Dune Software Question - AVS Forum | Home Theater Discussions And Reviews
Old 06-16-2011, 08:09 AM - Thread Starter
rodspr's Avatar
i have a Base 3.0, but this question can be answered by any Dune owners.
How can I get the Dune to stop after playing a file? Currently when playing an avi file for instance, it will continue to the next file. I would like to just go back to the folder and wait for me in this case.
I've looked thru the menu and know I'm just missing the setting to turn this off.
thanks
rodspr is offline
Old 06-16-2011, 10:37 AM
alexwill22's Avatar
If you are pressing play when you start your .avi file, then you are creating a playlist for everything in that folder. If you press enter from your remote on the selected file, then you are just playing that single .avi. After the video ends, it will go back to the list.
This is in the manual for dune.
alexwill22 is offline
Old 06-17-2011, 01:15 PM - Thread Starter
rodspr's Avatar
Thats what I thought I'd been doing. Tried that last night and it didn't work. I did pause the show a few times, but don't remember that causing issues in the past.
I am on the most recent beta firmware release, so maybe this is tied to that.
rodspr is offline
Old 06-19-2011, 05:09 AM
gibbo's Avatar
I've noticed the same thing on the latest Beta firmware. It auto playlists the entire folder reagrdless of whether you hit Play or Enter.
gibbo is offline
Old 06-21-2011, 08:24 AM
alexwill22's Avatar
I took a look at the new firmware last night. You have to change the settings for the play button and the enter button. In the new firmware, they are defaulted to play everything in the folder.
