Ripping Blu-Rays II - Page 362 - AVS Forum | Home Theater Discussions And Reviews
 1021Likes
post #10831 of 10844 Old Yesterday, 07:58 PM
brentsg's Avatar
Quoted: 143 Post(s)
Liked: 265
Originally Posted by shimonmor View Post
Thanks. I have been searching and everything I find is trying to sell me an app.
Edit: Ugh, so is this one. I'm not re-encoding. I'm almost at the point of deleting 400 movies and forgetting about Plex. I'm definitely not doing anything I can't do as batch runs.
It's really dumb that it can't play these, as they are just 1 video and audio stream per file, so simple. I have plenty of CPU to transcode on the fly if needed.
pepar likes this.
Pioneer ELITE PRO-720HD | Pioneer PDP-5010FD | Sony XBR-55X850B | LG OLED55E6P
OPPO BDP-103 | OPPO UDP-203 | Toshiba HD-XA2
PlayStation 4 Pro | Xbox One S
brentsg is online now
post #10832 of 10844 Old Yesterday, 08:08 PM
Kelson's Avatar
Quoted: 1969 Post(s)
Liked: 1161
Originally Posted by brentsg View Post
I'm revisiting several hundred M2TS files that were ripped (decrypted) straight from Blu-ray. They play with most of my clients, but Plex doesn't even notice them. . .
Any thoughts on why Plex doesn't see them?
Something is not set up right with your system. I have over 400 BD.m2ts rips on my server and Plex sees and serves them just fine.
If you would still prefer to convert them all to MKV, use MKVToolnix.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #10833 of 10844 Old Yesterday, 08:17 PM
brentsg's Avatar
Quoted: 143 Post(s)
Liked: 265
Thank you for the reply. I have no idea what could be wrong. They are all in a folder. I added that folder. There isn't anything else I could do.
All the other folders I add are fine.
I've even installed Plex Server on 2 machines (Shield TV, Mac Pro). Neither can see anything in that 1 folder. All the other folders in that volume are fine. All the files are using the same naming convention.
Oppo 203 navigates there and plays all of them fine.
post #10834 of 10844 Old Today, 01:06 AM
madaudio's Avatar
Quoted: 135 Post(s)
Liked: 73
This may seem dumb, ignorant, patronising in its assumptions etc. If so, profuse apologies in advance. Nothing like that intended, just throwing out a wild idea.
I do not have the shield, no experience with plex, etc etc.
I do have a digitised collection of ripped cds, dvds, dvd-As, and BDs, and .ts files recorded from a cable channel. And occassionally give myself a fright when looking for a particular file in a place where I know it is, only to find .... EMPTY folder!!! Panic, Panic.
This happens when I am searching a hard drive plugged into my router, and am doing so from my Oppo Blu-ray player in media server mode.
Then I realise - I have chosen "Music" from the Library icons in my Oppo home screen, and gone searching for a ripped BD file which, as far as the Oppo system is concerned, is a movie file, so it doesn't see it because I have pre-determined the Oppo to look for a music format file.
Again, apologies if I seem to be suggesting you are as dumb as I have been when I have done this, and maybe Plex on Shield (or anything else) doesn't do this anyway. But .... is it all possible that something like this is causing your system to not see what you know is there?
madaudio is offline
post #10835 of 10844 Old Today, 03:02 AM
brentsg's Avatar
Quoted: 143 Post(s)
Liked: 265
Good thought. Definitely chose the movie icon both times. I repeated the actions a bunch of times to rule out any such human error.
post #10836 of 10844 Old Today, 04:33 AM
Ken.F's Avatar
Quoted: 1560 Post(s)
Liked: 1351
Are you saying your m2ts movie files are all located in the same single folder? Plex needs each movie to be in it's own separate folder.
Ken.F is offline
post #10837 of 10844 Old Today, 06:04 AM
Otter0911's Avatar
Quoted: 71 Post(s)
Sorry Ken, no offense not true. I have my movies in one folder marked Plex Movies and they play just fine. Not in separate folders.
brentsg and mrfattbill like this.
Otter0911 is offline
post #10838 of 10844 Old Today, 06:53 AM
Ken.F's Avatar
Liked: 1351
OK, maybe I worded that poorly. For best results the file(s) for each movie should be located in a separate folder for each individual movie. Plex typically (but not always) has difficulties correctly identifying movies if the files for more than one movie are combined in the same folder. If Plex will not recogize multiple movie files in the same folder I recommend creating separate folders for each movie.
Ken.F is offline
post #10839 of 10844 Old Today, 08:15 AM
brentsg's Avatar
Quoted: 143 Post(s)
Liked: 265
I have probably twice as many DVD movies all in one folder and it's fine. I can't imagine creating 400 new folders.
If that was the case I'd find another method to view them.
post #10840 of 10844 Old Today, 08:31 AM
Ken.F's Avatar
Liked: 1351
Just try moving one of the movies into it's own folder and see if it works. At least you'll know if that's what is happening or not. If that is the problem then maybe FileBot is worth looking into. I haven't tried using it but it looks like it could be a solution to your problem.
http://www.filebot.net/
Ken.F is offline
post #10841 of 10844 Old Today, 08:49 AM
brentsg's Avatar
Quoted: 143 Post(s)
Liked: 265
Thanks folks. I'll play with it this weekend.
I just bought 6 8TB NAS drives and I was about to pull the trigger on a Synology 1817+. Just need proof of concept before I put down the last money.
Wish they had put a CPU that could transcode in this unit.
post #10842 of 10844 Old Today, 09:04 AM
brentsg's Avatar
Quoted: 143 Post(s)
Liked: 265
So I had a breakthrough it seems.
First off, I can't get the Shield TV to recognize anything in my M2TS folder (just movies) period. I've tried several times.
Second, I wasn't able to get the Mac Pro server to recognize the folder either, UNTIL I deleted some metadata that the Shield TV had parked in that folder. Somehow that was tripping it up, and now that it is gone things work fine. Strangely, the Shield TV recognizes the M2TS files in my TV Show folder just fine. It tries to transcode those but gives a warning that it's not powerful enough.
Otter0911 likes this.
post #10843 of 10844 Unread Today, 12:42 PM
garnuts's Avatar
Quoted: 84 Post(s)
Liked: 60
Plex file naming conventions are explained here:
https://support.plex.tv/hc/en-us/cat...ia-Preparation
Living Room: Denon X4000, XPA-5, Polk RTiA9, CSiA6, RTiA3-wides, FXiA4, OWM3, SVS PC12+, 4 Shakers, Epson 5030, VApex 92”, Sony XBR9 52”, PS3, Xbox 360, Darbee, Harmony 1.
Bedroom: Denon X2000, Polk: RTiA3, CSiA4, RTiA1, OWM3, SVS SB12-NSD, Sony XBR-55X850B, Sony BPD-S590, Xbox 360, RPi2-RasPlex, Darbee, Harmony 510.
Home Office: Onkyo 707, Polk: LSiM 703, LSiM 704, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors, Harmony 610.
garnuts is online now
post #10844 of 10844 Unread Today, 12:46 PM
brentsg's Avatar
Quoted: 143 Post(s)
Liked: 265
They are all named properly. I used the Plex naming convention years ago, though it was for a previous incarnation of the platform. It had no problem with most files once I removed the Android metadata that the Shield TV had stashed in the folder.
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
