New Dune HD Max and HD Smart anticipation thread Q3 2010 - Page 388 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #11611 of 11613 Unread 07-21-2016, 11:49 AM
rdgrimes's Avatar
Quoted: 1336 Post(s)
Liked: 643
Originally Posted by ChldsPlay View Post
Yeah, I don't want to do any rescanning or anything else where I have to redo all the customization I've already done. I was trying to figure out if I could go to the settings of where Zappiti looks and change that to reflect that it's attached to the Dune and not the PC. Something simple and fairly quick. I only add one or two movies at a time, and it's easy enough to scan them and just ignore all the ones it says need scanned or cleaned up. Certainly not worth an entire rescan.
It does ask for a complete export no matter how many things I have added. The one I did last night makes sense since I changed the theme, but usually it's just adding a movie or two and it still asks for a complete export.
You can modify the path to any drive in Media Center settings.
"Re-scan" doesn't exist. Every scan is a complete scan of all drives unless some are disconnected. Even if you just change the path for a drive, you still need to do a complete scan and clean up the broken file links. Changing a drive path means that all file links on that drive are broken. Zappiti won't go through and update file links for you, it creates new ones.
rdgrimes is online now
post #11612 of 11613 Unread 07-21-2016, 12:29 PM
ChldsPlay's Avatar
Quoted: 573 Post(s)
Liked: 303
New ones is not what I want since that means default images, and data, etc and not the ones I manually adjusted (which is probably 50% of the titles).
I was hoping there was a simple way, but it appears there is not.
The Hodor Theater - Now with Atmos
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT (3)
Surr./Back - Klipsch Pro Cinema KPT-8000M (4); Atmos In-ceiling - Niles DS8HD (4)
Subwoofers - Passive JTR Captivator Pro (2) - Powered by Crown XLS 5000.
Receiver - Yamaha Adventage A3050
ChldsPlay is online now
post #11613 of 11613 Unread Today, 06:39 AM
ChldsPlay's Avatar
Quoted: 573 Post(s)
Liked: 303
Ugh, Zappiti is being a real pain.
Ever since I switched to the grey theme it doesn't work right. I can only move around the initial titles that show up on the screen. Once it tries to scroll down to more titles it freezes up. This happens whether I'm looking at all of my movies, or just ones from a specific genre or letter. So I only have access to 15 titles or from the main movie section.
If I back out of Zappiti and use the Dune's standard interface it works without any problems. I have tried switching back to the default theme, but it hasn't improved things at all.
Dune Hd Smart B1 1080p Media Player
