Ripping Blu-Rays II - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 1000Likes
Old 12-06-2011, 02:59 PM
Wireless member
pepar's Avatar
Quoted: 962 Post(s)
Liked: 511
I did my first BD rip with Clown et al and noticed that the generated ISO is named Clown_BD Temp, which is the name of the temp folder. Is there a way ... I'm sure there is .. to have the ISO named as the movie?
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
Old 12-06-2011, 03:03 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Jeff
Unfortunately no
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 12-06-2011, 03:16 PM
Wireless member
pepar's Avatar
Quoted: 962 Post(s)
Liked: 511
Originally Posted by dbone1026 View Post
Unfortunately no
More noob questions ...
Will a networked media player identify the movies automatically, or will I need to manually tag (right term?)?
pepar is online now
Old 12-06-2011, 03:21 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
What do you mean "tag"? Most of the players now should recognize that you have a Blu-ray folder rip and play as such (i.e. you won't have to navigate to all the sub folders). However, if you are talking about how it appears, that requires some sort of jukebox functionality.
Cheers,
Damian
Old 12-06-2011, 03:41 PM
ToSi's Avatar
Does a 2-click solution exist? Something along the lines of DVD Shrink (open disk, save desired portion to 'storage' format)?
Every 6mos or so, I start looking around but lose interest after finding out that multiple steps (rip this, convert that, strip, re-package, etc..) are still required.
ToSi is offline
Old 12-06-2011, 03:45 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Been several options for a while (anydvd, clownbd, dvdfab, makemkv, another eac3to gui, etc...)
Cheers,
Damian
Old 12-06-2011, 03:56 PM
Samuraijones's Avatar
There is software that allows you to lose all that stuff, so there doesn't seem to be a reason to do it manually .. if it's possible. With the software, it's a few mouse clicks before ripping. You should research Clown BD.
I know there is software to do this.
I am curious if anybody has ever tried to just delete the files manually. I mean you are talking about a 5 second delete as apposed to waiting an extra 30 minutes for software.
If only I knew more.
Samuraijones is online now
Old 12-06-2011, 04:01 PM
ToSi's Avatar
See post #1 in this thread & the shortcomings listed in points 1, 2, & 3.
ToSi is offline
Old 12-06-2011, 04:04 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Re read your original post buddy. All you asked for was a 2 click process. Also, the programs I mentioned don't require you to do repackaging manually, etc...
Cheers,
Damian
Old 12-06-2011, 04:38 PM
GamingDaemon's Avatar
Ok, I am a newbie, and I am still reading this thread, but I am more confused than ever before. All I would like to do is:
  • Put one of my Blu Ray discs in my "beast of a machine" gaming PC's ODD, and using AnyDVD, or some other tool, end up with a single file that I can copy to my Home Server PC. I want this file to contain the lossless video and audio from the movie (I do care about subtitles for my foreign flicks, but I don't have many of those).
  • Later, stream this file to my HTPC over my gigabit network for playback using WMC, XBMC, or something similar.
So, my questions are:
  1. What is the best/simplest/most efficient way to do this?
  2. What is the best file format? (I am guessing not .mkv because of its limited support)
Thank you in advance. And sorry that I couldn't grok all of the answers given for this already.
GamingDaemon is offline
Old 12-06-2011, 04:40 PM
Wireless member
pepar's Avatar
Quoted: 962 Post(s)
Liked: 511
I literally tried ripping for the first time, and am trying to wrap my head around the whole networked media server/player thing. I have not settled on what format the BDs/DVDs should be in. My first rip was to an ISO with main movie and lossless audio.
What form do you have your BD's in?
Jeff
pepar is online now
Old 12-06-2011, 04:43 PM
Wireless member
pepar's Avatar
Quoted: 962 Post(s)
Liked: 511
I must be missing something. How do you get the Blu-ray onto your hard drive where you can delete a file?
pepar is online now
Old 12-06-2011, 04:49 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
1) If you want the full disc (i.e. menus, trailers, etc...) you can use AnyDVD or DVDFab. If you want the main movie you could use AnyDVD + Clown_BD (my preferred), DVDFab, MakeMKV, etc...
2) mkv support has definitely picked up so it is not a bad choice. I personally just stick with folder rips
Here is a wiki I put together on Clown_BD as well as a quick disc rip wiki
Cheers,
Damian
Old 12-06-2011, 04:50 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Jeff
I keep mine as a folder rip. An ISO is essentially the same thing (basically the folder rip is contained in the single ISO file). Either method is fine. You should be fine with your main movie ISO
Cheers,
Damian
Old 12-06-2011, 05:11 PM
Cool! Thank you. I don't wan't want all of the trailers, etc., and jsut the movie, then I will use AnyDVD + Clown_BD. What is a folder rip?
Old 12-06-2011, 05:16 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
folder rip just implies keeping the same structure as the actual disc (as opposed to throwing into a contain like an mkv). With Clown_BD you can rip to a folder rip or folder rip + iso (so the folder rip just gets contained in one clean container). Eiter way should get you what you want
Cheers,
Damian
Old 12-06-2011, 05:43 PM
Originally Posted by elario View Post
No, the trial period is for the other modules. As far as I know the basic HD Decrypter function is free and works beyond the 30 day period.
Whe you rip to an iso and look at the structure ther are many folders and files. You will have to excuse me I am pretty new to all of this. I was just curious if any body had tried to manualy delete the file within an iso foder.
Old 12-06-2011, 05:47 PM
skro's Avatar
Quoted: 13 Post(s)
The thing is.... an ISO rip is a file, not a folder, so you would need some software that can read/parse that file. Thus, why not use the appropriate software to do the work?
skro is offline
Old 12-06-2011, 05:49 PM
Wireless member
pepar's Avatar
Quoted: 962 Post(s)
Liked: 511
Folders would seem to be the best way to organize a library. If that's true, then generating the folder with the ripping/converting software might be the best way to accomplish that. ??
pepar is online now
Old 12-06-2011, 05:50 PM
Wireless member
pepar's Avatar
Quoted: 962 Post(s)
Liked: 511
Sure, but the software that would put all of the files there could put there only what you want in the first place making manually deleting unnecessary.
pepar is online now
Old 12-06-2011, 05:52 PM
Ok. I think I would prefer to have all of this in a single container like an .mkv file, rather than trying to mount a a bunch of .iso files on my Home Server. Am I wrong?
And is .mkv the only container choice for lossless video and audio?
Old 12-06-2011, 06:01 PM
Av8tr's Avatar
I use ANYDVDHD and rip to folders, and then use BDRebuilder to compress a little resulting in a movie only iso file about 22GB. I have to use a streamer that streams iso's of course which are not that common and a bit expensive. Would it be difficult to convert the iso's to m2ts and stream with the less expensive streamers like WD Live?
Av8tr is offline
Old 12-06-2011, 06:19 PM
Makes sense thanks for the clarification.
Old 12-06-2011, 06:35 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
mkv or m2ts/ts/ However, with standalone m2ts/ts you lose chapters which is one of the reasons i prefer mkv for standalone files
here are some mkv guides i have put together
http://www.mediasmartserver.net/tag/mkv/
Cheers,
Damian
Old 12-06-2011, 07:02 PM
CruelInventions's Avatar
Quoted: 478 Post(s)
Liked: 599
I thought that would be true for any streamed file, including mkv? That you will lose the use of chapters??
That's a note I had made for myself some time ago.
CruelInventions is offline
Old 12-06-2011, 08:46 PM
ambesolman's Avatar
Quoted: 1079 Post(s)
Liked: 907
[*]Put one of my Blu Ray discs in my "beast of a machine" gaming PC's ODD, and using AnyDVD, or some other tool, end up with a single file that I can copy to my Home Server PC. I want this file to contain the lossless video and audio from the movie (I do care about subtitles for my foreign flicks, but I don't have many of those).[*]Later, stream this file to my HTPC over my gigabit network for playback using WMC, XBMC, or something similar.
[*]What is the best/simplest/most efficient way to do this?[*]What is the best file format? (I am guessing not .mkv because of its limited support)
This is basically my issue as well. I ripped a BD (cars 2) with dvdfab: bluray copy: main movie, but because that part of the trial had expired it said it would use HD decrypter. You know what I ended up with. VLC plays some but not all the BDs I've ripped and WMC won't play any because it won't support whatever it's ripped as (AVCHD). I just want to rip it as one file to click on (?) with HD video and audio and play it via Hdmi to my receiver so I can watch it on my HT. Do I need a different player as well? It'd be nice if I could get everything working for free since I'm broke. And please dumb down any advice, I don't get this computer stuff. Thanks!
ambesolman is offline
Old 12-06-2011, 09:20 PM
Ok, thank you. I've been playing with MakeMKV and Clown_BD since your last post. Your WIKI's are awesome!
But -you knew there was going to be a "but" -MakeMKV costs money, I don't know how much, and Clown_BD is working as I type this so I do not know what it will produce yet. Is there a free app that makes a file will lossless video and audio? Is that BluRip? I am downloading that as I type too.
Old 12-06-2011, 09:21 PM
streamerlover's Avatar
I thought Makemkv was still free while in beta? I just downloaded it last week...
streamerlover is offline
Old 12-06-2011, 09:42 PM
It says "This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start the evaluation period now?"
Their grammar, not mine.
This is when I point it to the Blu Ray files copyied to my hard drive by AnyDVD HD.
Old 12-06-2011, 11:16 PM
So from my initial testing, only MakeMKV allows the final file to include chapters, but I could be wrong. Clown_BD seems to recognize that there are chapters, but doesn't include them in the final .ts file.
So MakeMKV seems like the best option.
Anyone else know of a good (free) program to convert the raw .m2ts Blu Ray files into a .mkv or .ts file container for all of the video and audio?
EDIT: Found the beta key for MakeMKV so I am set. Now I get lossless video, audio and chapters quickly and easily. Thank you all!
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
