Ripping Blu-Rays II - Page 211 - AVS Forum | Home Theater Discussions And Reviews
 2253Likes
post #6301 of 10958 Old 08-20-2014, 04:53 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
Originally Posted by jhughy2010 View Post
I've been having a miserable time with Handbrake nightly build (using QSV). Has anyone else given up trying to get a film encoded via QSV? I really am skeptical of the quality as well.
Anyhow, reverted back to a stable build and am using x264 (nice and slow).
Quality/Size ratio for QSV is terrible. With the latest Intel drivers and a Haswell you can get decent results but you have to use average bitrate instead of constant quality. If you use constant quality and set the quality to what you normally would the file will be at least double in size. Definitely larger than the source. Plus you'll have bitrate spikes. Whenever I tried constant quality I've always had it spike to at least 60Mbps. Anything with a lot of fast movement it typically gets up around 5~6Gbps and it obviously becomes unplayable when you hit those spikes. The last one I tried was an episode of Under the Dome and the source was about 5GB, constant quality was set to 20, 1080p and I ended up with a 96GB file. Looked terrible compared to the source. I re-ran it with standard x264 with the same settings and I get a 2GB file and the quality not noticeably different from the source. I'll sometimes use QSV for shows like Whose Line is it Anyway where I don't care about the quality. I just want to shrink it down a bit and convert from mpeg2/interlaced to AVC/progressive. Quality is definitely terrible though. QSV is no where near ready for prime time Blu-ray re-encoding. Unless you want all your rips to look like Yiffy encodes. But yeah.... try QSV with average bitrate and see if you get better results.
DotJun and jhughy2010 like this.
techmattr is offline
post #6302 of 10958 Old 08-20-2014, 11:04 PM
DotJun's Avatar
Quoted: 585 Post(s)
Liked: 159
Ripping Blu-Rays II
Would tweaking vbv buffer/bitrate (rate control) help this situation out?
Edit: help out the bitrate spikes I mean.
DotJun is offline
post #6303 of 10958 Old 08-21-2014, 11:18 AM
mike_carton's Avatar
Liked: 26
I tried Handbrake Main profile with Constant Quality at 20 on a 1080p file (AVC in MP4 with AAC) and produced H.265 in MP4 with audio copied through. The 5:30 min file took 8+ hours, wasn't that great and nearly doubled in size.
Yesterday I tried MediaCoder (apparently free) with same file. When I chose for the file to be processed in 4 parallel segments, it took ~25 min and reduced file size by 45%. No obvious degradation.
Need to try more samples (with both tools).
mike_carton is offline
post #6304 of 10958 Old 08-21-2014, 01:03 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Yesterday I tried MediaEncoder (apparently free) with same file. When I chose for the file to be processed in 4 parallel segments, it took ~25 min and reduced file size by 45%. No obvious degradation.
That sounds promising. I'd like to stick with handbrake because I'm used to it... I like what I have seen so far while compressing a few kid shows to H.265 but they took FOREVER (like 10+ hours).
I used the default settings: profile is none, tune is none, preset is set to veryfast, constant quality to 20... also, presets is "high profile" (on right side of screen).
What are some of the differences with "Tune" and "H.265 Profile"?
jhughy2010 is offline
post #6305 of 10958 Old 08-21-2014, 01:23 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
I did a quick 60 second sample of "The Jungle Book" (about half way through the film):
x264 - 30 MB
QSV H.264 - 71.8 MB
H.265 - Preset VeryFast - 24.6 MB, Preset Slow - 21.6 MB
No noticeable difference in PQ or overall quality. I think out of the three x264 is still the top pick due to compatibility at this point. Those results were all utilizing default (except high profile) in the video settings.
post #6306 of 10958 Old 08-21-2014, 01:31 PM
elario's Avatar
Quoted: 43 Post(s)
Liked: 66
Tune PSNR or SSIM tune the encoder to produce an output that looks worse but performs better according to these metrics. It exists so you can fairly compare the encoder with other encoders that are already optimized for these metrics. It shouldn't be used otherwise.
Profiles are basically defined levels of feature-set complexity. Higher profiles add in more stuff.
http://en.wikipedia.org/wiki/High_Ef...oding#Profiles
You shouldn't stray far from the medium preset, it's called medium for a reason. The faster presets provide worse compression, which goes against what you are trying to achieve with HEVC.
elario is offline
post #6307 of 10958 Old 08-21-2014, 05:10 PM
Liked: 26
I'm doing this out of curiosity about the progress of H.265 encoders. Which is why I'm avoiding animated clips as I suspect they're less challenging for encoders. If you're planning on actually using this, I suspect leaving the original file untouched is the best option followed by transcoding to H.264.
The file I mentioned above I coverted to H.265 again (same bitrate and format as above), this time using VLC; it didn't offer a choice of profiles. Took 28 minutes and produced a 35% smaller file. Even VLC itself won't play the video probably because the FourCC is hvc1 (Handbrake and MediaCoder are using hev1)
Next up: Try uncompressed 1080p AVI clip of 1 minute or so, if I can find such a thing on the web.
post #6308 of 10958 Old 08-21-2014, 05:39 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
The file I mentioned above I coverted to H.265 again (same bitrate and format as above), this time using VLC; it didn't offer a choice of profiles. Took 28 minutes and produced a 35% smaller file. Even VLC itself won't play the video probably because the FourCC is hvc1 (Handbrake and MediaEncoder are using hev1)
Nice! Keep experimenting and report back.
post #6309 of 10958 Old 08-22-2014, 04:13 PM
Liked: 26
The tool I've been trying out is MediaCoder, not MediaEncoder. Will edit the previous posts to reflect that.
post #6310 of 10958 Old 08-23-2014, 08:07 PM
DotJun's Avatar
Quoted: 585 Post(s)
Liked: 159
8 hours? Either it's nowhere near ready for mainstream or our hardware hasn't caught up yet. I remember the same thing happening when x264 came out.
Please tune to a metric for comparison as it makes things so much simpler.
Yep, I think I asked many posts ago to tune to either metric for ease of comparison. Really should also preset to medium. Actually, x264 defaults to medium so you shouldn't even have to specify a preset.
One more thing, maybe should set an avc level (though my vote goes for unrestricted) because I don't know how handbrake sets other parameters when the testers are using different levels.
DotJun is offline
post #6311 of 10958 Old 08-24-2014, 04:23 AM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
Anyone here prefer 720p rips over 1080p rips? To my eyes, 720p looks very good, and the other benefit is that it's a much smaller file size than a 1080p rip. I'm only watching on a 42" TV from ~6ft away, so I guess 1080p really is not beneficial to me anyway. I'm pretty sure 720p is the native resolution of my TV also.
hogger129 is offline
post #6312 of 10958 Old 08-24-2014, 09:59 AM
Wireless member
pepar's Avatar
Quoted: 1059 Post(s)
Liked: 549
If true, then your last sentence is probably the limiting factor in you seeing a dif between 720p and 1080p on your display.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #6313 of 10958 Old 08-24-2014, 09:21 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Originally Posted by DotJun View Post
Yep, I think I asked many posts ago to tune to either metric for ease of comparison. Really should also preset to medium. Actually, x264 defaults to medium so you shouldn't even have to specify a preset. One more thing, maybe should set an avc level (though my vote goes for unrestricted) because I don't know how handbrake sets other parameters when the testers are using different levels.
I don't see an AVC level setting in Handbrake (I just downloaded latest version.... not the nightly build though). Also, what would be the difference between medium and slow for preset?
post #6314 of 10958 Old 08-24-2014, 11:08 PM
funhouse69's Avatar
Quoted: 484 Post(s)
Liked: 154
I rip my Blu-Rays depending on the movie itself, something that is very visually appealing I rip full resolution and others I will down-res them to 720p using DVD Fab which does a really nice job. I have a 55" Sharp and sure there is a difference but I honestly don't think the average person would notice and for the storage space savings I am ok with it.
So I would say that I rip maybe 1 out of 10 movies full 1080p which is the native resolution of my TV.
Keep in mind that a very large percentage of HD Channels are still only 720p and I think that most of them look pretty good on FIOS.
One could also argue that you have to think of the future, more than likely you will get a larger TV at which time you might notice the difference more / wish you ripped them at 1080p? Since we all have our originals discs you can always go back and re-rip them =)
funhouse69 is offline
post #6315 of 10958 Old 08-25-2014, 12:37 AM
DotJun's Avatar
Quoted: 585 Post(s)
Liked: 159
Ripping Blu-Rays II
You can look up all the options here: http://mewiki.project357.com/wiki/X264_Settings
Just stick to medium preset with ssim or psnr tune then post the results. We aren't trying to optimize settings, just comparing between the different encoders on equal footing. thank you for all your time btw.
Edit: if you find that encoding is really interesting, might I also suggest checking out avisynth and megui as your encoder GUI over handbrake? I'm biased towards megui cause handbrake gave me a headache when I tried using it years ago
DotJun is offline
post #6316 of 10958 Old 08-25-2014, 12:18 PM
Wireless member
pepar's Avatar
Liked: 549
What is the best way to extract the audio from a Blu-ray Audio? Convert to what format? With what tool?
pepar is online now
post #6317 of 10958 Old 08-25-2014, 12:34 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3326 Post(s)
Liked: 2596
What's the purpose? Do you need to retain the original quality?
DVDFab has audio extraction and conversion under the Blu-ray Ripper module. I've used it to convert commentary tracks to mp3 for offline listening.
I'm trying to get away from DVDFab. I believe ffmpeg will do it, but I haven't set up scripts yet. I'd be starting from an MKV file created with MakeMKV.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #6318 of 10958 Old 08-25-2014, 12:40 PM
dbone1026's Avatar
Quoted: 232 Post(s)
Liked: 116
-Bill
You can also extract the audio using ClownBD
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #6319 of 10958 Old 08-25-2014, 01:06 PM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
-Bill
The reason ?
thestewman is offline
post #6320 of 10958 Old 08-25-2014, 01:22 PM
Wireless member
pepar's Avatar
Liked: 549
Yes, definitely.
Any special settings, or just run it through the paces as with a regular Blu-ray?
Thanks, guys!
pepar is online now
post #6321 of 10958 Old 08-25-2014, 01:27 PM
wmcclain's Avatar
Liked: 2596
Originally Posted by thestewman View Post
The reason ?
For what? Getting away from DVDFab? Recent developments in their business make the product less appealing than before.
-Bill
post #6322 of 10958 Old 08-25-2014, 01:44 PM
dbone1026's Avatar
Quoted: 232 Post(s)
Liked: 116
Yes, definitely.
Thanks, guys!
No special settings. You can just run it like you would a blu ray and de select and of the video stuff so you only get the audio tracks
Cheers,
Damian
post #6323 of 10958 Old 08-25-2014, 06:41 PM
DotJun's Avatar
Quoted: 585 Post(s)
Liked: 159
Eac3to is easy and will allow you to convert to many other formats.
DotJun is offline
post #6324 of 10958 Old 08-26-2014, 07:10 AM
Wireless member
pepar's Avatar
Liked: 549
Thanks. How does DTS-HD MA or TrueHD convert to FLAC ... losslessly? I must confess that I know jack about cinema formats other than to simply let my pre/pro decode them. BD Audio streamed from a file is new territory..
But maybe I should keep it as an ISO/folder structure and stream it via my Popcorn?
Jeff
Edit: quick googling results in forum posts about eac3to not incorporating the lossless part of DTS/Dolby formats .. only the cores. Still googling ...
pepar is online now
post #6325 of 10958 Old 08-26-2014, 07:13 AM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
I've kinda given up on H.265 it takes so long to even do a five minute clip. ATM I am encoding a ton of my collection to x264 (not QSV) and putting in on an external for travel. I have been bouncing back and forth with slow and medium. Everything else pretty much default except audio is to stereo. Would slow make for a smaller file size?
post #6326 of 10958 Old 08-26-2014, 10:25 AM
Brian Hampton's Avatar
Quoted: 584 Post(s)
Liked: 312
If I'm ripping Blus that I own and I own 1500 of them....
Should I use Raid 5 ... or just let the discs themselves serve as a backup and not use any type of Raid?
... One advantage if I decide not to do the raid backup notion is I can add the drives as I can afford them rather than saving up for 4 drives at a time type thing. Another advantage is 20% more storage capacity.
The major dis-advantage is the possibility of having to re-do 100+ movies... and also the mess of trying to salvage data from a bad drive .. I guess that's not really a big deal though is it... maybe when the drive if found to be faulty I can save 80% or more of the data ....
=Brian
Brian Hampton is offline
post #6327 of 10958 Old 08-26-2014, 11:59 AM
smitbret's Avatar
Quoted: 325 Post(s)
Liked: 99
Thank goodness..... since .h265 really has nothing to do with Ripping Blu-Rays anyway.
pepar likes this.
smitbret is offline
post #6328 of 10958 Old 08-26-2014, 12:03 PM
smitbret's Avatar
Quoted: 325 Post(s)
Liked: 99
=Brian
This was my quandry, too. I really hate the idea that I will need to re rip all of the DVDs and BRs if something crashed. Not to mention the fact, that I have compressed most of them over the last few years. I tend to cut 1080p down to about 8-12GB and 720p to about 6GB since I really don't see a difference at these sizes unless I know to look. I don't back them up since I figure the original discs are the backup. But I figure it's EASILY worth the extra $100 to know that I probably will never have to re rip/re encode them. It takes about 30-45 minutes to rip a BR and depending on the quality it can take 2 hours to 18 hours for me to do an encode. It only takes a couple dozen BRs before the $100 for a HDD and $60 for my FlexRAID software license looks like a great investment.
As far as expanding the array goes, this is one reason I went with FlexRAID instead of a Hardware RAID or ZFS RAID solution. It allows me to add new HDDs without breaking up the array and losing data. I just throw a new one in every year that falls into the $/GB sweet spot (right now that is 3TB) and my array grows.
smitbret is offline
post #6329 of 10958 Old 08-26-2014, 12:05 PM
Wireless member
pepar's Avatar
Liked: 549
Re-encoding has nothing to do with Ripping Blu-rays," period. I would be in favor of a thread dedicated to "re-encoding" ...
My $.02.
Jeff
smitbret and javanpohl like this.
pepar is online now
post #6330 of 10958 Old 08-26-2014, 01:36 PM
dbone1026's Avatar
Quoted: 232 Post(s)
Liked: 116
=Brian
I just do JBOD and use Stablebit drivepool to make everything appear as one large pooled drive. You can enable their redundancy feature which essentially gives you software RAID 1, but the benefit being you don't have to mess around with RAID and can add any types of drives you want . Obviously not the most efficient use of space but I am ok with
Cheers,
Damian
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
