Ripping Blu-Rays II - Page 304 - AVS Forum | Home Theater Discussions And Reviews
 980Likes
post #9091 of 10654 Old 02-20-2016, 09:37 PM
blackssr's Avatar
Quoted: 1160 Post(s)
Liked: 579
Originally Posted by Kelson View Post
Cool, thanks. That must be a function of the new version of TSMuxer.
I'll have to play with it and redo my LOTR EE's.
The last Hobbit 3D EE had chapters 1-50, I believe when completed.
I've paid for my sins. We're even!
blackssr is offline
post #9092 of 10654 Old 02-20-2016, 11:52 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Originally Posted by elee532 View Post
Can anyone offer thoughts as to why my BD rip is so slow (see attached). Going on 12 hours for a single BD rip. I've tried a few different discs. I'm using a Surface Pro 3 with Core i5 CPU. Drive is LG CP50NS20 6x.
It could be a problem with the disc. I've noticed extremely long processing times when there are faults on the disc which causes hundreds of retries and not enough of a problem to cause a fault.
I've also noticed longer than normal rip times when dealing with two USB devices. Even though USB has decent throughput, the latency is horrible.
DotJun is offline
post #9093 of 10654 Old 02-21-2016, 03:32 AM
bluewhale1's Avatar
Quoted: 420 Post(s)
Liked: 165
For those using ClownBD it hasn't been updated in a while. If you are updating each app itself which specific ones are you updating? I assume eac3to and tsmuxer are ok to manually update to a newer version but what about Aften, Mencoder and Muxman. As i understand it BDsup2sub should not be touched.
bluewhale1 is online now
post #9094 of 10654 Old 02-21-2016, 05:01 AM
Ken.F's Avatar
Quoted: 1478 Post(s)
Liked: 1262
You have the streaming server running. I never use it so I don't know if that's messing with the rip but it might be something to check.
Ken.F is offline
post #9095 of 10654 Old 02-21-2016, 09:02 AM
elee532's Avatar
Quoted: 78 Post(s)
I just realized that my NAS was connected to a 10/100 port, and not a 1Gb port. Ripping to the NAS was much faster this time. It took about 90 minutes for a bluray this time.
Sounds like the free disk space theory might have been right. Odd though. How much free disk space is necessary to rip a 30GB bluray?
elee532 is offline
post #9096 of 10654 Old 02-21-2016, 09:06 AM
elee532's Avatar
Quoted: 78 Post(s)
How do I merge two MKV files using MKVToolNIX? One contains the main movie and the other file contains extras. MKVToolNIX offers three options: Add Files, Append Files, Add files as additional parts. Which should I choose?
Also, one part has 16/48Hz 2-channel DTS track and the other 24/92 Hz 6-channel DTS-HD track. How will this be handled when the two MKV files are merged?
elee532 is offline
post #9097 of 10654 Old 02-21-2016, 11:24 AM
Kelson's Avatar
Quoted: 1953 Post(s)
Liked: 1148
I've been using Clown for years and the only app I've upgraded is eac3to to v3.31. I've read the "new" version of TSMuxer (which as actually 2yr old) has some changes to the CLI which gives Clown trouble so I leave it alone. The rest work fine as they are so I leave them alone also.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #9098 of 10654 Old 02-21-2016, 11:34 AM
bluewhale1's Avatar
Quoted: 420 Post(s)
Liked: 165
Thanks will update just that.
post #9099 of 10654 Old 02-21-2016, 12:30 PM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
Thanks for checking. I will try this for LOTR, Hobbit and Titanic.
jvh4 is offline
post #9100 of 10654 Old 02-21-2016, 12:39 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2744 Post(s)
Liked: 1971
Append appends them. That is: 2 10 minute source files will become 1 20 minute destination file.
All the tracks have to be of the same type and in the same order. You can mess with the order but it is more work. I suspect your audio tracks are not compatible as is.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #9101 of 10654 Old 02-21-2016, 12:43 PM
wmcclain's Avatar
Liked: 1971
You're using NTFS? I'd keep 10% free and defragment.
-Bill
post #9102 of 10654 Old 02-21-2016, 12:49 PM
bbusse's Avatar
Quoted: 102 Post(s)
Liked: 55
If you end up with a step by step to combine these 3D movies into one full length feature I'd be interested in it. I will have to tackle Titanic soon enough and hadn't considered it would be on two discs. The instructions posted on slysoft weren't exactly step by step simple to understand.
-B
bbusse is offline
post #9103 of 10654 Old 02-21-2016, 12:52 PM
elee532's Avatar
Quoted: 78 Post(s)
-Bill
NTFS. 44Gb free trying to rip a 33GB disc. Who knows. Not gonna worry about it any longer though. :-)
elee532 is offline
post #9104 of 10654 Old 02-21-2016, 12:57 PM
elee532's Avatar
Quoted: 78 Post(s)
This is definitely what I would like.
Bummer! Any idea what would happen? The two MKV files just won't merge? They would use the "lowest level" audio format? Off to do some experimenting.
You happen to know whether there is a support forum for MKVToolNix? I tried looking through some of the info on their website, but most of it was over my head.
elee532 is offline
post #9105 of 10654 Old 02-21-2016, 01:30 PM
artur9's Avatar
Quoted: 547 Post(s)
Liked: 189
Ben Hur 50 edition is also on two discs. At least, via naming, Kodi can make it look like one movie but I think combining the two parts would be better.
artur9 is offline
post #9106 of 10654 Old 02-21-2016, 10:21 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Ripping Blu-Rays II
-Bill
Windows' copy /b command will append two files with dissimilar streams.
I didn't have time to check out how it works when playing, does the player seamlessly switch from one audio format to another for instance, but I do know that it plays fine on mpchc.
DotJun is offline
post #9107 of 10654 Old 02-21-2016, 11:10 PM
UHD Addict
aaronwt's Avatar
Quoted: 5247 Post(s)
Liked: 3140
I've ripped from four USB BD drives concurrently. They rip just as fast as when I rip from one drive. I've ripped six concurrent titles when you add the two I have connected to SATA ports. As long as the hard drive can keep up, which an SSD typically can, the rip speeds will be the same as when just ripping one disc.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #9108 of 10654 Old 02-21-2016, 11:13 PM
UHD Addict
aaronwt's Avatar
Liked: 3140
Whatever the file size is should be all that is needed. At least that has been my experience. I've ripped titles where I only have Megabytes free after the rip. It hasn't caused me any issues.
mrfattbill likes this.
aaronwt is offline
post #9109 of 10654 Old 02-21-2016, 11:53 PM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I was talking about from a USB optical to a USB hdd.
DotJun is offline
post #9110 of 10654 Old 02-22-2016, 07:29 AM
UHD Addict
aaronwt's Avatar
Liked: 3140
I've also done that. One or more USB optical drives to one USB hard drive rips at the same speed as when connected to a SATA port. Of course I'm talking about the hard drive with a USB 3.0 connection.
aaronwt is offline
post #9111 of 10654 Old 02-22-2016, 08:11 AM
blackssr's Avatar
Liked: 579
Please let me know about Titanic. I tried several times with no luck.
Thanks in advance.
blackssr is offline
post #9112 of 10654 Old 02-22-2016, 08:16 AM
blackssr's Avatar
Liked: 579
If using Clown_Bd free space required would be twice the size of the source. Remember Clown_BD Creates a demux and remux directory, So in effect a 40 gig BD could require 80 gig free space while working.
blackssr is offline
post #9113 of 10654 Old 02-22-2016, 09:00 AM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
Thanks in advance.
The project isn't imminent, but I will definately report back.
@bbusse if I get the process down and repeatable, I'll work up a quick guide. Big if
jvh4 is offline
post #9114 of 10654 Old 02-22-2016, 05:17 PM
bbusse's Avatar
Quoted: 102 Post(s)
Liked: 55
Cool. I won't get to mine for a bit either so if I get there first and figure it out I will do the same.
-B
bbusse is offline
post #9115 of 10654 Old 02-23-2016, 03:39 PM
blackssr's Avatar
Liked: 579
Slysoft in Legal Trouble
http://www.myce.com/news/slysoft-dow...reasons-78654/
This should be interesting to see how it plays out.
blackssr is offline
post #9116 of 10654 Old 02-24-2016, 05:06 AM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
That's interesting.... I have no use for Slysoft but if it's being actively shut down I guess that proves it IS useful.
-Brian
Brian Hampton is offline
post #9117 of 10654 Old 02-24-2016, 07:37 AM
UHD Addict
aaronwt's Avatar
Liked: 3140
Yes, it shows they have been shut down now
Hi all,
We were not allowed to respond to any request nor to post any statement, but now it is official:
SlySoft has been shut down after almost 13 years. The official statement on the website (http://www.slysoft.com/ or http://h4.slysoft.com/) is kind of short:
At least I got many years of use from my ANy DVD lifetime license. I think I got it around a dozen years ago.
I guess I'll be creating more MKVs in the future.
aaronwt is offline
post #9118 of 10654 Old 02-24-2016, 07:42 AM
Kelson's Avatar
Liked: 1148
DVDFab quickly rose from the ashes and is doing business once again as if AACS-LA didn't exist. Let's see if SlySoft has the fortitude to do the same. Granted, Bejing owns the US debt and has more muscle than little Antigua.
- kelson h
Kelson is offline
post #9119 of 10654 Old 02-24-2016, 08:40 AM
blackssr's Avatar
Liked: 579
Can US still buy the full version of DVDfab with decryption capabilities without back door upgrades?
blackssr is offline
post #9120 of 10654 Old 02-24-2016, 09:45 AM
Kelson's Avatar
Liked: 1148
I believe DVDFab has been offering the full unrestricted version for direct download from their .cn-based website for some time now.
In any event, this link:
http://174.142.97.100/download/DVDFab9231.exe
is a direct link to their server to get you the the EU version with full capabilities.
For future versions you only need to change the version # in the link to the latest version.
i.e. "DVDFab9231" is for v 9.2.3.1 that was released yesterday
They publish the MD5 & SHA1 checksums for the releases on their forum page for new releases. You can use them to verify integrity and authenticity of the download. The relevant fact is they no longer publish separate EU and US checksums and the file you download from the direct EU link above appears identical to the one you download from their dvdfab.cn website.
It appears to be business as usual as if the AACS-LA didn't exist.
captainbrent likes this.
- kelson h
Kelson is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
