*Official* Popcorn Hour PCH-C200 Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #541 of 585 Old 02-16-2013, 11:51 AM
halfelite's Avatar
Quoted: 421 Post(s)
Liked: 222
what is the cost of the pico i was thinking it was $$$ around 75$ or so am i mistaken?
halfelite is offline
post #542 of 585 Old 02-16-2013, 12:30 PM
comicguy's Avatar
i linked above the pico and adapter. most i have ever paid was $35 shipped. Frequently the power brick goes cheap like $10 so the pair can be had for $30 shipped to your door in the us from amazon..
comicguy is offline
post #543 of 585 Old 02-16-2013, 09:22 PM
halfelite's Avatar
Quoted: 421 Post(s)
Liked: 222
well damn, I should have went that route when i still had the 200 series. for some reason I was thinking it was double that.
post #544 of 585 Old 11-14-2013, 03:03 PM
fuscobal's Avatar
Hello guys,
I've had the power supply failure also and gave the unit to a friend of mine who repaired the power supply and replaced all the cheap chinese caps with much better panasonic ones ! Hopefully these will last longer, unless there's a problem with the design itself which will lead to failure of the caps no matter how good they are. Now, if you can help me with my other problems I would be gratefull. I play my movies both by direct streaming from my computer (very good signal, less than 4m between the comp and the TV) and from the internal HD of my PCH. While most mkvs are fine, I encountered problems with the movies filmed by myself (mp4 or avchd) using the Canon 5D mk2 (25fps) and Canon legria HF-G30 (50fps). Sometimes I get slow motion, sometimes sound misses or gets interrupted...At first I streamed them from my comp and I thought the bitrate is too high for my connection so I copied them onto the internal hdd of my PCH but with the same results. This led me to believe the PCH processor itself is too weak for 50fps. Any ideas ?
fuscobal is offline
post #545 of 585 Old 11-15-2013, 02:06 AM
tiulian's Avatar
  Hello there !
I repaired fuscobal's power supply; now what I can say about it is that it is not such a crappy PSU, because it's a PFC (Power Factor Corrector) design, which is nice, and the two SMPS's (stand by and main) are very simple straight designs (no fancy feedback inventions, etc.); after the PFC there are two PSU's : the stand by PSU (5VSB), and the main PSU (5V, 12V); the problem here was the stand by PSU, which gave up, indeed, because the crappy chinese capacitors - mainly the high voltage rail (68uF / 400V); I replaced mostly all the chinese caps with Panasonic E series for the HV input rail, and Panasonic FC series for the output voltage rails (all rated at 105C). The stand by PSU repair was also a bit tricky, because I had to rewind the chopper transformer (primary winding was burned out badly due to short circuit of the switching transistor), but in the end, it came out very stable and I don't think it will break again soon. For added safety, I mounted 1Amp fuse after the PFC, just before the stand by PSU, so in case of failure, the transformer would not burn out again. Whichever of you wants to repair it, I can provide some help :)
tiulian is offline
post #546 of 585 Old 01-02-2014, 05:09 PM
audvid's Avatar
Quoted: 347 Post(s)
Liked: 94
Originally Posted by comicguy View Post
aaron,
then you have been very lucky. there are NUMEROUS threads about the POS power supply in this thing. I LOVE my PCH almost as much as my Dune but the power supply is a complete piece of crap. Here is what I have replaced mine with and it has run flawlessly. Have also done this replacement on about 10 other pch-200's for people.
http://www.amazon.com/Mini-Box-picoPSU-80-Output-Input-Supply/dp/B005TWE5E6/ref=sr_1_4?s=electronics&ie=UTF8&qid=1361025861&sr=1-4&keywords=picopsu
http://www.amazon.com/Kinamax-AD-LCD12-Monitors-Adapter-Supply/dp/B000VE7GQQ/ref=pd_bxgy_pc_img_y
comicguy, Would the 2nd one - the sabranet work or would I need to order both? If the 2nd one would work, I would just order it and keep it - in case I have a failure.. its so cheap..
audvid is online now
post #547 of 585 Old 01-03-2014, 05:41 AM
audvid's Avatar
Quoted: 347 Post(s)
Liked: 94
Originally Posted by sean_w_smith View Post
Thats a limitation of NMJ. Try Eversion+YAMJ
http://www.dentedboxes.com/doku.php/eversionb2:files
I just bought the pch c200. I have not received it yet. I am planning to use it on a network. I have a mediasonic 8 bay USB unit, with 5 drives in it, attached to my boxee, which acts as my NAS. I have two other media players 9Asus and WD) already on the network and they work just fine, showing all the drives on the network. Do I still need to download and install Eversion+YAMJ? I went to the website and I am not sure I am following about what it is that these do. Could you please eloborate on this subject and about the installation of these two?
Thank you
post #548 of 585 Old 01-03-2014, 03:28 PM
UHD Addict
aaronwt's Avatar
Quoted: 5185 Post(s)
Liked: 3097
My C200 from 2009 is still chugging along on the original Power Supply. I do have an extra one lying around somewhere. At least I think it is for the C200.
But I also don't use my C200 very much any more. When I use it, typically it is for a Tv show on a BD ISO. So I can see the full menus and select the epsisode. Most of my Tv show BD ISOs don't have the episodes in order when using BD lite. Although most of my Anime TV show BD ISOs have the epsiodes in order.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #549 of 585 Old 02-09-2014, 02:28 AM
johnno08's Avatar
~~good morning to all
I have just joined this site so far very impressed ... I cannot find a section that related to my issue ...... I have a C-200 and have some mkv files in 3d I noticed the other day that I get a line down the right hand side of the screen I say line it is part of the picture that should be on the left hand side hope that makes sense .... if I play files through pc no problems I think I have altered a setting somewhere but for the life of me don't know what... can anyone help sorry if this is in the wrong section but looked and cannot find a suitable section thanks in advance johnno
johnno08 is offline
post #550 of 585 Old 02-09-2014, 05:21 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
List all your video settings and connections.
Gary J is offline
post #551 of 585 Old 02-09-2014, 05:27 AM
johnno08's Avatar
vid out............ 1080p 50hz
framerate sync.....ntsc/pal
vid zoom..... fit to screen
tv type....16:9
colour space ..... ycbrc  (auto)
that's the  vidieo would you need any other setting Gary
 thank you
john
johnno08 is offline
post #552 of 585 Old 02-09-2014, 05:30 AM
johnno08's Avatar
vid out  ..... 1080p 50 hz
frame rate ... ntsc/pal
vid zoom  fit to screen
tv type      16:9
colourspace     ycbcr (auto)
do you need any other setting Gary
johnx
johnno08 is offline
post #553 of 585 Old 02-09-2014, 05:43 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
You are in Europe connecting to PAL TV by HDMI?
Gary J is offline
post #554 of 585 Old 02-09-2014, 06:22 AM
johnno08's Avatar
Hi again gary yes that's correct hdmi 1.4  cable
johnno08 is offline
post #555 of 585 Old 06-02-2014, 12:15 PM
ExitRooster's Avatar
Hey all, frequent AVS'r, new to this category and hardware.. Just picked up a used C-200 this past weekend, after seeing it advertized all over (usually on frontend PC media websites). On our TV's, we usually use the Rasbpi running XBMC, an HTPC (also running XBMC) or consoles like the PS3/360. The consoles get their media 90% of the time through TVersity running on a "home server" PC and are the focus as they are the room that the C-200 is to be used in.
I dabbled with it (the C-200) awhile, and ultimately ended up doing the factory reset thinking there was some form of file corruption/failure. Here's what I can tell you about it:
Plugging in a USB flash drive, the thing is flawless. Played every piece of content I threw at it, from old crappy avi (divx/xvid) to the highest q mkv I had around (dont have many, I've ripped my dvd collection, but not too many Blue_Rays since the format only plays on the HTPC - Rasb shudders too much, and neither console will play an mkv, part of the main reason for the purchase!). So that was great.
Plays files from network search just fine - C-200 see's all PC's, all drives connected and streams over my WIFI just fine. (woot, again!)
BUT... It seems to absolutely refuse to play ANYTHING through my TVersity server 'collection'. While I COULD enable sharing on the drives, I'd much prefer it to do as all other devices do and access content directly through TVersity. But it doesn't. It see's the folder hierarchy, it navigates up to the file, but when you play the file, it whirs away for a moment, and simply says, "Unable to play file" in the upper right. No errors, no telling me why, nada. And it's universal. It won't play a single file, not video of any type, not mp3 audio, nothing.
When I got it, it was on a really old firmware (2010-2011?).. I updated it about 5-6 times to 5.3.2013 I think it was.. Says it's the latest.. Tried access TVersity on just about every update, wondering and hoping that the issue would be resolved after each update, but it never resolved itself.
Are the two just not compatible? Is there any way to see a log/error report or something to help guide me as to why it's "unable to play file"? I know the files aren't corrupt, they play on everything else, lol frown.gif
As always, thanks in advance for any input on the matter..
As an aside.. After playing with this thing now, what awesomeness do the newer units offer that would make me want to run out and buy the 'latest and greatest'? Got to admit, it's REAL impressive, even for it's age.
ExitRooster is offline
post #556 of 585 Old 06-02-2014, 01:08 PM
halfelite's Avatar
Quoted: 421 Post(s)
Liked: 222
I seem to recall there is something wrong with the profile on tvversity and you either need to manually make it or adjust one that is there already.
As for what do newer units offer. they have a little better jukebox support. Once you make a jukebox for tv you might not go back to tv veristy. they offer ipad/android apps for controlling the unit and 3d support other then that not much has changed since the 200 series.
post #557 of 585 Old 07-02-2014, 12:42 PM
teddystacker's Avatar
Hi everyone,
Done a few searches on this with conflicting results..
Can any one tell me how to format a 3TB or 4tb hard disk so it can be read by my PCH C-200 , as a INTERNAL drive ie just pop into the front slot..
Some people say GPT the whole drive , some say MBR Format the whole drive.
Does anyone actually have a Large format 3 or 4 TB drive in their PCH?
Thanks in advance..
teddystacker is offline
post #558 of 585 Old 07-06-2014, 09:33 PM
DexS's Avatar
Hi
Has one tried playing a Blu Ray audio ISO rip on C200?
I can;t get it working.
Thx
DexS is offline
post #559 of 585 Old 07-07-2014, 12:10 AM
halfelite's Avatar
Quoted: 421 Post(s)
Liked: 222
Originally Posted by DexS View Post
Hi
Thx
How are you connecting to your amp. I dont know much about Bluray Audio discs except the PCM specs are very high.
post #560 of 585 Old 07-07-2014, 11:10 AM
UHD Addict
aaronwt's Avatar
Liked: 3097
I think I tried one once a few years ago and it didn't work. It was the Rush: Moving Pictures Blu-ray Audio Disc. I can't remember what happened if I ever got it to work or if I had issues with it. I don't remember it working though. But it's been a long time. I'm not even sure what server I have it on.
aaronwt is offline
post #561 of 585 Old 07-07-2014, 11:48 PM
DexS's Avatar
Using HDMI out.
Thx
DexS is offline
post #562 of 585 Old 02-14-2015, 05:25 PM
Two C-200 RF Remote Controls Interfesring with each other.
I recently brought a second C-200 complete with its orignal RF Remote control.
My issue is that the remote controls appear to be interfearing with each other , and causing hangs and also I have to re pair each remote after it stops working.
Does anyone know a method of pairing each RF remote with each individual C200 , so it does not interfear with the one I have in the next room?.
Thanks ain davce for any suggestions..
post #563 of 585 Old 02-14-2015, 05:26 PM
C-200 Power Supply Repair in USA?
I recently repaced A faulty Power supply in one of my C-200's with a Pico one.
I would like to get the faulty PSU repaired , so I have a backup.
Does anyone know anywhere in the USA/Canada where I could get it repaired?. I have found a reputable person in the UK who will do it , but would be much easier , if I did not have to send it overseas.
Thanks in advance for any suggestions..
post #564 of 585 Old 02-14-2015, 05:54 PM
mecmec's Avatar
Quoted: 407 Post(s)
Liked: 157
WHY OH WHY would you waste the time to repair the factory psu??? Get another pico unit if you need a spare!
aaronwt likes this.
mecmec is offline
post #565 of 585 Old 02-15-2015, 09:00 AM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Make sure you do the second part of #3 and power off and UNPLUG all NMT units you do not want to synch
1. Attach the provided antenna to the RF antenna port at the rear panel of your NMT.
2. Remove the batteries from the RF remote control.
3. Power ON your NMT and wait for it to complete its loading process.
(Power OFF and unplug the power cord of all other NMTs that you do not intend to
synchronize in this synchronization exercise.)
4. Re-insert the batteries into the RF remote control. By inserting the batteries, the RF
remote control will now synchronize with any RF-compatible NMT that is active.
5. The RF remote control and NMT is now synchronized and will function properly.
teddystacker likes this.
thestewman is offline
post #566 of 585 Old 02-15-2015, 10:06 AM
UHD Addict
aaronwt's Avatar
Liked: 3097
I wish the PCH players from the last few years still had RF remotes. The RF remote is one of the things I really love about my C200. I have it sitting behind my center channel speaker since I never need to actually touch it. And the RF remote works great for this.
aaronwt is offline
post #567 of 585 Old 02-15-2015, 11:03 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Is PCH still supporting and upgrading mighty C200. I have one unused since I got 210
zoro is offline
post #568 of 585 Old 02-15-2015, 03:42 PM
UHD Addict
aaronwt's Avatar
Liked: 3097
I think the last firmware release came out in Summer 2013 for the C200.
aaronwt is offline
post #569 of 585 Old 02-15-2015, 04:47 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
man, what to do with that such a bullet proof machine
zoro is offline
post #570 of 585 Old 02-15-2015, 05:29 PM
Simple - Resale value , does not look to good with a mod.
Putting it back "stock" will be much better..
Also I hate to just throw stuff away for the sake of a few $ repair.
Popcorn Hour C 200 Networked Media Tank Black
