SlingBox: way to watch diff recorded programs from DVR one on SlingPlayer, one on TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-25-2010, 12:05 PM - Thread Starter
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
I have a Slingbox Pro-HD connected to a Dish VIP722 DVR, I'm able to watch recorded programming on my Windows PC with the Slingplayer but if someone is also watching the DVR on TV connected to the DVR we're both forced to watch the same recorded program. It would be nice to be able to have me watch one recorded program with Slingplayer on my PC and someone else watching a different recorded program on TV where the DVR is outputting a signal directly to the TV. Anyway to do this?
WynsWrld98 is offline
post #2 of 9 Old 09-27-2010, 07:59 AM
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
I use a second receiver to do this. The extra $5/month is worth it for me
mlknez is offline
post #3 of 9 Old 09-27-2010, 10:23 AM - Thread Starter
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
you use a second receiver to do what? I'm talking about watching two different RECORDED programs (as in recorded on DVR) simultaneously using SlingBox (one recorded program on PC, the other recorded program via TV connected to DVR).
I looked into cost of adding a second DVR but even if I buy a DVR myself Dish charges an additional $14/month (when i asked them) just for having second DVR which is hard to swallow.
post #4 of 9 Old 09-27-2010, 11:12 AM
DreamWarrior's Avatar
Quoted: 324 Post(s)
Liked: 241
The answer is no. Your DVR only has one video output, so both the Slingbox and the TV connected to it will have to "share" it and see the same thing.... Unless I'm misunderstanding you, with one DVR you can't do what you want.
DreamWarrior is offline
post #5 of 9 Old 09-27-2010, 11:44 AM
UHD Addict
aaronwt's Avatar
Quoted: 5194 Post(s)
Liked: 3102
The DVR would need to have two video outputs AND two video decoders to do this. DVRs typically only have one video decoder, hence only one program can watched.
The best solution is to have a dedicated box to use with something like a Slingbox or Monsoon Platium HD.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #6 of 9 Old 09-27-2010, 12:37 PM
jmpage2's Avatar
Quoted: 12 Post(s)
Liked: 80
OP, what everyone else has told you is correct. You would need a DVR that not only had two video outputs, but also had the ability to send a specific program to one video output and a different program to another video output. It would also need to be able to process two different IR commands from two different remotes at the same time (one for each DVR feed).
Obviously nothing like this exists. You need another DVR for your Slingbox.
jmpage2 is offline
post #7 of 9 Old 09-27-2010, 01:04 PM
rishi76's Avatar
Actually there is a way. The 722 has 2 independent outputs that you can use to watch 2 different programs simultaneously - make sure you are using the "Dual" mode. But there are a few catches:
- Main output (say OP1) is the only one with HD capabilities. OP2 is only SD. You can still watch a HD program but it will show only in SD.
- OP1 uses IR remote, OP2 uses RF remote. Slingbox uses IR.
So, the options are:
1) Use OP2 on TV, OP1 on Sling. You have full separate control on both devices and Slingbox remote can be used to control the receiver. Cons - You will only get SD on TV through OP2.
2) If you want HD on TV, you have to use OP1 on TV, OP2 on Sling. But as OP2 uses RF remote, you cannot use Sling remote but only the dish RF remote. So you will have to be in the same house and use Dish remote. Obviously this won't work if you are trying to use Sling remotely.
rishi76 is offline
post #8 of 9 Old 09-27-2010, 01:49 PM
UHD Addict
aaronwt's Avatar
Liked: 3102
Wow! that is unusual to have two decoders. How many other boxes are capable of this? The best use of that feature I could see would be for when a person is archiving content to a disc. That way they can be burning content to the disc while also watching something else on the DVR. The TiVos cannot do this which I could have used back in 2003 when i got my first stand alone Philips DVD burners and I would burn content to disc to take over to my girlfiends house for us to watch.
aaronwt is offline
post #9 of 9 Old 09-27-2010, 02:15 PM
rishi76's Avatar
It actually gets even better. You can also add an (optional) OTA module to this receiver and that can be used as a 3rd decoder. I use it when I have to record 3 programs simultaneously and one of them is available OTA. I love the functionality as it means I have one central DVR that can feed multiple outputs. E.g. I use the OP2 to feed 3 other SD televisions across the house (they can all show only 1 thing though, but can be different from the main OP1 feeding the main HD TV). I can also watch part of the recording on OP1 and then pick it up from OP2 in another room. The 222 and also some of the older Dish 6xx series had the same features - look for "Duo" in the name. This alone makes the Dish DVRs wayy better than TiVo for me.
OP - You may have to add diplexers etc to make this work, but it is standard Dish stuff, so if you don't have it you can just call them and get it installed correctly. Just tell them you have another TV that you want to feed off the same receiver.
rishi76 is offline
