*Official* MyMovies For Dune Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 06-05-2011, 09:00 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Originally Posted by lsarver View Post
You can flag movies as watched in CM (Personal Data or whatever it's called). I don't think the flag is set automatically by the Dune. In any case, it's not exposed in the interface, AFAIK. (Not to hijack the thread, but XBMC does both--automagically.)
I go back and forth between HTPCs and appliances like the Dune. PCs are so much more flexible and powerful, and can be made to do really cool things--if you've got the patience. I got fed up with DirectShow filter hell about a year-and-a-half ago and used the Dune pretty much full time. It just works. But 3-6 months ago, as the collection got harder to manage, I revisited XBMC, which can now use a central SQL database for all XBMC installations in the house. A huge benefit! And it doesn't slow down like CM. And Smart Playlists can access all metadata on-the-fly from the main screen, e.g., list all movies with John Wayne and a Russian soundtrack.
Lately, CM seems to have mind of its own. For example, I change local movie titles to match sort titles or add the years to the titles to distinguish versions, and CM will randomly revert them--just some, not all.
I found a way to segregate unwatched in Zappiti, but it's high maintenance.
Maybe I could get you to show me XBMC one day. We are close enough . My immediate concerns about it are it's playback engine. How close it gets to source direct, and how nicely it plays with my HTPC hardware.
GetGray is offline
Old 06-05-2011, 09:08 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Well, last night I went to watch a freshly ripped movie "Due Date". Dune wouldn't play it. Says "loading", display goes to 00:00:00 and sits there. Gave up, switched to HTPC and played from there. Played instantly and without error. When the movies was over, the Dune was still hung. Had to power cycle it to clear. .
I sure wish Kalidescape didn't have their "vault" and proprietary storage. They could make a boatload from all the frustrated HTPC/Dune/Sage/etc users. Oh well...
GetGray is offline
Old 06-05-2011, 09:17 AM - Thread Starter
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Keep in mind right now you cannot bitstream HD Audio with XBMC, you need to instead use a 3rd party player (which comes with its own list of instabilities).
With Due Date was it a full rip or a main movie rip?
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 06-05-2011, 09:31 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Ahhh Was too good to be true
Due Date was a rip via MM drop-and-rip. I have MM set to produce iso, but AnyDVD is set to remove trailers. I launched via Zappiti on the Dune.
GetGray is offline
Old 06-05-2011, 09:39 AM - Thread Starter
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Sounds like issues with BD Live most likely. I know the Dune folks mentioned they are looking to implement BD Lite which may help. Basically with BD Lite the Dune would just go and play the main movie without trying to access all the full disc features (thus avoiding your issue). I only rip the main movie though so I never have issues
Cheers,
Damian
Old 06-05-2011, 09:58 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Maybe that's it. I do have AnyDVD set to disable it FWIW. My AnyDVD settings look like this:
GetGray is offline
Old 06-05-2011, 11:27 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
A little OT, but as it appears to be the casue of some of the playback issues I'm having, I went to the WHS server console (real console, not remote) and noticed the AnyDVD settings were back to the default. Not set to strip the junk. Not sure what causes them to get lost. MM services are runing as the local system account, I'm not sure if the AnyDVD settings are a per user setting or not either. I did find the setting different if I log on as a user or as administrator, so I'm assuming its a per user setting. Wonder how to set the settings and make them stick for local system account?
GetGray is offline
Old 06-05-2011, 09:35 PM
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
A little tip for those of you with a small, fast, SSD as your boot drive, but you want your my movies program AND data files to reside on a different drive.
Stop all My Movies services using task manager
move the my movies directory structure under c:\\ProgramData to the drive you want
create a symbolic link in the original location pointing to the new, example
in the c:\\ProgramData directory do the following
mklink /d "My Movies" "d:\\ProgramData\\My Movies"
The last step is to reinstall the hidden share for d:\\ProgramData\\My Movies\\FileStorage
The share name should be MyMoviesFileStorage$
This saved me nearly 1.8GB of storage on my SSD boot drive and countless reads/writes.
mlknez is offline
Old 06-06-2011, 06:41 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Great tip. Didn't know you could do a sim link in windows.
GetGray is offline
Old 06-06-2011, 07:02 AM
nolesrule's Avatar
I think Microsoft calls em shortcuts.
nolesrule is offline
Old 06-06-2011, 07:27 AM
mlknez's Avatar
Quoted: 205 Post(s)
Liked: 52
A symbolic link is a pointer that works at the file-system level as opposed to a shortcut, which is a pointer designed to work within explorer.exe. Since a symbolic link is essentially grafted to the file system, it doesn't have a footprint, so to speak, whereas a shortcut is an actual file on the hard disk
mlknez is offline
Old 06-07-2011, 12:21 AM
lsarver's Avatar
Sure. It's easy.
auto: If you watch a movie (not sure how much), XBMC will set the watched flag automatically.
manual: If you select a movie in any list and access the context menu*, you can set or clear Mark as Watched manually.
*keyboard: c; mouse: right-click; remote: whatever button you like
Bitstreaming of compressed HD audio should be in the next release. (It already does DD, DTS and PCM.)
Video is another matter: so far XBMC does DXVA (and/or Crystal HD) and auto-adjusts framerate (and may control luma levels); the rest is up to your video driver.
Actually this concern has me currently revisiting DS filters, specifically LAV Splitter, LAV Filter and LAVCUVID. Until XBMC supports this stuff natively, I was thinking about using MPC-HC as the video player within XBMC. Sort of kludgy, I know. . . . but I did this before XBMC supported Blu-ray.
Just so I'm not completely off-topic, does anyone know whether Dune might add Source Direct in a future firmware? It's the only major feature still lacking (as distinct from bugs).
DViCo managed to do it (sort of) in late firmware for the TViX M-6500A (8635), so it is possible on Sigma SoCs.
lsarver is offline
Old 06-07-2011, 07:28 AM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
I asked them at cedia and they said they were looking into it. But I got the distinct impression it was not high on any priority list. Also voted on their feature request thing but don't think it got a lot of attention there either.
GetGray is offline
Old 06-18-2011, 11:51 PM
timbreb's Avatar
ok so I'm a dunce.... Can't get anything to work.
Trying to get a Dune HD D1 to work with my movies.
Do I want to get a usb flash drive to store the index on? How do I format it correctly for the dune?
Once I do that how do I get the index to go on the dune? I have tried putting the flash drive that I have now in the computer that the mymovies collection manager is running on, tried accessing it across the network from my laptop..
no matter what I do when I go to try and configure the paths for the folders of movies it tells me that I have to directly hook the drive to the dune.
WHat the heck am I doing wrong?
timbreb is offline
Old 06-19-2011, 09:21 AM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
When you point MM to your movies, use the network path instead of a drive letter. Like //server/sharepath/movie/movie.iso instead of D:\\movie\\movie.iso
ScottJ is offline
Old 06-19-2011, 10:21 AM
timbreb's Avatar
Now are you talking about when I rip the movies to the comupter or when I set up the meta-data for the dune?
When I try and configure the paths in the setup for the metadata it won't give me the option of anything other than directly having the share connected to the dune. From the instructions it looks like I should have a couple of radio button options that I don't have on the tab (no SMB or UPNP)
timbreb is offline
Old 06-19-2011, 11:44 AM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
For each movie in MM, click the little disc button to bring up the list of discs. Then click something else (sorry, I don't have it in front of me right now) to tell MM where this movie is. There, you should use the network path.
ScottJ is offline
Old 06-19-2011, 12:09 PM
timbreb's Avatar
oh shoot... that's going to take some time to correct. Already have 160+ movies ripped all using local structure.
is there an easier way?
timbreb is offline
Old 06-19-2011, 03:03 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Iirc when you update one of them, MM will ask if you want to update all of them.
ScottJ is offline
Old 06-19-2011, 03:35 PM
timbreb's Avatar
I wish that was the case. I must be doing something wrong becasue it is only letting me update one at a time then it has to save it and is going very slow.
Is there another spot to change it? I am going into each movie and clicking on the little disc in the center of the page that gives me the path to the movie.
timbreb is offline
Old 06-19-2011, 04:15 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Maybe if you moved all your movies to a different directory, then when you update one, MM will see that they've all moved and offer to update all of them.
I'm kinda guessing here but it's worth a shot. I don't know of a better way.
ScottJ is offline
Old 06-19-2011, 06:28 PM
timbreb's Avatar
I feel like an idiot.
So I got it to finally see the metadata and I can see a listing of my movies on the screen but...
it won't play them. Comes up with an error like it can't access the folder. I have zero passwords and no firewall at the moment trying to get this working. Have it using my account name which is a admin account.
ARGH
oh and I can't add the shortcut for my movies to the home screen. says something about can't create shortcut.
timbreb is offline
Old 06-19-2011, 09:52 PM
timbreb's Avatar
So the actual error message that i am getting is.
Failed to open URL. Then it list the whole network location of the movie.
Does this have anything to do with how my system is set up it no passwords?
timbreb is offline
Old 06-20-2011, 04:00 AM - Thread Starter
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
ARGH
You need to have system storage and running a later fw in order to add shortcuts
Sounds like your paths are incorrect, can you confirm exactly what they look like in Collection Management
Cheers,
Damian
Old 06-20-2011, 08:25 AM
absolootbs's Avatar
Quoted: 18 Post(s)
Liked: 27
make sure that (assuming media and index are on the same smb server) they're both contained in the same share. i believe thats the error message you get when you attempt to access a second smb share from a single server.
absolootbs is offline
Old 06-20-2011, 08:54 AM
timbreb's Avatar
I'm not in front of my home computer at the moment. but if I remember correctly in collection managment the path looks something like \\\\desktop\\g\
ame of movie
the error that is showing on the dune has something to the effect of smb=Timbre:\\\\desktop\\g\
ame of movie
the media is on my desktop computer and the index is on a thumb drive in the dune. I suspect it has something to do with the login name and such but don't know why as I have no password requirements on the system
timbreb is offline
Old 06-20-2011, 09:08 AM
absolootbs's Avatar
Quoted: 18 Post(s)
Liked: 27
ah, yea, if the index is local then what i said doesn't apply. oh well, it was worth a shot.
Old 06-20-2011, 02:04 PM - Thread Starter
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Is anyone having success with TV Shows on the Dune/My Movies. It was sort of working previously. I updated to the latest WHS pre release and noticed that no new tv shows were added to the Dune Index (and even for the tv shows that were already there no episodes were showing). So I decided to delete my My Movies index and rebuild, and now no tv shows at all.
Cheers,
Damian
Old 06-27-2011, 06:50 AM
myraid's Avatar
Hello-
I have been using a Dune D1 for a few months now and it is great! I want to purchase a second one for our media room in our home, but had a few questions.
Presently, I am using My Movies and have my Index store on a USB stick inserted within the Dune unit. I am using Windows 7 to manage all of my DVD and Bluray rips with most stored on a RAID NAS setup. Is my only option to have the Index on my PC or can I add a second index to the new Dune? Is there anything I need to consider for either of these scenarios?
As well, I presently do not have a hard wire network run to the room where the new Dune will be located. Is anyone uing a Dune unit wirelessly and if so, how is the streaming? I can manage to run a line if needed, but was just wondering if anyone is using a Dune with a USB wireless adapter.
That is it for now and look forward to your insight.
Cheers.
myraid is offline
Old 06-27-2011, 06:56 AM - Thread Starter
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Originally Posted by myraid View Post
Hello-
Cheers.
I would think you could just copy the index from the one USB stick to a second USB stick. I keep my index stored on my server so both my Dunes can easily access that way.
As far as wireless, I would highly recommend just going wired and being done with
Cheers,
Damian
