*Official* Popcorn Hour PCH-C200 Owners Thread - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #571 of 588 Old 02-15-2015, 04:30 PM
teddystacker's Avatar
Originally Posted by thestewman View Post
Make sure you do the second part of #3 and power off and UNPLUG all NMT units you do not want to synch
1. Attach the provided antenna to the RF antenna port at the rear panel of your NMT.
2. Remove the batteries from the RF remote control.
3. Power ON your NMT and wait for it to complete its loading process.
(Power OFF and unplug the power cord of all other NMTs that you do not intend to
synchronize in this synchronization exercise.)
4. Re-insert the batteries into the RF remote control. By inserting the batteries, the RF
remote control will now synchronize with any RF-compatible NMT that is active.
5. The RF remote control and NMT is now synchronized and will function properly.
Thanks very much for the info - worked a treat - very grateful..
teddystacker is offline
post #572 of 588 Old 02-15-2015, 05:04 PM
UHD Addict
aaronwt's Avatar
Quoted: 6417 Post(s)
Liked: 3966
Doesn't Cloud Media still sell the Power Supplies for the C200? I had a spare one sitting around for many years, but I never needed it until last year when my C200 was almost five years old.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #573 of 588 Old 02-16-2015, 03:55 AM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Originally Posted by teddystacker View Post
Simple - Resale value , does not look to good with a mod.
Putting it back "stock" will be much better..
Also I hate to just throw stuff away for the sake of a few $ repair.
wrong on every level.
Gary J is offline
post #574 of 588 Old 02-16-2015, 05:14 AM
mecmec's Avatar
Quoted: 451 Post(s)
Liked: 187
Anyone who does a modicum of research before buying a c200 would be THRILLED to that you replaced the power supply as it is not an "if" it will fail, but a "when".
And I feel that shipping and time involved to repair the old pos psu is quite a bit more than a "few $ repair".
mecmec is offline
post #575 of 588 Old 02-16-2015, 01:19 PM
Thanks for your help guys..
Hopefully someone will come along with a suggestion as to a repair source ,rather than arguing the pros and cons.
Seemed to have turned into a ethics question..
My fault for asking such a stupid and silly request... Clearly I have no idea what I am doing here.. Gone are the days at forums where peioople were friendly , and did not just try to shoot everyone down.. I will retire to my own silly world..
post #576 of 588 Old 02-16-2015, 01:21 PM
Debateable to be honest , been out of stock for over a month.. Since Cloudmedia took over Stbas , things have been very hit and miss , as to any type of support.
post #577 of 588 Old 02-16-2015, 02:36 PM
mecmec's Avatar
Quoted: 451 Post(s)
Liked: 187
Sure, take the blown power supply to any reputable electronics repair shop. They will happily do a diagnostic on it to find out what is wrong. I had two quotes from reputable places in my area. The cost would have been diagnostic time of about $50 plus the actual time worked on the repair plus the cost of the parts needed. Both places said it would be about $100 give or take.
The power supplies are not overly complicated devices and nearly any reputable electrician should be able to diagnose and repair them.
Hope that is helpful enough for you...
mecmec is offline
post #578 of 588 Old 02-16-2015, 02:42 PM
Gary J's Avatar
Quoted: 423 Post(s)
Liked: 222
Pocket change when you have an emotional attachment to your PS.
Gary J is offline
post #579 of 588 Old 02-16-2015, 02:49 PM
mecmec's Avatar
Quoted: 451 Post(s)
Liked: 187
Originally Posted by gary j View Post
pocket change when you have an emotional attachment to your ps.
lol!
mecmec is offline
post #580 of 588 Old 02-18-2015, 02:11 PM
N2VWZ's Avatar
C200 Power Supply Repair is not difficult - You can do it yourself
I have 2 C200 players. The power supply failed on one of them. I repaired the failed supply for under $2.00 in parts cost. In my case, 3 capacitors had failed. This is a very common failure. To identify failed capacitors, remove the power supply from the C200 and take off the cover. Then look for domed or leaking capacitors. They are cheap and available from Digikey. You'll need soldering skills and appropriate tools to do this yourself, but it's not difficult job. It helps if you have an understanding and familiarity with electronic circuits (or a friend with these skills).
For additional help, do a Google search for "popcornhour C200 power supply repair" There are videos and photos available. Some places are even selling repair parts kits
N2VWZ is offline
post #581 of 588 Old 04-26-2015, 04:49 PM
SMWinnie's Avatar
Power supply issue?
I have a C-200 that won't boot up.
Starting with a power light with a red ring, if I hit the power button, I see a brief change that might be orange then the light goes back to red.
The PSU was replaced a few years ago. I cracked open the case and the PSU. The PSU has one bulging capacitor without obvious leakage.
Anybody see this before? I see lots of descriptions of blinking white rings but not the pattern I'm getting.
This C-200 does have a BD-ROM drive and a HD installed.
East Lansing (Lansing, MI DMA) A/V enthusiast getting content from xfinity, Netflix, OTA and off the shelf-o'-discs. A 4228 in the attic is almost good enough.
SMWinnie is offline
post #582 of 588 Old 04-26-2015, 07:31 PM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
anytime you get blinking its almost always the PSU on the 200 series. If you are not sure the power supply is a standard ATX so if you have a space PC PSU laying around you can test before buying a nw one. If you have a little bit of soldering skills you can fix it yourself for under 5$
halfelite is offline
post #583 of 588 Old 12-09-2015, 02:21 AM
esdee's Avatar
I am looking to buy a CD/DVD drive for my C-200, how is the installation? Is there any significant difference than installing into PC? I mean, I can just choose any optical drive and it should work, right?
esdee is offline
post #584 of 588 Old 12-09-2015, 12:08 PM
halfelite's Avatar
Quoted: 468 Post(s)
Liked: 242
it is the exact same as a pc install
post #585 of 588 Old 02-13-2016, 04:21 PM
dgozalie's Avatar
Liked: 0
Hello
sorry if it seems odd.. I just brought and old c200 player with very outdated firmware circa 2010.. well then i update the firmware and stuck to 02-04-110422-21.. i cannot update it to stepstone firmware... can anybody help since seems stepstone no more available from online update ?
Donny
dgozalie is offline
post #586 of 588 Old 05-21-2017, 10:18 AM
gregavi's Avatar
Quoted: 39 Post(s)
I have 2 A200s that have both failed at just about the same time. They both have the original power supply/cord/AC-DC adapter. When I plug in to the PCH, sometimes they will power on but if I rotate the cylindrical plug to the back of the PCH, the power will go on and off (based on the lights and fan going on and off) I have sprayed contact cleaner into the socket with no change. It's strange, if I wiggle the cord nothing happens, but if I rotate the connector it goes on and off. Does this sound like a power supply failure or something else? Also, I'm a little confused. Are these failures the AC-DC power cords that are failing, or is there a power supply inside the box that is failing, or both?
Thanks in advance.
It used to be:"Wine, Women and Song"Now it's: "Beer, The Old Lady and TV"My Theater Build http://s1116.photobucket.com/user/Gr...?sort=6&page=1
gregavi is offline
post #587 of 588 Old 05-21-2017, 01:05 PM
zrdb's Avatar
Thanks in advance.
Sounds like you may have a problem with the 2 contacts in the female jack on the PCH's board-you could try using a small jewelers screwdriver to carefully bend them in a little so they make solid contact with the male part on the power supply.
zrdb is offline
post #588 of 588 Old 05-21-2017, 02:23 PM
gregavi's Avatar
Quoted: 39 Post(s)
You were pretty much correct, except it was the power supply side that needed the pins tweaked. The PCH has the male pin. But it seems to be working again. Thanks for the suggestion.
gregavi is offline
Popcorn Hour C 200 Networked Media Tank Black
