Ripping Blu-Rays II - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 2241Likes
post #1351 of 10906 Old 05-10-2012, 02:28 PM
Carl Jones's Avatar
Originally Posted by aaronwt View Post
I used to use those enclosures and they worked well. But I eventally replaced mine with fanless enclosures with external power supplies. Since the enclosures are smaller and silent. Of course the PS is external, but I'm not moving my enclosures around alot like I used to when I had the Vantec ones.
What enclosure and BD drive do you recommend? Do you use multi drive enclosures?
Carl Jones
Carl Jones is offline
post #1352 of 10906 Old 05-10-2012, 02:38 PM
UHD Addict
aaronwt's Avatar
Quoted: 6046 Post(s)
Liked: 3747
I don't use any multi drive enclosures. Although it probably would have been easier when I first started ripping my BD titles. But I wouldn't need it now.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #1353 of 10906 Old 05-10-2012, 02:48 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
I use these http://www.amazon.com/gp/product/B00...ls_o02_s00_i00 external enclosures now. Although amazon shows them as "unavailable", so I wonder if they don't make them anymore?
A bit larger enclosure or a Wall Wart is the trade-off. The fan is a bit noisy but I only turn the enclosure on when I'm using it and that isn't for watching a Blu-ray in my HT but only for reading a disc at my PC in my office.
Sammy2 is online now
post #1354 of 10906 Old 05-10-2012, 03:07 PM
Carl Jones's Avatar
That's kind of where I am, although I'm still not following why you use an enclosure. Why not just buy an external drive?
Carl Jones
post #1355 of 10906 Old 05-10-2012, 05:01 PM
UHD Addict
aaronwt's Avatar
Liked: 3747
When i got mine it was much cheaper to get an internal drive and put it in my own enclosure. Although I don't know what prices are now for the external drives. But the internal drives have dropped a lot in price.
post #1356 of 10906 Old 05-10-2012, 05:13 PM
Carl Jones's Avatar
Ah! Thanks for the reply, so it is/was a cost issue. I'll be sure to check both ways but it seems these days cost is not a real big factor. However if performance or features were issues they would have been something I needed to learn about.
Carl Jones
post #1357 of 10906 Old 05-10-2012, 05:14 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
I'm of the "buy components" mindset so I can choose each for what suits my needs best.
post #1358 of 10906 Old 05-16-2012, 01:23 PM
Bugg77's Avatar
Well I read through about 500 posts and just got cross-eyed so I figured I'd go ahead and ask for advice.
I've got a PCH A300 on order and I want to start ripping my Blu-Ray collection to store on my NAS.
I've got three tiers that I want to rip/encode:
1) Favorite movies: I want to rip these so it is just the full quality main movie, HD Audio, and English Subtitles. Can I do this with DVDFab only or do I need another program after DVDFab removes the copy protection? If I wanted to do this with AnyDVD HD, what other program would I need to use?
2) Rainy Day shows: Same as #1, but encoded to save space. These would still be played on my PCH A300 through my AVR. What's a good container to use that balances compression and quality?
3) Portable copies: I'm perfectly comfortable using Handbrake to create my iPad/Android MP4s. If I get the first two sorted out, I'm pretty sure this one will work just fine.
Bugg77 is offline
post #1359 of 10906 Old 05-16-2012, 01:39 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
1. MakeMKV should handle 95% of these. ClownBD, MKVtoolnix and/or MKVMerge will pick up the rest.
2. Handbrake should take care of this for you. I haven't used this but have heard it mentioned a lot. I don't shrink anything I rip.
3. I think you answered your own question.
Others may have other comments or suggestions based on what they use (dbone1026).
post #1360 of 10906 Old 05-16-2012, 10:11 PM
mbaxter's Avatar
Originally Posted by mic j View Post
Handbrake now has the ability to burn in BR PGS subtitles (both regular and forced). It has been incorporated into the nightly build and from posts on other forums, it works quite well. Avatar with forced subtitles has been successfully transcoded with HB.
He speaks the truth!
With the latest nightly build of handbrake, these are the only steps you need follow to rip blurays with forced subtitles intact:
1) Run AnyDVD with bluray in drive
2) Run Handbrake, choose bluray drive as source, choose ATV2 preset, under Subtitles tab select the English PGS track, check "Forced Only" and "Burned In", then click Add.
3) Rip bluray and enjoy
All you guys messing with multiple programs, importing SRT files and going through dozens of steps to get forced subtitles on your bluray rips... well you can stop now.
BTW, I'm sure my steps outlined above would work just fine with the other HB presets as well (I have ATV2 so this is what I used).
mbaxter is offline
post #1361 of 10906 Old 05-17-2012, 04:44 AM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
Doesn't Anydvd HD cost $$ every year?
post #1362 of 10906 Old 05-17-2012, 05:15 AM
Kelson's Avatar
Quoted: 1989 Post(s)
Liked: 1196
Check their website for their terms. They may have different pay plans like DVD Fab where you can license yearly or lifetime. Like any software, major version releases may cost you an upgrade fee -- it all depends on their terms. Just go to their website and get the information first-hand.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #1363 of 10906 Old 05-17-2012, 05:31 AM
UHD Addict
aaronwt's Avatar
Liked: 3747
When I bought mine several years ago I got a lifetime license. So it was a onetime cost. It was certainly worth it for me. I figured at the time I would get a lifetime license since I had purchased a couple of other programs from them many, many years ago and didn't get a lifetime license at the time so the license expired. And since I use Any DVD HD regularly, it was worth the $80 or $90 cost at the time.
post #1364 of 10906 Old 05-17-2012, 06:03 AM
dbone1026's Avatar
Quoted: 221 Post(s)
Liked: 111
Great, but you do realize there are quite a few people who don't want to encode their Blu-rays but instead want to keep the original quality
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #1365 of 10906 Old 05-17-2012, 06:19 AM
mrfattbill's Avatar
Quoted: 108 Post(s)
Liked: 93
Amen to that
Bill
mrfattbill is offline
post #1366 of 10906 Old 05-17-2012, 09:59 AM
GusGus748s's Avatar
Quoted: 423 Post(s)
Liked: 703
great, but you do realize there are quite a few people who don't want to encode their blu-rays but instead want to keep the original quality
+1
GusGus748s is offline
post #1367 of 10906 Old 05-17-2012, 02:25 PM
L33TX43RT's Avatar
...you do realize there are quite a few people who don't want to encode their Blu-rays but instead want to keep the original quality
What he said.
L33TX43RT is offline
post #1368 of 10906 Old 05-17-2012, 08:08 PM
Bugg77's Avatar
Pardon the stupid question, but how do you check a rip to make sure the HD audio was included properly? My PCH A 300 won't be here for a few weeks and I don't have an HTPC to check it on. For that matter, how do I verify video resolution?
Bugg77 is offline
post #1369 of 10906 Old 05-17-2012, 08:11 PM
dbone1026's Avatar
Quoted: 221 Post(s)
Liked: 111
download a program called Mediainfo
Cheers,
Damian
post #1370 of 10906 Old 05-17-2012, 08:35 PM
Bugg77's Avatar
Thank you! I suspected there was a program out there but I just finished working 14 hours and taking care of two babies... This boy is tired!
Bugg77 is offline
post #1371 of 10906 Old 05-18-2012, 04:16 AM
dbone1026's Avatar
Quoted: 221 Post(s)
Liked: 111
No prob, here is the link:
http://mediainfo.sourceforge.net/en
Cheers,
Damian
post #1372 of 10906 Old 05-18-2012, 04:21 AM
Wireless member
pepar's Avatar
Quoted: 1044 Post(s)
Liked: 544
Also, your receiver/processor should display the audio codec it receives, and your display should be able to give the input resolution.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #1373 of 10906 Old 05-18-2012, 06:12 AM
alexsquared's Avatar
My guess in reading his question is that he is pre-ripping before his PH shows up and he wants to be certain he is ripping correctly.
Once the PH comes in, he can use the method you describe.
alexsquared is offline
post #1374 of 10906 Old 05-18-2012, 06:19 AM
mrfattbill's Avatar
Quoted: 108 Post(s)
Liked: 93
I love mediainfo
Bill
post #1375 of 10906 Old 05-18-2012, 07:45 AM
txmxer's Avatar
Quoted: 20 Post(s)
Don't forget to support Handbrake and the other freebies that you use.
If you just try it and don't love it, don't sweat it, but handbrake is awesome and it's important to keep it funded.
txmxer is offline
post #1376 of 10906 Old 05-20-2012, 03:17 AM
L33TX43RT's Avatar
Handbrake is great for recoding actual video files, including decrypted ISOs. I've had mixed experiences using it for ripping, in conjunction with a decrypter. Handbrake scans through title segments of a BD disc much slower than other official rippers, making the process very tedious. Since I choose not to compress any of my BDs beyond a lossless MKV file, MakeMKV and DVDFab work best for me.
post #1377 of 10906 Old 06-06-2012, 11:57 PM
Tesla1856's Avatar
Quoted: 119 Post(s)
Liked: 68
I tested it and this works great. Thanks! (used for Mission Impossible 4 - Ghost Protocol)
Now, if I could just find a way to spot Forced Subs ... or when I need to do this procedure. I mean, without watching the whole movie first, or playing with tracks in VLC to find out what is inside each one.
Originally Posted by trondmm View Post
That works, but there is a much quicker way.
Open MKVMergeGUI
Select File -> Header Editor
In Header Editor, select File -> Open
Select your MKV file.
You'll now see the list of tracks. Open the subtitle track you want to be forced.
Click on "Forced Display" Flag.
In right window, set Current Value to "yes".
Select File -> Save
Takes a few seconds.
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
post #1378 of 10906 Old 06-07-2012, 06:28 AM
LVS
LVS's Avatar
^ If you don't normally view subtitles or they aren't important outside of the forced subs, you could just rip the forced subs on all your movies and leave subtitles turned on all the time. Wish I would have figured this out before ripping my entire library with subs...
LVS is offline
post #1379 of 10906 Old 06-07-2012, 11:34 AM
Tesla1856's Avatar
Quoted: 119 Post(s)
Liked: 68
Right, but instead, I like:
- Normal English subs (for whole movie) off by default.
- Forced English Subs on always (for foriegn dialog).
- Option to turn on English subs in case they are speaking English but I still can't make out what they are saying.
If I want any more than that or to watch the extras, I move from HTPC to real Blu-Ray player and pop-in the real Blu-Ray.
Was much easier with DVDs ... you could rip the whole VIDEO_TS folder and get everything. But I think Blu-Ray is still worth the extra trouble ( 1080p, HD, and the movie re-masterings we are seeing).
post #1380 of 10906 Old 06-07-2012, 06:33 PM - Thread Starter
agogley's Avatar
Quoted: 56 Post(s)
Liked: 25
When I started this thread, I didn't realize it would be so popular. I've learned a lot through 47 pages.
agogley is offline
3d blu-ray , blu ray , copier , Dune Hd Smart B1 1080p Media Player , home cinema , ripper
