Ripping Blu-Rays II - Page 361 - AVS Forum | Home Theater Discussions And Reviews
 1014Likes
post #10801 of 10822 Old 04-05-2017, 01:16 PM
Wireless member
pepar's Avatar
Quoted: 1011 Post(s)
Liked: 522
Anybody using JRiver? Popcorn Hour has been great for movies, but doesn't cut it for a large music library. PM me.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #10802 of 10822 Old 04-13-2017, 10:25 AM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
Further update on using Handbrake and enabling H.264 Intel QSV encoding... Apparently the issue I am having (where the video turns to garbage every few seconds) is disc specific. I can encode the movie Lion with no issues trying multiple times. But when i try to encode Hidden Figures, it fails every time.
I like the fact that using QSV reduces encoding times a lot... For example, encoding the movie Passengers can be done in 20-30 minutes, but using the built-in H.264 encoder in Handbrake will take about 150 minutes in the Super HQ mode.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #10803 of 10822 Old 04-14-2017, 10:41 AM
mrfattbill's Avatar
Quoted: 98 Post(s)
Liked: 89
The files are already ripped and not being converted directly from the disc correct?
Bill
mrfattbill is offline
post #10804 of 10822 Old 04-14-2017, 08:35 PM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
Bill
Yes...
Jon S is offline
post #10805 of 10822 Old 04-15-2017, 06:15 AM
Wireless member
pepar's Avatar
Liked: 522
Yes...
Your processor is not maxed out? Your data bus isn't saturated? Check the bitrate of the passage that encodes correctly and the one they fails.
pepar is online now
post #10806 of 10822 Old 04-15-2017, 10:32 AM
hart2hart's Avatar
Quoted: 53 Post(s)
Ripping Blu-Rays II
I've had a couple of movies out of 500ish (one of them is a version of Good Will Hunting) that I've ripped as movie only to iso file using eac3to and tsmuxer via Blu-Ray Ripper and Clown_Bd with a playback issue. They just stop playing on a Dune Solo player at consistent spots in the movie.
I am ripping again now using only tsmuxer and will try both CloneBD and MakeMKV to see results.
Has anyone else seen this and / or know what causes it?
hart2hart is online now
post #10807 of 10822 Old 04-15-2017, 11:30 AM
jasonkennethrose's Avatar
Quoted: 140 Post(s)
Liked: 43
I don't have Good Will Hunting but if you have any other example discs that I do have I will be more than willing to test. I do know that in 0.098 version of Blu-Ray Ripper there was a change to the tsMuxer commands to fix corruption of H264 video with SEI and VIU data. If you are still having issues after that version I would have to see a disc that showed the issue.
You can try tsMuxerGUI and use the option "Do not change SEI and VUI data" on Good Will Hunting to see if it fixes your issue.
jasonkennethrose is offline
post #10808 of 10822 Old 04-15-2017, 04:07 PM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
The problem I am getting is that the video is okay for two seconds and flashes into garbage for two seconds and this keeps on repeating throughout the video. it's not a bit rate issue... Rogue One is 36GB and Hidden Figures is about 29GB in size. Both movies run a bit over two hours. Rogue One has no issues using QSV but Hidden Figures crashes all the time, whether I use H.264 or H.265 Intel QSV Encoding...
Jon S is offline
post #10809 of 10822 Old 04-20-2017, 11:13 PM
DotJun's Avatar
Quoted: 576 Post(s)
Liked: 155
Curious, do you get the same outcome if you encode without qsv enabled?
DotJun is offline
post #10810 of 10822 Old 04-21-2017, 06:17 AM
johnBlanker's Avatar
Quoted: 418 Post(s)
Liked: 68
Ripping directly to NAS?
I set the temp storage and the output destination on DVDfab to the workstation pc. DVDfab seems to rip as native bd folder in the temp folder first, then it converts to ISO and sends it to the output destination. When it is complete (usually 30 min or so) I copy and paste the ISO to the shared folder on the NAS. I'd like to eliminate this 2-stage process and rip directly to the shard NAS folder but it takes forever. If I set the output destination to the NAS shared folder in DVDfab it takes hours. Does anyone know why?
What do you guys do?
johnBlanker is online now
post #10811 of 10822 Old 04-21-2017, 06:50 AM
Quoted: 140 Post(s)
Liked: 43
I copy from the disc straight to a NAS using AnyDVD-HD to decrypt on the fly and Blu-Ray Ripper to take just the main movie. Depending on the length and how the disc was authored it can take from 15 to 30 minutes a movie. Works every time.
post #10812 of 10822 Old 04-21-2017, 06:54 AM
Quoted: 418 Post(s)
Liked: 68
Does Anydvd store in a temp folder on the workstation first? I will try again. I was using a freenas build but now I have switched over to a Netgear NAS, maybe things will be different. Though I suspect this might be a dvdfab thing.
post #10813 of 10822 Old 04-21-2017, 08:26 AM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
nope... works fine with the built-in encoder. It's only QSV and it is title specific... Hidden Figures will crash 100% of the time. Passengers will crash 50% of the time... Rogue One will work 100% of the time... So it's a crap shoot when i buy and rip a new title...
Jon S is offline
post #10814 of 10822 Old 04-21-2017, 08:30 AM
Quoted: 140 Post(s)
Liked: 43
AnyDVD-HD decrypts disc's. It does this on the fly (as you read/copy information). It can also rip directly to ISO or folder structure. It does not require a temp folder you can rip from disc to a save location in ISO or folder format.
If you are looking to process the disc in any way (movie only) you just need AnyDVD-HD running while your program accesses the information.
post #10815 of 10822 Old 04-21-2017, 08:37 AM
sharok's Avatar
Quoted: 259 Post(s)
Liked: 77
I have a DVD Audio (David Tipper - Surrounded) which has a 24 bit/96Khz (MLP format). What software should I use to rip this DVD-Audio?
Makemkv cannot extract the MLP format. I don't know what else to use.
sharok is offline
post #10816 of 10822 Old 04-21-2017, 09:02 AM
Wireless member
pepar's Avatar
Liked: 522
Running RAID on your NAS? What level/scheme?
pepar is online now
post #10817 of 10822 Old 04-21-2017, 11:11 AM
rdgrimes's Avatar
Quoted: 2180 Post(s)
Liked: 1513
2 choices:
1) Rip the individual tracks as wav or FLAC files. This requires software such as "DVDAExplorer" or "DVD Audio Extractor"
2) Rip an ISO of the disc, which can ONLY be done using DVDFab DVD Copy module in "clone" mode. The ISO can only be used to create another disc, since no media player boxes support DVD-A. (The ISO can be played with an Oppo BDP-93 that has ISO support firmware)
rdgrimes is online now
post #10818 of 10822 Old 04-21-2017, 12:42 PM
Wireless member
pepar's Avatar
Liked: 522
Originally Posted by rdgrimes View Post
2 choices:
I have both. In my experience there are some titles on which one will work and not the other, and then other titles vice versa. One requires a license.
Jeff
pepar is online now
post #10819 of 10822 Old 04-21-2017, 01:17 PM
Quoted: 418 Post(s)
Liked: 68
Yes, raid5
post #10820 of 10822 Old Yesterday, 10:24 PM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
I have been playing around with Handbrake... Encoding in Super HQ mode takes a loooonnnnng time...
I encoded Avatar in Super HQ mode... Even with my Intel i7-6700K 4.00 GHz CPU, the encode took five hours to complete.
But the quality of the file is noticeably more detailed than when encoding in the fast mode (which takes 45-60 minutes)... I use quality of 23 on the compression. The end file came out 7.6GB in size.... Encoding Live Die Repeat: Edge of Tomorrow with the same settings came out to three hours and the file was under three GB in size....
Jon S is offline
post #10821 of 10822 Old Today, 05:06 AM
Wireless member
pepar's Avatar
Liked: 522
Yes, raid5
From your post I take it that moving a completed ISO to the NAS takes less time than outputting the ISO being generated by the ripping operation as it is being created?
pepar is online now
post #10822 of 10822 Old Today, 06:07 AM
Quoted: 418 Post(s)
Liked: 68
Yes, raid5
You are correct
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
