*Official* WD TV Live Hub Thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
post #1831 of 2271 Old 02-20-2012, 02:54 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
To copy from a USB disk, browse to the item or folder(s) you want to copy, and press OPTIONS -- COPY.
Then select the internal drive as the destination and it will copy it to the internal drive.
WDFan1970 is offline
post #1832 of 2271 Old 02-20-2012, 03:05 PM
kingpcgeek's Avatar
Quoted: 53 Post(s)
Liked: 80
Originally Posted by WDFan1970 View Post
Not quite. As Telemike indicated, you can also copy from a USB disk attached to the WD. You don't have to use a network to copy files.
Before you correct me you might want to reread what I wrote. the only way to copy from laptop to the WD internal drive is via a network connection
TiVo Roamio Pro, TiVo Elite (Killed by Cox), TiVo 4, 8 TiVo Minis, Roku 3, Cox Cable, Sonos, Amazon Echo
kingpcgeek is offline
post #1833 of 2271 Old 02-20-2012, 03:36 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
D'oh! My bad. Mea culpa! Corrected.
post #1834 of 2271 Old 02-21-2012, 05:41 PM
mikegski's Avatar
I have had the WD Live Hub for a while now and all seems to work just fine, but recently I decided to set up Netflix on it. Everything went fine got through all the start pages and setups without any issues. Searched movies and decided to play a Movie tonight, clicked play and all seem to start just fine but there was no picture......Sound is perfectly fine movie seems to load fine but the TV screen is completely black!
I can play videos and all other services without issue, netflix seems to be the only service that will not work properly! I called Netflix and they dont have a clue, i didnt expect much from them anyways.
Has anyone else experienced this issue with the WD Live Hub when trying to use Netflix? Any idea's??
mikegski is offline
post #1835 of 2271 Old 02-21-2012, 06:00 PM
msgohan's Avatar
Does your display support HDCP?
LG B7 (OLED65B7P, 2017 -- bought 2017/05/31 & I couldn't be happier so far!) | Panasonic CX850 (TC-55CX850U, 2015 -- bought OLED to replace it due to poor off-angle, weird HDR colors, etc.)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #1836 of 2271 Old 02-22-2012, 02:14 PM
JoeBoy73's Avatar
Quoted: 17 Post(s)
Liked: 29
Just curious if anyone was running this projector setup (CIH) and have you used the "subtitle shift" feature? Does it help? Trying to decide between 16:9 and 2:35 screens!
JoeBoy73 is online now
post #1837 of 2271 Old 02-23-2012, 07:24 AM
Rudy_P's Avatar
Read this might be useful. http://www.hdfury.com/hdmi-hdcp/hdcphdmi-definition/
Rudy_P is offline
post #1838 of 2271 Old 02-23-2012, 02:57 PM
mikegski's Avatar
My TV is brand new just bought it 2 months ago, I would think it should be compliant wouldnt it? Its an LG 60pv250 plasma???
mikegski is offline
post #1839 of 2271 Old 02-23-2012, 02:59 PM
mikegski's Avatar
My TV is an LG 60pv250 which i jsut bought 2 months ago new! THe more i read about this I am thinking it is the HDCP thing WTF is LG doing making a new TV that is not compliant????
mikegski is offline
post #1840 of 2271 Old 02-23-2012, 06:16 PM
Rudy_P's Avatar
I am sure it is compliant. Try to use component cable, and if it works then panic.
Rudy_P is offline
post #1841 of 2271 Old 02-29-2012, 07:42 AM
znutz's Avatar
Need a bit of help. Trying to use a wired Ethernet connection to connect WD Live Hub to home network. Setup network connection automatically and connection test checks out. I am able to see the WD Live hub from my home pc under network devices. Problem is, I can't login to my home network from the WD Live Hub. I keep getting the error "incorrect username and password." Nothing on my network is password protected other than the wireless key. I am using a Linksys E3000 as a router. Any help would be appreciated!
znutz is offline
post #1842 of 2271 Old 02-29-2012, 08:09 AM
LVS
LVS's Avatar
Check your Workgroup/Domain setting on the server and WDTV just to make sure they are the same.
LVS is offline
post #1843 of 2271 Old 02-29-2012, 08:47 AM
znutz's Avatar
Thanks for the quick response. Found the solution!!! Linksys E3000 router has NAS capability. Was acting as a "master broswer" by taking over the Workgroup name. Changed Linksys default workgroup name to "failgroup" and this allowed windows to control the workgroup "workgroup." More detail here if others are experiencing the same issue with this particular router.
http://homecommunity.cisco.com/t5/Wi.../false#M197008
znutz is offline
post #1844 of 2271 Old 02-29-2012, 03:22 PM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
Folks, in case you have New Firmware Detection turned off, WD released a new firmware today.
post #1845 of 2271 Old 02-29-2012, 03:46 PM
kingpcgeek's Avatar
Quoted: 53 Post(s)
Liked: 80
What's in this update? Release 3.03.13 (2/29/2012)
Supports Skitter TV internet television service.
Supports MLB.TV.
Resolved Get Content Info conflict caused by folders with similar names.
Resolved mp4 video freezing, audio sync and "Unsupported Message" issues.
Resolved unable to play MOV videos.
Resolved MKV video with FLAC audio does not play audio issue.
Resolved Vorbis audio in MKV container audio spikes during playback issue.
Resolved issue AAC and MP3 2CH audio outputs 7CH via HDMI pass-through to AV receiver.
Resolved VUDU HDX quality does not pass-through 7.1 audio to the receiver.
Resolved MP3 audio playback issue in FLV video container.
Resolved Picasa downscaling photo resolution issue.
Resolved issue with 2CH+ PCM outputted as 2CH PCM only.
Resolved remote shortcut keys conflict with the onscreen keyboard during search.
Resolved movie thumbnail extremely grainy and pixilated.
Resolved rescan media library after every reboot.
Resolved rescan Get Content Info does not refresh thumbnail issue.
Resolved movie backdrops do not display without network connection or after network disruption.
Resolved several Spotify user interface and translation issues.
Resolved Spotify popping and glitching sounds when skipping tracks issue.
Resolved Spotify tracks do not play when sharing playlist.
Resolved Yota Music intermittently hangs issue.
Resolved YouTube Leanback rebooting issue.
Resolved PlayJam unable to un-mute issue.
Resolved ComedyTime Pause and Play will not work after FFW or RWD several times.
Resolved several language translation issues.
General info:
Blockbuster video download service will no longer be supported on the WD TV as of 3/31/2012. You will still be able to watch your purchased videos.
Mediafly will no longer be supported as of 3/31/2012.
How about HBOGO Western Digital?
post #1846 of 2271 Old 03-01-2012, 05:52 AM
stepmback's Avatar
Quoted: 17 Post(s)
I am now like three or four firmwares back. I was on the latest version but had way too many issues staying connected to my network. The version I am on now is stable and plays all my files just fine.
I do not see anything on the list of updates that makes me want to update. However I may give it a go on one of my hubs just to see. I can always roll back.
stepmback is offline
post #1847 of 2271 Old 03-01-2012, 08:07 AM
EricRobins's Avatar
I am happy to see that we should be able to get MLB.TV on our LiveHubs.
Before I switch from the EI subscription via Directv to MLB.TV, I really want to know what the DVR functionality is like. For example, I am not sure I can live w/o the 30-second skip that I am used to on my D* DVR's.
Can anyone tell me what to expect?
EricRobins is offline
post #1848 of 2271 Old 03-03-2012, 01:57 PM
Rudy_P's Avatar
One big problem for me with new firmware 3.03.13. Videos from my camcorder Panasonic HDC-TM900 in the original format (1080p , 60 frames per second , 25k bitrate, .m2ts) are not playing right. Video is very jerky and every few seconds it breaks up. My second unit still on 3.01.19 firmware plays ok.
Rudy_P is offline
post #1849 of 2271 Old 03-04-2012, 03:56 AM
billpan's Avatar
I updated to the latest fw and i still cant understand why the hub cant output AAC 5.1 audio as PCM 5.1,just like the PS3...Also does anyone know if WD will add cinavia?
billpan is offline
post #1850 of 2271 Old 03-05-2012, 04:05 PM
kevinf's Avatar
I would like to rip my concert blu rays and play them back with DTS-MA on my hub is this possible ?
kevinf is offline
post #1851 of 2271 Old 03-05-2012, 04:07 PM
csrini1's Avatar
Quoted: 224 Post(s)
Liked: 78
you will get only dts core.
csrini1 is offline
post #1852 of 2271 Old 03-05-2012, 04:13 PM
kevinf's Avatar
Thanks for the quick response I guess I will have to wait for an update .
kevinf is offline
post #1853 of 2271 Old 03-05-2012, 04:20 PM
kingpcgeek's Avatar
Quoted: 53 Post(s)
Liked: 80
There will be no update for DTS-MA
post #1854 of 2271 Old 03-08-2012, 04:49 AM
Loubut's Avatar
I think its greed, rather than ability (ie, somebody who owns a 'right' wants to be paid big amounts of money to allow WD to do this)
Loubut is offline
post #1855 of 2271 Old 03-09-2012, 07:20 AM
tim1_2's Avatar
The latest firmware seems to have fixed the movie thumbnail issue with pictures not showing up properly for your movie library. This may have been addressed in a previous firmware release, but I updated a few months ago and had to roll-back in order to get my thumbnails to work properly. Anyway, I don't have any issues with the latest firmware.
tim1_2 is offline
post #1856 of 2271 Old 03-09-2012, 11:06 PM
famous600's Avatar
Just hooked up an external drive for the first time. Any idea how I can get content info for the movies on the external? Seems like its only an option on the internal drive.
famous600 is offline
post #1857 of 2271 Old 03-10-2012, 06:07 AM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
It's the exact same process with USB disks as the internal drive...
post #1858 of 2271 Old 03-10-2012, 02:14 PM
cabinguy's Avatar
I'm just in the process of setting up the Live/Hub and I'm sorry if this has been asked before but I searched with no result.
My problem is I can't seem to find a way to show music listed by artist without it lumping all of the "The" bands together. IE The Band, The Clash, The Rolling Stones are all listed under the letter T.
I know I can just rename the folders and have the "The Rolling Stones" listed under "Rolling Stones" but somehow "The Church" listed under "Church" just does not seem right.
cabinguy is offline
post #1859 of 2271 Old 03-12-2012, 05:30 AM
tim1_2's Avatar
A two-part question regarding the built-in Twonky server for the Live Hub:
1) Do people have much success with this? I want to enable the Twonky server on the Hub, and then watch my media on a different TV, through a Sony Blu-Ray Player. I haven't set this up yet, but I understand that the Sony BR player is compatible with Twonky.
2) Has anyone enabled the Twonky server on their hub, and then used an App on an iPhone or iPad to access their media? I'm guessing this likely isn't possible? According to App Store reviews, the official Twonky app stinks, but it looks like PlugPlayer may do the trick? http://www.plugplayer.com/
That's it for now, thanks.
tim1_2 is offline
post #1860 of 2271 Old 03-12-2012, 05:52 AM
WDFan1970's Avatar
Quoted: 158 Post(s)
Liked: 51
(snip)...
Keep in mind the Twonky Server does not transcode. So the media Twonky is serving must be compatible with the app or device that's receiving it.
So if your Sony BD player can play the files you have via DLNA, then you'll be fine.
I've used Buzz Player for the iPad on occasion... It does work, but again, the original files must be 100% iPad compliant (meaning MP4 / h.264 video and AAC or MP3 audio in either a MOV or MP4/M4V container.)
