked: 114
www.mymovies.dk I've been very happy with it.
GetGray is online now
post #11557 of 11557 Old Today, 01:31 PM
EVT
EVT's Avatar
Quoted: 44 Post(s)
Liked: 25
I was happy with it too until just recently. Since upgrading to version 5.2 (all versions of it) when I add a Movie it doesn't get added to my Dune index unless I do a full update of the metadata for the Dune index which takes hours! Previously it was automatically updated when I added a movie.
As well, all TV shows I've added since moving to 5.2 cannot be launched using the iPad app.
Those caveats aside it works quite well and hopefully these issues get sorted out - I was a pretty happy camper for the previous 4 years.
EVT is online now
Dune Hd Smart B1 1080p Media Player
