Ripping Blu-Rays II - Page 262 - AVS Forum | Home Theater Discussions And Reviews
 980Likes
Old 05-06-2015, 08:20 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Originally Posted by ScottJ View Post
VOB sounds like DVD, not Blu-Ray...?
That's correct sir.
DotJun is offline
Old 05-06-2015, 09:00 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Originally Posted by DotJun View Post
It does scrape, but as I said the weird part is that it will show runtime if I use an encoded video but it does not when I do a 1:1 on a .vob file.
When playing the actual file you can pause the movie and the correct time remaining is correct. My problem is before the movie is even played, out in the movie menu the field for runtime is blank. I don't have this problem with encoded files.
My front end that I use is Mediaportal.
If you can edit the movie data, just do so. The MediaPortal documentation for that is here. That will solve the immediate problem of missing data. As for why it behaves that way, I have no clue. Have you tried the MediaPortal forum? Surely someone else has encountered the issue.
I use PCH with a third party database manager.
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 05-06-2015, 10:46 AM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
Originally Posted by Lils Roro View Post
As I understand the deal, if I want to rip a commercial BD to a hard drive, as a minimum I will need 1) a computer drive that reads BDs and 2) the AnyDVD HD software which costs 79 euros (currently $85). Is this correct?
And something like the free ImgBurn will be needed to do the actual ripping, but it's AnyDVD HD that makes this possible (?).
You need a Blu-ray drive (either internal or external) and there are a number of programs which can make a rip. MakeMKV is not the easiest but it's free.
hogger129 is offline
Old 05-06-2015, 10:48 AM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
Originally Posted by Peter M View Post
Guys,
Thanks for the suggestions for my little problem.
I looked at VLC but it's conversion abilities seem limited - all it gave me was sample freq and bit rate choices - no bit depth.
I persevered with eac3to and eventually figured it out, however after conversion I tried to play the FLAC tracks and all I got was silence ! My processor showed 7.1 PCM input but there was no sound.
I think the problem may be the DTS decoder - I didn't download anything from arcsoft and just used eac3to exactly as downloaded. It didn't throw up any errors and appeared to do the conversion OK, but now I'm thinking this may have been my problem.
What I've done to keep me going is to use DVDFab to rip to MKV just the audio as pass through and it plays fine as 7.1 DTS HD-MA.
I'll probably download the arcsoft DTS decoder and give eac3to another try.
Cheers,
Get it from here - http://www.dll-found.com/dtsdecoderd..._download.html
In MakeMKV, you have to select the advanced options and there is a spot where you specify the location of the DTS-HD decoder DLL file. Then it should work correctly. FLAC, in my experience, outcompresses LPCM, DTS-HD MA and Dolby TRUEHD so there's no reason not to use FLAC unless your playback system doesn't support it.
Old 05-06-2015, 09:30 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Jeff
Oh I know how to edit it manually. I was just wondering if this was an inherent problem with 1:1 vob's/m2ts? I actually haven't tried out an m2ts to see if the same problem is there.
What is PCH and does it also give you the same problem m seeing?
DotJun is offline
Old 05-07-2015, 06:20 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
A-300, and I only do 1:1 BD rips ... main movie, lossless audio and, if needed, subtitles. Some movies I need to manually match, and some concert BDs I need to completely enter manually. But I have never had the issue you are having.
Try the Mediaportal forum!
pepar is offline
Old 05-07-2015, 08:00 AM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
Question - with MKV, is less compression better? So there is an option in MKV for FLAC, hence a smaller file?
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
Old 05-07-2015, 08:17 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
FLAC is lossless compression so it does no harm to the original quality.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Old 05-07-2015, 09:45 AM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
.mkv is the video container, does not compress. The video codec is what compresses (i.e. H264, H265, MPEG-2, VC1 etc). MakeMKV won't add any compression. If you want to compress the video, you'll need something like Handbrake or Vidcoder. All MakeMKV is doing is taking the titles, audio tracks and subtitles you choose and dumps them into an .mkv container.
As for the audio, FLAC is lossless compression meaning that it compresses it a little in order to save space, but no information is discarded, hence why it is called lossless compression. But upon decompression it perfectly recreates the source. The problem is that it's not really supported in home video the way that PCM, DTS and Dolby are since FLAC isn't part of the DVD or Blu-ray spec. That's why with Blu-ray ripping you'll hear a lot of people who convert the lossless track to 640kbps DD 5.1.
Old 05-25-2015, 01:36 PM
bill913's Avatar
I have a question about BD movies with multiply threads. I use anydvd and typically open the files, find the longest stream, and copy to my hard drive ( takes 30-45 min). I have searched this thread for several days and tried several different approaches but have not come up with a good solution. I downloaded BD clone and it selected the correct playlist. I selected the ISO I had made with anydvd but it indicated it was going to take over 4 hours to do the conversion. Does anyone know a quicker way to get a playable copy for my WD Hub. Thanks for any help.
bill913 is offline
Old 05-25-2015, 07:46 PM
smitbret's Avatar
Quoted: 314 Post(s)
Liked: 96
When I run into BDs with multiple playlists, I set Any DVD to run its SpeedMenu option and open the BD in Power DVD. The menu tells you which playlist appears to be correct. It has been correct 100% of the time for me but a few people have mentioned that it missed occasionally.
smitbret is offline
Old 05-26-2015, 06:28 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Does SpeedMenu need a licensed BD player app to work? Would an unlicensed app, i.e. PotPlayer, where the MPLS is manually selected, use SpeedMenu?
Jeff
pepar is offline
Old 05-26-2015, 07:22 AM
UHD Addict
aaronwt's Avatar
Quoted: 5218 Post(s)
Liked: 3123
Jeff
You need a player that has full BD menu capability to see the speed menu. My PCH C200 and Netgear NTV550 media players will show the speed menu since they have full BD menu capability.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 05-26-2015, 08:05 AM
johnBlanker's Avatar
Quoted: 410 Post(s)
Liked: 68
The only method I know of that is 100% accurate is the method involving setting up a process monitor while playing it in Power Dvd. Someone made a post about it way back, I will try to find it.
Here it is. This is a real life-saver. Sure beats googling for the correct mpls.
johnBlanker is offline
Old 05-26-2015, 08:20 AM
Kelson's Avatar
Liked: 1147
Could you please list the post #. Your link does not work for me, which happens every now and then for people like me who have changed the default number of posts shown on each screen.
- kelson h
Kelson is offline
Old 05-26-2015, 08:22 AM
Quoted: 410 Post(s)
Liked: 68
post #7557
Old 05-26-2015, 08:24 AM
Kelson's Avatar
Liked: 1147
thanks
- kelson h
Kelson is offline
Old 05-26-2015, 09:31 AM
hogger129's Avatar
Quoted: 94 Post(s)
Liked: 74
What drives do you guys recommend for backup? I have a 1TB and 2TB external but am using them for music backup. I see the largest portable USB drive one can get currently is 2TB.
Old 05-26-2015, 09:41 AM
Quoted: 410 Post(s)
Liked: 68
Do you mean powered by USB cable only? Yeah you are going to be restricted in size since AFAIK those are usually 2.5" laptop HDD. I haven't come across 3.5" HDD that can operate on USB power alone.
In my setup, I do not run any redundancy. I have 7TB in my pc/server and I run another 7TB in a pro-raid external SATA enclosure as a backup. Use sync software to sync up the two every week or so. I only use WD green drives for both server and backup pool. I also exclusively use WD drives at work. They have served me well. I'm just familiar with them.
Old 05-26-2015, 11:20 AM
UHD Addict
aaronwt's Avatar
Liked: 3123
I have a couple of 4TB USB powered drives. They use two, 2TB 2.5 inch drives in a RAID 0 configuration and gets it's power from the USB 3.0 ports. It has read/write speeds of over 220MB/s(1760Mb/s).
The Seagate Backup Plus Fast 4TB Portable External Hard Drive USB 3.0 (STDA4000100).
Very small and very portable since there is no need for a power supply. And very fast too.
http://www.amazon.com/Seagate-Backup...+4Tb+fast+plus
aaronwt is offline
Old 05-29-2015, 09:17 AM
bill913's Avatar
BD's with multiply play lists
Thanks for the reply. My question is if I know the correct play list, What is the best software to convert the ISO into a playable file for my WD Hub?
bill913 is offline
Old 05-29-2015, 09:23 AM
GreySkies's Avatar
Quoted: 618 Post(s)
Liked: 432
I do off-site back up via Crash Plan.
GreySkies is offline
Old 05-29-2015, 09:55 AM
Kelson's Avatar
Liked: 1147
Either Clown_BD to extract the native .m2ts file or MakeMKV to extract and repackage the .m2ts as .MKV.
The only advantage of MKV is that the chapter skip points are preserved for players that are able to do chapter skip with MKV files. The WD Live-SMP and subsequent WDTV Media Player are both able to use chapter skip in MKV files but I believe the Hub does not.
pepar likes this.
- kelson h
Kelson is offline
Old 05-29-2015, 11:03 AM
Quoted: 410 Post(s)
Liked: 68
+1 for makemkv
Old 05-31-2015, 11:05 AM
dazz87's Avatar
Quoted: 79 Post(s)
Liked: 40
Anyone else having an issue with the new MakeMkv beta 1.9.2. This morning I launch makemkv and it stated it was expired and that i needed to download the newest version. So I go on their site and download the latest version (been doing it for the past 2 years without no issue) This morning I removed the old version and then install 1.9.2. After I launch the program and get error "evaluation period has expired" But 1.9.2 is the latest version..... I then go and apply the trial key and it ask me to re launch the program. I launch the program and now I get this error.
Never had this issue before. Any suggestions?
dazz87 is offline
Old 05-31-2015, 11:09 AM
Keenan's Avatar
Quoted: 2212 Post(s)
Liked: 2001
I think it's every 2 months that the key changes and the developer just hasn't posted a new key yet. Give it a few days and it will probably show up.
Keenan is online now
Old 05-31-2015, 11:16 AM
dazz87's Avatar
Quoted: 79 Post(s)
Liked: 40
Okay I see. Thanks, I guess one way to make it work is to set my comp clock back to a old date.
This is what I have on my about tab.
ellisr63 likes this.
dazz87 is offline
Old 05-31-2015, 11:31 AM
cc_in_oh's Avatar
Quoted: 921 Post(s)
Liked: 525
Mine is exactly the same except where your says "Evaluation Ended" mine says "not started". I think I've had 1.9.2 for at least a month now...
It would be interesting to know if setting the clock back works - I don't think I've tried that since DOS days and even then it was iffy...
CC
Who knew "flammable" and "inflammable" mean the same thing???
cc_in_oh is online now
Old 05-31-2015, 11:40 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Wonder when they'll start charging?
pepar is offline
Old 05-31-2015, 11:53 AM
jsmiddleton4's Avatar
Quoted: 591 Post(s)
Liked: 200
Still tracking down exactly why, what changed, etc., but currently DVDFab FULL version is available even for US. Interesting, very interesting.....
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
