Ripping Blu-Rays II - Page 235 - AVS Forum | Home Theater Discussions And Reviews
 1014Likes
post #7021 of 10802 Old 01-05-2015, 05:57 AM
the_abbot's Avatar
Quoted: 228 Post(s)
Liked: 38
MKV rip vs original bluray PQ.
For some reason, in my mind I can clearly see the difference between the two. Is it just my imagination or does an mkv rip (no compression) have slightly less PQ than the original bluray format?
the_abbot is offline
post #7022 of 10802 Old 01-05-2015, 06:01 AM
Kelson's Avatar
Quoted: 1962 Post(s)
Liked: 1157
Originally Posted by agogley View Post
What version of Eac3to are you using?
I don't know the specific version. It is whatever version that was installed with Clown_BD.
So here is what else to try. If you know the playlist number you want to rip, try using TSMuxer instead of eac3to.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #7023 of 10802 Old 01-05-2015, 06:10 AM
Kelson's Avatar
Liked: 1157
As long as there is no re-compression or re-coding involved in the rip, the digital content of the rip is identical to the BD source. What may not be the same are the settings on your HDTV for the HDMI inputs used to play a BD disk vs. the media player you are using to stream the rip.
People have made reports like this before and many were traced to a BD player on one HDMI input and a media player on another HDMI input. Most HDTV's allow discrete video settings for individual HDMI inputs. If the settings on the HDMI inputs you are comparing are not the same then you will see differences in the PQ due to video processing effects.
the_abbot and mrfattbill like this.
- kelson h
Kelson is offline
post #7024 of 10802 Old 01-05-2015, 06:41 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 25
MAKEMKV question for the experts.
MakeMKV Question.
I've used MakeMKV from BDs before and never thought to do this:
http://www.makemkv.com/dtshd/
Is that still necessary? It seems like I've been getting the DTS-HD file just fine with setting the path location for the dtsdecoderdll.dll.
agogley is offline
post #7025 of 10802 Old 01-05-2015, 06:44 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 25
I tried that and it worked successfully. Now what?
agogley is offline
post #7026 of 10802 Old 01-05-2015, 06:49 PM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
MakeMKV Question.
It's only necessary if you're converting the DTS-HD to FLAC in MakeMKV. If you did a rip and kept the DTS-HD audio, something like Handbrake or VidCoder should not have a problem re-encoding DTS-HD to other formats.
agogley likes this.
hogger129 is offline
post #7027 of 10802 Old 01-05-2015, 07:23 PM
Kelson's Avatar
Liked: 1157
Cool. So, where do you want to go from here? You have an .m2ts file from TSMuxer that is a perfectly good container (that is all I use for BD). If you want to end up with MKV, then click the "Blu-ray disk" output button in TSMuxer. That will generate a BDMV folder structure for the title with a playlist that contains the chapter points. You then "open" that folder in MakeMKV and proceed to make your MKV in normal fashion.
You are home free.
P.S. -- eac3to is v 3.27.0.0
- kelson h
Kelson is offline
post #7028 of 10802 Old 01-05-2015, 08:00 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 25
You are home free.
LOL. I want to be able to use Clown! I like being able to generate a second AC3 file. I don't normally use MKV. I normally use an ISO.
Oddly enough, I just put in Live Die Repeat, Edge of Tomorrow. Guess what? Works fine. Going to go back and try the previous movies.
agogley is offline
post #7029 of 10802 Old 01-05-2015, 09:46 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 25
You are home free.
So when I pop in Divergent and run Clown, I get this message saying "Sony Screenpass, use mpls 0267?" To which I reply no and then go into Clown. I wonder if this is part of the problem?
agogley is offline
post #7030 of 10802 Old 01-05-2015, 09:59 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 25
Originally Posted by pepar View Post
Why are we whining about what studios do differently on rentals than on the retail release?
I hate it when studios give me a second rate release on the rental because I actually watch a lot of rentals (on a standalone BD player in my HT). I don't want to pay for the retail version just to watch it once. (I usually don't buy a movie unless I've rented it first too).
It's really obvious when this happens because my receiver tells me which audio is running. So here I am, playing by the rules...paying for a rental and watching it the way the studios tell me to like a good boy on my licensed Panasonic BD player and yet I get stuck with second rate audio and apparently, video.
agogley is offline
post #7031 of 10802 Old 01-05-2015, 10:01 PM
UHD Addict
aaronwt's Avatar
Quoted: 5479 Post(s)
Liked: 3309
You need to rent from a place that doesn't use rental versions. Like www.3d-blurayrental.com
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #7032 of 10802 Old 01-05-2015, 10:14 PM
DotJun's Avatar
Quoted: 575 Post(s)
Liked: 155
Clown_BD is an easy GUI for eac3to which then links to BDSup2Sub. I use Clown to demux all the English subtitle tracks. It will identify forced subs that have header flags and create separate subtitle tracks containing only the forced subs. It will not identify forced sub tracks without header flags. So I use Suprip to quickly inspect all the sub tracks to identify the track(s) that I want in the rip. I then do the full rip. For a forced sub track that Clown identifies, it always muxes it in first in line. My player ignores flags so I put my own flag in the filename to let me know to turn on the first sub track when I watch the movie.
This process is specific to my particular player and the work-flow originated from discussions in my player's thread.
I see. I don't use clown so I wasn't aware of its capabilities. Thanks for the info.
Why not use suprip to spit out an srt of forced only, then mux that into your movie? You simply have to tell your player to always turn subs on.
How are you hardburning them in?
Also, Dbone wrote an article (kinda dated now) about using clown_BD and MKV Merge together. This might be useful for this topic.
Only way to hard burn is to re-encode.
Eac3to will not process it. I just ran it from the cmd line and it simply will not work. So at least I know it is Eac3to and not anything to do with the Clown_BD GUI. Now just to figure out what I need to do to fix it.
The only other possible thing I can think of, is that AnyDVD HD has something wrong with it. But I can rip it and play it no problem so that seems a little odd. Also seems odd that I can process STTNG but not Divergent or Stargate. Maybe something to due with seamless branching. I'm checking over at the Doom9 forum to see if anybody can help me there.
It's not eac3to as I own both of those discs and did not have any problems. In fact, I don't think I've ever had any problems with any discs I've processed.
What is the command line you are using on this operation of eac?
DotJun is online now
post #7033 of 10802 Old 01-05-2015, 10:47 PM
techflaws's Avatar
Quoted: 144 Post(s)
Liked: 77
What is your process that you use, since you are using MakeMKV, right? (I'm sure you probably described it 15 times in this 500 page thread).
Depends on how many BDs I rip in a row and what tracks I find when checking the BD first in VLC. Ripping one BD only, I sometimes even open the main playlist in MKVToolnix (with AnyDVD in the background) and go from there. If it's several BDs, I rip the main movies to HDD with DVDFab and then drop them in MakeMKV Batch Converter. I'm using the advanced settings in MakeMKV to mux German audio and subs (and forced) as the first tracks and if this does not work due to the forced subs not being flagged, I remux them using MKVToolnix's job queue. Often enough this works just fine so I don't care about an additional step since it's mostly automated reducing my time of attention.
Tech Flaws
Things can only get better
techflaws is offline
post #7034 of 10802 Old 01-05-2015, 11:33 PM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 700
I stopped using Clown, and now I only use MakeMKV. With MakeMKV I can have same PQ as BD, DTS-MA / TrueHD / Atmos and AC3. Clown takes too long to rip BD's. It used to be my ripper of choice, but now MakeMKV works much better. There has been a few BD's that MakeMKV couldn't rip. So, I used ClownBD and MKVMerge to create a MKV with chapters.
mr266 likes this.
GusGus748s is offline
post #7035 of 10802 Old 01-06-2015, 05:46 AM
Wireless member
pepar's Avatar
Quoted: 1006 Post(s)
Liked: 520
My MO is to only buy Blu-Rays l-o-n-g after they are released, and then do it from Amazon Marketplace so that I am paying a fraction of the release price. I should mention that I do see many movies in the theater, nearly always 3D, IMAX or IMAX 3D. In a way, that is part of the screening process I use to decide what movies to buy. So rentals play zero role in my enjoyment of movies. Generally, I don't watch those movies in my home theater, but do so on a bedroom 5.1 system ... and from bed.
Movies that I want to watch but not own, I stream. So I accept (and never notice) the audio may not be lossless.
My wife likes Xfinity On Demand where titles can cost $5-$6 to "rent." I find that absurd, but she enjoys it so I refrain from stating my opinion.
You could simply not rent titles that cripple the audio?
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #7036 of 10802 Old 01-06-2015, 05:49 AM
Kelson's Avatar
Liked: 1157
OK, I guess I got turned around here.
So for the problem title(s) that crashes eac3to, use TSMuxer to open the playlist of the title and select all the streams of that title (they are all selected by default). Set the TSMuxer output to "Blu-ray disk" and click go. TSMuxer will then extract the title with all its streams and join the seamless branching title into a single .m2ts file. The final output will be the BluRay BDMV folder structure and TSMuxer will have fixed any problems with the original .m2ts file that was crashing eac3to.
You can then run Clown_BD and open the BDMV folder that TSMuxer just created and process the video with Clown like you always did.
- kelson h
Kelson is offline
post #7037 of 10802 Old 01-06-2015, 05:59 AM
Wireless member
pepar's Avatar
Liked: 520
Wow! That there even is such a business suggests that there is a market for the better audio of release versions and/or extended/director's cuts. Interesting,
pepar is offline
post #7038 of 10802 Old 01-06-2015, 06:10 AM
artur9's Avatar
Quoted: 592 Post(s)
Liked: 205
Better audio really makes the experience much more immersive for me. But it could be because I like ghost stories. I haven't found that the better audio for action movies too compelling except for Abrams' Star Trek, Dredd and Gravity.
MakeMKV Question.
I tried that but without HDMI it didn't do me much good. So now I just rip the soundtrack as is in anticipation someday of getting an HDMI-capable and high-res-capable pre pro.
artur9 is offline
post #7039 of 10802 Old 01-06-2015, 07:16 AM
Kelson's Avatar
Liked: 1157
As far as the MKV container format is concerned, when I started ripping BD's 4yr ago I went with Clown_BD and native BD.m2ts containers because, at the time, MKV was still immature and one would read posts almost daily of people having problems with MKV files and their particular players -- that included the WDTV Live family which were my players. Since then MKV tools have greatly improved along with player compatibility so that it is not an issue and MKV is a fine universal container format. If starting to rip today, I would have no preference between BD.MKV or BD.m2ts. However, my library was established as BD.m2ts and has grown, so I have just stuck with the BD.m2ts format to keep things consistent.
I have played with MakeMKV and have it installed on my main workstation. All in all, I find the Clown interface much more to my liking for ripping BD's -- especially when it comes to handling forced subtitles. With Clown I can demux the sub streams and inspect them so I know exactly what I'm getting before I do the full rip. I don't have that option with MakeMKV. This is just my personal preference and the way I like to work with BD rips. I know others have their own preferences. As far as speed goes, well I'm down to ripping only a 1-2 BD's per month if I'm lucky so I prefer to savor the experience.
DVD's are a different matter -- I've come to appreciate MKV for DVD rips. I generally rip full DVD's to DVD.iso to get the full menus for TV series, but if I'm just ripping the main title of a DVD movie I've been using MakeMKV for that and am pretty happy with the DVD.MKV results. If I were to ever rip individual episodes of a TV series DVD, I would also use MakeMKV for that and use MKV files.
Same goes for HDTV captures. I like to collect select HDTV series recorded on my TiVo's. After transferring the captures to my PC and editing with VRD, I'll save them as MKV files for archiving on my server or burning to BD-R.
- kelson h
Kelson is offline
post #7040 of 10802 Old 01-06-2015, 08:28 AM
mrfattbill's Avatar
Quoted: 97 Post(s)
Liked: 89
I personally use M2TS for movies and TV series stuff and I use MKV for concerts, where chapters are vastly more important. Containers were more important when I was using WDTV's exclusively but now HTPC's running XBMC/KODI are the king of my household so container is pretty irrelevant at this point.
Bill
mrfattbill is offline
post #7041 of 10802 Old 01-06-2015, 10:29 AM
Wireless member
pepar's Avatar
Liked: 520
Sure, for me as well, and I'd bet most here, too. But to see signs that enough renters care about that to make it a viable business model is encouraging. On the other hand there are people who watch pirated movies made with a @#$%^ a camera held by someone sitting in a movie theater. That one continually stuns me.
pepar is offline
post #7042 of 10802 Old 01-06-2015, 10:51 AM
artur9's Avatar
Quoted: 592 Post(s)
Liked: 205
I thought that was an urban legend spread by the studios? I thought most of the pirating was done by employees stealing final cuts?
artur9 is offline
post #7043 of 10802 Old 01-06-2015, 11:35 AM
Wireless member
pepar's Avatar
Liked: 520
Think "Asia" for the handheld camera pirated movies.
pepar is offline
post #7044 of 10802 Old 01-06-2015, 12:58 PM
dbone1026's Avatar
Quoted: 218 Post(s)
Liked: 110
Ooohhh ... Asia Carrera did that as well
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #7045 of 10802 Old 01-06-2015, 01:09 PM
Wireless member
pepar's Avatar
Liked: 520
You dawg you.
pepar is offline
post #7046 of 10802 Old 01-06-2015, 04:59 PM
artur9's Avatar
Quoted: 592 Post(s)
Liked: 205
I find these forums ceaselessly educational.
artur9 is offline
post #7047 of 10802 Old 01-06-2015, 08:40 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 25
I really want to figure out why Clown_BD isn't working for these two movies. Obviously something is wrong and needs fixin. I can always go around and use something else.
I'm using Clown GUI. When that didn't work I tried in the Doom9 forum and they wrote the command line for me. It essentially did the same operation then when it gets to the end it says it can't open the file. I'm starting to suspect my BD drive mostly just as a process of elimination. I mean that is pretty much the last thing to check except for the question I'm about to ask you.
Can you tell me what playlist you used? I'm using 760. However, when I run Clown it asks me about Sony Screen pass and suggests using 0267 .mpls. I'm choosing no, but maybe I should choose yes?
agogley is offline
post #7048 of 10802 Old 01-07-2015, 01:58 AM
DotJun's Avatar
Quoted: 575 Post(s)
Liked: 155
Divergent: 810
Stargate: I think there was only one option on that one?
post #7049 of 10802 Old 01-07-2015, 04:43 AM
Wireless member
pepar's Avatar
Liked: 520
I picked up Stargate in the bargain bin at BestBuy one day a while back and just got around to processing it. But for whatever reason I keep getting an error when using clown_BD. It says it can't open the DTS-Master Audio file. I'd paste the actual error but I deleted the logs...It gets to the end of the 3rd EAC pass then bugs out.
Which version of Stargate? I have two and might have some time to try ripping it before I escape the winter weather.
Jeff
What was the per movie giving you problems?
One other thing, if they are Sony movies, yes use Screen Pass' playlist recommendation!
pepar is offline
post #7050 of 10802 Old 01-07-2015, 05:10 AM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 25
Divergent: 810
I don't get 810 as an option. I'm using a retail version that includes Blu-Ray + DVD + Digital.
Jeff
Stargate 15th Anniversary. It's that and Divergent that are giving me problems.
agogley is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
