Ripping Blu-Rays II - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 980Likes
post #1231 of 10646 Old 04-12-2012, 11:09 AM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 24
Originally Posted by sanderdvd View Post
Any IMGBURN users out here?:
I want to burn my 2D movies on a BR disc. The movies are BDMV+CERTIFICATE folder. I checked the guides on the imgburn community but cannot find a guide for BDMV+CERTIFICATE burning on BR disc.
Someone has a step-by-step guide how to do this exactly? (pc noobish guide please )
I'm kinda confused? Are you merely trying to make a backup copy of your BR? If so, you'd do it like you burn any other image. You'd select the root folder and then burn it to the disc as an image.
BTW, I do hope you aren't trying to make illegal copies.
agogley is offline
post #1232 of 10646 Old 04-12-2012, 11:52 AM
mbaxter's Avatar
Has anyone successfully ripped the Avatar Blu-Ray? Mine plays fine but fails with read errors whenever I try to rip it, no matter which software I use.
I've tried DVDFab, MakeMKV, AnyDVD + IMGburn... same result every time.
Is this some sort of deliberate copy protection (like they do with DVD's) or could I really just have a less-than-perfect disc?
mbaxter is offline
post #1233 of 10646 Old 04-12-2012, 12:05 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Nope, that just mean that your copy has either damaged / corrupted files, and you'll just have to use another disk. I had the same issue with Iron Man 2. My parents have their own copy. So, I switched them BD copy, and I was able to rip that one.
GusGus748s is online now
post #1234 of 10646 Old 04-12-2012, 02:18 PM
mic j's Avatar
Yes, but it took a FW update to my Plextar usb reader to be able to do it. The Avatar BD is only readable on players that have a certain type of FW. Mine did not have it upon release and I tried multiple discs without success. I also had read that only certain FW would be able to read it. After about 8 months, Plextar had a FW update and viola!!! It plays with no problem now.
mic j is offline
post #1235 of 10646 Old 04-12-2012, 10:52 PM
alexsquared's Avatar
Anyone having problems with Lady and The Tramp? The drive doesn't even seem to recognize it.
alexsquared is offline
post #1236 of 10646 Old 04-13-2012, 02:02 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
That's not true for every BD reader. There are some disk that come defective from manufacturing, but they are playable in DVD/BD players. However, the DVD/BD disk will give you and error if you try to rip them due to the corrupted file(s), which makes it impossible to rip.
I've got two BD like that within my 300 BD collection.
What ripping software are you using. If you are using AnyDVD HD, post a log file in the forum, and they will tell you the reason.
post #1237 of 10646 Old 04-13-2012, 07:01 AM
DVDFab. It's odd. It doesn't even seem to recognize there is a disc in the drive as a "source".
post #1238 of 10646 Old 04-13-2012, 07:07 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
That's odd indeed. I don't have much experience with DVDFab since when I tested the trial version, which didn't work for me. Every movie I ripped with DVDFab stuttered badly. DVD and BD. The only one that has worked well for me is ClownBD + AnyDVD HD for BD movies and MakeMKV for SD movies.
Try using a different BD movie and see if the drive reads it. If it doesn't try re-staring your PC. If that doesn't work then it your drive.
post #1239 of 10646 Old 04-13-2012, 07:09 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I randomly have Blu-rays that my ROM Drive won't recognize. I usually end up having to put in another PC and it will work
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #1240 of 10646 Old 04-13-2012, 07:28 AM
Unfortunately, I only have one with a BD drive. I'm concerned it is the disc as it also has problems, albeit different ones, on my standalone player.
post #1241 of 10646 Old 04-13-2012, 07:42 AM
mic j's Avatar
I never said it was true for every BD reader. It was true for my reader and there are articles on the internet documenting the FW problem...with "SOME" BD readers. There are also bad discs. That's true with all movies. I tried multiple discs without success. I am simply offering someone having a problem an alternative reason why they might be having a problem. And yes, I used AnyDVDHD and Clown_BD. And no, I will not post a log as I no longer have the ability to do that.
Here is a link to an article on the subject: http://www.studiobriefing.net/2010/0...t-play-avatar/
Chill.
mic j is offline
post #1242 of 10646 Old 04-13-2012, 07:44 AM
mic j's Avatar
Yes. That is the problem I experienced. The reader would not play the disc.
mic j is offline
post #1243 of 10646 Old 04-13-2012, 08:15 AM
scottlindner's Avatar
I have that problem sometimes and I disconnect the BD drive, reboot, and reconnect. It doesn't always work and may not even be related at all. Maybe it's just the reboot that's helping. Sometimes I get the impression that happens when you have BD aware software running before you put the disc in the drive and that just jacks up the OS from detecting it in some way. I typically can get it to work after fiddling with whacking programs, rebooting, and ejecting/inserting a bunch of times.
scottlindner is offline
post #1244 of 10646 Old 04-13-2012, 02:33 PM
UHD Addict
aaronwt's Avatar
Quoted: 5192 Post(s)
Liked: 3099
I've always liked having several BD Rom drives from different manufacturers. Sometimes a disc will not read right from one drive, but will be fine from a drive from a different manufacturer. I currently use a couple of LiteOn drives, several Samsung drives, and several LG drives. When I have had a problem disc, a drive from one of those manufacturers will read it.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #1245 of 10646 Old 04-13-2012, 02:37 PM
Exactly. I have experienced this with all optical media and not just BD.
post #1246 of 10646 Old 04-13-2012, 02:42 PM
mic j's Avatar
But you also have more computing, network, and storage resources than most major companies.
mic j is offline
post #1247 of 10646 Old 04-13-2012, 02:48 PM
What does it take for that classification? I'm wondering if I fit into that camp as well.
post #1248 of 10646 Old 04-13-2012, 03:08 PM
mic j's Avatar
I'll stay out of this and you and aaron compare the "size" of your resources!!
mic j is offline
post #1249 of 10646 Old 04-13-2012, 06:12 PM
blackssr's Avatar
Quoted: 1158 Post(s)
Liked: 578
I have cooler cars than Aaron does that count?
I've paid for my sins. We're even!
blackssr is online now
post #1250 of 10646 Old 04-14-2012, 06:47 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 24
I'm running Lady and the Tramp now, and it reads fine. However, it does force a sub that you don't want forced. So I suggest turning forced subs off with Clown_BD for this movie.
agogley is offline
post #1251 of 10646 Old 04-20-2012, 08:23 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I am having an issue ripping Saving Private Ryan using MakeMKV 1.7.4. It plays fine in my Samsung BDP-2500. Has anybody else experienced this? I haven't had time to try ClownBD yet and am also getting errors with imgburn.
Sammy2 is offline
post #1252 of 10646 Old 04-20-2012, 08:38 AM
Could you describe the issue?
post #1253 of 10646 Old 04-20-2012, 08:51 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
It won't read the disc, just spits out errors.
Maybe it is my Samsung BD drive?
Maybe I'll try a reboot to see if that clears things up?
Maybe there's a f/w update I need?
I should try a disc known to work to see if it reads it.
I'll do some troubleshooting but thought maybe if there was a known issue I could save some troubleshooting time.
Sammy2 is offline
post #1254 of 10646 Old 04-20-2012, 08:54 AM
Brajesh's Avatar
Quoted: 300 Post(s)
Liked: 126
I've had that happen on rare occasions, which is why I use two different brands of BD drives. If it doesn't work in one, it will in the other.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #1255 of 10646 Old 04-20-2012, 08:56 AM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Get a different disk and try it again.
post #1256 of 10646 Old 04-20-2012, 08:58 AM
I have had that happen before. I don't know what I do to solve it but just doing the typical things like reboot, clean disc, bang keyboard, curse at Bill Gates a couple of times, etc. That all seems to work after a while.
post #1257 of 10646 Old 04-20-2012, 09:10 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Thanks, I will start with a reboot and check my f/w then go from there.
Sammy2 is offline
post #1258 of 10646 Old 04-21-2012, 07:54 AM
maineiac13's Avatar
Quoted: 13 Post(s)
I am trying to convert one BD50 to two BD25s. The BD50 has two main titles, both about 17GB in size, plus some other titles which are less than 8gb total.
Using ImgBurn, I ripped the BD50 to an ISO. What I would like to do next is to do something that is similar to how Clone DVD works. Namely, just eliminate one of the main titles and a few of the other titles and create a BD25 from that. And then reverse the process and eliminate the other titles for the second BD25. Thus preserving all the menus, etc. though of course not having proper links to certain titles on each BD25.
I have looked at a number of programs, including DVD Fab....but it appears that all you can choose is either the entire disk or one main title. There does not seem to be an option to choose multiple titles. Am I missing something obvious???
Update: I think I have figured out how I will do this. Rather than ripping the BD50 to an ISO, I will rip it to the hard drive in its regular file structure. Then I will go into the BDMV/STREAM folder and remove some of the m2ts files (First of course I need to check and see which ones are which). Then create a BD25 using ImgBurn. Then I will move the m2ts files back...but take others out and repeat the process. This should work I think but I won't get a chance to do this till sometime next week.
maineiac13 is offline
post #1259 of 10646 Old 04-21-2012, 05:19 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1146
Originally Posted by maineiac13 View Post
Update: I think I have figured out how I will do this . . . . This should work I think but I won't get a chance to do this till sometime next week.
Word of advice, get yourself some BD-RE to do your tests so you won't be throwing away BD-R.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #1260 of 10646 Old 04-21-2012, 05:27 PM
maineiac13's Avatar
Quoted: 13 Post(s)
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
