Xbox360 media extender problem - AVS Forum
Old 05-02-2011, 07:21 AM - Thread Starter
rsoares28's Avatar
Hello, I just purchased a 4gb xbox 360 to use as a WMC media extender for my living room tv. The setup process was seemless, the xbox gave me a code and i entered it in WMC in my computer and WMC loaded up on my xbox in the living room.
First problem is i noticed a lag while navigating through the WMC and mediabrowser menus. Second problem, when i play any of my videos, which are all 1080p mkv's the picture quality is horrible, stuttering and kind of looks like streamed live video.
The source computer is an i5 2500k with an asus h67 EVO mobo, 8gb or ram, SSD for OS and a WD black 1tb for media.
The router is a 4port gigabit SMC WIFI N router/modem supplied by my cable company. Port 1 of the router goes to my my office pc as described above.....Port 2 of the router is connected to an 8port gigabit trendnet switch in my living room with connects to the xbox, ps3 and internet enabled tv.
Port 3 of the router is connected to a 5port Dlink Gigabit switch in my bedroom connected to a networked bluray player
Port 4 is connected to an ethernet wall plate is another bedroom but nothing is connected to it.
My ps3 currently streams the same 1080p videos perfectly with playstation media server so i dont think theres a problem with my network.
I read the realtek NIC's are giving problems with the xbox as an extender. I heard of people enabling Flow control, i checked and mine says enabled. Not sure what else to do
Any advice on how to fix this issue?
rsoares28 is offline
Old 05-02-2011, 07:39 AM
mbrodie617's Avatar
Try plugging the x-box directly into the router and not into 8port gigabit trendnet and see if this is the bottle neck. If this solves the problem, find a way to bypass the trendnet. It this does not solve the problem, the try another port.
Also, does the x-box have a gigabit or fast ethernet card in it or is this wireless? The device itself might be the bottleneck.
I have always found that when trying to stream HD, it is better to wire whenever possible rather than going wireless.
Gaming doesn't kill people! Crazy, pent up, overly agressive, repressed, gun wielding people kill people.
PSN ID: Mbrodie617
mbrodie617 is offline
Old 05-02-2011, 10:38 AM - Thread Starter
rsoares28's Avatar
Hello thanks for the reply.
I will try another port tonight. the xbox does not have gigabit ethernet. It can't be the switch because the ps3 which is also connected to it streams the same 1080p mkv's perfectly.
Old 05-02-2011, 12:21 PM
mbrodie617's Avatar
If that doesn't work and you find that the trendnet isn't the issue, try plugging the x-box into the PS3's port and see if it's the port itself.
You also might want to try swapping cables and see if this clears the issue up.
Lots of testing to be done to solve this one...
PSN ID: Mbrodie617
Logitech Harmony Xbox 360 Remote
