Ripping Blu-Rays II - Page 330 - AVS Forum | Home Theater Discussions And Reviews
 789Likes
post #9871 of 9898 Old 09-25-2016, 05:10 AM
Liked: 0
I had asked before some time ago but i'm not sure it will be ok. So again.
I have a original disc (Valkyrie) and I want a backup from this. The file it's 45,2GB (48.541.593.873 bytes) . Can I use a single 50GB (actual free size it's 45,1GB 48.440.016.896 bytes) ? Can I burn this with NERO ?
Vasilis07 is offline
post #9872 of 9898 Old 09-25-2016, 07:09 AM
Greg Jones's Avatar
Originally Posted by stonesfan129 View Post
Something like this - https://www.amazon.com/LG-Electronic...+blu+ray+drive or this https://www.amazon.com/LG-Portable-B...+blu+ray+drive should work fine. Note that the first drive supports the BDXL discs, which could be an advantage if 4K UHD ripping becomes a thing. Quality is exactly the same as long as you are just doing rips, not compressing.
The drive in the first link (BE14NU40) seems to be a discontinued model and only available used. There is another model from LG that seems to its replacement (BE16NU50). Here is a link.
Cheers,
Sony XBR-65X850D; Emotiva XMC-1 Pre/Pro; Emotiva XPA-7 Gen 3 Amp; Sony BDP-S470; Paradigm Monitor 7 Mains; Paradigm CC-370 Center; Paradigm Titan Surrounds; Velodyne DLS3750R Sub
Greg Jones is offline
post #9873 of 9898 Old Yesterday, 04:11 PM
yangh's Avatar
Quoted: 13 Post(s)
Liked: 6
Sorry for my naive questions. This post is so long I may as well just ask the simple question here.
I have now accumulated a few dozen BD discs that I want to rip into my server. I'm not interested to transcoding/MKV or anything, essentially I just want to backup the whole disc into an iso or folder whichever is the best for KODI to play on my HTPC. What are the best software for this purpose? I'll do this under Windows 10 and an external BD drive. Thanks!
yangh is offline
post #9874 of 9898 Old Yesterday, 04:42 PM
Wireless member
pepar's Avatar
Quoted: 764 Post(s)
Liked: 455
Read the first post, always the thing to do before posting. That's a large part of how this "thread" got so long.
You will need to compare your gear's file compatibility with the output formats of any software you choose.
pepar is offline
post #9875 of 9898 Old Yesterday, 05:38 PM
yangh's Avatar
Quoted: 13 Post(s)
Liked: 6
Thank for the quick reply! I read the first post and several pages and googled..
If I get it correct, it seems my best choice is to buy AnyDVD HD, once has it installed I can use other tools to copy BD disc into an ISO. Or with AnyDVD HD running, I can just copy the whole disc as into a folder on hard disk?
I'm using KODI on my HTPC running Windows 10. KODI seems to be able to play BD folders ok.
yangh is offline
post #9876 of 9898 Old Yesterday, 05:43 PM
ScottJ's Avatar
Quoted: 248 Post(s)
Liked: 132
There are so many options, and it really depends on how you plan to play the ripped movies. I know nothing about Kodi so can't give you a complete answer.
One thing to consider with ripped Blu-rays is forced subtitles. About 5% of discs out there have a handful of subtitles which a Blu-ray player will display automatically. (District 9, Gran Torino for examples.) The movie can be really confusing without the forced subs. You have to rip carefully to make sure you capture the forced subs properly, where "properly" depends on what your playback system supports. Many don't support any forced subs at all; I expect Kodi supports MKV forced subs. You can rip to MKV using MakeMKV. No transcoding is necessary. Of course you will lose the Blu-ray menus.
ScottJ is offline
post #9877 of 9898 Old Yesterday, 06:04 PM
yangh's Avatar
Quoted: 13 Post(s)
Liked: 6
yes forced subtitle is the reason I think it's better to backup the whole BD so hopefully not to worry about forced subtitles. I don't have a chance to test whether KODI (XBMC) support forced subtitles, but I'll should be able to figure it out once I start ripping.
Can MakeMKV also be used just to back up the BD into a folder on hard drive?
Edit: seems it does? "MakeMKV can create a decrypted backup of a Blu-ray disc on a hard drive. Decrypted backup will contain all files from original disc but M2TS files will be decrypted (both AACS and BD+ will be removed). "
http://www.makemkv.com/faq/item/4
yangh is offline
post #9878 of 9898 Old Yesterday, 06:14 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 1973 Post(s)
Liked: 897
Yes, MakeMKV has a full backup option as well as MKV output.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #9879 of 9898 Old Yesterday, 06:21 PM
yangh's Avatar
Quoted: 13 Post(s)
Liked: 6
Thanks for confirming that! Now I'm leaning toward MakeMKV. I couldn't find its price right away on its website. How much does it cost?
yangh is offline
post #9880 of 9898 Old Yesterday, 06:29 PM
wmcclain's Avatar
Liked: 897
"Free while in beta" which seems to be a permanent status. You have to reenter a key every couple of months.
Perpetual license is $50. Enter the key only once. Well worth it.
-Bill
Keenan and captainbrent like this.
post #9881 of 9898 Old Yesterday, 06:36 PM
yangh's Avatar
Quoted: 13 Post(s)
Liked: 6
got it. Will test it first. If it works well $50 seems to be a very reasonable price.
yangh is offline
post #9882 of 9898 Old Today, 05:22 AM
Kelson's Avatar
Quoted: 1849 Post(s)
Liked: 1084
I'm not interested to transcoding/MKV or anything, essentially I just want to backup the whole disc into an iso or folder . . . What are the best software for this purpose? I'll do this under Windows 10 and an external BD drive.
Taking your post strictly at face value, there is a simple answer:
Download/Install MakeMKV (free). Use the File/Backup command to rip the full disk to a folder.
Done
If you want an .iso, Download/Install ImgBurn (free). Use it to create an .iso image file of the folder you just ripped with MakeMKV.
Done.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #9883 of 9898 Old Today, 05:27 AM
artur9's Avatar
Quoted: 485 Post(s)
Liked: 156
For how well it works and how easy to use it's a bargain. Once you have it set up with a custom profile (optional) it's a snap to have a ripping session.
artur9 is offline
post #9884 of 9898 Old Today, 07:42 AM
mr266's Avatar
Quoted: 108 Post(s)
Liked: 710
A quick question since people recently have mentioned using MakeMKV to do a full copy/backup. I have been using the free version for awhile now but have never seen the backup button enabled (always greyed out). Is this just an option with the paid version, or am I mission something?
WDTV Live SMP with WD EX4100 NAS
Polk RTI8 Front, Polk CSI5 Center, Polk RTI4 Surround
MTX SW2 12” SUB, Sharp AQUOS LC-70C6400U
URC-WR7 Universal Remote
Motorola QIP7232 (P2) FIOS DVR, Sony BDP-S590 Blu Ray Player
Panasonic SA-HE100 AVR,Technics SL-B20 Turntable
mr266 is online now
post #9885 of 9898 Old Today, 07:54 AM
metalsaber's Avatar
Quoted: 827 Post(s)
Liked: 704
I use makemkv, but I assumed that most referring to making sure all the checkboxes were selected to do a full copy. I don't do that as its a waste of space. I don't need subs or foreign languages or special features. I just rip the movie and the lossless english audio.
metalsaber is offline
post #9886 of 9898 Old Today, 08:03 AM
wmcclain's Avatar
Liked: 897
It's greyed out when you have a disc open. Close the disc in the menu and the option will be available.
-Bill
post #9887 of 9898 Old Today, 08:34 AM
cnelson87's Avatar
Having trouble with the forced sub track on Captain America Civil War BR. Ripped with AnyDVD and processed with Clown_BD to movie-only BR folder structure. The second EN sub track is for the Russian lang parts, it definitely should be marked as forced, but isn't. Don't think I've ever seen forced subs like this before -- I assume the forced behavior is handled in the menu coding, which is lost when remuxing. Any ideas?
cnelson87 is offline
post #9888 of 9898 Old Today, 08:47 AM
mr266's Avatar
Quoted: 108 Post(s)
Liked: 710
-Bill
Just tried it again. The save selected files button is active but the backup button never goes active at any time.
mr266 is online now
post #9889 of 9898 Old Today, 08:54 AM
wmcclain's Avatar
Liked: 897
I insert a disc. File -> Backup is available on the menu and there is a Backup icon on the tool bar.
I open the disc by menu or by clicking on the image. Backup menu selection and icon are not active.
I do File->Close. Menu and icon selections are available again.
Note this works only for Blu-ray, not DVD.
If that is not what you see then I recommend the MakeMKV forum for help.
-Bill
post #9890 of 9898 Old Today, 09:08 AM
mr266's Avatar
Quoted: 108 Post(s)
Liked: 710
-Bill
Thanks Bill. Got it to work using your instructions and a BD. Seems odd to do an extra step when it could easily be coded to give your the back up choice once the disc is opened. Also strange that it only works with BD and not any disc. Anyway, thanks again.
-Mike
mr266 is online now
post #9891 of 9898 Old Today, 10:01 AM
LastButNotLeast's Avatar
Quoted: 1240 Post(s)
Liked: 888
That's why it's still in beta.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #9892 of 9898 Old Today, 10:14 AM
replayrob's Avatar
Quoted: 567 Post(s)
Liked: 514
^ and still free!
“You cannot play God and then wash your hands of the things you created.”
Commander Bill Adama
replayrob is offline
post #9893 of 9898 Old Today, 01:09 PM
mr266's Avatar
Quoted: 108 Post(s)
Liked: 710
Originally Posted by replayrob View Post
^ and still free!
Well that brings me back to the original question...can you do these things with the paid version?
mr266 is online now
post #9894 of 9898 Old Today, 01:26 PM
Liked: 888
Sure, you just don't need to enter a new code periodically.
post #9895 of 9898 Old Today, 02:04 PM
AVS Club Gold
aaronwt's Avatar
Quoted: 4413 Post(s)
Liked: 2637
Originally Posted by pepar View Post
Again, aaronwt, why ISO and not simply folder structure?
Jeff
It's what I decided on back in 2009 when I first started ripping my BDs. Since it was just a matter of quickly ripping it. And you have the one ISO file. It's always worked well with my media players. And I continue to use ISOs except for the titles with playlist obfuscation. And I use makeMKV to create an MKV for those after selecting the correct title.
Plus with the ISO and can easily access the full menus if I want. Or I can even use it to create an MKV later.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #9896 of 9898 Old Today, 02:06 PM
AVS Club Gold
aaronwt's Avatar
Liked: 2637
I was thinking about the additional processing step to convert the folder structure back to ISO. Of course, I am assuming that aaronwt's ISOs are not 1:1.
Jeff
Yes. They are all 1:1. After shrinking DVDs in the early 2000's I swore i would never, ever do that again. So every BD rip I've done, since I started in 2009, are 1:1 rips.
it's why I have a total of 129 TB of storage between my three unRAID setups.
aaronwt is offline
post #9897 of 9898 Old Today, 03:37 PM
yangh's Avatar
Quoted: 13 Post(s)
Liked: 6
Just curious, is there anything you can't do with a BD folder backup comparing to the ISO backup? Except that ISO is convenient for burning a disc copy?
yangh is offline
post #9898 of 9898 Old Today, 08:44 PM
Liked: 888
And you're keeping all these movies forever WHY?
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
