Netgear NeoTV 550 - Page 209 - AVS Forum | Home Theater Discussions And Reviews
post #6241 of 6259 Old 01-25-2014, 04:03 PM
pdxrealtor's Avatar
Quoted: 137 Post(s)
Liked: 148
I've been playing with Media Center Master and I've got it working good for everything but boxed sets or 'collections'. I prefer to browse the Netgear movie wall as 'all videos'. In doing so Im having a problem with the boxed sets not being 'grouped' under one folder.
What have you all found is the best way to handle box sets and the 'all videos' view?
pdxrealtor is offline
post #6242 of 6259 Old 01-28-2014, 02:26 PM
thetoad's Avatar
I never figured out how to cause "folders" in the movie wall. I just ended up using the file browser. It shows the thumbnails so lets me keep the organization I prefer. With that said, I use the dune more now.
thetoad is offline
post #6243 of 6259 Old 01-28-2014, 06:03 PM
pdxrealtor's Avatar
Quoted: 137 Post(s)
Liked: 148
Toad - I'm sure you've seen this. I tested the various folder organizations in this example and the structure identified by a number 6 works perfect on the all movies view, as well as of course the search by genre etc.....
Pete over at MCM is going to take a look and see if he can make the program organize like this from the get go, but I don't think that will be possible.
post #6244 of 6259 Old 02-10-2014, 10:03 PM
pdxrealtor's Avatar
Quoted: 137 Post(s)
Liked: 148
Does any of you Netgear 550 owners know how to search for a movie using the keypad? There is a search box in the upper right when you are on the movie wall. But I can't figure out for the life of me how to get it to work!! Driving me nuts!
post #6245 of 6259 Old 02-12-2014, 11:14 AM
RDHolmes's Avatar
Quoted: 63 Post(s)
Liked: 49
Use the telephone style number pad at the top of the remote.
Bob Holmes
Curmudgeon
RDHolmes is offline
post #6246 of 6259 Old 02-13-2014, 05:50 PM
pdxrealtor's Avatar
Quoted: 137 Post(s)
Liked: 148
I was trying to access it with the iPad remote app, and that does not work.
Thanks for the info!
post #6247 of 6259 Old 09-02-2014, 04:18 AM
varun432's Avatar
Quoted: 31 Post(s)
Sorry for bumping into an old dead thread...
I am trying to use neotv550 in home automation software irule for feedback and commands.
I have a command level interface file for neotv550.
I have been successful in adding its basic network commands via port 30000.
But when I use port 49156 and try the command availabe under That port I am unable to achieve anything.
The problem I think might be in the fact that I can not create a proper hex code.
I am trying to send receiver message control x119
With host control command power (18) or Play(1) or Pause (2) or stop (3).
How's the hex command created by using both.
Or am I wrong somewhere.
The file can be found at netgear website.. Google it as NeoTv Network command Interface V3.0
Please help Guyz
I am stuck for last one week..
Sent from my iPhone
varun432 is offline
post #6248 of 6259 Old 09-02-2014, 09:31 AM
wildchild22's Avatar
Quoted: 13 Post(s)
hi there set the neotv up a network gateway in irule using port 30000
in irulebuilder put them in like this
play in irule is
\x19
power toggle is
\x18
pause is
\x10
etc
hope this helps
Please help Guyz
Sent from my iPhone
wildchild22 is offline
post #6249 of 6259 Old 09-02-2014, 09:36 AM
varun432's Avatar
Quoted: 31 Post(s)
Thanks for the reply..
Yes I have those commands at port 30000.
But according to the network command interface v3.0 49156 can be used for feedback as well..
That is what I am not able to achieve.. It would be nice if you could check the file and let me know how is the command line for play pause stop etc will be in that case..
The commands differ at that port..
Thanks in advance
Sent from my iPhone
varun432 is offline
post #6250 of 6259 Old 09-02-2014, 10:25 AM
Quoted: 13 Post(s)
Hi there I cannot get feedback either.
Thanks in advance
Sent from my iPhone
post #6251 of 6259 Old 09-02-2014, 10:51 AM
varun432's Avatar
Quoted: 31 Post(s)
Ok..
But btw what do you think would be a play command in that situation...
Sent from my iPhone
varun432 is offline
post #6252 of 6259 Old 09-02-2014, 02:52 PM
Quoted: 13 Post(s)
No Idea sorry I cannot help.
Ok..
Sent from my iPhone
post #6253 of 6259 Old 09-02-2014, 02:56 PM
RDHolmes's Avatar
Quoted: 63 Post(s)
Liked: 49
Thanks in advance
You might try posting in the iRule thread.
Bob Holmes
Curmudgeon
RDHolmes is offline
post #6254 of 6259 Old 09-29-2014, 10:15 PM
liquidmetal's Avatar
Hello All!
Still loving watching full blurays on this beauty!
I have a question. When watching a mkv and you hit the back button the remote, the video still plays in the
upper right corner of the screen while you can browse on the left side of the screen. How do you get the
video to appear full screen again? I tried all kind of stuff and could not get it to go back to the video that
is playing in the upper right corner.
liquidmetal is offline
post #6255 of 6259 Old 09-29-2014, 10:50 PM
varun432's Avatar
Quoted: 31 Post(s)
I Press the Menu Button and I am back to full screen whole watching mkv's
Sent from my iPhone
varun432 is offline
post #6256 of 6259 Old 09-30-2014, 09:06 PM
Let me try that. I thought I did.
post #6257 of 6259 Old 10-02-2014, 06:30 AM
jhck66's Avatar
Quoted: 60 Post(s)
Liked: 38
Has anyone tried Transformers: Age of Extinction with the Dolby Atmos track?
jhck66 is offline
post #6258 of 6259 Old 10-11-2015, 01:51 PM
Zonker007's Avatar
Quoted: 58 Post(s)
TV Show Episodes on the Movie Wall
Hope some folks may still be around to answer this question. When I create a TV Folder with Series -> Season -> Episodes and place all the tags for each episode in there, the individual episodes show up on the Movie wall rather than Just the Series Folder which I was hoping would show up. It makes for a very cluttered movie wall.
When I remove the TAG files and just have the episodes in the folder structure, then the Movie Wall acts properly in having just the Series Folder appear which I can then drill down to the season and episode. Of course then I lose all the TAG data about the episodes.
Is there a way to structure it so that if I include the TAG files for the episodes I don't have each episode appear on the movie wall and instead just have the Series Folder appear?
Z
Zonker007 is online now
post #6259 of 6259 Old 10-11-2015, 02:49 PM
wiatrak's Avatar
If you have any TAG file, then you have "entry" in Movie Wall. No solution for series unfortunately.
"...Those who go beneath the surface do so at their peril..."
Don Quixote was a villain! http://commons.wikimedia.org/wiki/Windmill
wiatrak is offline
