*Official* WD TV Live Hub Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 2271 Old 11-28-2010, 12:21 PM
bigspndr's Avatar
Originally Posted by bill913 View Post
Hope someone can give me a hand. I have a Live Hub connected to my home network and can get most functions to work OK after several weeks. But I have not found a way to copy BD and get it to play on the hub (DVD works fine). I have tried DVDFAB in the copy mode with no luck. I can get some bits of video and no audio. I have tried the rip mode but cant's see the files on the HUB. As you can probably tell I am new to both the hub and BD copy. Is there any reasonably easy way to accomplish what I am trying to do. I have been reading post for several days and am not getting anywhere.
convert the BD to m2ts file. It plays fine on mine. Its under the BLUE RAY RIPPER section
bigspndr is offline
post #632 of 2271 Old 11-28-2010, 05:06 PM
thelangs's Avatar
Convert it to MKV using dvdfab.. It works great on the hub
thelangs is offline
post #633 of 2271 Old 11-29-2010, 02:47 PM
bill913's Avatar
Originally Posted by hal90002010 View Post
bill913
You have more than enough horsepower,ram and hard drive space.
Are you using DVDFAB main movie or full disc to move the BluRay to a local drive, then transfer to the hub?
I am using DVDfab "main movie" and putting it in the video folder on my computers hard drive. I end up with several folders and many files, but the only thing that will play are files called streams that are pieces of the movie with no audio.
bill913 is offline
post #634 of 2271 Old 11-29-2010, 05:21 PM
hal90002010's Avatar
OK, What movies?
It should be working for you.
And You are playing it from the drive in the hub?
Hal90002010 Conquerer of the Great Barrier
hal90002010 is offline
post #635 of 2271 Old 11-29-2010, 06:11 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
Originally Posted by didapipo View Post
I second this.
If the encodes are Side-by-Side (SBS) encodes , and the TV has the option to reformat SBS 3D content. Does Live hub stream 3d files okay?
Just about ANY media player can play SBS movies. SBS isn't special in any way. It's just plain, vanilla video in all respects.
WDFan1970 is offline
post #636 of 2271 Old 11-29-2010, 08:05 PM
leppychaun's Avatar
I aslo had issues with using the Network Share on windows 7 .. i tried all the tutorials on Youtube to no luck ..the Media share would work , i could network the drive to drag and drop files ..but for the life of me could not get the hub to find the network . I then notices on my router that the Hub was only connected via 10/100 for some reason ... turned out the Ethernet cable i was using was not working correctly ( how it functioned in the first place i don't know ) I redid the cable by putting new ends on it and suddenly the connect went from 10/100 to the 1000 on the router and my Network Share started working on the Hub out of nowhere .. Maybe this will help .. as far as the data trans rate .. it is ridiculously slow .. max I can get is 10/mbs it was the same speed with the bad connection as with the 1gbt connection .. this tells me there is some serious issues witht the firmware ..
leppychaun is offline
post #637 of 2271 Old 11-29-2010, 11:54 PM
roodkopje's Avatar
half SBS will work but not full SBS because of the 3840x1080 resolution i guess
roodkopje is offline
post #638 of 2271 Old 11-30-2010, 05:00 AM
saintsaints's Avatar
I got network shares working, but how come it all goes away when you turn on media library. I would like to retrieve thumbnail content to go with my network shares.
saintsaints is offline
post #639 of 2271 Old 11-30-2010, 07:02 AM
ChopstickHero's Avatar
I just picked one up last night. Was playing around with it and ended up watching Iron Man 2 (bluray rip 1080p). Looked and sounded great.
Questions for owners who've had one for much longer: is the fan always on (in standby too)? I noticed after i turned off the unit, the unit was slightly warm (not hot by any means) and the fan was on. I went to bed and forgot to check this morning if the fan was still running....
ChopstickHero is offline
post #640 of 2271 Old 11-30-2010, 07:30 AM
velocci's Avatar
Quoted: 137 Post(s)
hi there, I can't go through all 11 pages of this thread. can someone tell me if this unit plays BD iso files and if anyone has tried playing .flv files?
www.jvpix.com
system: Onkyo TX-NR 646 AVR with Polk Audio RtiA3 fronts,
BIC America F12 sub and Polk Audio RC-65i rears
velocci is offline
post #641 of 2271 Old 11-30-2010, 07:48 AM
TheMocoMan's Avatar
Whoops! Meant "Menu Support" sorry folks!
TheMocoMan is offline
post #642 of 2271 Old 11-30-2010, 09:44 AM
Originally Posted by TheMocoMan View Post
It will NOT play Blu-ray .ISO files.
Haven't tried .FLV yet.
Yes it will play BLURAY ISO.
Will not play FLV.
Dont have any idea what mocoman is talking about.
All of my full blurays are ISO.
post #643 of 2271 Old 11-30-2010, 10:13 AM
hmaliks's Avatar
Turn media sharing on and I am unable to see my WHS share. I think it's a bug that needs to be resolved. Media sharing is also important if you have DVD ISOs and want the hub to remember the time line so that you can watch it later from the same spot. If media sharing is turned off it doesn't remember timeline from DVD ISOs. So these are two bugs I have noticed or read on forums so far.
hmaliks is offline
post #644 of 2271 Old 11-30-2010, 10:22 AM
WolfMan69's Avatar
How is the PQ on normal DVD ISOs?
The wifey still has a ton of DVDs she watches...
WolfMan69 is offline
post #645 of 2271 Old 11-30-2010, 10:49 AM
hmaliks's Avatar
Will not play FLV.
Any menus when you play BLURAY ISOs? Can you give some details please?
hmaliks is offline
post #646 of 2271 Old 11-30-2010, 12:13 PM
No menus, it just plays the biggest file.
post #647 of 2271 Old 11-30-2010, 12:16 PM
hmaliks's Avatar
Thanks, Do you know if BDMV structure also runs the same way, without menus?
It will be nice to have menus though, although what I read they will not be doing that. May be some licensing issue.
hmaliks is offline
post #648 of 2271 Old 11-30-2010, 12:27 PM
No blu menus any way yet.
post #649 of 2271 Old 11-30-2010, 12:29 PM
hmaliks's Avatar
So in you ISOs if you have multiple audio or sub streams, it cannot be handled. is this assumption correct?
hmaliks is offline
post #650 of 2271 Old 11-30-2010, 12:47 PM
velocci's Avatar
Quoted: 137 Post(s)
other than the internal HDD, is this unit worth the extra $100 over the WD Live Plus?
www.jvpix.com
velocci is offline
post #651 of 2271 Old 11-30-2010, 01:00 PM
Charles R's Avatar
Liked: 649
Having used both I think most would much prefer the Hub's interface and the remote is better if you plan on using it. Also the Hub will server other clients... handy if you will be using more than one player.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #652 of 2271 Old 11-30-2010, 01:02 PM
velocci's Avatar
Quoted: 137 Post(s)
which one plays more file types?
www.jvpix.com
velocci is offline
post #653 of 2271 Old 11-30-2010, 03:24 PM
hmaliks,
Will play most Audio and all subs, Just hit the options button.
If Audio is DTS MA HD Just convert to MKV with no compresion using DVDFAB and it will play the audio just fine.
post #654 of 2271 Old 11-30-2010, 03:47 PM
USER MANUAL!!!!!!!!!
http://www.wdc.com/wdproducts/librar...779-705046.pdf
Manual
post #655 of 2271 Old 11-30-2010, 06:21 PM
the.goatboy's Avatar
If this was mentioned earlier, sorry for the repeat but my Macs and Playstation 3 find my hub without me having configured anything special. Thought that was pretty cool. I actually tested via the PS3 connecting to the hub; I then was able to play a locally stored movie off of the hub, through the PS3 to the TV.
the.goatboy is offline
post #656 of 2271 Old 11-30-2010, 06:36 PM
Originally Posted by Warrior King View Post
Change workgroup (should have known that) i was able to see my server name show up but not able to access the files.
The hub keep asking for password for which i don't have one for the server. I tried leaving "anonymous" in there but nothing, i also try leaving it blank still not able to access my shares or folders.
Any idea why this is not working...................
What if you create a generic user account on your server (ie. "hub"), add it to the local administrators security group, AND assign it a password. Add the user account to the security settings of your shared media folder with "full control" then try connecting to it again. This time when you're prompted for a username and password it should work using this new account. I don't know what the behavior of the WD hub is, but I've seen numerous times where connections to a folder share don't work because the connecting object can't or won't accept BLANK passwords. It's worth a shot and will only take you a few minutes to try it out; if you do, let us know the results good or bad. Good luck.
post #657 of 2271 Old 11-30-2010, 06:57 PM
ben12345's Avatar
Quoted: 93 Post(s)
Liked: 27
I just got a WD TV Live Hub and it says you need to download the discovery tool, the "WD Discovery" software. When I download the file it is for a Windows PC. What about this software for a Mac? Do you have to have this software for WD to work properly?
ben12345 is offline
post #658 of 2271 Old 11-30-2010, 07:04 PM
I did my initial setup of the hub through my TV; only later on did I download and install the discovery tool and connect to the hub. Any chance you have VMware Fusion or Parallels Workstation installed on you Mac? You could install the discovery tool on a Windows VM on the Mac and get to it that way; just a thought.
post #659 of 2271 Old 11-30-2010, 08:23 PM
Warrior King's Avatar
Thanks for the reply.....That probably would work if i was running windows but i am running a Linux base UnRaid server. There might be away to do it like you stated but i'm not sure about how to go about it. I will swing over to the limetech site and see.
I really believe it has something to do with the HUB. As stated earlier prior to the HUB i had the LIVE PLUS and it work fine with the UnRaid server absolutely no issues. It has to be some kind of share issues with the HUB. I will continue messing around with it until it fly across the room
Warrior King is offline
post #660 of 2271 Old 11-30-2010, 08:59 PM
Killer Banana's Avatar
I picked up a WD TV Live Hub this afternoon and have been loading my music files onto it all evening. One glitch I found was that (at least on my home network) the internal hard drive on the Hub does not like having more than one file copied to it at a time. Every time I attempted to click & drag multiple large files to the Hub I would lose the network connection entirely and have to close all of the windows on my PC, go down to my basement, restart the Hub, go back upstairs, and restart the WD Discovery tool. Dragging just one file at a time was no problem though.
That issue aside, I'm happy with it. The GUI is intuitive, and it does what I want it to do: Stream video and decode lossless audio. I have it hooked up to my Yamaha RX-V863 by HDMI for video and 5.1 channel sound, and I have the analog audio outs connected to my Emotiva USP-1 for 2-channel audio.
SoundofMind:
My God man, he has a 1803!
Killer Banana is offline
