Ripping Blu-Rays II - Page 277 - AVS Forum | Home Theater Discussions And Reviews
 980Likes
post #8281 of 10646 Old 10-22-2015, 01:51 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Originally Posted by Brian Hampton View Post
Hey,
Anyone want to tell me the thoughts on the best ways lately to have very large storage pools?
I have 2 4 bay NAS units with 4GB drives and Raid 5. Currently have about 1100 of my Blu Rays backed up on it.
I don't know if I should put together another ... or is there a better way now?
One thing I looked at today was the 6TB WD NAS Cloud gizmos. I wonder if I should start using those and then just mirror the drives to external USB 6TB archive type drives.
-Brian
I really am an advocate of Stablebit Drivepool coupled with their Scanner. I think it is the BEST solution for pooling various drives as one pool (I folder mounted the drives). Scanner is an incredible piece of software that will warn you well in advance of any drive failure. For my sensitive stuff like family photos and videos I enabled file duplication within Drivepool just in case. But in regards to my media (movies, shows, etc.) I am confident it will remain safe with Scanner.
jhughy2010 is offline
post #8282 of 10646 Old 10-22-2015, 02:43 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
Hey,
-Brian
If you use the cloud it will take for ever to backup...not to mention use a lot of your allotted data. I have a 20TB NAS, and I am thinking of getting another to have a dual backup.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #8283 of 10646 Old 10-22-2015, 06:03 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
If the 4-bay NAS are not enough, I would recommend you get a NAS array that can candle more drives... They go up to 10 bays but the prices are pretty steep. I don't care for the WD Cloud drives because they are pretty slow due to the slow processors in the NAS (I should know, I have one). Better NAS units have quad-core Celerons or even Intel I3 processors with 8GB RAM....
I am contemplating getting either a QNAP or one of the newer Asustor NAS arrays...
Brian Hampton likes this.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #8284 of 10646 Old 10-22-2015, 06:13 PM
Dr_Mark's Avatar
Quoted: 129 Post(s)
Liked: 180
Check out Synology servers on Amazon. WELL worth the money
Life is enjoyable with good quality
Dr_Mark is offline
post #8285 of 10646 Old 10-22-2015, 06:14 PM
UHD Addict
aaronwt's Avatar
Quoted: 5193 Post(s)
Liked: 3101
Hey,
-Brian
I use unRAID for my setups. I have one unRAID setup with 53TB. One with 41TB, and one with 35TB of total space.
Prior to unRAID I used a WIndows Home Server that had around 53TB of storage. But when I switched to unRAID I repurposed those drives to the unRAID setups. Although I've been finally getting rid of the last of those drives that used to be in my WHS. They were a bunch of the WD green drives. Which were great at the time, back in 2009/2010, but they run hotter than current 7200 rpm drives. So I've been in the process of replacing them and also increasing some of my storage capacity in the process.
ellisr63 likes this.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #8286 of 10646 Old 10-22-2015, 09:07 PM
artur9's Avatar
Quoted: 543 Post(s)
Liked: 185
What's the impact of it being so slow? Aren't all those disk devices slow?
artur9 is offline
post #8287 of 10646 Old 10-22-2015, 10:40 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
Copying a file from my computer to the Cloud drive is slow... The transfer rate averages 20-30Mbps.. Couple of minutes per movie....
Some of the newer NAS have a transfer rate about 200Mbps..
Jon S is offline
post #8288 of 10646 Old 10-23-2015, 01:34 AM
latreche34's Avatar
Quoted: 115 Post(s)
Liked: 57
Good lord! Are you backing up for Netflix or have a cloud storage business?
latreche34 is online now
post #8289 of 10646 Old 10-23-2015, 01:46 AM
latreche34's Avatar
Quoted: 115 Post(s)
Liked: 57
Hey,
-Brian
I would just keep the 1100 discs, too much time and money duplicating the library to HDD's
post #8290 of 10646 Old 10-23-2015, 04:14 AM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
I do keep the discs.
On the server though they stay organized and I can even voice search for a movie or keyword.
A bonus is I found a handful of damaged discs that I didn't realize were damaged. I replaced some of them and just kept the others for playback through the BDP (which is still hooked up of course.)
-Brian
Brian Hampton is offline
post #8291 of 10646 Old 10-23-2015, 06:47 AM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
Hey,
If you are talking about large storage pools for storing/serving video files -- IMHO, NAS units are an expensive overkill. Video storage disk farms are written to infrequently and mainly read from so a hardware RAID configuration that continuously updates parity information is not required. A PC-based solution with software RAID is ideal. A small i3 PC like a NUC or Shuttle with a bunch of USB-3 ports and 8-bay USB-3 disk towers will provide you with a reasonably-priced disk farm with enormous capacity and speed. While unRaid is good, it is a single-task system. I prefer a Windows-based system so I can have other things running on the server: FlexRAID for the softRAID solution; Mezzmo DLNA server; Plex server; TiVo servers. With PC softRAID like FlexRAID you can have the parity disk updated nightly or on demand after you add video to the array; you are also not confined to using the same sized disks in the array and the disks are NTFS formatted and individually accessible. It's highly flexible and highly expandable -- you just keep adding HDD's as you need them. The only caveat is that the parity disk(s) need to be as big or bigger than the largest disk in the array.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #8292 of 10646 Old 10-23-2015, 07:35 AM
UHD Addict
aaronwt's Avatar
Liked: 3101
20--30Mb/s?!? That is slower than the rate on a BD? But even 200Mb/s is very slow. Even my Old INTEL NAS with a RAID 5 would get 700Mb/s transfer rates. My unRAID with a Cache drive sees around 850Mb/s transfer rates. Of course when writing directly to the array it's much slower. Those speeds are only around 250Mb/s to 320Mb/s. But I use the ones without a cache drive strictly for BD rips. So those speeds aren't an issue when ripping a disc.
aaronwt is offline
post #8293 of 10646 Old 10-23-2015, 09:38 AM
Quoted: 572 Post(s)
Liked: 302
Thanks !
post #8294 of 10646 Old 10-23-2015, 11:49 AM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
I agree... I too was going to utilize FlexRAID, however, I found their website to be down for the better part of a month so there was no way of even purchasing/downloading the software. There was a massive exodus from FlexRAID at the time and lots of people recommended Stablebit as a solution/alternative. So far I am very pleased. If I had enough storage space I would enable file duplication for all media, however, I feel Scanner does a fine job at protecting my data through their disk failure early warning tools.
Kelson likes this.
post #8295 of 10646 Old 10-23-2015, 02:40 PM
Kelson's Avatar
Liked: 1147
I wasn't aware of stable-bit. I'll take a look and see what if offers.
thanks.
- kelson h
Kelson is offline
post #8296 of 10646 Old 10-23-2015, 02:55 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
The fact that he says couple of minutes per movie makes me wonder if you guys are speaking in the same units (megaBITS vs. megaBYTES)???
Theater 1: LG OLED55E6P 4K TV, Samsung UBD-K8500 UHD Blu-ray player, Oppo UDP-203, Dune HD Solo 4K
Theater 2: Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D (CFW), Dune Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
post #8297 of 10646 Old 10-23-2015, 03:20 PM
Quoted: 572 Post(s)
Liked: 302
Kelson,
If I buy a case that supports 10 drive bays.... In theory I could put together a 36TB server using 10 4TB drives .... right?..... I think this is what I want to do. I already have 8 of the drives in my NAS units.
I may not even do the software RAID part... don't know yet... Since I have all the original discs I may forego any type of redundancy apart from making some data base files that say what movies are on which ones.
-Brian
post #8298 of 10646 Old 10-23-2015, 03:56 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Kelson,
-Brian
Drivepool would work perfect for this and it is exactly what I do. I bought both drivepool + scanner... it pools the drives nicely (mount to a C drive folder) and then scans the disks on a scheduled basis.
post #8299 of 10646 Old 10-23-2015, 04:32 PM
ScottJ's Avatar
Quoted: 296 Post(s)
Liked: 152
Kelson,
Why not use 6TB HDDs? If you consider the cost of the NAS itself in the per-TB price, it might be cheaper.
(Or maybe you are planning to move your existing 4TB HDDs to the new box?)
ScottJ is offline
post #8300 of 10646 Old 10-23-2015, 05:19 PM
desertdome's Avatar
Quoted: 1119 Post(s)
Liked: 1222
Originally Posted by SOWK View Post
If MakeMKV ever does go down permanently what is a good alternative?
AnyDVD HD and JRiver Media Center.
Insert Disc
Click Rip
Get only the main title of movie on drive array in about 20 minutes
My 6 year old rips Blu-rays for me (as do the two older kids).
desertdome is offline
post #8301 of 10646 Old 10-23-2015, 05:50 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
This does look cool...question though: the picture shows an F drive for your pooled set of drives. So, I'm confused when you said "mount to a C drive folder"...what does that mean?
Chris
fatherom is offline
post #8302 of 10646 Old 10-23-2015, 06:28 PM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Chris
Yes it is very simple. Simply mount each drive to a folder under C drive. I asked this question awhile ago prior to creating the C drive folder and mounting each drive.
The instructions are attached.
Once you install each drive and mount them to a folder (they will not show up in file explorer when mounted to a folder) you install Drivepool. In Drivepool you'll create a "pool" then add the "folder mounted" drives to the "pool".
fatherom likes this.
post #8303 of 10646 Old 10-23-2015, 07:16 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
Wow...never knew you could mount drives as folders like that. Good to know. And, in a way, that kind of already allows "pooling" of multiple drives into a single location, but I can see where Drivepool would let you re-organize what the single volume presents as far as directories and locations of files.
But here's what I'd like to do:
I currently have 8 existing drives full of stuff. I know Drivepool will allow me to pool all 8 of those drives and leave the data untouched. I can then organize the pooled directory into any structure I like, without touching the original data on the 8 original drives. So far, so good.
But when I add something new, I don't want drivepool to decide where it ends up. I still want to put the new files on one of the 8 drives of my choosing, in a directory on that drive of my choosing. THEN I want to decide where in the pool those new files go.
Is this possible?
Chris
EDIT: just realized that drivepool tends to take over and there's no way to really get around that. Also realized that with some clever folder mount points I could achieve what I want. It begs the question...if the goal is simply to merge a bunch of disks into one large area, what advantage does drivepool provide over just mounting the disks as folders in one place?
jhughy2010 likes this.
fatherom is offline
post #8304 of 10646 Old 10-24-2015, 12:08 AM
jhughy2010's Avatar
Quoted: 840 Post(s)
Liked: 275
Is this possible?
Chris
I think I kind of grasp what you are asking... let me try to clarify and if I cannot check this thread out and then this one.
Both the aforementioned threads really helped me understand the pooling process and helped me understand how pooling with Drivepool aided in data simplicity and integrity.
Mounting drives to a NTSF folder doesn't necessarily create a "pool" like I think you are thinking. In fact, mounting the drives to a single folder is what I did and it doesn't create a single pool like one might think.
There are lots of different ways you can organize the pool structure. The two main different ways in organizing the data is either allowing an equal amount of data to be spread among the drives or filling up one drive at a time.
It sounds to me like you may want multiple pools? In my opinion why not make one giant pool and then have multiple folders in that pool.
I think this is the most simplistic and reasonable way to use Drivepool. I enabled duplication for the things I don't have external disks for (i.e. pictures and videos) while the movies need not have file duplication (after all that would take up lots of space). Duplicated files do not end up on the same drive and the data allotment ends up equal among the multiple drives.
Lastly, aside from using software RAID like Drivepool or flexRAID I do not think you'd want to mount to a folder on the C drive... Anyhow, there are members that know a heck of a lot more about this stuff than I do and hopefully they can chime in.
post #8305 of 10646 Old 10-24-2015, 07:12 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
Sorry, you are right... it is MBps... not Mbps...
Jon S is offline
post #8306 of 10646 Old 10-24-2015, 08:45 PM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
I've done some reading and decided, for my purposes, I can achieve a combined set of media from my 8 drives by using NTFS symbolic links and junctions. That way I can still manage my 8 drives independently, but still have a single combined view of all my media that my media players see.
fatherom is offline
post #8307 of 10646 Old 10-25-2015, 02:58 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Originally Posted by cnelson87 View Post
I'm fairly certain that is not true. Pretty sure the blu-ray video spec is 1920x1080 (1440x1080 and 1280x720 are also spec but I've never seen one). I've ripped hundreds of blu-rays over the years and running them through MediaInfo has never, not even once, reported a video resolution other than 1920x1080.
MPEG-2 requires luma to be devisable by 16, hence 1088. Your player will auto crop the bottom 8 pixels. If you demux the video you can clearly see the bottom 8 pixels as being garbled, assuming the app you view your demuxed video and the demuxed itself does not autocrop the original video.
DotJun is offline
post #8308 of 10646 Old 10-25-2015, 02:59 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Yes. i did the shrinking stuff back in 2001 through 2004 with DVDs. When I started ripping my BDs in 2009 I swore I would never mess with shrinking anything again. I just want to rip it and be done with it. And especially now, with storage cheaper than ever, I'm not worried about making a small 45GB file smaller..
The topic was for people that want to compress and not that storage is cheap
DotJun is offline
post #8309 of 10646 Old 10-25-2015, 07:17 AM
Ken.F's Avatar
Quoted: 1471 Post(s)
Liked: 1255
Everyone keeps saying how cheap storage is but nobody has offered to buy me any HDDs. Other people's money is easy to spend.
ellisr63 and DotJun like this.
Ken.F is offline
post #8310 of 10646 Old 10-25-2015, 07:56 AM
Vorkosigan's Avatar
Quoted: 39 Post(s)
Liked: 34
You may want to take a look at the latest Unraid. It now supports Docker apps and running VMs.
Vorkosigan is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
