Ripping Blu-Rays II - Page 271 - AVS Forum | Home Theater Discussions And Reviews
 2260Likes
post #8101 of 11009 Old 09-04-2015, 10:38 AM
Wireless member
pepar's Avatar
Quoted: 1078 Post(s)
Liked: 552
Sure, and mine bitcoins in the background!
pepar is online now
post #8102 of 11009 Old 09-04-2015, 12:57 PM
Jon S's Avatar
Quoted: 928 Post(s)
Liked: 303
Originally Posted by jhughy2010 View Post
What do you plan to use this PC for? Be specific... is it for HTPC, re-encoding, ripping media, server purposes, gaming, etc... ?
If you are specific maybe we can help you build the perfect solution.
I use the PC to convert BR discs to MKV files... I then copy the files to a network drive so I can stream. I also use it for some work purposes as needed. I do not use it for HTPC or for gaming.
I already purchased a new PC... Intel i7-6700 4.0 GHz LGA-1151 Skylake processor, 16 GB RAM, one TB WD Caviar Black HDD, AMD R7 370 Radeon 2 GB video card, LG B-R recorder, full size tower case,800 PS and Windows 10 Professional for $1300. My old PC took about 45-60 minutes to transcode a BR file to a 2GB MKV file... My guess is that the new PC should be about 50-60% faster. The motherboard supports RAID so I will use the HDD from the old computer to use in a raid array for data and add a 250-500GB SSD for the boot files...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #8103 of 11009 Old 09-04-2015, 01:06 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
A NUC with an external BD drive could do this...
Having that in mind... the PC you just bought is incredibly overkill...
What do you mean by transcoding? I think you meant to say re-encoding? Is this done via Handbrake?
jhughy2010 is offline
post #8104 of 11009 Old 09-04-2015, 02:56 PM
cnelson87's Avatar
Originally Posted by Balthazar2k4 View Post
I used MakeMKV in conjunction with AnyDVD HD. Worked without a hitch.
Cool, thanks, I'll try that. I usually prefer ripping the main movie to a blu-ray folder structure, but only because that's what I've always done and I'm used to it. I'll give .mkv format a try.
cnelson87 is offline
post #8105 of 11009 Old 09-04-2015, 03:13 PM
Jon S's Avatar
Quoted: 928 Post(s)
Liked: 303
Yes, Handbrake... Remember, I plan to keep this computer for several years unless something great comes along... My wife uses laptops and have replaced them about every 18 months... Her latest laptop, a HP Scepter with an Intel i7 finally was as fast as my older PC.
Jon S is offline
post #8106 of 11009 Old 09-04-2015, 03:56 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Gotcha. It's worth it for Handbrake.
post #8107 of 11009 Old 09-04-2015, 10:24 PM
Wireless member
pepar's Avatar
Liked: 552
Jon, the SSD will make as much of a speed improvement as the newer CPU and associated architecture, i.e. bus speeds. I have an Intel 400GB PCIe NVMe as my boot and it is stupid fast. Also have several SATA SSD that i use for bouncing BD rips around during ClownBD processing.
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #8108 of 11009 Old 09-08-2015, 12:32 PM
Jon S's Avatar
Quoted: 928 Post(s)
Liked: 303
I noticed that Amazon has Sandisk Ultra II SSDs on sale today.... I picked up a 480GB SSD for $127... They also have the 960GB model for $257...
aaronwt, ellisr63 and jhughy2010 like this.
Jon S is offline
post #8109 of 11009 Old 09-08-2015, 01:11 PM
Wireless member
pepar's Avatar
Liked: 552
I use the leaderboard at storagereview.com and always factor reliability and speed into my decisions.
Jeff
ellisr63 likes this.
pepar is online now
post #8110 of 11009 Old 09-08-2015, 01:59 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Jeff
I just had a Crucial m4 64GB drive fail in less than 2 years. They took care of it without any problems though. I am still leary of SSD drives being able to last as long as HDDs do.
ellisr63 is offline
post #8111 of 11009 Old 09-08-2015, 02:05 PM
Wireless member
pepar's Avatar
Liked: 552
I share that concern, but the performance boost is too much to ignore. Backup/imaging strategy is still important, probably more so.
pepar is online now
post #8112 of 11009 Old 09-08-2015, 02:10 PM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
I had thought about going with SSDs for my NAS, but it would be too expensive, and I don't want to be worrying about drive failures every year.
ellisr63 is offline
post #8113 of 11009 Old 09-08-2015, 02:12 PM
Wireless member
pepar's Avatar
Liked: 552
That I would definitely not do! Plus, 5400rpm is sufficient for streaming media.
pepar is online now
post #8114 of 11009 Old 09-08-2015, 03:56 PM
Jon S's Avatar
Quoted: 928 Post(s)
Liked: 303
I would use the 480GB SSD for the boot and work drive for handbrake and transfer the finished file to my regular HDD... I also will keep an image of the boot drive on the regular HDD as a backup...
Jon S is offline
post #8115 of 11009 Old 09-08-2015, 05:13 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
I currently use MakeMKV or Pavtube Bytecopy to rip my Blurays. Sometimes with the new movies there seems to be a bunch of mpls to choose from, but they never seem to be the right number. It's like more program skips some versions. Is there any better products for bit for bit MKVs?
Lowell
The MarvelAtmos Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
post #8116 of 11009 Old 09-08-2015, 05:55 PM
UHD Addict
aaronwt's Avatar
Quoted: 6421 Post(s)
Liked: 3966
I typically use MakeMKV with AnyDVD HD running in the background and it hasn't caused me any issues. I always just ignore the warnings that initially pop up.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #8117 of 11009 Old 09-08-2015, 11:02 PM
DotJun's Avatar
Quoted: 585 Post(s)
Liked: 160
You don't need ssd speed for handbrake encoding unless you are doing extremely fast encoding by using lower bit rate and/or lower resolution.
The only time I've ever seen the hdd becoming a bottleneck when it comes to encoding is when you are encoding raw uncompressed video.
DotJun is online now
post #8118 of 11009 Old 09-09-2015, 05:48 AM
mecmec's Avatar
Quoted: 455 Post(s)
Liked: 187
I'm still old school ISO. IMGburn and anydvd running into the background, one click 15-20 minutes later, done. I know I'm in the minority with ISO but I have yet to a have a single problem with my work flow, so stick with what works for me.
mecmec is offline
post #8119 of 11009 Old 09-09-2015, 05:56 AM
UHD Addict
aaronwt's Avatar
Liked: 3966
I use ISOs 99% of the time. And also use IMGBurn and any DVD HD. But the other 1% is when I use MakeMKV. For those titles that have hundreds of choices and only one correct one.
aaronwt is offline
post #8120 of 11009 Old 09-09-2015, 06:03 AM
Kelson's Avatar
Quoted: 2030 Post(s)
Liked: 1209
That's all well and good if you are still using legacy players that can handle a BD.iso rip and provide full menu support. Those haven't been made in years. BD.iso menu support is a thing of the past -- most regretfully. All of todays players play a single-title file so most of us are forced to rip their BD's as single titles -- which means digging into the structure and establishing a workflow for dealing with the distribution nasties like playlist obfuscation and the perennial problem -- forced subtitles.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #8121 of 11009 Old 09-09-2015, 06:17 AM
mecmec's Avatar
Quoted: 455 Post(s)
Liked: 187
I would not call my Oppo 103D a player that has not been made "in years". :-) Never an issue with playlist obfuscation or forced subtitles.
But yes, most of my back up players are long in the tooth. Right now I have sitting idly, a dune duo, modified pioneer bdp-62, netgear neotv 550, pch-200, and a dune smart b1, and probably a few others I should get around to digging out and ebaying!
mecmec is offline
post #8122 of 11009 Old 09-09-2015, 06:24 AM
Kelson's Avatar
Liked: 1209
Oppo removed .iso playback so I presume you are using hacked firmware?
If so you are a brave soul to take a chance bricking a $600 player.
billmich likes this.
- kelson h
Kelson is offline
post #8123 of 11009 Old 09-09-2015, 06:44 AM
johnBlanker's Avatar
Quoted: 418 Post(s)
Liked: 68
I normally use the pdvd and process monitor to find the playlist for discs with playlist obfuscation. I just tried this on Insurgent and this did not work. It didnt clearly show the mpls when the movie was playing. Does anyone know about this? Anything i can do?
johnBlanker is offline
post #8124 of 11009 Old 09-09-2015, 07:50 AM
Wireless member
pepar's Avatar
Liked: 552
My guess is that he simply did not advance the firmware past the one with ISO compatibility. It was known in advance that ISO was removed.
pepar is online now
post #8125 of 11009 Old 09-09-2015, 08:01 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3408 Post(s)
Liked: 2662
ISO firmware from OPPO lasted only about 5 months on the BDP-93. It was actually Medaitek that enabled and then removed it in the software support kit for the chip. The studios came down like a ton of bricks on both companies.
Anyone with ISO support on the -103 series is using some sort of hacked firmware. I've heard of it but never investigated.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #8126 of 11009 Old 09-09-2015, 08:03 AM
Kelson's Avatar
Liked: 1209
An ingenious suggestion was made a little ways back that I have not tried yet -- Insurgent will be a good test. At the least it is another tool to put in the toolbox for dealing with Lions Gate.
Originally Posted by jevans64 View Post
This a form of copy deterrent Lion's Gate is using to "fool" ripping software. It is called obsfucation. What I do is put the disc in my player and enter chapter mode. I write down the start times of each chapter and compare them with the times shown when listing the chapters in MakeMKV. It should work similar in your software, just visit their forums and search for a thread for the movie. Lion's Gate is using different sequences for each version of the movie, so they will be different depending on whether it is a rental, 2D, LE/DC ( Limited Edition/Director's Cut ), or 3D package.
- kelson h
Kelson is offline
post #8127 of 11009 Old 09-09-2015, 09:00 AM
Quoted: 418 Post(s)
Liked: 68
thanks Kelson. this doesn't really fit in my "one-click" lifestyle.
Looking at this post: http://www.makemkv.com/forum2/viewto...&t=9469#p41339
This guy talks about a "file compare tool (#4)". This is what I need since Process Monitor gives me this:
C:\Users\AppData\Local\Cyberlink\PowerDVD14\Caches \PowerDVD14Cache\LocalStorage\2.0\BUDA\1b7ac4686ea 688d84929a19ea1778d5c29cdb12c\7fff4c47\80000000000 000040150000000000002\00286.mpls
no, 286 is not the correct mpls.
I wonder if blackcell or blackssr have encountered this.
post #8128 of 11009 Old 09-09-2015, 09:09 AM
Ken.F's Avatar
Quoted: 1729 Post(s)
Liked: 1574
DVDFab was giving away free lifetime licenses for Passkey last month so I tried it out. It takes a few minutes to load a disc but it works great. It even tells you the mpls playlist for the main movie. I tested it out with "You're Next". MakeMKV lists 34 different playlists for that movie. Passkey didn't have any trouble picking out the correct one.
Ken.F is online now
post #8129 of 11009 Old 09-09-2015, 09:13 AM
Wireless member
pepar's Avatar
Liked: 552
Again, simply not moving to the newer firmware was the "workaround."
Hopefully, mecmec will chime in here.
pepar is online now
post #8130 of 11009 Old 09-09-2015, 09:24 AM
ScottJ's Avatar
Quoted: 318 Post(s)
Liked: 162
No. The BDP-93 original firmware supported ISO playback. The BDP-103 never did.
ScottJ is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
