Ripping Blu-Rays II - Page 213 - AVS Forum | Home Theater Discussions And Reviews
 2253Likes
post #6361 of 10958 Old 08-28-2014, 08:16 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Originally Posted by KMFDMvsEnya View Post
I would appreciate some advice on picking out a solid BR drive, any suggestions?
Best regards,
KvE
I've purchased 3 LG drives for BD ripping and all have been exceptional. They usually were on sale at Newegg during the time of purchase.
I have had great experience with all three. The last one I purchased was this one: http://www.newegg.com/Product/Produc...82E16827136269
Also found at Amazon for a bit cheaper.
The laptop drive I bought to replace my stock one was this: http://www.newegg.com/Product/Produc...82E16827136257
All great drives for playback and ripping.
jhughy2010 is offline
post #6362 of 10958 Old 08-28-2014, 08:40 PM
UHD Addict
aaronwt's Avatar
Quoted: 6222 Post(s)
Liked: 3855
I've also had great luck with LG drives. I've used over half a dozen of them and half a dozen from Lite-On, and several from Samsung. The LG ones seemed to be the best drives I have used over the years. With the Samsung being next. At least that has been my experience.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #6363 of 10958 Old 08-28-2014, 10:01 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
+1 on the LG drives. Highly rated over at CDFreaks (MyCE.com).
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6364 of 10958 Old 08-29-2014, 06:13 AM
mrfattbill's Avatar
Quoted: 109 Post(s)
Liked: 94
4 LG drives here. On a rare occasion a disc wont work in one but will work in another, same drive and same firmware, it always pays to have more than one.
Bill
mrfattbill is offline
post #6365 of 10958 Old 08-29-2014, 08:28 AM
KMFDMvsEnya's Avatar
Quoted: 260 Post(s)
Liked: 450
Thank you all for the LG suggestion and I will give the WH16NS40 a shot.
Is it worth getting the retail version with the included Cyberlink software or just save the difference and find a decent free solution for disc playback?
Also is Riplock an issue with this drive and if so can it be addressed via a firmware upgrade?
Thanks again,
KvE
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is offline
post #6366 of 10958 Old 08-29-2014, 10:59 AM
Wireless member
pepar's Avatar
Quoted: 1059 Post(s)
Liked: 548
I don't know if this is still a valid concern or not, but when I tracked down my LGs I sought out a particular model that was compatible with the hacked firmware that would remove Riplock. GGW-H20L is the model I use; I had to buy two off of eBay from China as they are no longer current in the U.S. My read/rip speed increased about 15% with the new firmware.
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #6367 of 10958 Old 08-29-2014, 11:43 AM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Thanks again,
KvE
Considering you are asking this question in a "ripping blu rays" topic I would say stick with the OEM version simply because you can rip your BD in a matter of 10-20 minutes or so and play them back via MPC-HC or VLC for free. I have no experience with ISO playback but I think you'll need somthing like PowerDVD for that.
post #6368 of 10958 Old 08-29-2014, 12:38 PM
Wireless member
pepar's Avatar
Liked: 548
BD ISO's can be mounted like any other ISO. They can be mounted with the freeware Virtual CloneDrive from SlySoft. From there they can be played with any player software. Just a few days ago I discovered PotPlayer Mini 64. (No tee-hees please) It is freeware and has settings and options out the wazoo. It does not display BD Java menues, you need to know which playlist to load, and then you need to manually select the audio stream you want to hear. Did I mention it is free?
BTW, "ripping" is the step where the encryption is removed and the movie/disc is transferred to the hard drive. Some rip to ISO, some to folder structure, some to MKV, etc, etc. But it's all "ripping" with no target format implied.
Jeff
pepar is offline
post #6369 of 10958 Old 08-29-2014, 10:30 PM
StratmanX's Avatar
Quoted: 32 Post(s)
I don't know if the player is good but I enjoyed watching the kitty's play.
http://download.cnet.com/Daum-Potpla...-75587055.html
Tee hee.
StratmanX is offline
post #6370 of 10958 Old 08-30-2014, 07:59 PM
artur9's Avatar
Quoted: 671 Post(s)
Liked: 237
I stuck an internal BD player into my Mac Pro. About this mac says: PIONEER BD-ROM BDC-207D
Just to buck the LG parade here
artur9 is offline
post #6371 of 10958 Old 08-31-2014, 07:43 AM
UHD Addict
aaronwt's Avatar
Liked: 3855
Pioneer is supposed to have good BD drives too. Or so I've heard. I've never personally used one though.
aaronwt is offline
post #6372 of 10958 Old 08-31-2014, 04:43 PM
StratmanX's Avatar
Quoted: 32 Post(s)
Good review of the Pioneer BDR-209DBK at http://goughlui.com/?p=8997.
I have the previous model Pioneer BDR-208M and has been functioning fine for my purposes. I have not ripped a BD so don't know about read speeds.
post #6373 of 10958 Old 09-02-2014, 02:19 PM
blackssr's Avatar
Quoted: 1176 Post(s)
Liked: 588
Originally Posted by ScottJ View Post
I have 1500+ movies with no RAID. I do a weekly long self-test (via SMART) and replace a disk ASAP if the self-test fails for any reason. I've had several HDDs get read errors but I've only had to re-rip one movie. The other times, the data would eventually read successfully (if very slowly).
Keep in mind that RAID is really intended for high availability, not backup. There are many failure scenarios with RAID that could result in the loss of the entire pool. With individual disks, it's easy to take one disk and move it to another system, if necessary to get the data.
Raid 6 with a global hot spare is what I run in my video server. I would have to loose 2 drives at once in order to have an issue. I have the built in email client notify me of any issue that occurs. The hot spare is set to come on line and rebuild automatically with highest priority.
blackssr is offline
post #6374 of 10958 Old 09-02-2014, 02:31 PM
blackssr's Avatar
Liked: 588
Originally Posted by Brian Hampton View Post
If I'm ripping Blus that I own and I own 1500 of them....
Should I use Raid 5 ... or just let the discs themselves serve as a backup and not use any type of Raid?
... One advantage if I decide not to do the raid backup notion is I can add the drives as I can afford them rather than saving up for 4 drives at a time type thing. Another advantage is 20% more storage capacity.
The major dis-advantage is the possibility of having to re-do 100+ movies... and also the mess of trying to salvage data from a bad drive .. I guess that's not really a big deal though is it... maybe when the drive if found to be faulty I can save 80% or more of the data ....
=Brian
Raid 6 with hot spare.
blackssr is offline
post #6375 of 10958 Old 09-02-2014, 02:35 PM
UHD Addict
aaronwt's Avatar
Liked: 3855
That is one thing I wish unRAID could do. Have two drive failures and still be able to rebuild. Although I can't say I've run across that issue yet so my three unRAID setups have been performing well over the years. One day I've got to get back to replacing my old 1.5TB drives with 2TB drives and replacing my 2TB drives with 3TB drives.
I still have several 3TB drives I bought on sale a while ago that are still sitting in the Newegg box. I replace the 2TB drives with the 3TB drives. Then move the 2TB drives over to replace the 1.5TB drives. It's just the process takes so long.
aaronwt is offline
post #6376 of 10958 Old 09-02-2014, 03:04 PM
ScottJ's Avatar
Quoted: 318 Post(s)
Liked: 162
That sounds like it's hardly worth the trouble for such a small increment. Why not leave the 2TB drives as-is and replace the 1.5TB with the 3TB? And why not use 4 or 6TB HDDs? And 8TB is coming soon.
jhughy2010 likes this.
ScottJ is offline
post #6377 of 10958 Old 09-02-2014, 03:17 PM
smitbret's Avatar
Quoted: 325 Post(s)
Liked: 99
Why not just clear the drives, add them to the pool and just expand the storage? Or are you using 2TB parity drives?
smitbret is offline
post #6378 of 10958 Old 09-02-2014, 03:31 PM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
So what do folks agree on here as far as resolution? Better to rip at 720p or 1080p if I want to keep my rips down below ~8GB?
I'm just using DVDFab for transcoding which seems to do 'good enough' in comparison to better encoders like Handbrake with x264.
hogger129 is offline
post #6379 of 10958 Old 09-02-2014, 03:56 PM
smitbret's Avatar
Quoted: 325 Post(s)
Liked: 99
That's a good question.
I used to be a big proponent of a high bitrate 720p was better than a low bitrate 1080p. Honestly, for me, it just came down to how much grain I wanted to keep and/or how much action was in the movie. Really, only you can decide because it's very subjective. As .x264 encoding has advanced, there are some really good 1080p encodes that are less than 4GB these days.
If I really care and I am still strapped for space, I will still go for 720p, especially for action and movies with lots of shadows and dark scenes (to avoid blocking). For comedies and dramas that are relatively static I'm not afraid to go 1080p.
It's just a personal choice. I'm sure I have some encodes that would just make some people throw up and others that people would call absolute overkill.
DotJun likes this.
smitbret is offline
post #6380 of 10958 Old 09-02-2014, 04:02 PM
Kelson's Avatar
Quoted: 2010 Post(s)
Liked: 1201
If "good enough" is good enough for you then rip to 720p.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #6381 of 10958 Old 09-02-2014, 04:06 PM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
Thanks guys. These were really the answers I was after. Seems that 720p is probably a better way for me to go if I am concerned with conserving disk space. I guess if 1080p quality really matters to me, I'll just get the BD out.
post #6382 of 10958 Old 09-02-2014, 04:33 PM
UHD Addict
aaronwt's Avatar
Liked: 3855
Because they cost a lot more. The 3TB drives I got were under $100. The cost per TB is much lower with the 3TB and lower drives. Although they are coming down on the 4TB drives. While above 4TB is very expensive per TB. I don't plan on using any of those in my unRAID setups for a long while.
I only have a 2TB parity drive in my unRAID 1 setup, so I don't plan on going over 2TB. In my unRAID 2 and unRAID 3 setups I have 3TB parity drives so those are the ones I use 3TB drives in.
aaronwt is offline
post #6383 of 10958 Old 09-02-2014, 04:51 PM
ScottJ's Avatar
Quoted: 318 Post(s)
Liked: 162
Gotcha, forgot about unRAID. Still seems like it would more efficient to replace only the smallest drives -- including the parity drive -- before messing with the other boxes.
As for cost per TB, don't neglect the not-insignificant cost of each HDD bay. Case, SATA controllers, power supply, etc. Including that, and placing a relatively high value on my time, the 4TBs have been economical for nearly two years, and 6TB at $300 is already there. Again, for me. Your value measure is obviously different.
ScottJ is offline
post #6384 of 10958 Old 09-02-2014, 04:58 PM
Wireless member
pepar's Avatar
Liked: 548
IIRC, with unRAID the parity drive must be as large as the largest array drive.
pepar is offline
post #6385 of 10958 Old 09-02-2014, 06:14 PM
UHD Addict
aaronwt's Avatar
Liked: 3855
I've already got around 68 drives between my three unRAID setups. So it's not too economical for me to switch to a larger drive. Although I guess I could sell some of the smaller capacity drives. I sold several dozen 1.5TB and smaller drives last year. WHich was at least better than me trashing them. But at this point since two of my unRAID setups have the maximum number of drives and I still have space in all three, I can afford to wait until the 4TB and larger drives come down in price.
Although if I do ever go to the 4TB and larger drive sizes I will probably build a fourth unRAID setup. And then retire my unRAID 1 and unRAID 2 setups.
aaronwt is offline
post #6386 of 10958 Old 09-03-2014, 05:45 AM
DotJun's Avatar
Quoted: 585 Post(s)
Liked: 159
As we all know, Murphy says that the most likely time you will have a second drive failure is when you are rebuilding from a drive failure. Can you imagine how much teeth biting is going on during the verify+initialization process on a 4tb x24 array?
DotJun is offline
post #6387 of 10958 Old 09-03-2014, 06:10 AM
Kelson's Avatar
Liked: 1201
When I was researching FlexRaid, I believe I read that it supports multiple parity drives to accommodate multiple drive failures for big disk arrays. The parity drives have to be as big as the largest drive in the array and each parity drive covers for one array drive failure.
- kelson h
Kelson is offline
post #6388 of 10958 Old 09-03-2014, 09:38 AM
blackssr's Avatar
Liked: 588
Draft Day Playlist for RedBox
151) 00698.mpls, 1:50:00
[515+516+513+505+512+502+511+519+510+518+501+503+51 7+509+507+520+504+514+506+508].m2ts
- Chapters, 16 chapters
- h264/AVC, 1080p24 /1.001 (16:9)
- DTS Master Audio, English, multi-channel, 48kHz
- AC3, Spanish, multi-channel, 48kHz
blackssr is offline
post #6389 of 10958 Old 09-03-2014, 09:43 AM
blackssr's Avatar
Liked: 588
Those 8 TB are sweet but $$$$$$$$$$$$$$$$$$.. I have 16 4 TB hdds and just built a new RAID 6 server to replace my aging RAID 5 Server. Never had an issue with the Raid 5 at all. I just figured after 5 years of service it was time. After Raid 6 proves itself I will break down RAID 5 and dump parts on eBay.
blackssr is offline
post #6390 of 10958 Old 09-03-2014, 12:15 PM
Wireless member
pepar's Avatar
Liked: 548
Originally Posted by blackssr View Post
I have 16 4 TB hdds
What are you guys doing, hosting the Library of Congress??
pepar is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
