Ripping Blu-Rays II - Page 364 - AVS Forum | Home Theater Discussions And Reviews
 2243Likes
post #10891 of 10910 Old 08-09-2017, 07:01 PM
Ken.F's Avatar
Quoted: 1659 Post(s)
Liked: 1430
Originally Posted by garnuts View Post
Illegal?
I'm not asking about ripping rentals. Redbox also sells discs at the kiosk. I wasn't sure if they were just getting rid of old rental discs or if they were new retail versions.
Sammy2 likes this.
Ken.F is online now
post #10892 of 10910 Old 08-09-2017, 07:17 PM
cswiger's Avatar
Quoted: 265 Post(s)
Liked: 116
Originally Posted by nyauditor View Post
After ripped to my NAS via Make MKV, I am not able to play back through XBox One (Synology media server). Do I need to perform extra steps during ripping or need to convert to mkv? Any app that can make the file easily readable via Xbox One?
Howdy, @nyauditor --
Start with https://handbrake.fr/ -- it will convert the BDMV rip from MakeMKV into a .mp4 file, and it has preset tunings available specifically for both the Xbox 360 and XBOne.
Primary (2.1): Thiel CS 1.2 / Velodyne F1000 sub / Adcom GFA-555 Mk2 / Rotel 970BX / Sony CDP-CA9 ES
Secondary (5.1): Paradigm Mini-Monitor v.3 / CC270 v.3 center / ADP-170 v.2 surrounds /
SVS SB1000 sub / Marantz SR-6010 / AppleTV + Win7 PC / BenQ BL3200PT
cswiger is offline
post #10893 of 10910 Old 08-10-2017, 03:59 AM
nyauditor's Avatar
Thank you.
nyauditor is online now
post #10894 of 10910 Old 08-10-2017, 04:49 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
Alternately from changing to MP4 you can use Emby Server which will transcode on the fly to whatever device you are playing the content on. If the device supports full 1:1 HD or even 4K then you get that. If it doesn't, you still get to view it on your xbone. You need some decent specs under the hood of the machine running the Emby Server to do the on the fly transcoding though. My Devil's Canyon Haswell i5 does quite well with this task and will also do WMC and extenders all at the same time.
Sammy2 is offline
post #10895 of 10910 Old 08-14-2017, 01:56 PM
Moebius's Avatar
Quoted: 144 Post(s)
Liked: 84
Ok, I'm driving myself crazy trying to remember the magic google phrase I used, but when I began researching ripping my collection a couple weeks back, I came across a db style list, either here or elsewhere, that was basically a compilation of which titles from a given disc contained the actual movie. Now that I have my NAS set up and have started the great ripping project, I can't for the life of me find that list again. Anyone familiar with it?
So far I've done pretty well, but have hit a few snags, most recently Deathly Hallows part 1. There are 4 "long" titles on the disc, 2 pairs of identical lengths. I'm guessing the longer ones are the maximum movie mode thing they did but I can't figure out which of the shorter two would be the right choice, or what the difference is between them. Google has been uncooperative in this particular quest.
Remember, no matter where you go... You're not where you were anymore.
Moebius is offline
post #10896 of 10910 Old 08-16-2017, 02:02 PM
Wryker's Avatar
Quoted: 135 Post(s)
Liked: 61
If you're using ANYDVDHD see if the correct playlist appears when you open the program.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #10897 of 10910 Old 08-17-2017, 08:30 AM
Moebius's Avatar
Quoted: 144 Post(s)
Liked: 84
Makemkv in this case, though I ended up guessing right in terms of the movie in question. However, I still can't find the list I had stumbled across before that showed which title/playlist had what content. I'd swear it was on AVS, but no amount of pleading with Google will produce that particular search result again.
Moebius is offline
post #10898 of 10910 Old 08-17-2017, 10:13 AM
woodgieroo's Avatar
Quoted: 30 Post(s)
Liked: 25
Was it this?
woodgieroo is online now
post #10899 of 10910 Old 08-17-2017, 11:35 AM
brentsg's Avatar
Quoted: 167 Post(s)
Liked: 291
I"m rusty b/c I had a virtual machine with all my ripping tools, and I lost it (drive issue).
I had AnyDVD (Slysoft ver) HD, so I am trialing that again. I downloaded the MakeMKV demo and it seems like MakeMKV is complaining about AnyDVD... Maybe I'm not doing this right.
Before I had an old script that made calls to various apps and it was slick, but I can't seem to track that down. In the end I had a bunch of m2ts files, which Plex doesn't like anyways. Any suggestions to workflow, or point me in a direction?
Pioneer ELITE PRO-720HD | Pioneer PDP-5010FD | Sony XBR-55X850B | LG OLED55E6P
OPPO BDP-103 | OPPO UDP-203 | Toshiba HD-XA2
PlayStation 4 Pro | Xbox One S
brentsg is online now
post #10900 of 10910 Old 08-17-2017, 11:39 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3238 Post(s)
Liked: 2524
MakeMKV doesn't require AnyDVD to be present; I think the complaint is just a warning.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #10901 of 10910 Old 08-17-2017, 11:44 AM
brentsg's Avatar
Quoted: 167 Post(s)
Liked: 291
So what do people use AnyDVD with these days?
post #10902 of 10910 Old 08-17-2017, 12:08 PM
LastButNotLeast's Avatar
Quoted: 1776 Post(s)
Liked: 1396
I don't understand the question. AnyDVD (HD) is used for ripping discs. You don't use it "with" anything.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #10903 of 10910 Old 08-17-2017, 12:14 PM
Keenan's Avatar
Quoted: 2416 Post(s)
Liked: 2241
-Bill
That pops up but I've always ignored it and never had any negative effects with any rips I've done.
Keenan is offline
post #10904 of 10910 Old 08-17-2017, 12:49 PM
Moebius's Avatar
Quoted: 144 Post(s)
Liked: 84
Originally Posted by woodgieroo View Post
Was it this?
No, I kept coming across that in my repeat searching. It was similar, but rather than specs, it had playlist/title info on it. So for X Blu Ray Title 1, MPLS 800,801 contained English Theatrical Release, Title 3 MPLS 802 had Directors cut, and so on. I'm seriously beginning to think I hallucinated it at this point. If not, we need one. Would make life easy for the weird discs, or the Disney style where they use a separate title for Spanish version or the like (Force Awakens and Rogue One).
Moebius is offline
post #10905 of 10910 Old 08-17-2017, 01:27 PM
Liked: 1396
I found this guide on how to do it, if that helps you at all.
http://www.mediasmartserver.net/2011...ain-movie-rip/
Michael
post #10906 of 10910 Old 08-17-2017, 02:20 PM
dchabby's Avatar
Quoted: 83 Post(s)
Liked: 37
Originally Posted by archer75 View Post
Handbrake has many presets. I start with the H.265 1080p30. And then the only thing I change is the video tab. Video codec is h.265. Framerate is same as source with variable framerate checked. Encoder preset at medium. Encoder tune: none, encoder profile: auto
Constant quality I have at 18 for the stuff I care about. I'll change it to 20 or even 22 for DVD's or animation. Sometimes comedies. But mostly it stays at 18.
Set the destination wherever you want it saved and what you want it saved as. I save mine in the drive I rip to. Upon completion I make sure all is well with the file before deleting the original and moving it over to my movie storage.
On the audio tab I leave codec as auto passthru. This just takes the HD audio track I rip in makemkv and adds it to the final MKV untouched.
Next is the subtitles tab. I have makemkv rip english forced subtitles ONLY. If there is one you'll see it here. If there isn't one then you won't see it here. If it does show up then I check burn in. It becomes part of the image and you don't have to deal with compatibility issues with subtitle files.
I save all that as my default so I don't have to set it up every time.
There's a ton of other settings you can tweak but I find these result in a file that is identical to the original. I compare frame by frame on a color turned 34" monitor and I watch the files on a 145" 1080p projector as well as a 65" OLED. I can also compare streams on my nvidia shield tv to my oppo 203(streaming on both) or compare disc playback on the oppo to my nvidia shield and just flip between inputs. I did a lot of work to come up with settings that I feel are perfect.
Hi I realize every disk will be different but what would your average rip come out to in GB's with these settings ?
dchabby is offline
post #10907 of 10910 Old 08-17-2017, 05:10 PM
archer75's Avatar
Quoted: 223 Post(s)
Liked: 82
5-10GB. Retaining the HD audio track.
Streaming Devices: Nvidia Shield TV, 2x Roku 3's, 1st and 2nd gen chromecast, Amazon Fire TV stick 2nd gen, Apple TV 4, xbox 360, xbox one
Displays: Vizio M602i-B3, LG OLED65B6, panasonic ax100u on a 145" S-I-L-V-E-R painted screen, 40" Samsung(don't recall model #)
Receivers: Denon X3300, Yamaha RX-V663. Bluray/UHD player: Oppo UDP-203
Retired - HTPC: Intel e6300 2.8ghz, Intel DG45ID, 2gb DDR2, Radeon 5570, MCE IR receiver
archer75 is offline
post #10908 of 10910 Old 08-17-2017, 07:36 PM
brentsg's Avatar
Quoted: 167 Post(s)
Liked: 291
Michael
I guess what I'm remembering is adjunct software that I used with AnyDVD to redo that audio tracks, so I retained very specific audio tracks/formats.
post #10909 of 10910 Old Yesterday, 08:02 AM
mrfattbill's Avatar
Quoted: 108 Post(s)
Liked: 94
Maybe ClownBD?
Bill
RaggedEdge likes this.
mrfattbill is offline
post #10910 of 10910 Old Yesterday, 07:27 PM
Liked: 1396
As mentioned in the guide linked above (10905).
Michael
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
