Ripping Blu-Rays II - Page 206 - AVS Forum | Home Theater Discussions And Reviews
 997Likes
post #6151 of 10693 Old 07-11-2014, 06:36 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
I'm officially annoyed. I'm able to encode MKV to MKV (it plays fine via MPC-HC) but still no encode from MKV to MP4 (error code). It was working this morning but gave up on me. Any ideas?
jhughy2010 is offline
post #6152 of 10693 Old 07-11-2014, 08:29 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2760 Post(s)
Liked: 1990
There is a free utility called mediainfo. Get the text output for (1) the original MKV file, (2) the MKV from HandBrake, and (3) the MP4 from HandBrake.
I believe mkvmerge will accept MP4 input and produce MKV output. It would be interesting to see if the resulting MKV plays. That would indicate a problem with the MP4 container, or lack of support for certain codecs or options in that container.
-Bill
jhughy2010 likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6153 of 10693 Old 07-11-2014, 08:39 PM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 96
How big are the .mp4 files when you are done? If they are lager than 4GB, then you'll have to enable large file support or they won't playback on anything.
smitbret is offline
post #6154 of 10693 Old 07-11-2014, 10:34 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
-Bill
Thanks for your response but I'm thinking smitbret hit the nail on the head.
Thank you thank you. This has to be the solution (tried encoding on my HTPC vs laptop with same results).
Avatar was 10GB and Man of Steel was 9GB. Perhaps I can try to get smaller? (What setting do I adjust on handbrake?)
post #6155 of 10693 Old 07-12-2014, 02:46 AM
SeeMoreDigital's Avatar
Quoted: 468 Post(s)
Liked: 197
As mentioned previously by Bill. Please run your 'problem' .MP4 file through an application called MediaInfo set to text mode. And post what it reports, IN FULL as a text (.txt) file?
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
I've been testing hardware media playback devices and software A/V encoders and decoders since 2001 | My Network Layout and A/V Gear
SeeMoreDigital is offline
post #6156 of 10693 Old 07-12-2014, 06:44 AM
wmcclain's Avatar
Liked: 1990
There is a Large File MP4 checkbox in Handbrake. The problem is described in the FAQ: https://trac.handbrake.fr/wiki/SupportFAQ#fourgb
-Bill
post #6157 of 10693 Old 07-12-2014, 10:31 AM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Thanks for your help, however, the large file checkbox did the trick.
-Bill
Thanks for your advice... this is precisely what was the issue. Avatar compressed nicely down to 10GB from 37GB. I'm thinking that is a very huge encode, however, the video looks decent so I may keep it for my tablets.
post #6158 of 10693 Old 07-12-2014, 11:12 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
What version of Handbrake are you using? I haven't seen that Large File check box in quite a few releases. A lot of those configurations are done automatically now. If you're running v 0.9.9 or newer I'd be confused as to why you have that check box and I don't...
techmattr is offline
post #6159 of 10693 Old 07-12-2014, 04:40 PM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 96
It's there, right below the Destination field, v0.9.9.5530.
smitbret is offline
post #6160 of 10693 Old 07-12-2014, 04:52 PM
Colby66's Avatar
Open Blu-ray ripper 2 BD software
Newbe to the forum and am looking for information/experiences/reviews on the "Open Blu-ray ripper 2" software. I assume it would be in this forum but doing a search of such produced nothing. Is there a better forum I should be looking in?
Colby66 is offline
post #6161 of 10693 Old 07-12-2014, 05:18 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
I had the nightly builds installed on my C: drive and I uninstalled and installed 0.9.9.5530 yesterday. Apparently when I did that some or all of the settings/GUI configuration carried over from the nightly. I uninstalled and reinstalled a couple times and still didn't have the Large File check box. I uninstalled and installed to D: instead and there it is. I see the check box now. Very strange considering it deletes everything out of the program files folder. So it's just the nightly builds that don't have that check box. Sorry for the confusion
post #6162 of 10693 Old 07-12-2014, 10:02 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
I'm just curious but why did you opt to not use the nightly build? So far it is working ok for me I am on my third encode using H264 QSV. Only "Life of Pi" failed on me but I'm not sure why that happened. Trying it again soon (it's now at the end of my queue).
post #6163 of 10693 Old 07-12-2014, 10:23 PM
johnBlanker's Avatar
Quoted: 410 Post(s)
Liked: 68
Is there any free software that allows you to identify discs that have seamless branching files? I used to use dvdfab passkey with bdinfo but the passkey was only a 30 day trial. Bdinfo wont work without software like slysoft anydvd. It helps to streamline ripping if i know there are multiple m2ts files before i rip. Thanks
johnBlanker is offline
post #6164 of 10693 Old 07-13-2014, 05:14 AM
wmcclain's Avatar
Liked: 1990
Is it enough to see that the playlist has multiple M2TS files? MakeMKV will do that. You click on the various components of the title and it will display info about them.
-Bill
post #6165 of 10693 Old 07-13-2014, 05:27 AM
wmcclain's Avatar
Liked: 1990
Try here: Ripping Blu-Rays II
-Bill
post #6166 of 10693 Old 07-13-2014, 07:23 AM
Quoted: 410 Post(s)
Liked: 68
-Bill
Didnt know makemkv will do that. Gotta give it another look. Thanks
post #6167 of 10693 Old 07-13-2014, 09:02 AM
Colby66's Avatar
-Bill
Colby66 is offline
post #6168 of 10693 Old 07-13-2014, 01:40 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
I use the nightly builds for most things but it has some weird banding issue with VC-1. So I switched back to the .9.9 release to re-encode VC-1. I typically use Ripbot for VC-1 content but didn't have it setup.
post #6169 of 10693 Old 07-13-2014, 09:07 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Do either of those apps allow you to encode to 10bit? That will help out your banding issue.
DotJun is offline
post #6170 of 10693 Old 07-14-2014, 02:24 AM
Quoted: 468 Post(s)
Liked: 197
Personally, I would not recommend doing this...
If at some time, you decide to play your 10-bit encodes using a hardware media player (ie: STB, Blu-ray player, Smart TV, etc) - they wont work.
EDIT: Any software media player which offers GPU decoding, won't decode 10-bit encodes using the GPU. They will decode using the CPU.
post #6171 of 10693 Old 07-14-2014, 08:54 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
No idea. They are still working out issues with the decoder. Not a concern since I should be using Ripbot for VC-1 anyway.
post #6172 of 10693 Old 07-16-2014, 09:08 AM
hifiaudio2's Avatar
Quoted: 374 Post(s)
Liked: 110
Anyone looked at Grand Budapest? Makemkv reports 4 titles with different "angles" to choose from. All are the same MPLS file but different segment maps. Makemkv chose the first one by default and unchecked the others. Normally it doesn't uncheck anything for me by default. How do I know what to choose?
hifiaudio2 is offline
post #6173 of 10693 Old 07-16-2014, 09:32 AM
ScottJ's Avatar
Quoted: 299 Post(s)
Liked: 152
I ripped this last night using ClownBD. It lists the m2ts files that make up each angle. I looked for where the files differed, and played those m2ts files to see. The angles are used for different languages for the on-screen text (credits, newspaper headlines). The first one is English.
This is the first movie I've seen with multiple angles like that, and I've ripped 1400+. Usually (Disney) they use multiple playlists instead of one playlist with multiple angles.
ScottJ is online now
post #6174 of 10693 Old 07-16-2014, 09:38 AM
hifiaudio2's Avatar
Quoted: 374 Post(s)
Liked: 110
post #6175 of 10693 Old 07-16-2014, 06:11 PM
thehun's Avatar
Quoted: 647 Post(s)
Liked: 536
Originally Posted by kneedragger View Post
Been ripping my DVD and Blu-rays for years and went back to re-rip my Blu-ray so i can have the HD track. Does anyone know if it's possible to have everything unchecked after it initially reads the disc with makeMKV?
Yes
De sagittis Hungarorum libera nos, Domine!
The Hun
thehun is offline
post #6176 of 10693 Old 07-16-2014, 06:55 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Since you only got a simple "yes" answer I'll provide the instructions
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=1377
kneedragger likes this.
post #6177 of 10693 Old 07-16-2014, 07:04 PM
kneedragger's Avatar
Quoted: 18 Post(s)
kneedragger is offline
post #6178 of 10693 Old 07-17-2014, 12:08 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I'm pretty sure he breaks hardware compatibility with his choice of encoding parameters anyway so he might as well go 10 bit to make it look even better while also compressing even more.
DotJun is offline
post #6179 of 10693 Old 07-19-2014, 07:04 AM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
Having recently put all my CDs losslessly onto a hard drive, I thought I would investigate doing this with my blus.
However, I have 1200 blus and I find new ones that I want just about every week.
So am I right to think if I wanted to do this I would need 40Tb of hard drives and it would take countless hours and after putting say $2000 into it I would have ,... Well,... More or less pretty much what I had to begin with.
I'm interested but it really doesn't seem worth it.
Brian Hampton is offline
post #6180 of 10693 Old 07-19-2014, 08:01 AM
Wireless member
pepar's Avatar
Quoted: 931 Post(s)
Liked: 507
If you look at it as a task that must be started and completed, then that is daunting indeed. But assemble the server and then rip your new purchases as they are acquired. And rip your existing titles just in advance of you wanting to watch them. Or do 10-20 at a time ... from your go to titles that you watch repeatedly. Aren't there *some* titles that you never or rarely watch? If so, rip them last or not at all until you want to watch them. IOW, break down the daunting task into smaller easy to digest bites and prioritize.
Or sequester yourself in your room with several cartons of K-cups and don't come out until you are done.
Jeff
pepar is online now
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
