Ripping Blu-Rays II - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 980Likes
post #3871 of 10646 Old 08-21-2013, 05:02 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Here is your subs exported showing up on my MKV track...
And my original sub track on my MKV video track...
Killroy is offline
post #3872 of 10646 Old 08-21-2013, 05:04 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Originally Posted by itznfb View Post
What version of BDSup2Sub are you using? Mine is blank and I get WARNING: Problems during RLE decoding of picture OBJ at offset 0x003e1c0e when viewing the blank frames.
Version 4.0.0
Killroy is offline
post #3873 of 10646 Old 08-21-2013, 05:07 PM
itznfb's Avatar
Liked: 58
Originally Posted by Killroy View Post
Version 4.0.0
That's it... it's the damn version. BDSup2Sub 5.0.0 and earlier work perfectly. 5.1.0, 5.1.1 and the ++ version are all broken. Thanks for the help guys. I'm going to e-mail the developer this info.
Running Windows Home Server 2011 Evil Abandoned Edition
itznfb is offline
post #3874 of 10646 Old 08-21-2013, 05:11 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
That's why I don't upgrade apps unless there is something broken.
Killroy is offline
post #3875 of 10646 Old 08-21-2013, 05:43 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Just checked and mine is 4.0.0; it is the one that came in the Clown BD "package."
It will be interesting to see what's up with the ++ versions ...
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #3876 of 10646 Old 08-21-2013, 05:48 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
I loaded itznfb's Avatar subs and got this. Did I do something wrong?
pepar is online now
post #3877 of 10646 Old 08-21-2013, 06:46 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I'm still struggling with this Avatar forced subs rip. Has anyone ripped Avatar successfully while maintaining forced subs only with the original Na'vi font? If so, how did you do it? The closest I've come is MakeMKV which at first I though ripped them correctly. However upon second look it actually ripped a time frame of where the Na'vi subs appear. So there are subtitles that show up saying (Speaking Na'vi). The mkv I have re-encoded with Handbrake and burned in forced subs works perfect but I'd like to figure out the process for doing this manually.
I have the .srt if you are interested. I extracted them myself with eac3to then processed the forced stuff with suprip.
DotJun is offline
post #3878 of 10646 Old 08-21-2013, 06:55 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
That's normal. Certain timings and graphics give the app the fritz.
Killroy is offline
post #3879 of 10646 Old 08-21-2013, 07:14 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Originally Posted by ogbuehi View Post
I am new to this so please forgive my questions if they seem noobish. I have a collection o f BR’s I would like to transfer to a HDD. I would like to be able to play the files with iTunes (mp4 if possible). But I’ll settle if the file will be playable by VLC or Cyberlink. I don’t need any of the menus or any of the extras. I’ve perused the thread but it’s fairly large at this point. From what I have been able to gather, I need a combination of software; AnyDVD and ClownBD? I’m getting a PC built by Origin to handle the horsepower, so if you have any advice on spec’s of the hardware, that would be appreciated as well. Thanks in advance.
1. Start anydvdhd
2. Start tsmuxer
3. Select your bd drive and then the correct mpls or m2ts file (usually the largest m2ts file)
4. Select what tracks you want to keep and choose either ts or m2ts for output type then hit start.
DotJun is offline
post #3880 of 10646 Old 08-21-2013, 07:21 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Originally Posted by jevans64 View Post
If you want to ruin the PQ/AQ of your movie, then you will need something like Handbrake.
*sigh*
DotJun is offline
post #3881 of 10646 Old 08-21-2013, 07:54 PM
itznfb's Avatar
Liked: 58
Jeff
I think the ++ are a fork of the original BDSup2Sub but they seem pretty buggy. The ones I was using kept freezing.
Thanks but once I downgraded my BDSup2Sub version it's been working great.
*sigh*
indeed
itznfb is offline
post #3882 of 10646 Old 08-23-2013, 08:25 AM
itznfb's Avatar
Liked: 58
Here is another question for the Clown_BD and mkvmerge group. How do you process LPCM audio? It appears tsMuxer may be capable of this and then remux via ffmpeg? Though I can't find anything in Clown_BD that allows you to save the original LPCM file. It seems to always convert it automatically. mkvmerge will officially never support LPCM according to the author.
I wonder what MakeMKV uses to mux LPCM since it seems to have no issue. I'm guessing ffmpeg?
itznfb is offline
post #3883 of 10646 Old 08-23-2013, 08:36 AM
artur9's Avatar
Quoted: 546 Post(s)
Liked: 186
When using makemkv, is there a way to get it to change the order of the soundtracks?
I'ld like to keep the lossless track, the lossy track, and a PCM track but I'd like the order to be lossy, PCM then lossless as I have several devices that can't play the lossless track and I don't want the kids to have to fiddle with it.
artur9 is offline
post #3884 of 10646 Old 08-23-2013, 09:33 AM
itznfb's Avatar
Liked: 58
I've never used the feature but here's a post from author: http://www.makemkv.com/forum2/viewtopic.php?f=10&t=4566
itznfb is offline
post #3885 of 10646 Old 08-23-2013, 09:46 AM
artur9's Avatar
Quoted: 546 Post(s)
Liked: 186
Wow! Thanks, I already have a profile for my device so this should be easy.
artur9 is offline
post #3886 of 10646 Old 08-24-2013, 03:20 PM
artur9's Avatar
Quoted: 546 Post(s)
Liked: 186
Worked great! I just went the my device's profile and adjusted the track weights. Now, a question about replacing the subtitles.
Right now I'm using this command to remove existing subtitles and adding a new one. Is it necessary to include the .sub or is using the .idx enough?
mkvmerge -S -o Big_Trouble_In_Little_China_t00.mkv Big_Trouble_In_Little_China_t00.mkv.old x17577.sub x17577.idx
artur9 is offline
post #3887 of 10646 Old 08-24-2013, 03:41 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Either way. If you just specify the .idx mkvmerge is smart enough to find the .sub.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #3888 of 10646 Old 08-24-2013, 09:19 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I'm guessing eac3to? Honestly I dont know smile.gif I usually convert PCM to flac.
DotJun is offline
post #3889 of 10646 Old 08-26-2013, 01:41 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Is MediaInfo the preferred app to analyze .m2ts and report audio and video specs?
Jeff
pepar is online now
post #3890 of 10646 Old 08-26-2013, 01:43 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
Jeff
I don't know about preferred, but it gives a full suite of information.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #3891 of 10646 Old 08-26-2013, 02:37 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
pepar is online now
post #3892 of 10646 Old 08-26-2013, 04:35 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Using Clown BD and converting some ISOs into M2TS, I noticed Se7en's DTS-HD MA being listed as "7.1 (strange setup)." Googling that gets me to, among other places, Doom9's eac3to forum/thread and something about "strange setups" not mapping correctly. I haven't watched the movie for a while, maybe never from the 7.1 Blu-ray, so I have no experience with incorrect mappings.
Anybody know anything about this? Perhaps I did something wrong when I originally ripped the BD and I should go back and redo it?
Jeff
pepar is online now
post #3893 of 10646 Old 08-26-2013, 04:42 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Jeff
Don't worry about it. The worst that will happen is that the center channel audio seems a little lower or the over all audio is about 10-15% lower than non-strange-setup 7.1.
Killroy is offline
post #3894 of 10646 Old 08-26-2013, 05:12 PM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
lol And that's acceptable? I still don't get why people spend any time on this 3rd party crap.
Gary J is offline
post #3895 of 10646 Old 08-26-2013, 05:29 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Try tsmuxer.
DotJun is offline
post #3896 of 10646 Old 08-26-2013, 05:44 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Try tsmuxer.
Don't feed the ...
DotJun likes this.
pepar is online now
post #3897 of 10646 Old 08-26-2013, 05:45 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
The Doom9 thread said something about surrounds/rear surrounds not mapping correctly. I'll re-read the posts ... and then pop the disc in and check how it sounds.
Jeff
pepar is online now
post #3898 of 10646 Old 08-26-2013, 05:57 PM
Killroy's Avatar
Quoted: 21 Post(s)
Liked: 64
Jeff
I've tested that bug and I was never ever able to re-produce it. I am able to reproduce the 7.1 FLAC bug in the Dunes that swap the rear-surrounds with the surrounds. But that is a bug in the Dunes not eac3to. The fix was actually quite easy and ingenious on my part...but that's for another thread.
Killroy is offline
post #3899 of 10646 Old 08-26-2013, 06:00 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Maybe DTS decoders remap on the fly? If eac3to can tell it's "strange" so could the decoders.
Jeff
pepar is online now
post #3900 of 10646 Old 08-29-2013, 05:53 AM
GPBURNS's Avatar
Quoted: 124 Post(s)
Liked: 283
I am wanting to rip my Dark Knight movies to a constant 2:35 aspect Ratio - basically looking to crop the IMAX screens - I have a CIH setup.
just wondering if anybody has done this and what software you have used. Thanks
15400 Watts of Seaton Power -Quad SubMersived
GPBURNS is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
