Ripping Blu-Rays II - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 980Likes
post #1261 of 10654 Old 04-21-2012, 09:12 PM
scottlindner's Avatar
You could use MakeMKV to extract the video tracks that you want and then burn that, or create an ISO for testing.
scottlindner is offline
post #1262 of 10654 Old 04-22-2012, 10:22 AM
maineiac13's Avatar
Quoted: 13 Post(s)
I was thinking of that too....but I guess I am confused about how to convert a group of mkv files into a compliant BD disc (or ISO.) I was thinking of just using ImgBurn...but don't you have to have the files in the BDMV and CERTIFICATE folders first?
Plus I had originally created MKV files, but in trying to preview them (using WinDVD Pro 11) I was able to get sound....but not picture. Whereas when I kept the files as m2ts files, I got both picture and sound.
And finally, isn't this actually an extra step...that is starting with m2ts, then using MakeMKV, then using ImgBurn or something else to create the ISO...instead of just leaving them as m2ts and burning with ImgBurn?
maineiac13 is offline
post #1263 of 10654 Old 04-22-2012, 10:26 AM
Don't extract to mkv, do a backup. Iit decrypts and creates the BR file structure based on the tracks you selected.
post #1264 of 10654 Old 04-22-2012, 10:42 AM
maineiac13's Avatar
Quoted: 13 Post(s)
But isn't that essentially what is done when I rip the BD50 (with ImgBurn or AnyDVD HD) to my hard disk (as files not as ISO)? Then all I need to do is to cut the file(s) I don't want and paste them to another folder temporarily. Then burn the remaining files to a BD25 (after first testing with BD-RE or ISO). Then do the same thing for the second BD25.
I guess I am not seeing where what you are suggesting is any easier than what I am planning to do.
Update: I just created an ISO doing it as I had planned and it works fine. My "problem" for getting it to a BD25 is that I need to wait for my BD burner to arrive. What I thought was a BD burner in my existing system turned out to be just a BD reader only...though it writes CDs and DVDs.
post #1265 of 10654 Old 04-22-2012, 01:18 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Just an idea or suggestion...
I still play my real (factory produced) Blu-Ray discs in my stand-alone Blu-Ray player. However, once the movie (DVD or BD) ends up on a harddrive, I leave it on that "media" and playback with XBMC-HTPC (or you coud also use a "media box" like WD or Boxee).
If you like computers, you will likely use a computer as your file-server. Or, a NAS (like a Synology) is another way to go.
I made the switch a couple of years ago. DVD-Rs were cheap, but DVD-DLs and BD-Rs were pretty expensive. Plus, you eliminate burn time, possible burn failures, and burned discs that degrade or fail after a few years.
For backups, you still have the original discs. Or, if the thought of re-ripping it all again scares you, just buy a second HDD as a backup.
I use ethernet to move movies around, but you can also use smaller USB HDDs and flash drives.
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
post #1266 of 10654 Old 04-22-2012, 02:24 PM
UHD Addict
aaronwt's Avatar
Quoted: 5247 Post(s)
Liked: 3140
As a collection grows a second hard drive for a back up turns into dozens for a backup. It's not practical unless you have a collection that is small, like only a few terabytes.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #1267 of 10654 Old 04-22-2012, 05:53 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
I see your sig ... and I'm only at 10tb.
A 2tb (2000gb) will hold 50 - 40gb BD rips. Lets say that costs $100.
How much does 50 dual-layer (or largest you can buy) blank disks cost?
For storage "space" or the room they take up, they are around equal (higher with burnt discs if you include cases). HDD also wins the "creation time" factor.
To be "fair" about backup costs ... either they are both $0 (originals ARE backups) or both numbers above double.
post #1268 of 10654 Old 04-23-2012, 09:22 PM
mbaxter's Avatar
Originally Posted by GusGus748s View Post
Nope, that just mean that your copy has either damaged / corrupted files, and you'll just have to use another disk. I had the same issue with Iron Man 2. My parents have their own copy. So, I switched them BD copy, and I was able to rip that one.
You were absolutely right. I exchanged for another copy and was able to rip the whole thing with no errors.
However, after I converted the .mkv to .m4v using Handbrake and played on my Apple TV2, I noticed the forced subtitles (Navi language) are missing. This is odd because I always choose the "Forced Subtitles" option in handbrake when I convert, and it usually works fine.
What gives? Is there something special about the Avatar bluray?
mbaxter is offline
post #1269 of 10654 Old 04-24-2012, 01:11 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
I had issues with Avatar subs too. My Dune D1 wont play them automatically, but my $80 dollar AIOS does...weird.
GusGus748s is offline
post #1270 of 10654 Old 04-24-2012, 05:54 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
The forced subs for Avatar don't appear in what format (mkv or Folder Rip)?
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #1271 of 10654 Old 04-24-2012, 08:40 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
I ripped all of my BD with ClownBD with the force subs checked, and secondary AC3 sound track
I have to turn the subs on by pressing the subs button on the remote for the D1. The AIOS does it automatically.
post #1272 of 10654 Old 04-24-2012, 08:44 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Thanks for confirming, I have actually noticed the same behavior with my Avatar Clown_BD rip. Been meaning to revisit but just got caught up with other stuff
Cheers,
Damian
post #1273 of 10654 Old 04-24-2012, 09:17 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
I've noticed this behavior with my D1 for any movie that has force subs. Even though, I've got the check mark for forced subs with ClownBD the D1 doesn't automatically detect the force subs. I've got to turn them on. However, my AIOS automatically detected them, which it surprised the hell out of me. May be there is something within the Dune's set up like an option to turn this on? I haven't messed out with the set up stuff. So, I guess I'll give it a try!
post #1274 of 10654 Old 04-24-2012, 09:23 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I only have an issue with Avatar, all others have worked as expected for me
Cheers,
Damian
post #1275 of 10654 Old 04-24-2012, 09:25 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
Not for me, I ripped and watched Mission Impossible Ghost Protocol, and when they were speaking in German, the subs did not come on. I had to turn the force subs on, which was the first sub file.
What FW are you using for your Dune players?
post #1276 of 10654 Old 04-24-2012, 09:29 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I know a little German...
Pretty sure I am using whatever the latest beta fw is
Cheers,
Damian
post #1277 of 10654 Old 04-24-2012, 11:43 AM
Brajesh's Avatar
Quoted: 302 Post(s)
Liked: 129
Thought the Dune added support for forced subs in MKV's and ISO's?
Hi-deft Media Keen Videosaurus
Brajesh is online now
post #1278 of 10654 Old 04-24-2012, 11:54 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
ISOs/Folder rip support has always been there. mkv support for forced subs has never been added (unless it has been done recently?)
Cheers,
Damian
post #1279 of 10654 Old 04-24-2012, 11:50 PM
rochoa21's Avatar
What program can you use to rip certain parts of blu rays?
rochoa21 is offline
post #1280 of 10654 Old 04-25-2012, 06:12 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
You mean scenes from a movie? If so I would use VideoReDo is a great snipping tool (although expensive)
Cheers,
Damian
post #1281 of 10654 Old 04-25-2012, 06:24 AM
Kelson's Avatar
Quoted: 1953 Post(s)
Liked: 1148
But for people who do a lot of editing of captured TV shows, worth every penny. As far as BD title editing, all versions handle MPEG-2, the H.264 version handles H.264/AVC. I don't think any version handles VC-1 (admittedly, VC-1 encoded BD titles are rare). To be honest, I've never had need to open up a BD.m2ts file from a BluRay rip in VideoRedo. But from my normal use and familiarity of it for editing .tivo files, I don't believe it will support multiple audio tracks and I'm not sure about subtitles at all.
Maybe something to try some night.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #1282 of 10654 Old 04-25-2012, 10:14 AM
rochoa21's Avatar
I want to be able to snip certain scenes.
rochoa21 is offline
post #1283 of 10654 Old 04-25-2012, 07:10 PM
mbaxter's Avatar
So did anybody ever find a reliable way to get the forced subtitles from Avatar? If there's a paid (ie: not free) solution for this, that's fine.
Is there an easy way to tell if a given bluray has forced subtitles? It would be nice to know before you rip, because extracting them doesn't appear to be a trivial task...
mbaxter is offline
post #1284 of 10654 Old 04-26-2012, 08:37 AM
mic j's Avatar
I downloaded an srt file and added it to the mkv using Subler. They are not as pretty as the original which has a "Papyrus" font, but they are readable. It's the font that has cause a lot of the problems with playback as most media streamers do not support it.
mic j is offline
post #1285 of 10654 Old 04-26-2012, 09:21 AM
mbaxter's Avatar
Thanks but subler is Mac-only. Is there an any PC-based solution? I just want to rip blurays to an AppleTV friendly format and reliably get the forced subtitles burned into the resulting file. I don't mind paying for a solution; my time is more important to me than my money.
Any suggestions?
mbaxter is offline
post #1286 of 10654 Old 04-26-2012, 09:23 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Any suggestions?
I would think Handbrake would do the trick. It reads unprotected Blu-rays, allows you to burn in subs, and has an Apple TV preset
Cheers,
Damian
post #1287 of 10654 Old 04-26-2012, 12:49 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Avatar worked for me. This is what I do:
Use DVDFab BluRay Copy - to copy whole BD to files
Use MakeMKV on main title (includes Audio, Subs, ForcedSubs and Chapters)
Use MKVMergeGUI to change Forced flag on the one alien dialog sub
Look back in this thread a bit for similar discussion on Forced Subs.
No Apple-TV here, but it should be similar to the above.
post #1288 of 10654 Old 04-26-2012, 01:40 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Is this it? You can pay or download now for free?
Sammy2 is offline
post #1289 of 10654 Old 04-26-2012, 01:55 PM
Tesla1856's Avatar
Quoted: 89 Post(s)
Liked: 66
Yes, that is it.
All the various sub-programs run from the one main program. I just have BluRay Copy (Lifetime license), but I also sometimes use the free HD Decrypter (free, slightly limited, version of DVD Copy). I think everything is 30 day trial, so download free and check it out if you want.
post #1290 of 10654 Old 04-26-2012, 03:10 PM
dandirk's Avatar
Quoted: 29 Post(s)
Speaking of subs...
I primarily use makemkv for movie only and play back on xbmc... As you may know makemkv gives little info about the sub tracks, it is impossible to tell if a track has forced subs or if those forced subs are CC or actual non-English translations...
Is there a site or some resource I can look up if subs are burned in screen or if they are forced sub tracks?
dandirk is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
