Ripping Blu-Rays II - Page 238 - AVS Forum | Home Theater Discussions And Reviews
 980Likes
post #7111 of 10646 Old 01-15-2015, 02:00 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Originally Posted by pepar View Post
His physical BD disk or his rip thereof?
I assumed, at the time, his physical disc since I thought he wasn't able to play the output rips using any method.
Originally Posted by agogley View Post
Ok, so I ripped Divergent to my hard drive using AnyDVD HD. I used txmuxer to create an m2ts file. I then used eac3to to extract the audio and video. Then I used txmuxer to create a a BD file folder which I then made into an ISO. It works fine.
So for whatever reason eac3to just doesn't like the source of this particular movie. Strangest thing.
I'm even more curious now. I have a couple questions if you please?
1. The m2ts you created with tsmuxer, did that play fine?
2. Can you take the resulting eac demuxed files and remux using tsmuxer into an m2ts and not be folder or ISO? Does it play ok?
3. Is the movie a single large file according to the mpls?
Originally Posted by JRock3x8 View Post
are you collecting a fee on answering all these questions? you should be
I ran tsmuxer on that Star Wars mkv (which is fully loaded as you can see, maybe even too much) and it gave no audio - just testing 10s clips for now.
Haha no fee. I like to help out whenever I can. So the file you have started out as an mkv? Why did you run tsmuxer on an mkv? I've never tried it myself, but I didn't think it could open mkv's.
I did the test with Divergent. I gave up on Stargate a while back and put it up in the attic with my other movies.
And yes, with eac3to and TxMuxer, although I used the txmuxer gui.
I use the tsmuxer GUI myself. Can I ask you to check if stargate is a single large file and if not, how many files are in the list?
I'm very sorry for all the work i am asking you to do just to scratch my curiosity itch.
DotJun is offline
post #7112 of 10646 Old 01-15-2015, 02:09 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Ripping Blu-Rays II
All this talk on another thread about how storage is so cheap got me thinking about the cost and logistics of it all so as usual I found some time and checked on how different I see things vs others.
So here is what I'm asking:
Let me know if you can notice a difference in these stills. Please forgive the fact that one of them wasn't cropped and that the color might be slightly off on one or all because I was just doing a quick test in which color wasn't a factor.
Also, please try to not think too much about the name of these files as they were just named by the batch, which is why one of them isn't cropped cause I had run out of time but decided to include it in the test anyway.
Most importantly, please please please do not look at the file size! It's not that hard to look at the file size and see what is going on here but then, the goal isn't to win the I guessed right game
After all that, just let me know which you think looks best, if there is a best or let me know if you think they all look identical.
Btw, this is just a test for curiosities sake as I've said it many times over that at these resolutions, it's pretty damned hard for a person to tell a difference when watching it in motion.
DotJun is offline
post #7113 of 10646 Old 01-15-2015, 07:18 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
I tired ripping it straight from the blu-ray but there is something unique about the copy protection on those star wars blu-rays - I suppose I could try it with another disk like The Matrix. Even ripping the Star Wars movies took FOREVER compared to my other discs.
The MKV recognized just fine but again no audio on the output file.
JRock3x8 is offline
post #7114 of 10646 Old 01-15-2015, 07:18 AM
UHD Addict
aaronwt's Avatar
Quoted: 5193 Post(s)
Liked: 3100
It's a still picture though. It's different between watching one still and watching 24 stills played every second.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #7115 of 10646 Old 01-15-2015, 07:23 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Ripping Blu-Rays II
My last paragraph addresses this fact doesn't it? I might have used the wrong word though (details), so I edited the paragraph to read resolutions instead.
1. Try to rip just one audio track instead of all of them and see what happens.
Just to make sure, when you play the disc, you get audio yes? When you play your ripped file and tell your player to play the same audio stream that the disc played, you get no audio yes? You are using the same player to play both files yes?
DotJun is offline
post #7116 of 10646 Old 01-15-2015, 07:24 AM
UHD Addict
aaronwt's Avatar
Liked: 3100
I know the Fox distributed titles will enable rip lock on my Pioneer BDR-209DBK BD burner. So they will be limited to 2x rip speeds. While non Fox distributed titles have no problem with fast rip speeds. While my Pioneer BDC-207DBK BD rom drive won't get hit by rip lock with the Fox distributed titles. But it is also limited to only 8x rip speeds on single layer discs while the Pioneer BD burner will hit 12x rip speeds.
aaronwt is offline
post #7117 of 10646 Old 01-15-2015, 07:33 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
The disc just produces an error message, it won't rip at all. That's why I went the MKV route.
JRock3x8 is offline
post #7118 of 10646 Old 01-15-2015, 09:27 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1146
I'm having a hard time understanding how a BD title can cause rip-lock. Rip-lock is a drive firmware implementation to lower the read speed that can be removed from many drives with MediaSpeedCodeEdit. Are you sure what you are seeing is not just a result of the particular DRM that is being employed that is requiring more processing and slowing things down that way? It may be causing the particular drive to reset or track seek more than another drive.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #7119 of 10646 Old 01-15-2015, 09:35 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Alright I will take a stab at this. FROM MY IPAD MINI, the second image looks like it has more detail that the first. Maybe more than the third.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #7120 of 10646 Old 01-15-2015, 09:36 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
AnyDVD HD up to date with latest version?
pepar is online now
post #7121 of 10646 Old 01-15-2015, 10:37 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
What is that? And therefore, no.
JRock3x8 is offline
post #7122 of 10646 Old 01-15-2015, 10:44 AM
UHD Addict
aaronwt's Avatar
Liked: 3100
Yes. If i go to my LG drive there is no issue. If I use my Pioneer BD rom drive there is no issue. It will rip up to 8X on the dual layer Fox Disc. But if I use my Pioneer BD burner it will go up to something like 2.4x speed and then drop to the 2X rip lock speed and stay there. I've ripped a bunch of titles now with that BD burner. Only Fox distributed discs have this issue with my Pioneer BD burner. I've never had that issue with my dozen other BD drives from LG, LiteOn and Samsung.
aaronwt is offline
post #7123 of 10646 Old 01-15-2015, 02:25 PM
mecmec's Avatar
Quoted: 407 Post(s)
Liked: 157
I am with you on this. I have the same issue with my pioneer drive. That's why its good to have an assortment from different manufacturers... :-)
mecmec is offline
post #7124 of 10646 Old 01-15-2015, 06:42 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 24
Incorrect. I've been able to rip using AnyDVD HD and play. I've been able to convert to AC3 using Clown_BD GUI. And I've been able to use Slysoft's new CloneBD as well as MakeMKV.
Yes to #1 and #2 . I'm not sure what you are trying to get at with #3 . I produce a single m2ts not sure how the playlist is different?
Not sure what you mean. Please specify what I'm looking at and for.
agogley is offline
post #7125 of 10646 Old 01-15-2015, 10:35 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Newer versions are developed and released to deal with the encryption that is on new movies.
pepar is online now
post #7126 of 10646 Old 01-16-2015, 12:30 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Ripping Blu-Rays II
I'm not understanding what the "mkv route" is? Do you mean downloaded?
Thanks pepar, I appreciate your time and effort, and if you want the details on the differences between the files I can pm you.
There isn't a right or wrong answer mind you, I'm just curious as to people's answers and whether the file name and files sizes (for those that looked at them) changed people's minds in perceived quality.
Anyone else? Someone with a huge screen take a stab? @Kelson , help a brother out?
Open the correct mpls file using tsmuxer. In the area labeled "input files", how many m2ts files are nested under the mpls file you selected to open?
DotJun is offline
post #7127 of 10646 Old 01-16-2015, 02:25 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
instead of ripping the piece from the disk, I ripped the piece from my ripped MKV (referenced above in that ridiculously long info dump)
whoever asked about AnyDVD - wouldn't a recent copy of MakeMKV do the same thing? I've noticed they are always pushing out new versions of that every 3 months or so.
JRock3x8 is offline
post #7128 of 10646 Old 01-16-2015, 06:18 AM
Kelson's Avatar
Liked: 1146
I'm sorry @DotJun , this whole discussion has taken so many twists and turns, it has left me in a confused dust.
I'm just waiting for the next topic to start fresh, at this point.
- kelson h
Kelson is offline
post #7129 of 10646 Old 01-16-2015, 06:28 AM
Kelson's Avatar
Liked: 1146
I've been playing a lot with MakeMKV using the full-disk rip option -- not making an MKV file. In my experience over the last 4-5 months, I have found that MakeMKV alone can crack and rip about 90% of the commercial BD disks I have tried. For the other 10% (usually the newest releases) I have to use one of the big-2 rippers (DVD Fab or AnyDVD HD) to do a full-disk rip -- in my case I use DVD Fab.
mr266 likes this.
- kelson h
Kelson is offline
post #7130 of 10646 Old 01-16-2015, 06:44 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
MakeMKV worked for Star Wars - it was just incredibly slow.
JRock3x8 is offline
post #7131 of 10646 Old 01-16-2015, 06:58 AM
Kelson's Avatar
Liked: 1146
I use LG burners with rip-lock removed (currently a pair of WH16NS40) and a full disk BD rip generally takes 25 min with DVD Fab or MakeMKV. I rarely see one take more than 30 min -- and that is ripping two disks at a time.
- kelson h
Kelson is offline
post #7132 of 10646 Old 01-16-2015, 07:06 AM
UHD Addict
aaronwt's Avatar
Liked: 3100
When I use MakeMKV I still have AnyDVD HD running in the background.
aaronwt is offline
post #7133 of 10646 Old 01-16-2015, 07:08 AM
UHD Addict
aaronwt's Avatar
Liked: 3100
Two, three, five or six discs at a time. They will all rip just as fast individually or concurrently as long as the storage medium they are going to can keep up.
aaronwt is offline
post #7134 of 10646 Old 01-16-2015, 07:33 AM
Kelson's Avatar
Liked: 1146
From what I read here, most people do. I don't have AnyDVD, I have DVD Fab and either way my preferred workflow is to rip the full disk to my HDD before further processing.
- kelson h
Kelson is offline
post #7135 of 10646 Old 01-16-2015, 08:57 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Rip to an SSD? And then "bounce it around" SSDs when processing with Clown?
Jeff
pepar is online now
post #7136 of 10646 Old 01-16-2015, 09:09 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Oh, I was just asking you to check out the pics I posted like three posts ago, and give me an honest opinion.
I am so confused right now haha when you say your original rip soul not play the audio portion even though the audio streams were present, how did you actually rip it? Using what?
DotJun is offline
post #7137 of 10646 Old 01-16-2015, 10:08 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
YAH! Forums! Good for confusing threads of different stories! LOL.
OK, so to recap...
1) open tsmuxer,
throw in Star Wars in the Blu-Ray Drive,
open SW4 from tsmuxer,
gives error message (something about the disc, not a read error),
close tsmuxer
2) open tsmuxer,
import SW4 MKV ripped using MakeMKV (at an earlier date) using all default settings (so EVERYTHING is in that MKV file right down to the Aramaic subs),
MKV imports into tsmuxer just fine.
I go to give it a 10s clip that I want copied out of the MKV (split and cut, no split, cut 10s, can't remember what output settings were) ,
click start muxing, and it creates the file with the correct video but no audio.
JRock3x8 is offline
post #7138 of 10646 Old 01-16-2015, 10:29 AM
Kelson's Avatar
Liked: 1146
No, just SATA III drives. SSD would offer me no benefit over mechanical HDD since the limitation is processing.
I do use separate physical HDD's for Clown_BD processing so that for each stage it is reading from one drive and writing to the other. That does speed things up quite a bit than using a single drive.
- kelson h
Kelson is offline
post #7139 of 10646 Old 01-16-2015, 10:52 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
OK, so to recap...
1) open tsmuxer,
close tsmuxer
2) open tsmuxer,
Looks like your problem with #1 is not having a decrypter?
I can't really help with #2 as I've never used makemkv.
DotJun is offline
post #7140 of 10646 Old 01-16-2015, 11:16 AM
JRock3x8's Avatar
Quoted: 646 Post(s)
Liked: 163
so on the one hand that makes sense for 1 but then why can I rip it with MakeMKV if I can't decrypt it? OK, anyways. Sounds like best practice is install AnyDVD HD and then try again with the blu ray?
JRock3x8 is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
